p_milan
Tűzfalat már kikapcsoltam a routerben is meg az XPben is. A routerben van valami,mert ha kiiktatom akkor megy jól minden!
p_milan
Hol találtál te ehhez FW-t?
Más.
A WarCraft 3 kb 5percig látom a servereket,aztán semmi, újra kell indítanom, hogy megint lássa. Utorrentnél ugyan ez. 5percig aktív vagyok, aztán passzív. És a többi programnál is hasonló a helyzet! Egy darabig minden rendben, aztán valami mintha letiltaná a kapcsolatot a routerben!
Mi a franc ez? -
p_milan
HEllo!
Valaki tudja mit jelent ez a Security Logban :
2007/04/16 11:37:29 : Blocked access attempt from 60.37.191.114
2007/04/16 11:37:28 : Blocked access attempt from 124.184.154.99
2007/04/16 11:37:28 : Blocked access attempt from 222.128.26.164
2007/04/16 11:37:27 : Blocked access attempt from 200.189.60.251
2007/04/16 11:37:26 : Blocked access attempt from 88.80.105.137
2007/04/16 11:37:24 : Blocked access attempt from 213.240.251.129
2007/04/16 11:37:22 : Blocked access attempt from 81.192.255.193
2007/04/16 11:37:19 : Blocked access attempt from 194.165.112.57
2007/04/16 11:37:15 : Blocked access attempt from 85.68.200.189
2007/04/16 11:37:15 : Blocked access attempt from 60.39.189.149
2007/04/16 11:37:14 : Blocked access attempt from 59.124.70.207
2007/04/16 11:37:14 : Blocked access attempt from 67.188.49.3
2007/04/16 11:37:12 : Blocked access attempt from 60.48.187.169
2007/04/16 11:37:10 : Blocked access attempt from 81.37.131.47
2007/04/16 11:37:10 : Blocked access attempt from 88.105.33.194
2007/04/16 11:37:10 : Blocked access attempt from 207.255.212.249
2007/04/16 11:37:09 : Blocked access attempt from 195.14.170.246
2007/04/16 11:37:08 : Blocked access attempt from 60.26.131.47
2007/04/16 11:37:08 : Blocked access attempt from 67.188.49.3
2007/04/16 11:37:08 : Blocked access attempt from 60.49.111.162
2007/04/16 11:37:07 : Blocked access attempt from 74.96.22.84
2007/04/16 11:37:07 : Blocked access attempt from 201.78.237.106
2007/04/16 11:37:05 : Blocked access attempt from 67.188.49.3
2007/04/16 11:37:04 : Blocked access attempt from 218.253.110.192
2007/04/16 11:37:03 : Blocked access attempt from 203.114.153.147
2007/04/16 11:37:03 : Blocked access attempt from 201.236.185.254
2007/04/16 11:37:02 : Blocked access attempt from 219.74.166.250
2007/04/16 11:37:02 : Blocked access attempt from 218.81.174.76
2007/04/16 11:37:01 : Blocked access attempt from 124.189.213.6
2007/04/16 11:37:01 : Blocked access attempt from 84.3.173.108
2007/04/16 11:37:00 : Blocked access attempt from 205.206.26.72
2007/04/16 11:36:58 : Blocked access attempt from 84.149.227.173
2007/04/16 11:36:58 : Blocked access attempt from 125.31.16.206
2007/04/16 11:36:58 : Blocked access attempt from 84.1.178.196
2007/04/16 11:36:56 : Blocked access attempt from 61.54.160.185
2007/04/16 11:36:56 : Blocked access attempt from 82.44.170.93
2007/04/16 11:36:54 : Blocked access attempt from 125.108.99.4
2007/04/16 11:36:54 : Blocked access attempt from 205.206.26.72
2007/04/16 11:36:53 : Blocked access attempt from 80.250.114.91
2007/04/16 11:36:53 : Blocked access attempt from 64.20.102.51
