Mag__
ez sajnos ebben a formában már nem müködik az uj openelec-ben:
login as: root
root@192.168.0.16's password:
# OpenELEC - The living room PC for everyone #
# ...... visit http://www.openelec.tv ...... #
##############################################OpenELEC (official) Version: 5.0.8
OpenELEC:~ # sudo apt-get install transmission-daemonThere is no working 'sudo'.
On debian/ubuntu/all general purpose linux distributions 'sudo'
allows a permitted user to execute a command as the superuser
or another user, as specified by the security policyWith OpenELEC you have root access by default, so you dont need 'sudo'
OpenELEC:~ # apt-get install transmission-daemon
There is no working 'apt-get'.
'apt-get' is a command to install, update and remove software which
is stored in a non local repo. 'apt-get' does nothing then connecting to such
repo, downloads the software, unpacks the software, updates a big
local database with all filepaths and other informations about the
installed software or removes or updates installed Software.With OpenELEC it is not possible to change the system for security and
stability reasons so even 'apt-get' would not be able to do this.
We also dont have and want to maintain such a repo for various other
great reasons.Also Ubuntu or Debian packages are often outdated and not compatible
with OpenELECTIP: use XBMC's addon browser to enhance your OpenELEC system
- Apple Watch Sport - ez is csak egy okosóra
- Path of Exile (ARPG)
- Gitáros topic
- OLED TV topic
- MWC 2026: Rám nézett a Robot Phone, zavarba jöttem
- Motorola Edge 60 Fusion - nem csak a forma időtálló
- Milyen okostelefont vegyek?
- Bittorrent topik
- Hitelkártyák használata, hitelkártya visszatérítés
- BESZÁMÍTÁS! Asrock B450M R5 5500 8GB DDR4 256GB SSD GTX 1050 Ti 4GB Zalman T3 Plus DeepCool 400W
- MSI MAG B650 TOMAHAWK WIFI + AMD Ryzen 9 7950X3D
- BESZÁMÍTÁS! Asus ROG Strix B450F R5 5600 32GB DDR4 512GB SSD RTX 2070 Super 8GB Zalman S2 TG TT 650W
- Beszámítás! Apple Mac Mini M4 16GB 256GB számítógép garanciával, hibátlan működéssel
- 10genes kishibàs pc(i3-10105f/8gb/gt1030/win11/SSD/hdd)
- HIBÁTLAN iPhone 12 Pro Max 128GB Pacific Blue -1 ÉV GARANCIA - Kártyafüggetlen, 100% Akkumulátor
- BESZÁMÍTÁS! AMD Ryzen 7 5800X3D 8 mag 16 szál processzor garanciával hibátlan működéssel
- Surface Pro 7+ i5-1135G7 16G 256GB 1 év garancia
- AKCIÓ! MSI Thin A15 B7VE FHD Gamer notebook - R5 7535HS 16GB DDR5 512GB SSD RTX 4050 6GB W11
- iPhone 17 Pro Max Kozmosznarancs - Bontatlan !! www.stylebolt.hu - Apple eszközök és tartozékok !!
wassermann
