Shummo
Próbálok integrálni egy Xiaomi A1 camerát a videoP2Proxy segítségével, de a telepítésnél elkapadok. a MAKE parancsnál az alábbi logot kapot. Esetleg valaki tudna abban segíteni, hogy merre induljak el?
pi@raspberrypi:~/videoP2Proxy $ makemake all-ammake[1]: Entering directory '/home/pi/videoP2Proxy'CC main.oCC av.oCC avframe.oCC client.oCC iotc.oCXX rtsp.ortsp.cxx: In function ‘void* min(void*)’:rtsp.cxx:65:34: warning: control reaches end of non-void function [-Wreturn-type]65 | env->taskScheduler().doEventLoop();| ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~CXXLD videop2proxy/usr/bin/ld: av.o:/home/pi/videoP2Proxy/common.h:15: multiple definition of `MODE_RTSP_FIFO'; main.o:/home/pi/videoP2Proxy/common.h:15: first defined here/usr/bin/ld: av.o:/home/pi/videoP2Proxy/common.h:14: multiple definition of `MODE_RTSP_FIFO_FILE'; main.o:/home/pi/videoP2Proxy/common.h:14: first defined here/usr/bin/ld: av.o:/home/pi/videoP2Proxy/common.h:11: multiple definition of `MODE_STDOUT'; main.o:/home/pi/videoP2Proxy/common.h:11: first defined here/usr/bin/ld: av.o:/home/pi/videoP2Proxy/common.h:11: multiple definition of `MODE_RTSP'; main.o:/home/pi/videoP2Proxy/common.h:11: first defined here/usr/bin/ld: avframe.o:/home/pi/videoP2Proxy/common.h:11: multiple definition of `MODE_STDOUT'; main.o:/home/pi/videoP2Proxy/common.h:11: first defined here/usr/bin/ld: avframe.o:/home/pi/videoP2Proxy/common.h:11: multiple definition of `MODE_RTSP'; main.o:/home/pi/videoP2Proxy/common.h:11: first defined here/usr/bin/ld: client.o:/home/pi/videoP2Proxy/common.h:11: multiple definition of `MODE_STDOUT'; main.o:/home/pi/videoP2Proxy/common.h:11: first defined here/usr/bin/ld: client.o:/home/pi/videoP2Proxy/common.h:11: multiple definition of `MODE_RTSP'; main.o:/home/pi/videoP2Proxy/common.h:11: first defined here/usr/bin/ld: iotc.o:/home/pi/videoP2Proxy/common.h:11: multiple definition of `MODE_STDOUT'; main.o:/home/pi/videoP2Proxy/common.h:11: first defined here/usr/bin/ld: iotc.o:/home/pi/videoP2Proxy/common.h:11: multiple definition of `MODE_RTSP'; main.o:/home/pi/videoP2Proxy/common.h:11: first defined here/usr/bin/ld: rtsp.o:/home/pi/videoP2Proxy/common.h:15: multiple definition of `MODE_RTSP_FIFO'; main.o:/home/pi/videoP2Proxy/common.h:15: first defined here/usr/bin/ld: rtsp.o:/home/pi/videoP2Proxy/common.h:14: multiple definition of `MODE_RTSP_FIFO_FILE'; main.o:/home/pi/videoP2Proxy/common.h:14: first defined here/usr/bin/ld: rtsp.o:/home/pi/videoP2Proxy/common.h:11: multiple definition of `MODE_STDOUT'; main.o:/home/pi/videoP2Proxy/common.h:11: first defined here/usr/bin/ld: rtsp.o:/home/pi/videoP2Proxy/common.h:11: multiple definition of `MODE_RTSP'; main.o:/home/pi/videoP2Proxy/common.h:11: first defined herecollect2: error: ld returned 1 exit statusmake[1]: *** [Makefile:488: videop2proxy] Error 1make[1]: Leaving directory '/home/pi/videoP2Proxy'make: *** [Makefile:391: all] Error 2 -
Shummo
Sziasztok. Raspi pi 4 - Rasbian OS (bullseye) apt update/upgrade óta egy olyan kellemetlen jelenség fogad, hogy újraindítás után ha próbálok SSHval belépni, akkor már látja a hálózaton a PI-t, de vissza van utasítva a kapcsolódás.
Puttyt használok: eddig amint látta a gépet már lépett is be. Most kb 2 percig még az alábbi üzenet fogal azután, hogy beírom a jelszót/vagy kapcsolódok RSA keyyel.