2007/04/16 11:36:52 : Blocked access attempt from 76.213.174.185
2007/04/16 11:36:52 : Blocked access attempt from 195.246.48.216
2007/04/16 11:36:51 : Blocked access attempt from 205.206.26.72
2007/04/16 11:36:50 : Blocked access attempt from 218.80.74.177
2007/04/16 11:36:47 : Blocked access attempt from 124.157.152.123
2007/04/16 11:36:47 : Blocked access attempt from 125.33.243.202
2007/04/16 11:36:46 : Blocked access attempt from 88.105.33.194
2007/04/16 11:36:39 : Blocked access attempt from 58.252.237.32
2007/04/16 11:36:38 : Blocked access attempt from 24.2.175.249
2007/04/16 11:36:37 : Blocked access attempt from 58.247.158.221
2007/04/16 11:36:34 : Blocked access attempt from 70.95.128.54
2007/04/16 11:36:34 : Blocked access attempt from 88.105.33.194
2007/04/16 11:36:34 : Blocked access attempt from 62.77.79.106
2007/04/16 11:36:31 : Blocked access attempt from 87.118.186.56
2007/04/16 11:36:29 : Blocked access attempt from 195.162.221.136
2007/04/16 11:36:29 : Blocked access attempt from 88.105.33.194
2007/04/16 11:36:28 : Blocked access attempt from 81.182.115.217
2007/04/16 11:36:28 : Blocked access attempt from 62.77.79.106
2007/04/16 11:36:26 : Blocked access attempt from 220.39.248.1
2007/04/16 11:36:26 : Blocked access attempt from 82.239.141.31
2007/04/16 11:36:26 : Blocked access attempt from 203.218.145.227
2007/04/16 11:36:25 : Blocked access attempt from 88.105.33.194
2007/04/16 11:36:24 : Blocked access attempt from 85.186.167.101
2007/04/16 11:36:23 : Blocked access attempt from 89.84.143.4
2007/04/16 11:36:22 : Blocked access attempt from 207.255.212.249
2007/04/16 11:36:19 : Blocked access attempt from 218.6.18.90
2007/04/16 11:36:18 : Blocked access attempt from 124.184.154.99
2007/04/16 11:36:16 : Blocked access attempt from 77.216.31.64
2007/04/16 11:36:14 : Blocked access attempt from 58.34.28.69
2007/04/16 11:36:14 : Blocked access attempt from 124.184.154.99
2007/04/16 11:36:12 : Blocked access attempt from 87.126.123.234
2007/04/16 11:36:09 : Blocked access attempt from 60.26.128.162
2007/04/16 11:36:08 : Blocked access attempt from 124.184.154.99
2007/04/16 11:36:05 : Blocked access attempt from 60.50.132.193
2007/04/16 11:36:04 : Blocked access attempt from 189.160.101.144
2007/04/16 11:36:03 : Blocked access attempt from 219.73.98.195
2007/04/16 11:36:01 : Blocked access attempt from 87.120.166.235
2007/04/16 11:35:59 : Blocked access attempt from 66.198.39.109
2007/04/16 11:35:58 : Blocked access attempt from 221.8.27.200
2007/04/16 11:35:58 : Blocked access attempt from 207.255.212.249
2007/04/16 11:35:56 : Blocked access attempt from 125.123.203.2
2007/04/16 11:35:53 : Blocked access attempt from 220.176.156.45
2007/04/16 11:35:52 : Blocked access attempt from 89.215.221.131
2007/04/16 11:35:52 : Blocked access attempt from 66.198.39.109
2007/04/16 11:35:50 : Blocked access attempt from 219.135.206.241
2007/04/16 11:35:50 : Blocked access attempt from 66.198.39.109
2007/04/16 11:35:50 : Blocked access attempt from 84.40.227.191
2007/04/16 11:35:49 : Blocked access attempt from 125.228.163.154
2007/04/16 11:35:48 : Blocked access attempt from 84.149.227.173
