slylecz
Bocsi, szerintem most másoltam be először életemben ilyen hosszú szöveget mutatóba.
Most annyi gond van, hogy nem indul el a rendszer.
Sebaj, megpróbálom mégegyszer előlről, de mostmár okosabban, a megfelelő mappákba letöltve, hogy ne panaszkodjon. Hátha ez az indulás proléma is megoldódik
slylecz
Végül sikerült felraknom, amit el is érek, de vannak benne ezek a "Permission denied" sorok, amik nem tudom, hogy mire utalnak.
De itt van az egész:
sly@raspberrypi:~ $ sudo apt install /home/sly/mongodb-org-server_4.4.18_arm64.deb
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Note, selecting 'mongodb-org-server' instead of '/home/sly/mongodb-org-server_4.4.18_arm64.deb'
The following packages were automatically installed and are no longer required:
libraspberrypi0 libwpe-1.0-1 libwpebackend-fdo-1.0-1
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libssl1.1
The following NEW packages will be installed:
libssl1.1 mongodb-org-server
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,397 kB/20.3 MB of archives.
After this operation, 83.1 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.raspberrypi.com/debian bookworm/main arm64 libssl1.1 arm64 1.1.1w-0~deb11u1+rpt1 [1,397 kB]
Get:2 /home/sly/mongodb-org-server_4.4.18_arm64.deb mongodb-org-server arm64 4.4.18 [18.9 MB]
Fetched 1,397 kB in 2s (859 kB/s)
Preconfiguring packages ...
Selecting previously unselected package libssl1.1:arm64.
(Reading database ... 147768 files and directories currently installed.)
Preparing to unpack .../libssl1.1_1.1.1w-0~deb11u1+rpt1_arm64.deb ...
Unpacking libssl1.1:arm64 (1.1.1w-0~deb11u1+rpt1) ...
Selecting previously unselected package mongodb-org-server.
Preparing to unpack .../mongodb-org-server_4.4.18_arm64.deb ...
Unpacking mongodb-org-server (4.4.18) ...
Setting up libssl1.1:arm64 (1.1.1w-0~deb11u1+rpt1) ...
Setting up mongodb-org-server (4.4.18) ...
Adding system user `mongodb' (UID 112) ...
Adding new user `mongodb' (UID 112) with group `nogroup' ...
Not creating `/nonexistent'.
Adding group `mongodb' (GID 122) ...
Done.
Adding user `mongodb' to group `mongodb' ...
Done.
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for libc-bin (2.36-9+rpt2+deb12u7) ...
N: Download is performed unsandboxed as root as file '/home/sly/mongodb-org-server_4.4.18_arm64.deb' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
sly@raspberrypi:~ $ sudo systemctl daemon-reload
sly@raspberrypi:~ $ sudo systemctl enable mongod
Created symlink /etc/systemd/system/multi-user.target.wants/mongod.service → /lib/systemd/system/mongod.service.
sly@raspberrypi:~ $ sudo systemctl start mongod
sly@raspberrypi:~ $ apt list curl
Listing... Done
curl/stable,stable-security,now 7.88.1-10+deb12u5 arm64 [installed]
curl/stable,stable-security 7.88.1-10+deb12u5 armhf
sly@raspberrypi:~ $ sudo apt install openjdk-17-jre-headless
ca-certificates-java java-common
Suggested packages:
default-jre fonts-dejavu-extra fonts-ipafont-gothic fonts-ipafont-mincho fonts-wqy-microhei | fonts-wqy-zenhei fonts-indic
ca-certificates-java java-common openjdk-17-jre-headless
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 42.7 MB of archives.
After this operation, 193 MB of additional disk space will be used.
Get:1 http://deb.debian.org/debian bookworm/main arm64 ca-certificates-java all 20230710~deb12u1 [11.9 kB]
Get:2 http://deb.debian.org/debian bookworm/main arm64 java-common all 0.74 [6,388 B]
Get:3 http://deb.debian.org/debian-security bookworm-security/main arm64 openjdk-17-jre-headless arm64 17.0.11+9-1~deb12u1 [42.7 MB]
Fetched 42.7 MB in 5s (9,380 kB/s)
Selecting previously unselected package ca-certificates-java.
(Reading database ... 147790 files and directories currently installed.)