Putty Fatal Error - Remote side unexpectedly closed network connection.
Egyébként ez az üzenet azután jelent eddig meg, hogy nyomtam egy restartot, de most boot alatt is csinalja.
Eltelik a 2 perc, utána minden megy. jelszó/ RSA login.
Szóval valamilyen process gátolja vagy még nem idult még el, ami eddig nem így volt.
Esetleg merre induljak el kutakodni?
Köszönöm -
Shummo
User/Group szerkezetben kérném a segítséget.
Van a PI-n egy HDD. a KODI NFS-en keresztül olvassa a HDD tartalmát. /etc/exports az alábbi ódon néz ki.
#/media/d***a/nas *(rw,all_squash,insecure,async,no_subtree_check,anonuid=1001,anongid=1001)
Problémám, hogy random módon jogosultsági problémába futok. Ezért szeretném megoldani úgy, hogy az NFS ne legyen ennyire nyitott, hanem csak a KODI tudjon rajta átmenni.példa kedvéért:
PI id 1000
KODI id legyen mondjuk 1001Hogy tudom azt megoldani, hogy a chown pi:pi megmaradjon, de az NFS-en keresztül a 1001, tehát KODI id-vel hozzá lehessen férni a fájlokhoz.
Vagy teljesen mind1 mit hagyok a NFS IDnek (maradhat a PI)? Mivel tudom biztonságosabbá tenni?
Az alábbira gondoltam, csak mégsem működik.
sudo setfacl -R -m "u:kodi:r" /media/d***a/nas -
Shummo
Sajnos mégse jó. Elindulni elindul szépen felcsatolódik, de ha a HDDről akarok másolni, akkor egyből behal.
Dmesg az alábbit írja, ebből valaki ki tud hámozni valamit??
sdb a 2. drive (külső tápja is van a háznak)91.132758] usb 2-1.1: cmd cmplt err -71
[ 91.133768] usb 2-1.1: cmd cmplt err -71
[ 91.148707] usb 2-1.1: cmd cmplt err -71
[ 91.164134] usb 2-1.1: cmd cmplt err -71
[ 91.183128] usb 2-1.1: cmd cmplt err -71
[ 91.198858] usb 2-1.1: cmd cmplt err -71
[ 91.216662] usb 2-1.1: cmd cmplt err -71
[ 93.176447] usb 2-1.1: USB disconnect, device number 4
[ 93.185436] sd 1:0:0:0: [sdb] tag#25 uas_zap_pending 0 uas-tag 1 inflight: CMD
[ 93.185449] sd 1:0:0:0: [sdb] tag#25 CDB: opcode=0x28 28 00 0c 6b e1 40 00 04 00 00
[ 93.185460] sd 1:0:0:0: [sdb] tag#26 uas_zap_pending 0 uas-tag 2 inflight: CMD
[ 93.185466] sd 1:0:0:0: [sdb] tag#26 CDB: opcode=0x28 28 00 0c 6b e5 40 00 04 00 00
[ 93.185475] sd 1:0:0:0: [sdb] tag#27 uas_zap_pending 0 uas-tag 3 inflight: CMD
[ 93.185476] sd 1:0:0:0: [sdb] tag#25 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=DRIVER_OK cmd_age=2s
[ 93.185481] sd 1:0:0:0: [sdb] tag#27 CDB: opcode=0x28 28 00 0c 6b e9 40 00 04 00 00
[ 93.185490] sd 1:0:0:0: [sdb] tag#24 uas_zap_pending 0 uas-tag 4 inflight: CMD
[ 93.185491] sd 1:0:0:0: [sdb] tag#25 CDB: opcode=0x28 28 00 0c 6b e1 40 00 04 00 00
[ 93.185494] sd 1:0:0:0: [sdb] tag#26 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=DRIVER_OK cmd_age=2s
[ 93.185498] sd 1:0:0:0: [sdb] tag#24 CDB: opcode=0x28 28 00 0b 0b 40 00 00 04 00 00
[ 93.185498] blk_update_request: I/O error, dev sdb, sector 208396608 op 0x0:(READ) flags 0x80700 phys_seg 128 prio class 0
[ 93.185500] sd 1:0:0:0: [sdb] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=DRIVER_OK cmd_age=2s
[ 93.185505] sd 1:0:0:0: [sdb] tag#28 uas_zap_pending 0 uas-tag 5 inflight: CMD
