Z10N
Ahogy mondtam PS5 SoC.
https://videocardz.com/newz/amd-4700s-desktop-kit-is-based-on-playstation-5-soc
The 4700S APU is attached to AMD A77E Fusion Controller Hub (FCH), the same one that was used by the AMD A9-9820 system, which was based on Xbox One APU codenamed “Durango”. This is why it was incorrectly believed that 4700S may also be based on Xbox APU, except on a newer version from Series X or Series S.
In terms of clock speeds, the 8GB GDDR6 memory is clocked at an effective 14 Gbps, while the APU appears to go up to 3.2 GHz. Unfortunately, though CPU-Z software does not recognize this processor yet. Thanks to faster memory the bandwidth is actually a lot higher than DDR4-3200 based system
$150-ert egesz jo kis htpc alap lenne.
Z10N
Ezek amolyan gyártási selejtek, amelyeket a Sony vagy a Microsoft nem tud hasznosítani
Based On PlayStation 5 SoC “Ariel”
Z10N
https://videocardz.com/newz/amd-launches-4700s-desktop-kit-featuring-zen2-apu-from-xbox-series
- Filmgyűjtés
- Gurulunk, WAZE?!
- Végleg lemondott a régi gépekről a Steam
- Lakáshitel, lakásvásárlás
- Házimozi belépő szinten
- Méretes és széles gaming monitorral bővült az MSI kínálata
- Bittorrent topik
- LEGO klub
- Samsung Galaxy S25 Ultra Titanium Jetblack Titán dizájn, 120 Hz AMOLED, AI Pro kamera
- Ventilátor bazár /NZXT/CORSAIR/LIAN LI/DEEPCOOL/ZALMAN/120MM/140MM/VEZÉRLŐK/LED KIT-ek/
- Alienware 17r4 olvass
- Samsung Galaxy S22 128GB, Kártyafüggetlen, 1 Év Garanciával
- Apple iPhone 16 128GB, Kártyafüggetlen, 1 Év Garanciával