Preparing to unpack .../ca-certificates-java_20230710~deb12u1_all.deb ...
Unpacking ca-certificates-java (20230710~deb12u1) ...
Selecting previously unselected package java-common.
Preparing to unpack .../java-common_0.74_all.deb ...
Unpacking java-common (0.74) ...
Selecting previously unselected package openjdk-17-jre-headless:arm64.
Preparing to unpack .../openjdk-17-jre-headless_17.0.11+9-1~deb12u1_arm64.deb ...
Unpacking openjdk-17-jre-headless:arm64 (17.0.11+9-1~deb12u1) ...
Setting up java-common (0.74) ...
Setting up ca-certificates-java (20230710~deb12u1) ...
No JRE found. Skipping Java certificates setup.
Setting up openjdk-17-jre-headless:arm64 (17.0.11+9-1~deb12u1) ...
update-alternatives: using /usr/lib/jvm/java-17-openjdk-arm64/bin/java to provide /usr/bin/java (java) in auto mode
update-alternatives: using /usr/lib/jvm/java-17-openjdk-arm64/bin/jpackage to provide /usr/bin/jpackage (jpackage) in auto mode
update-alternatives: using /usr/lib/jvm/java-17-openjdk-arm64/bin/keytool to provide /usr/bin/keytool (keytool) in auto mode
update-alternatives: using /usr/lib/jvm/java-17-openjdk-arm64/bin/rmiregistry to provide /usr/bin/rmiregistry (rmiregistry) in auto mode
update-alternatives: using /usr/lib/jvm/java-17-openjdk-arm64/lib/jexec to provide /usr/bin/jexec (jexec) in auto mode
Processing triggers for ca-certificates-java (20230710~deb12u1) ...
Adding debian:ACCVRAIZ1.pem
Adding debian:AC_RAIZ_FNMT-RCM.pem
Adding debian:AC_RAIZ_FNMT-RCM_SERVIDORES_SEGUROS.pem
Adding debian:Actalis_Authentication_Root_CA.pem
Adding debian:AffirmTrust_Commercial.pem
Adding debian:AffirmTrust_Networking.pem
Adding debian:AffirmTrust_Premium_ECC.pem
Adding debian:AffirmTrust_Premium.pem
Adding debian:Amazon_Root_CA_1.pem
Adding debian:Amazon_Root_CA_2.pem
Adding debian:Amazon_Root_CA_3.pem
Adding debian:Amazon_Root_CA_4.pem
Adding debian:ANF_Secure_Server_Root_CA.pem
Adding debian:Atos_TrustedRoot_2011.pem
Adding debian:Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068_2.pem
Adding debian:Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.pem
Adding debian:Baltimore_CyberTrust_Root.pem
Adding debian:Buypass_Class_2_Root_CA.pem
Adding debian:Buypass_Class_3_Root_CA.pem
Adding debian:CA_Disig_Root_R2.pem
Adding debian:Certainly_Root_E1.pem
Adding debian:Certainly_Root_R1.pem
Adding debian:Certigna.pem
Adding debian:Certigna_Root_CA.pem
Adding debian:certSIGN_Root_CA_G2.pem
Adding debian:certSIGN_ROOT_CA.pem
Adding debian:Certum_EC-384_CA.pem
Adding debian:Certum_Trusted_Network_CA_2.pem
Adding debian:Certum_Trusted_Network_CA.pem
Adding debian:Certum_Trusted_Root_CA.pem
Adding debian:CFCA_EV_ROOT.pem
Adding debian:Comodo_AAA_Services_root.pem
Adding debian:COMODO_Certification_Authority.pem
Adding debian:COMODO_ECC_Certification_Authority.pem
Adding debian:COMODO_RSA_Certification_Authority.pem
Adding debian:DigiCert_Assured_ID_Root_CA.pem
Adding debian:DigiCert_Assured_ID_Root_G2.pem
Adding debian:DigiCert_Assured_ID_Root_G3.pem
Adding debian:DigiCert_Global_Root_CA.pem
Adding debian:DigiCert_Global_Root_G2.pem
Adding debian:DigiCert_Global_Root_G3.pem
Adding debian:DigiCert_High_Assurance_EV_Root_CA.pem