[ 93.185505] sd 1:0:0:0: [sdb] tag#26 CDB: opcode=0x28 28 00 0c 6b e5 40 00 04 00 00
[ 93.185510] sd 1:0:0:0: [sdb] tag#28 CDB: opcode=0x28 28 00 0b 0b 48 00 00 04 00 00
[ 93.185512] sd 1:0:0:0: [sdb] tag#27 CDB: opcode=0x28 28 00 0c 6b e9 40 00 04 00 00
[ 93.185513] blk_update_request: I/O error, dev sdb, sector 208397632 op 0x0:(READ) flags 0x80700 phys_seg 128 prio class 0
[ 93.185518] sd 1:0:0:0: [sdb] tag#0 uas_zap_pending 0 uas-tag 6 inflight: CMD
[ 93.185520] blk_update_request: I/O error, dev sdb, sector 208398656 op 0x0:(READ) flags 0x80700 phys_seg 128 prio class 0
[ 93.185524] sd 1:0:0:0: [sdb] tag#0 CDB: opcode=0x28 28 00 0b 0b 50 00 00 04 00 00
[ 93.185531] sd 1:0:0:0: [sdb] tag#1 uas_zap_pending 0 uas-tag 7 inflight: CMD
[ 93.185537] sd 1:0:0:0: [sdb] tag#1 CDB: opcode=0x28 28 00 0b 0b 58 00 00 04 00 00
[ 93.185544] sd 1:0:0:0: [sdb] tag#2 uas_zap_pending 0 uas-tag 8 inflight: CMD
[ 93.185549] sd 1:0:0:0: [sdb] tag#2 CDB: opcode=0x28 28 00 0b 0b 60 00 00 04 00 00
[ 93.185577] sd 1:0:0:0: [sdb] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=DRIVER_OK cmd_age=2s
[ 93.185579] sd 1:0:0:0: [sdb] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=DRIVER_OK cmd_age=2s
[ 93.185584] sd 1:0:0:0: [sdb] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=DRIVER_OK cmd_age=2s
[ 93.185587] sd 1:0:0:0: [sdb] tag#0 CDB: opcode=0x28 28 00 0b 0b 50 00 00 04 00 00
[ 93.185588] sd 1:0:0:0: [sdb] tag#28 CDB: opcode=0x28 28 00 0b 0b 48 00 00 04 00 00
[ 93.185595] sd 1:0:0:0: [sdb] tag#24 CDB: opcode=0x28 28 00 0b 0b 40 00 00 04 00 00
[ 93.185594] blk_update_request: I/O error, dev sdb, sector 185288704 op 0x0:(READ) flags 0x80700 phys_seg 128 prio class 0
[ 93.185595] blk_update_request: I/O error, dev sdb, sector 185290752 op 0x0:(READ) flags 0x80700 phys_seg 128 prio class 0
[ 93.185604] blk_update_request: I/O error, dev sdb, sector 185286656 op 0x0:(READ) flags 0x80700 phys_seg 128 prio class 0
[ 93.185648] sd 1:0:0:0: [sdb] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=DRIVER_OK cmd_age=1s
[ 93.185658] sd 1:0:0:0: [sdb] tag#1 CDB: opcode=0x28 28 00 0b 0b 58 00 00 04 00 00
[ 93.185665] blk_update_request: I/O error, dev sdb, sector 185292800 op 0x0:(READ) flags 0x80700 phys_seg 128 prio class 0
[ 93.185705] sd 1:0:0:0: [sdb] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=DRIVER_OK cmd_age=1s
[ 93.185704] blk_update_request: I/O error, dev sdb, sector 185290752 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 93.185715] sd 1:0:0:0: [sdb] tag#2 CDB: opcode=0x28 28 00 0b 0b 60 00 00 04 00 00
[ 93.185721] blk_update_request: I/O error, dev sdb, sector 185286656 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 93.185723] blk_update_request: I/O error, dev sdb, sector 185294848 op 0x0:(READ) flags 0x80700 phys_seg 128 prio class 0
[ 93.187921] Aborting journal on device sdb3-8.
[ 93.187969] Buffer I/O error on dev sdb3, logical block 121667584, lost sync page write
[ 93.187988] JBD2: Error -5 detected when updating journal superblock for sdb3-8.
