Lala6
Kipróbáltam, sajnos így sem jó, még mindig ugyanaz a hiba üzenet jön
SQL-kérés :
CREATE TABLE `e107_upload` (
`upload_id` int( 10 ) unsigned NOT NULL AUTO_INCREMENT ,
`upload_poster` varchar( 100 ) NOT NULL default '',
`upload_email` varchar( 100 ) NOT NULL default '',
`upload_website` varchar( 100 ) NOT NULL default '',
`upload_datestamp` int( 10 ) unsigned NOT NULL default '0',
`upload_name` varchar( 100 ) NOT NULL default '',
`upload_version` varchar( 10 ) NOT NULL default '',
`upload_file` varchar( 100 ) NOT NULL default '',
`upload_ss` varchar( 100 ) NOT NULL default '',
`upload_description` text NOT NULL ,
`upload_demo` varchar( 100 ) NOT NULL default '',
`upload_filesize` int( 10 ) unsigned NOT NULL default '0',
`upload_active` tinyint( 3 ) unsigned NOT NULL default '0',
`upload_category` tinyint( 3 ) unsigned NOT NULL default '0',
PRIMARY KEY ( `upload_id` )
)ENGINE = MYISAM DEFAULT CHARSET = latin2 AUTO_INCREMENT =1
MySQL jelzi:
#1064 - You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'DEFAULT CHARSET = latin2 AUTO_INCREMENT =1' at line 15 -
Lala6
Próbálgatom ismételten. Leírom, hogy pontosan hogyan.
Egy táblát lementettem(e107_upload) phpmyadminon keresztül. Tökéletes a mentés, tömörítve nincs.
Átmentem a dox.hu phpmyadmin felületére, megnyitottam az adatbátist, sql, megkerestem a file-t a gépemen, végrehajt gomb...és utánna ezt a hibaüzenetet kaptam:
Adatbázis tsz : localhost
Hiba
SQL-kérés :
`upload_poster` varchar( 100 ) COLLATE latin2_hungarian_ci NOT NULL default '',
`upload_email` varchar( 100 ) COLLATE latin2_hungarian_ci NOT NULL default '',
`upload_website` varchar( 100 ) COLLATE latin2_hungarian_ci NOT NULL default '',
`upload_name` varchar( 100 ) COLLATE latin2_hungarian_ci NOT NULL default '',
`upload_version` varchar( 10 ) COLLATE latin2_hungarian_ci NOT NULL default '',
`upload_file` varchar( 100 ) COLLATE latin2_hungarian_ci NOT NULL default '',
`upload_ss` varchar( 100 ) COLLATE latin2_hungarian_ci NOT NULL default '',
`upload_description` text COLLATE latin2_hungarian_ci NOT NULL ,
`upload_demo` varchar( 100 ) COLLATE latin2_hungarian_ci NOT NULL default '',
)ENGINE = MYISAM DEFAULT CHARSET = latin2 COLLATE = latin2_hungarian_ci AUTO_INCREMENT =1
MySQL jelzi:
#1064 - You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'collate latin2_hungarian_ci NOT NULL default '',
`upload_emai
Utánna megpróbáltam, hogy az sql fáljból kimásoltam a parancsokat és beillesztettem a phpmyadmin sql fülénél található parancs mezőbe. Szintén ugyanezt az üzenetet kaptam vissza.
Mi lehet a probléma?
PHPMyAdmin verziók:
uw.hu:
Üdvözöl a phpMyAdmin 2.6.1-pl3
MySQL 4.1.10-standard-log, szerver: 192.168.0.100, felhasználó: [email]
dox.hu
Üdvözöl a phpMyAdmin 2.5.6
MySQL 4.0.22-log, szerver: localhost, felhasználó: tsz@localhost -
Lala6
Senki nem tud segíteni?
Lala6
Meg ilyet is ír:
MySQL jelzi:
`description -
Lala6
Ezt írja ki az ATW-n: Fatal error: Maximum execution time of 10 seconds exceeded in /libraries/read_dump.lib.php on line 77
A dox.hu-n is ugyanezt annyi különbséggel, hogy 5 seconds van a 10 helyett.
Kipróbáltam az atw-n, hogy csináltam új táblákat, lementettem őket, letöröltem, majd vissza tettem a mentésből, gond nélkül megcsinálta...
[Szerkesztve] -
Lala6
Gondban vagyok. Van egy egyszerű portálom az uw-n, most ezt az egészet átszeretnám tenni az atw-re. A portál e107 motorral megy. Az uw-n a phpmyadmin-ban lementettem az atatbázist, de az atw-re nem tudom feltölteni a táblákat, mindig kiír valamilyen hiba üzenetet. Az oldal tartalmát ftp-n átmásoltam az új helyre, az adatbázist létrehoztam, de a táblákat nem tudom áttenni. Próbáltam úgy is, hogy csak 1-et teszek át egyszerre, de úgy is hibát jelez. Kínomban kipróbáltam a dox.hu-n is, és nagy meglepetésemre ugyanazok a hibák jöttek.
Valaki megtudná mondani, hogy hogyan tegyem át a meglévő adatbázisomat(táblákat) az új helyre? Már kezdem feladni
- MasterDeeJay: Egy nem átlagos Asus videókártya (GTX950M 2GB GDDR3)
- Path of Exile (ARPG)
- AMD vs. INTEL vs. NVIDIA
- AliExpress tapasztalatok
- Új Lenovo Thinkpad X1 2in1 Gen9 WUXGA Ultra 7 165U 12mag 32GB 512GB Intel Arc iGPU Win11 Garancia
- AKCIÓ! Acer Predator Helios Neo 16 PHN16 notebook-i9 13900HX 16GB DDR5 1TB SSD RTX 4060 8GB W11
- Dell XPS 13 9300 i7-1065G7 8GB 1000GB FHD+ 500nit! 1 év garancia
- BESZÁMÍTÁS! Gigabyte B650M R5 7600 16GB DDR5 512GB SSD RX 9070 XT 16GB NZXT H7 Flow fehér 750W
- BESZÁMÍTÁS! ASRock A520M R5 5500 16GB DDR4 512GB SSD RTX 2060 6GB CM Masterbox MB311L ARGB 500W