Adding debian:DigiCert_TLS_ECC_P384_Root_G5.pem
Adding debian:DigiCert_TLS_RSA4096_Root_G5.pem
Adding debian:DigiCert_Trusted_Root_G4.pem
Adding debian:D-TRUST_BR_Root_CA_1_2020.pem
Adding debian:D-TRUST_EV_Root_CA_1_2020.pem
Adding debian:D-TRUST_Root_Class_3_CA_2_2009.pem
Adding debian:D-TRUST_Root_Class_3_CA_2_EV_2009.pem
Adding debian:emSign_ECC_Root_CA_-_C3.pem
Adding debian:emSign_ECC_Root_CA_-_G3.pem
Adding debian:emSign_Root_CA_-_C1.pem
Adding debian:emSign_Root_CA_-_G1.pem
Adding debian:Entrust.net_Premium_2048_Secure_Server_CA.pem
Adding debian:Entrust_Root_Certification_Authority_-_EC1.pem
Adding debian:Entrust_Root_Certification_Authority_-_G2.pem
Adding debian:Entrust_Root_Certification_Authority_-_G4.pem
Adding debian:Entrust_Root_Certification_Authority.pem
Adding debian:ePKI_Root_Certification_Authority.pem
Adding debian:e-Szigno_Root_CA_2017.pem
Adding debian:E-Tugra_Certification_Authority.pem
Adding debian:E-Tugra_Global_Root_CA_ECC_v3.pem
Adding debian:E-Tugra_Global_Root_CA_RSA_v3.pem
Adding debian:GDCA_TrustAUTH_R5_ROOT.pem
Adding debian:GlobalSign_ECC_Root_CA_-_R4.pem
Adding debian:GlobalSign_ECC_Root_CA_-_R5.pem
Adding debian:GlobalSign_Root_CA.pem
Adding debian:GlobalSign_Root_CA_-_R3.pem
Adding debian:GlobalSign_Root_CA_-_R6.pem
Adding debian:GlobalSign_Root_E46.pem
Adding debian:GlobalSign_Root_R46.pem
Adding debian:GLOBALTRUST_2020.pem
Adding debian:Go_Daddy_Class_2_CA.pem
Adding debian:Go_Daddy_Root_Certificate_Authority_-_G2.pem
Adding debian:GTS_Root_R1.pem
Adding debian:GTS_Root_R2.pem
Adding debian:GTS_Root_R3.pem
Adding debian:GTS_Root_R4.pem
Adding debian:HARICA_TLS_ECC_Root_CA_2021.pem
Adding debian:HARICA_TLS_RSA_Root_CA_2021.pem
Adding debian:Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.pem
Adding debian:Hellenic_Academic_and_Research_Institutions_RootCA_2015.pem
Adding debian:HiPKI_Root_CA_-_G1.pem
Adding debian:Hongkong_Post_Root_CA_1.pem
Adding debian:Hongkong_Post_Root_CA_3.pem
Adding debian:IdenTrust_Commercial_Root_CA_1.pem
Adding debian:IdenTrust_Public_Sector_Root_CA_1.pem
Adding debian:ISRG_Root_X1.pem
Adding debian:ISRG_Root_X2.pem
Adding debian:Izenpe.com.pem
Adding debian:Microsec_e-Szigno_Root_CA_2009.pem
Adding debian:Microsoft_ECC_Root_Certificate_Authority_2017.pem
Adding debian:Microsoft_RSA_Root_Certificate_Authority_2017.pem
Adding debian:NAVER_Global_Root_Certification_Authority.pem
Adding debian:NetLock_Arany_=Class_Gold=_FĹ‘tanĂşsĂtvány.pem
Adding debian:OISTE_WISeKey_Global_Root_GB_CA.pem
Adding debian:OISTE_WISeKey_Global_Root_GC_CA.pem
Adding debian:QuoVadis_Root_CA_1_G3.pem
Adding debian:QuoVadis_Root_CA_2_G3.pem
Adding debian:QuoVadis_Root_CA_2.pem
Adding debian:QuoVadis_Root_CA_3_G3.pem
Adding debian:QuoVadis_Root_CA_3.pem
Adding debian:Secure_Global_CA.pem
Adding debian:SecureSign_RootCA11.pem
Adding debian:SecureTrust_CA.pem
Adding debian:Security_Communication_ECC_RootCA1.pem
Adding debian:Security_Communication_RootCA2.pem
Adding debian:Security_Communication_RootCA3.pem
Adding debian:Security_Communication_Root_CA.pem
Adding debian:SSL.com_EV_Root_Certification_Authority_ECC.pem
Adding debian:SSL.com_EV_Root_Certification_Authority_RSA_R2.pem