[ 93.402674] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[ 94.032695] sd 1:0:0:0: [sdb] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
[ 96.676905] EXT4-fs error (device sdb3): ext4_get_inode_loc:4382: inode #2097417: block 8388656: comm smbd: unable to read itable block
[ 96.691517] EXT4-fs error (device sdb3): ext4_get_inode_loc:4382: inode #2097417: block 8388656: comm smbd: unable to read itable block
[ 96.713396] EXT4-fs error (device sdb3): ext4_get_inode_loc:4382: inode #2097417: block 8388656: comm smbd: unable to read itable block
[ 96.734350] EXT4-fs error (device sdb3): ext4_get_inode_loc:4382: inode #2097417: block 8388656: comm smbd: unable to read itable block
[ 96.756573] EXT4-fs error (device sdb3): ext4_get_inode_loc:4382: inode #2097153: block 8388640: comm smbd: unable to read itable block
[ 96.782828] EXT4-fs error (device sdb3): ext4_get_inode_loc:4382: inode #2097153: block 8388640: comm smbd: unable to read itable block
[ 96.809998] EXT4-fs error (device sdb3): ext4_get_inode_loc:4382: inode #2097593: block 8388667: comm smbd: unable to read itable block
[ 96.830396] EXT4-fs error (device sdb3): ext4_get_inode_loc:4382: inode #2097593: block 8388667: comm smbd: unable to read itable block
[ 96.849925] EXT4-fs error (device sdb3): ext4_get_inode_loc:4382: inode #2097593: block 8388667: comm smbd: unable to read itable block
[ 96.869336] EXT4-fs error (device sdb3): ext4_get_inode_loc:4382: inode #2097593: block 8388667: comm smbd: unable to read itable block
[ 96.886061] EXT4-fs warning (device sdb3): htree_dirblock_to_tree:1028: inode #2097153: lblock 0: comm smbd: error -5 reading directory block
[ 96.887258] EXT4-fs warning (device sdb3): htree_dirblock_to_tree:1028: inode #2097593: lblock 0: comm smbd: error -5 reading directory block
[ 96.888670] EXT4-fs warning (device sdb3): htree_dirblock_to_tree:1028: inode #2097593: lblock 0: comm smbd: error -5 reading directory block
[ 96.889611] EXT4-fs warning (device sdb3): htree_dirblock_to_tree:1028: inode #2097153: lblock 0: comm smbd: error -5 reading directory block
[ 96.911973] EXT4-fs warning (device sdb3): htree_dirblock_to_tree:1028: inode #2097153: lblock 0: comm -
Shummo
Raspberry pi 4-el kapcsolatban az alábbi problémába ütkoztem.Alap konfig. USB3.0ról (SSD) bootol a rendszer, ami bullseye alapú raspbian. + a másik 3.0 porton lóg egy 1 TB-os HDD. (SSD axagon / HDD +tápos orico külső tokban )
Az utóbbi időben meggyűlt update/upgrade után a bajon a HDD felcsatolásával, de 1-2 restart után csak sikerült neki.
csak az SSD látom /sda alatt, de a HDD nem csatolódik sdb-re.Tegnap frissítettem egyet, aminek az lett az eredménye, hogy már nem is látja a HDD-t ha bedugom a 3.0-ba, de USB 2.0n minden hibátlan, megy az automount is.
/ets/fstab így néz ki:
UUID=c................................... /media/d....a ext4 defaults,auto,users,rw,nofail,x-systemd.device-timeout=15 0 0Tudnátok segíteni, hogy milyen irányba induljak el.
Kernel gond lehet ez? -
Shummo
Egy parancsot szeretnék lefuttatni minden induláskor kb 30 mp késleltetéssel
A parancs:docker exec -it hassio_audio pactl load-module module-alsa-sinkA problémám, hogy hiába teszem a CRONTABba
@reboot sleep 30 && docker exec -it hassio_audio pactl load-module module-alsa-sink
Vagy
csinálok egy .sh-t :#!/bin/bashsleep 30docker exec -it hassio_audio pactl load-module module-alsa-sinkAz eredmény mégis az, hogy a parancsnak nincs hatása. Lefut, de a modul nem töltődik be.
Ha csak simán SSHn beírom akkor viszont működik.
root vagy pi@raspberrypi:~ $ docker exec -it hassio_audio pactl load-module module-alsa-sinkTudtok ebben esetleg segíteni?
Shummo
Steven
#43702
Ahogy azt írtam is, nekem nem serviceként fut (nem nox).