2007/04/16 11:35:48 : Blocked access attempt from 61.173.124.65
2007/04/16 11:35:48 : Blocked access attempt from 200.232.192.188
2007/04/16 11:35:47 : Blocked access attempt from 82.35.153.117
2007/04/16 11:35:47 : Blocked access attempt from 89.79.124.169
2007/04/16 11:35:46 : Blocked access attempt from 207.255.212.249
2007/04/16 11:35:44 : Blocked access attempt from 189.160.101.144
2007/04/16 11:35:41 : Blocked access attempt from 201.9.222.204
2007/04/16 11:35:40 : Blocked access attempt from 88.105.33.194
2007/04/16 11:35:40 : Blocked access attempt from 207.255.212.249
2007/04/16 11:35:38 : Blocked access attempt from 88.112.128.142
2007/04/16 11:35:37 : Blocked access attempt from 59.155.149.35
2007/04/16 11:35:37 : Blocked access attempt from 207.255.212.249
2007/04/16 11:35:36 : Blocked access attempt from 190.37.42.60
2007/04/16 11:35:35 : Blocked access attempt from 84.0.158.110
2007/04/16 11:35:33 : Blocked access attempt from 85.117.47.146
2007/04/16 11:35:32 : Blocked access attempt from 81.183.104.208
2007/04/16 11:35:32 : Blocked access attempt from 87.203.16.38
2007/04/16 11:35:31 : Blocked access attempt from 218.90.238.146
2007/04/16 11:35:29 : Blocked access attempt from 81.183.104.208
2007/04/16 11:35:29 : Blocked access attempt from 82.44.114.65
2007/04/16 11:35:29 : Blocked access attempt from 61.145.35.96
2007/04/16 11:35:28 : Blocked access attempt from 67.188.49.3
2007/04/16 11:35:25 : Blocked access attempt from 88.80.96.19
2007/04/16 11:35:22 : Blocked access attempt from 205.206.26.72
2007/04/16 11:35:22 : Blocked access attempt from 67.188.49.3
2007/04/16 11:35:22 : Blocked access attempt from 88.222.172.48
2007/04/16 11:35:20 : Blocked access attempt from 222.67.90.78
2007/04/16 11:35:19 : Blocked access attempt from 59.35.4.183
2007/04/16 11:35:19 : Blocked access attempt from 67.188.49.3
2007/04/16 11:35:17 : Blocked access attempt from 88.105.33.194
2007/04/16 11:35:17 : Blocked access attempt from 196.217.144.162
2007/04/16 11:35:16 : Blocked access attempt from 88.72.8.26
2007/04/16 11:35:16 : Blocked access attempt from 205.206.26.72
2007/04/16 11:35:16 : Blocked access attempt from 76.213.174.185
2007/04/16 11:35:16 : Blocked access attempt from 72.232.38.26
2007/04/16 11:35:13 : Blocked access attempt from 60.209.203.209
2007/04/16 11:35:13 : Blocked access attempt from 218.81.250.161
2007/04/16 11:35:13 : Blocked access attempt from 205.206.26.72
2007/04/16 11:35:10 : Blocked access attempt from 221.6.202.165
Megy egy torrent kliens ( utorrent ), és gondolom azoknak a kapcsolatait blokkolja le, de nem tudom miért. Már megpróbáltam beállítgatni a dolgokat, engedélyeztema portokat, de csak blokkol mindent. Így alig van ember akitől tudna tölteni! Valakinek valami ötlet?
- Mac Mini M4 AZONNAL 16GB 256GB 1 év gar
- Dell Latitude 5400 14" FHD IPS, i7 8665U, 8-16GB RAM, SSD, jó akku, számla, 6 hó gar
- BESZÁMÍTÁS! ASUS H510M i7 11700 16GB DDR4 500GB SSD RTX 3060 Ti OC 8GB Zalman Z1 PLUS ADATA 600W
- Dell Latitude 5440 14" Touchscreen i5-1235U 16GB 256GB 1 év garancia
- Keresünk iPhone 16/16 Plus/16e/16 Pro/16 Pro Max
