Tomato firmware
-kolibri-
Felraktam az új verziót: tomato-RT-N18U-ARM--140-AIO-64K-NOSMP
administration/configuration/restore -> default configuration/erase all data in nvram memory
majd azitt leírtak szerint JFFS fstab.
Viszont ellenőrzésnél nincs ott a mount ami 132-es verzióval simán ment:root@unknown:/tmp/home/root# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 20864 20864 0 100% /
devtmpfs 127896 0 127896 0% /dev
tmpfs 127896 216 127680 0% /tmp
devfs 127896 0 127896 0% /dev
/dev/mtdblock5 65536 1672 63864 3% /jffs
root@unknown:/tmp/home/root# free -t
total used free shared buffers cached
Mem: 255792 38964 216828 0 5692 13376
-/+ buffers/cache: 19896 235896
Swap: 524284 0 524284
root@unknown:/tmp/home/root# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro,relatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=127800k,nr_inodes=31950,mode=755)
proc on /proc type proc (rw,relatime)
tmpfs on /tmp type tmpfs (rw,relatime)
devfs on /dev type tmpfs (rw,noatime)
sysfs on /sys type sysfs (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
/dev/mtdblock5 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw,relatime)
root@unknown:/tmp/home/root# dmesg
unted
Freeing init memory: 188K
emf: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
et_module_init: passivemode set to 0x0
et_module_init: txworkq set to 0x0
et_module_init: et_txq_thresh set to 0x0
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.86 (r456083)
wl_module_init: passivemode set to 0x0
wl_module_init: txworkq set to 0x0
eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.73 (r448163)
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
SCSI subsystem initialized
csw_retry 100
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
exFAT: Version 1.2.9
xhci_hcd 0000:00:0c.0: xHCI Host Controller
xhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 1
xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000
xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
usb usb1: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
xHCI xhci_add_endpoint called for root hub
xHCI xhci_check_bandwidth called for root hub
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
[xhci-hub] usb2mode:[0]
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd 0000:00:0b.1: EHCI Host Controller
ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 2
ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000
ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usb 1-1: new SuperSpeed USB device using xhci_hcd and address 2
xhci_hcd 0000:00:0c.0: WARN: short transfer on control ep
xhci_hcd 0000:00:0c.0: disable burst on ep 1
xhci_hcd 0000:00:0c.0: WARN no SS endpoint bMaxBurst
xhci_hcd 0000:00:0c.0: disable burst on ep 2
scsi0 : usb-storage 1-1:1.0
device vlan1 entered promiscuous mode
device eth0 entered promiscuous mode
device eth1 entered promiscuous mode
br0: port 2(eth1) entering forwarding state
br0: port 1(vlan1) entering forwarding state
scsi 0:0:0:0: Direct-Access Seagate Expansion 9300 PQ: 0 ANSI: 6
sd 0:0:0:0: [sda] 1953525167 512-byte logical blocks: (1.00 TB/931 GiB)
xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 4f 00 00 00
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda: sda1 sda2 sda3
sd 0:0:0:0: [sda] Attached SCSI disk
Ebtables v2.0 registered