Desktop verziót használok.És így indul autómatikusan:
sudo nano /etc/xdg/lxsession/LXDE-pi/autostartnem serviceként.
A desktop verzió pedig kell, mert van benne RSS + kereső funkció., ami a WEB UIba nincsMIndenesetre köszönöm
Shummo
sziasztok. Valaki tudna segiteni abban, hogy a rASpberry Pi -4 re kötött + HDD-n a Qbittorent a letöltött új fájlokat jó permissionnal hozza látre?
Rendszer SSDn, a Qbittorent desktop verziót használom (nem a NOX)
az új fájl "rw----r--" jön létre.
az OWNER az a pi:pi, plusz az alábbi parancsoat futtattam:sudo chown -R pi:pi /nassudo find /nas -type d -exec chmod 775 {} \;sudo find /nas -type f -exec chmod 775 {} \;
+ a SETFACL paranncsal hozzáadtam egy +usert is akit NFS kapcsolat esetén használok.A letöltési mappa essetében el tudtam érni hogy a default group jogok szintén rw legyen.
De hiábasetfacl -d -m g::rwx /nas/downloadsparancs. Mégse lesz az alapértelmezett az X is.
Szóval most rw-rw-r-- jön létre a fájl.+ Ami érdekes, ha én hozok létre egy fájl mondjuk a Windwoson belül a + userrel, akkor az rwxrw-r-- joggal jön létre.
Esetleg valaki tudna segíteni, hogy oldható meg, hogy az alap a chmod 770 vagy 775 legyen?
Vagy legalább a User(group) legyen RWX.
Köszönöm -
Shummo
Sziasztok. Újabb kérdésben kérném a segítségeteket.
Debian 10 fut az rpi4en külső SSDről és van még rajta egy másik hdd.Szeretnék egy automata biztonsági mentést beállítani a rendszerről, szóval hogy hetente mentse az ssdn lévő rendszert a hddre vagy esetleg másik a hálózaton lévő hddra.
Ehhez milyen progit/módszert javasoltok?
Shummo
Sziasztok. Segítséget szeretnék kérni az alábbiakhoz.
Jelenleg wireguardot futtatok az RPI 4en. Minden szépen működik server - client irányban..
Jeleng azonban azt szeretném, ha a client - client irány is menne. Azaz el szeretném érni az egyik cliensről a másik clienst.
A belső hálózatról el tudom érni jelenleg a clienst, de peer-server-peer már nem látszódik. Pingelés se megy.jelenleg a wireguard configom így néz ki, az IPTABELEST kellene valahogy kiegészíteni, átírni, csak nem értek hozzá.
PostUp = iptables -A FORWARD -i wg0 -j ACCEPT; iptables -A FORWARD -o wg0 -j ACCEPT; iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADEPostDown = iptables -D FORWARD -i wg0 -j ACCEPT; iptables -D FORWARD -o wg0 -j ACCEPT; iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE -
Shummo
Sziaztok.
Van egy Rpi4en aluminium Armor Case-ben. A Bluetooth viszonylag kicsi területen elérhető. Nagyjából 1 szobában. (A xiaomi gateway-en viszont gond nélkül kommikál kicsit távolabbról is egy BT eszközzel).
Gondolom a burkolat ennyire lekorlátozza.Kérdésem az lenne, hogy valamilyen módon tudom e növelni a hatótávot?
Van egy ilyen noname USB-s BT adapterem[link].
Esetlegesen megoldható hogy az RPI-t ezzel használnjam? (rendszer: Raspbian) -
Shummo
Olyan kérdésem lenne felétek, hogy mivel oldható meg, hogy egy olyan mappában ( aminek az OWNERje a PI) ha új mappát hozok létre akkor az már alapból a GROUP által irható módon jöjjön létre , és ne kelljen mindig permissiont állítani rá(chmod 775).Jelenleg csakaz OWNER által írható, ami azért nem jó, mert a sambat más userekkel használják, amik a GORUP része, de így nem tudják irni, a Qbittorent (PI user) által létrehozott mappákat/fájlokat.
Köszönöm
Shummo
Erre esetleg valakinek nincs ötlete: [41459] ?