Adding debian:SSL.com_Root_Certification_Authority_ECC.pem
Adding debian:SSL.com_Root_Certification_Authority_RSA.pem
Adding debian:Starfield_Class_2_CA.pem
Adding debian:Starfield_Root_Certificate_Authority_-_G2.pem
Adding debian:Starfield_Services_Root_Certificate_Authority_-_G2.pem
Adding debian:SwissSign_Gold_CA_-_G2.pem
Adding debian:SwissSign_Silver_CA_-_G2.pem
Adding debian:SZAFIR_ROOT_CA2.pem
Adding debian:Telia_Root_CA_v2.pem
Adding debian:TeliaSonera_Root_CA_v1.pem
Adding debian:TrustCor_ECA-1.pem
Adding debian:TrustCor_RootCert_CA-1.pem
Adding debian:TrustCor_RootCert_CA-2.pem
Adding debian:Trustwave_Global_Certification_Authority.pem
Adding debian:Trustwave_Global_ECC_P256_Certification_Authority.pem
Adding debian:Trustwave_Global_ECC_P384_Certification_Authority.pem
Adding debian:T-TeleSec_GlobalRoot_Class_2.pem
Adding debian:T-TeleSec_GlobalRoot_Class_3.pem
Adding debian:TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi_-_Surum_1.pem
Adding debian:TunTrust_Root_CA.pem
Adding debian:TWCA_Global_Root_CA.pem
Adding debian:TWCA_Root_Certification_Authority.pem
Adding debian:UCA_Extended_Validation_Root.pem
Adding debian:UCA_Global_G2_Root.pem
Adding debian:USERTrust_ECC_Certification_Authority.pem
Adding debian:USERTrust_RSA_Certification_Authority.pem
Adding debian:vTrus_ECC_Root_CA.pem
Adding debian:vTrus_Root_CA.pem
Adding debian:XRamp_Global_CA_Root.pem
done.
sly@raspberrypi:~ $ sudo apt install jsvc
libcommons-daemon-java
Suggested packages:
java-virtual-machine
jsvc libcommons-daemon-java
Need to get 307 kB of archives.
After this operation, 1,778 kB of additional disk space will be used.
Get:1 http://deb.debian.org/debian bookworm/main arm64 libcommons-daemon-java all 1.0.15-10 [281 kB]
Get:2 http://deb.debian.org/debian bookworm/main arm64 jsvc arm64 1.0.15-10 [26.0 kB]
Fetched 307 kB in 0s (1,375 kB/s)
Selecting previously unselected package libcommons-daemon-java.
(Reading database ... 148116 files and directories currently installed.)
Preparing to unpack .../libcommons-daemon-java_1.0.15-10_all.deb ...
Unpacking libcommons-daemon-java (1.0.15-10) ...
Selecting previously unselected package jsvc.
Preparing to unpack .../jsvc_1.0.15-10_arm64.deb ...
Unpacking jsvc (1.0.15-10) ...
Setting up libcommons-daemon-java (1.0.15-10) ...
Setting up jsvc (1.0.15-10) ...
sly@raspberrypi:~ $ sudo update-alternatives --config java
There is 1 choice for the alternative java (providing /usr/bin/java).
Selection Path Priority Status
* 0 /usr/lib/jvm/java-17-openjdk-arm64/bin/java 1711 auto mode
1 /usr/lib/jvm/java-17-openjdk-arm64/bin/java 1711 manual mode
Press <enter> to keep the current choice[*], or type selection number: 2
Press <enter> to keep the current choice[*], or type selection number: 1
sly@raspberrypi:~ $ wget https://static.tp-link.com/upload/software/2024/202402/20240227/Omada_SDN_Controller_v5.13.30.8_linux_x64.deb
--2024-06-13 19:00:21-- https://static.tp-link.com/upload/software/2024/202402/20240227/Omada_SDN_Controller_v5.13.30.8_linux_x64.deb
Resolving static.tp-link.com (static.tp-link.com)... 2600:9000:2050:f000:c:35e7:f300:93a1, 2600:9000:2050:a200:c:35e7:f300:93a1, 2600:9000:2050:7200:c:35e7:f300:93a1, ...