device eth1 left promiscuous mode
kernel BUG at kernel/timer.c:681!
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = ce00c000
[00000000] *pgd=9f2db031, *pte=00000000, *ppte=00000000
Internal error: Oops: 817 [#1] PREEMPT
last sysfs file: /sys/module/nf_conntrack/parameters/hashsize
module: ebtable_filter bf5aa000 1045
module: ebtables bf5a1000 15023
module: ehci_hcd bf593000 32941
module: xhci_hcd bf580000 52841
module: exfat bf562000 91793
module: vfat bf55a000 8505
module: fat bf549000 43594
module: ext4 bf508000 221458
module: crc16 bf502000 999
module: jbd2 bf4ef000 48637
module: mbcache bf4e8000 4927
module: usb_storage bf4d9000 34746
module: sd_mod bf4cd000 22075
module: scsi_wait_scan bf4c7000 408
module: scsi_mod bf4a1000 110762
module: usbcore bf47d000 103930
module: jffs2 bf45f000 93034
module: zlib_deflate bf455000 19481
module: nf_nat_pptp bf44f000 1594
module: nf_conntrack_pptp bf449000 3331
module: nf_nat_proto_gre bf443000 879
module: nf_conntrack_proto_gre bf43d000 3096
module: nf_nat_ftp bf437000 1136
module: nf_conntrack_ftp bf430000 4933
module: nf_nat_sip bf429000 4987
module: nf_conntrack_sip bf420000 15753
module: nf_nat_h323 bf419000 4741
module: nf_conntrack_h323 bf40b000 33999
module: wl bf029000 3875271
module: et bf012000 61889
module: igs bf009000 12311
module: emf bf000000 15802
Modules linked in: ebtable_filter ebtables ehci_hcd xhci_hcd exfat vfat fat ext4 crc16 jbd2 mbcache usb_storage sd_mod scsi_wait_scan scsi_mod usbcore jffs2 zlib_deflate nf_nat_pptp nf_conntrack_pptp nf_nat_proto_gre nf_conntrack_proto_gre nf_nat_ftp nf_conntrack_ftp nf_nat_sip nf_conntrack_sip nf_nat_h323 nf_conntrack_h323 wl(P) et(P) igs(P) emf(P)
CPU: 0 Tainted: P (2.6.36.4brcmarm #29)
PC is at __bug+0x1c/0x28
LR is at __bug+0x18/0x28
pc : [<c003aec4>] lr : [<c003aec0>] psr: 60000013
sp : cf2f3c80 ip : 0000000a fp : 00000000
r10: 00000000 r9 : 00000000 r8 : 000001c6
r7 : cf2dc16c r6 : 0083685b r5 : 0083685b r4 : cf2dcfd4
r3 : 00000000 r2 : 00000001 r1 : 60000013 r0 : 00000028
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c53c7d Table: 9e00c059 DAC: 00000015
Process hotplug (pid: 859, stack limit = 0xcf2f2268)
Stack: (0xcf2f3c80 to 0xcf2f4000)
3c80: 00000000 c0061c34 cf2f3ca4 00000000 00000000 00000000 ceb6a400 cf2dc16c
3ca0: 000001c6 bf51ab30 cf2dc000 00000000 00000000 000001c6 bf5368c0 bf51b314
3cc0: cf4d0088 bf51c5e8 00000002 c02d32d0 cf1f2a80 cf4c7fc0 bf53a2b0 00000000
3ce0: 00000000 cf2dc000 00000000 bf522fdc 00000000 00000000 bf53a2b0 bf53a23c
3d00: 0000043f 00000000 00000440 00000000 00000000 00000000 c8238f88 c822b500
3d20: 00000000 00000000 bf5368c0 000001c6 cf4d0088 cf4d0088 cf4d0000 cebd2380
3d40: cf2dc000 00000000 cf4cd000 00000000 00000000 bf5235d4 00000000 ceb6a400
3d60: cf2dc14c bf50edb4 00000004 00000004 00000004 cf2dce7c cf2dce80 c0172d14
3d80: 00001d11 00000000 00000000 cf4c7fc0 00000380 00000000 cf2dce00 00000008
3da0: cf2dce00 00000000 00001d11 cf2dc000 cf4cd000 ceb6a400 cf2dc14c bf51f2e0
3dc0: 00001000 00000000 bf4d2110 c0147c48 9e370001 000001fe 00000024 0000000c
3de0: cf2f2000 c0147c84 cf2dce00 00000000 ce7a80c0 cf1f3760 00000000 00000000
3e00: 0000003b 00000000 cf4cd000 00000000 00000000 00000000 0e880cff 00000000
3e20: 00000000 00000000 00000000 00000000 00000000 00000000 ff7fc000 000001fe