Shummo
Sziasztok. Valaki esetleg már hallom ilyenről:
Konfig: RPI4 + SSDn a rendszer USB3 tokban (quirkssel megoldva a stabil kapcsolat)
+ USB3-n van egy 1TB HDD mellette plusz táppal falból.Amikor ezt így össze raktam akkor írás ment 80-90 MB/s olvasás pedig 110 MB/s körül, amikor gigabiten másolok hálózaton egy másik gép SSDjére/ről. (SSD/HDD esetén is)
Aztán most nem, tudom hogy, de azt vettem észre, hogy írás maradt ahogy volt 80+, de olvasás nem bír 50+t elérni....
Ami vicces, mert a SSD-ről ugyan úgy megy a dolog (80+/100+). HDD azonban már csak (80+/50).
Még sose tapasztaltam olyat, hogy kevesebb legyen az olvasási tempo mint az írás...
A próbálkozásaim zsákutcába fulladtak. Esetleg tudtok valami támpontot nyújtani merre kezdjem a kutakodást? -
Shummo
UberMutant
#41266
Tudom hogy van webes felület, de azzal nem tudom megcsinalni, hogy a .torrent fájlt hozzárendeljem alapértelmezett megnyitással.
A transmissionnal amit eddig használtam duplakattra már adta is hozzá a torrentet a sorhoz.
A webes felületet viszont be kell tölteni, torrent hozzáad, stb.
Szóval nem annyia fluid nekem, azért szeretném a GUIt.Vagy megoldható, hogy a windows egyből a qbittorentben nyissa meg/ adja hozzá a torrentet?
Shummo
Tegnap néztem gyorsan egy tesztet: Nálam qBittorrent 30MB/s tudott, ugyan azzal a torrentel a Transmission csak 15-18 MB/st.
Viszont sajnos úgy látom a Qbittorrentnek nincs Desktop GUIja( szóval client ami csatlakozik a serverre csak nem WEBen) mint a Deluge-nak vagy a Transmissionnak.
Deluge-ról mi a tapasztalat a qBittorrent-hez képest? Van értelme rápróbálnom?
Shummo
Sziasztok. Jelenleg a ROuteremre van kötve egy HDD usb 3.0 házzal.
Tervbe vettem hogy átteszem a HDDt a raspberry Pi 4-re. (csak külső tápos ház is kell majd hozzá, szóval egyelőre infót gyűjtök megéri e)
PI-n fut még nekem Home assistant / wireguard /mysql, > kb 20 % CPU load mellett.Kérdésem lenne hogy esetleg valaki használja e a raspberry pi-t RASPBIAN rendszerrel NAS ként is.
Ha igen, milyen tempót várhatok adatmozgatás terén? SMB/NFS érdekelne főleg.Jelenleg nekem a routeren SMB/NFSként megy, max adatátvielti sebesség 35-40MByte/s. (szóval még bőven bírja a HDD)
Transmission letöltés pedig max 7-8MB/s. -
Shummo
Sziasztok. Passzív hűtést vennék a PI 4.re. (4gb). Erről valakinek van véleménye: [link]
A topicban ajánlott armor Casehez képest ez jobban tetszene, mivel rendesen bezarja, nem lóg ki a nyák. A linken szereplő jobban tetszik, viszont nyilván az eredmény a fontos nem a külleme.
- Milyen széket vegyek?
- TP-LINK routerek
- BestBuy topik
- Európába tart a Xiaomi Watch 5, eSIM-es verzió is jöhet
- Dell Optiplex 3050 SFF,i3-6100,8GB DDR4,256GB SSD, WIN11
- HP ProLiant DL360e G8 8xSFF 1U 2xE5-2450L (16 mag/32 szál), 144GB DDR3, iLO4, B120i, P410 1GB BBU
- ÁRGARANCIA! Épített KomPhone i5 12400F 16/32/64GB RAM RX 9060 XT 16GB GAMER PC termékbeszámítással
- ÁRGARANCIA! Épített KomPhone R7 5700X 16/32/64GB RAM RX 9060 XT 16GB GAMER PC termékbeszámítással
- HP EliteDesk 800 G3 (USDT), i5-6500T, 8GB DDR4,128GB SSD,WIN11
- Vállalom Xiaomi Okoskamerák szoftveres javíttását
- iPhone 16 Pro 128GB Desert Titanium -1 ÉV GARANCIA - Kártyafüggetlen
- Dell Wyse 5470,14",FHD, N4100 CPU,8GB DDR4,128GB SSD,WIN11
- GYÖNYÖRŰ iPhone 14 Pro Max 128GB Deep Purple - 1 ÉV GARANCIA -Kártyafüggetlen, MS3702
wassermann