Connecting to static.tp-link.com (static.tp-link.com)|2600:9000:2050:f000:c:35e7:f300:93a1|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 194341084 (185M) [application/octet-stream]
Saving to: â€Omada_SDN_Controller_v5.13.30.8_linux_x64.deb’
Omada_SDN_Controller_v5.13.30.8_linux_x 100%[=============================================================================>] 185.34M 44.5MB/s in 4.3s
2024-06-13 19:00:25 (43.4 MB/s) - â€Omada_SDN_Controller_v5.13.30.8_linux_x64.deb’ saved [194341084/194341084]
sly@raspberrypi:~ $ sudo apt install /home/sly/Omada_SDN_Controller_v5.13.30.8_linux_x64.deb
Note, selecting 'omadac' instead of '/home/sly/Omada_SDN_Controller_v5.13.30.8_linux_x64.deb'
omadac
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/194 MB of archives.
After this operation, 182 MB of additional disk space will be used.
Get:1 /home/sly/Omada_SDN_Controller_v5.13.30.8_linux_x64.deb omadac all 5.13.30.8 [194 MB]
Selecting previously unselected package omadac.
(Reading database ... 148218 files and directories currently installed.)
Preparing to unpack .../Omada_SDN_Controller_v5.13.30.8_linux_x64.deb ...
Unpacking omadac (5.13.30.8) ...
Setting up omadac (5.13.30.8) ...
Install Omada Controller succeeded!
current data is empty
Omada Controller will start up with system boot. You can also control it by [/usr/bin/tpeap].
check omada
Starting Omada Controller. Please wait........................................................................................................................
Started successfully.
You can visit http://localhost:8088 on this host to manage the wireless network.
N: Download is performed unsandboxed as root as file '/home/sly/Omada_SDN_Controller_v5.13.30.8_linux_x64.deb' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
sly@raspberrypi:~ $ -
slylecz
Valaki esetleg foglalkozott azza, hogy miként lehet ráerőszakolni egy 4-es málnára Omada szoftvervezérlőt?
Elvileg alapból nem támogatja, de itt egy leírás arról, hogy sikerülhet.
https://github.com/themattman/mongodb-raspberrypi-binaries/blob/main/README.md
De ez nekem nagyon nem jön össze... -
slylecz
Egy Pi4-es lapra hogyan köthető több 2.5"-os hdd, hogy ne terhelje a saját tápegységét?
köszi
- Elektromos rásegítésű kerékpárok
- Sütés, főzés és konyhai praktikák
- Biztosan felbúgnak a ventilátorok az új GeForce driverrel
- Foxpost
- Erős Gamer PC i7-9700K RTX 3060 12GB 16GB Trident Z 850W Gold NZXT H510 Flow
- BESZÁMÍTÁS! ASRock A520M R5 5500 8GB DDR4 250GB SSD GTX 1050 Ti 4GB Sharkoon RGB Slider 400W
- BESZÁMÍTÁS! Asus PRIME H510M i5 11400 16GB DDR4 512GB SSD RX 6600 8GB Rampage SHIVA Adata 600W
- BESZÁMÍTÁS! MSI B650 R7 7700 32GB DDR5 1TB SSD RTX 5070Ti 16GB LIAN LI LANCOOL 207 ADATA 850W
- Asztali PC , i7 9700 , RX 6600 , 16GB DDR4 , 512GB m.2 , 500GB HDD
- Apple iPhone 13 Pro 256GB,Újszerű,Dobozaval,12 hónap garanciával
- Apple iPhone 15 128GB Black használt megkímélt 100% akku 6 hónap garancia
- ÁRGARANCIA!Épített KomPhone i5 14600KF 32/64GB RAM RX 9070 16GB GAMER PC termékbeszámítással
- Bialetti kézi kávéőrlő
- 226 - Lenovo LOQ (15IRX10) - Intel Core i7-13650HX, RTX 5060
wassermann