3e40: 00000014 0000001e 00000000 00000000 00000003 cf1ff000 cf1ff00c cf2dc000
3e60: ce00a000 ce00a000 00000000 c0159c78 c00bf1c0 ce00a000 00004003 00000000
3e80: 00000004 cf4084e0 00000003 cf408540 00000000 cf2dc000 ce00a000 ce00a000
3ea0: 00000000 c00c008c 33616473 cf1f3e00 0000000a c009db80 00000000 cf2f2000
3ec0: cf805f00 c0417da0 cf805f68 cf805f00 bf53bc1c cf1f3300 00000000 ce00a000
3ee0: cf2f3f48 bf519ae4 bf51d8c8 cf805f00 cf2f3f48 c00bf230 cf805f00 c00d4d14
3f00: bf53bc1c cf1f3140 ce00a000 cf1f3300 00000000 c00bf340 00000000 cf1f3300
3f20: 0000000a 00000000 cf1f3140 c00d7710 00000404 00048fc6 cf2f3f84 00000000
3f40: 00000404 c0037ae8 cf8058c0 cf4ce400 00000000 cf80d000 befaac70 00000000
3f60: 00000404 c0037ae8 cf2f2000 00000000 00000000 c00d8054 ce00a000 c00bbea8
3f80: cf356f00 ce00a000 cf1f3300 cf1f3140 00000000 00048fc6 befaab20 befaac70
3fa0: 00000015 c0037940 00048fc6 befaab20 befaac70 befaab20 400444e0 00000404
3fc0: 00048fc6 befaab20 befaac70 00000015 00000001 00000000 00000000 00000000
3fe0: 4019c72c befaa9b0 00037a70 4019c73c 20000010 befaac70 145a002a 008d8332
[<c003aec4>] (PC is at __bug+0x1c/0x28)
[<c003aec4>] (__bug+0x1c/0x28) from [<c0061c34>] (mod_timer+0x1fc/0x210)
[<c0061c34>] (mod_timer+0x1fc/0x210) from [<bf51ab30>] (init_once+0x170/0x1bc [ext4])
[<bf51ab30>] (init_once+0x170/0x1bc [ext4]) from [<bf51b314>] (ext4_freeze+0x11c/0x12c [ext4])
[<bf51b314>] (ext4_freeze+0x11c/0x12c [ext4]) from [<bf51c5e8>] (ext4_error_inode+0x40/0xd4 [ext4])
[<bf51c5e8>] (ext4_error_inode+0x40/0xd4 [ext4]) from [<bf522fdc>] (ext4_ext_fiemap_cb+0x4a8/0x534 [ext4])
[<bf522fdc>] (ext4_ext_fiemap_cb+0x4a8/0x534 [ext4]) from [<bf5235d4>] (ext4_ext_check_inode+0x24/0x30 [ext4])
[<bf5235d4>] (ext4_ext_check_inode+0x24/0x30 [ext4]) from [<bf50edb4>] (ext4_iget+0x58c/0x6c0 [ext4])
[<bf50edb4>] (ext4_iget+0x58c/0x6c0 [ext4]) from [<bf51f2e0>] (ext4_fill_super+0x1a18/0x2780 [ext4])
[<bf51f2e0>] (ext4_fill_super+0x1a18/0x2780 [ext4]) from [<c00c008c>] (get_sb_bdev+0x148/0x180)
[<c00c008c>] (get_sb_bdev+0x148/0x180) from [<bf519ae4>] (ext4_get_sb+0x20/0x84 [ext4])
[<bf519ae4>] (ext4_get_sb+0x20/0x84 [ext4]) from [<c00bf230>] (vfs_kern_mount+0x54/0x120)
[<c00bf230>] (vfs_kern_mount+0x54/0x120) from [<c00bf340>] (do_kern_mount+0x34/0xe4)
[<c00bf340>] (do_kern_mount+0x34/0xe4) from [<c00d7710>] (do_mount+0x15c/0x7a0)
[<c00d7710>] (do_mount+0x15c/0x7a0) from [<c00d8054>] (sys_mount+0x84/0xc4)
[<c00d8054>] (sys_mount+0x84/0xc4) from [<c0037940>] (ret_fast_syscall+0x0/0x30)
Code: e59f0010 e1a01003 eb0a5d36 e3a03000 (e5833000)
---[ end trace bfe73f5310988bbc ]---
Adding 524284k swap on /dev/sda2. Priority:-1 extents:1 across:524284k
pgd = cf364000
[00000000] *pgd=9f2f9031, *pte=00000000, *ppte=00000000
Internal error: Oops: 817 [#2] PREEMPT
CPU: 0 Tainted: P D (2.6.36.4brcmarm #29)
sp : cf35bc80 ip : c040f7f4 fp : 00000000
r7 : cf373b6c r6 : 00836865 r5 : 00836865 r4 : cf3739d4
r3 : 00000000 r2 : c03cc094 r1 : 60000013 r0 : 00000028
Control: 10c53c7d Table: 9f364059 DAC: 00000015
Process mount (pid: 897, stack limit = 0xcf35a268)
Stack: (0xcf35bc80 to 0xcf35c000)
bc80: 00000000 c0061c34 cf35bca4 00000000 00000000 00000000 cfc43400 cf373b6c
bca0: 000001c6 bf51ab30 cf373a00 00000000 00000000 000001c6 bf5368c0 bf51b314
bcc0: cf4d02c8 bf51c5e8 00000002 c02d32d0 cf356a00 cf4cf6c0 bf53a2b0 00000000
bce0: 00000000 cf373a00 00000000 bf522fdc 00000000 00000000 bf53a2b0 bf53a23c
bd00: 00000109 00000000 0000010a 00000000 00000000 00000000 c8234cf4 c822b500
bd20: 00000000 00000000 bf5368c0 000001c6 cf4d02c8 cf4d02c8 cf4d0240 ceb20380
bd40: cf373a00 00000000 cf4cf900 00000000 00000000 bf5235d4 00000000 cfc43400
bd60: cf373b4c bf50edb4 00000004 00000004 00000004 cf37387c cf373880 c0172d14
bd80: cf98e8a0 00000000 00000000 cf4cf6c0 00000380 00000000 cf373800 00000008
bda0: cf373800 00000000 00000080 cf373a00 cf4cf900 cfc43400 cf373b4c bf51f2e0
bdc0: 00000400 00000000 bf4d2110 c0147c48 9e370001 000001ff 0000001e 0000000a
bde0: cf35a000 c0147c84 cf373800 00000000 ce7a80c0 00000000 00000000 00000000
be00: 00000004 00000000 cf4cf900 00000000 00000000 00000000 000ffbff 00000000
be20: 00000000 00000000 00000000 00000000 00000000 00000000 04043000 00000004
be40: 00000016 00000018 00000000 00000000 00000001 cf1ff000 cf1ff00c cf373a00
be60: 00000000 00000000 00000000 c0159c78 c00bf1c0 00000000 00004003 00000000
be80: 00000004 cf4089c0 00000003 cf408a20 00008000 cf373a00 00000000 00000000
bea0: 00000000 c00c008c 31616473 cfbe6600 0000000a c009db80 00000000 cf35a000
bec0: cf805e60 c0417da0 cf805ec8 cf805e60 bf53bc1c cfbe6740 00008000 00000000
bee0: cf35bf48 bf519ae4 bf51d8c8 cf805e60 cf35bf48 c00bf230 cf805e60 c00d4d14
bf00: bf53bc1c cfbe6880 00000000 cfbe6740 00008000 c00bf340 00000000 cfbe6740
bf20: 00000008 00008000 cfbe6880 c00d7710 00008400 cfbe6740 0000000a 00000000
bf40: 0000000a c009da48 cf8056e0 cf4b0480 00001000 cf116000 000820a8 00000000
bf60: 00008400 c0037ae8 cf35a000 00000000 00000001 c00d8054 00000000 08583b01
bf80: 0000000f 00000000 cfbe6740 cfbe6880 00000000 00000000 be8b0c68 4020b3b0
bfa0: 00000015 c0037940 00000000 be8b0c68 000820a8 0007f3f2 0007f402 00008400
bfc0: 00000000 be8b0c68 4020b3b0 00000015 00000000 00080e10 00000000 00000001
bfe0: 401b372c be8b0a88 00039a1c 401b373c 20000010 000820a8 00000000 00000000
---[ end trace bfe73f5310988bbd ]---
ipt_account 0.1.21 : Piotr Gasidlo <quaker@barbara.eu.org>, http://code.google.com/p/ipt-account/Mit rontottam el?
-kolibri-
Újabb tapasztalat, észrevétel. Időnként tapasztalom csak a magas pinget illetve time out-ot, aztán helyre áll. Interferencia okozhat ilyen gondot? Mert bőven van wifi
-kolibri-
Asus rt-n18u routerem 132-es tomato-val 3 hónap stabil futás után magas pinget és mindenféle kapcsolat eldobásokat tapasztalatok wifin. Kábelen stabil. Próbáltam wifi beállításokkal játszani, de egy idő után ismét magas ping time out. Van valakinek valami ötlete tapasztalata? Próbáltam frissíteni 140-re de ott az USB mountolás problémák miatt inkább visszaállásra kényszerültem így nem tudtam tesztelni.
Még 1 kérdés: a Backup Configuration minden verzióval kompatibilis? Mármint ha csináltam egy backupot 132-n azt tudom restore-olni 140-en? Mert akkor holnap újra próbálkozom a 140-es verzióval.
● Olvasd el az összefoglalót!
- PC Game Pass előfizetés
- iPhone 13 mini 128GB Green -1 ÉV GARANCIA - Kártyafüggetlen, MS4052, 94% Akkumulátor
- Dell XPS 13 9333,13.3",FHD,i5-4210U,8GB RAM, 128GB SSD,WIN10,TOUCH
- ÚJ Bontatlan Sony Bravia K-65XR90 - 4K HDR Google Mini LED TV - 3 év garancia
- Dell Optiplex 3020 MT,i3-4130,8GB RAM,128GB SSD,WIN10
- Veszünk: PS5 Fat/Slim/Digital/Pro konzolt, játékokat, Portalt stb. Kérj ajánlatot!
tjsz
