bajoros
Archer c5 suste firmmel ezidáig teljes megelégedéssel használva digi nettel.
lassan egy hete rendszeresen eldobálja a netet, ami fél-egy percen belül visszajön.
Informatikai végzettség hiányában nem tudom kideryteni okát.
Vajon a router kekeckedik velem vagy a hálózat illetve digi eszköz lehet a hunyó???
Rendszernaplót kielemezné valamely hozzáértő szaki???Köszönöm előre is
Fri Apr 29 16:51:26 2016 kern.info kernel: [ 42.750000] br-lan: port 2(wlan1) entered forwarding state
Fri Apr 29 16:51:26 2016 kern.info kernel: [ 42.760000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Fri Apr 29 16:51:28 2016 daemon.notice netifd: Network device 'wlan1' link is up
Fri Apr 29 16:51:28 2016 daemon.notice netifd: Interface 'wan6' is now up
Fri Apr 29 16:51:28 2016 kern.info kernel: [ 44.750000] br-lan: port 2(wlan1) entered forwarding state
Fri Apr 29 16:51:29 2016 daemon.info dnsmasq[1963]: started, version 2.71 cachesize 150
Fri Apr 29 16:51:29 2016 daemon.info dnsmasq[1963]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC
Fri Apr 29 16:51:29 2016 daemon.info dnsmasq-dhcp[1963]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Fri Apr 29 16:51:29 2016 daemon.info dnsmasq[1963]: using local addresses only for domain lan
Fri Apr 29 16:51:29 2016 daemon.info dnsmasq[1963]: reading /tmp/resolv.conf.auto
Fri Apr 29 16:51:29 2016 daemon.info dnsmasq[1963]: using nameserver 193.110.56.8#53
Fri Apr 29 16:51:29 2016 daemon.info dnsmasq[1963]: using nameserver 193.110.57.4#53
Fri Apr 29 16:51:29 2016 daemon.info dnsmasq[1963]: using nameserver 2a01:368:a::2#53
Fri Apr 29 16:51:29 2016 daemon.info dnsmasq[1963]: using nameserver 2a01:368:a::1#53
Fri Apr 29 16:51:29 2016 daemon.info dnsmasq[1963]: read /etc/hosts - 1 addresses
Fri Apr 29 16:51:29 2016 daemon.info dnsmasq[1963]: read /tmp/hosts/dhcp - 1 addresses
Fri Apr 29 16:51:29 2016 daemon.info dnsmasq-dhcp[1963]: read /etc/ethers - 0 addresses
Fri Apr 29 16:51:29 2016 daemon.notice netifd: Interface 'wan6' has lost the connection
Fri Apr 29 16:51:29 2016 daemon.warn odhcpd[1407]: A default route is present but there is no public prefix on br-lan thus we don't announce a default route!
Fri Apr 29 16:51:30 2016 kern.info kernel: [ 46.720000] br-lan: port 3(wlan0) entered forwarding state
Fri Apr 29 16:51:30 2016 kern.info kernel: [ 46.730000] br-lan: port 3(wlan0) entered forwarding state
Fri Apr 29 16:51:30 2016 kern.info kernel: [ 46.730000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Fri Apr 29 16:51:30 2016 daemon.notice netifd: Interface 'wan6' is now up
Fri Apr 29 16:51:31 2016 daemon.notice netifd: Network device 'wlan0' link is up
Fri Apr 29 16:51:31 2016 daemon.info dnsmasq[1963]: reading /tmp/resolv.conf.auto
Fri Apr 29 16:51:31 2016 daemon.info dnsmasq[1963]: using local addresses only for domain lan
Fri Apr 29 16:51:31 2016 daemon.info dnsmasq[1963]: using nameserver 193.110.56.8#53
Fri Apr 29 16:51:31 2016 daemon.info dnsmasq[1963]: using nameserver 193.110.57.4#53
Fri Apr 29 16:51:31 2016 daemon.info dnsmasq[1963]: using nameserver 2a01:368:a::2#53
Fri Apr 29 16:51:31 2016 daemon.info dnsmasq[1963]: using nameserver 2a01:368:a::1#53
Fri Apr 29 16:51:31 2016 user.emerg syslog: setting up led USB1
Fri Apr 29 16:51:31 2016 user.emerg syslog: setting up led USB2
Fri Apr 29 16:51:31 2016 user.emerg syslog: setting up led WLAN5G
Fri Apr 29 16:51:31 2016 user.emerg syslog: sh: write error: Invalid argument
Fri Apr 29 16:51:31 2016 user.emerg syslog: setting up led WLAN2G
Fri Apr 29 16:51:32 2016 kern.info kernel: [ 48.730000] br-lan: port 3(wlan0) entered forwarding state
Fri Apr 29 16:51:32 2016 user.emerg syslog: could not get IP address for eth0
Fri Apr 29 16:51:33 2016 daemon.err miniupnpd[2102]: could not open lease file: /var/upnp.leases
Fri Apr 29 16:51:33 2016 daemon.notice miniupnpd[2102]: HTTP listening on port 5000
Fri Apr 29 16:51:33 2016 daemon.notice miniupnpd[2102]: HTTP IPv6 address given to control points : [2a01:36c:118:2541:7846:2e8:368f:7120]
Fri Apr 29 16:51:33 2016 daemon.notice miniupnpd[2102]: Listening for NAT-PMP/PCP traffic on port 5351
Fri Apr 29 16:51:34 2016 daemon.info dnsmasq[1963]: exiting on receipt of SIGTERM
Fri Apr 29 16:51:34 2016 daemon.info dnsmasq[2171]: started, version 2.71 cachesize 150
Fri Apr 29 16:51:34 2016 daemon.info dnsmasq[2171]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC
Fri Apr 29 16:51:34 2016 daemon.info dnsmasq-dhcp[2171]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Fri Apr 29 16:51:34 2016 daemon.info dnsmasq[2171]: using local addresses only for domain lan
Fri Apr 29 16:51:34 2016 daemon.info dnsmasq[2171]: reading /tmp/resolv.conf.auto
Fri Apr 29 16:51:34 2016 daemon.info dnsmasq[2171]: using nameserver 193.110.56.8#53
Fri Apr 29 16:51:34 2016 daemon.info dnsmasq[2171]: using nameserver 193.110.57.4#53
Fri Apr 29 16:51:34 2016 daemon.info dnsmasq[2171]: using nameserver 2a01:368:a::2#53
Fri Apr 29 16:51:34 2016 daemon.info dnsmasq[2171]: using nameserver 2a01:368:a::1#53
Fri Apr 29 16:51:34 2016 daemon.info dnsmasq[2171]: read /etc/hosts - 1 addresses
Fri Apr 29 16:51:34 2016 daemon.info dnsmasq[2171]: read /tmp/hosts/dhcp - 1 addresses
Fri Apr 29 16:51:34 2016 daemon.info dnsmasq-dhcp[2171]: read /etc/ethers - 0 addresses
Fri Apr 29 16:51:35 2016 daemon.info dnsmasq-dhcp[2171]: DHCPREQUEST(br-lan) 192.168.1.101 1c:b7:2c:aa:f4:f7
Fri Apr 29 16:51:35 2016 daemon.info dnsmasq-dhcp[2171]: DHCPACK(br-lan) 192.168.1.101 1c:b7:2c:aa:f4:f7 Bajoros-Pc
Fri Apr 29 16:51:35 2016 user.notice AutoMount: Stopped.
Fri Apr 29 16:51:36 2016 user.notice mwan3: ifup interface wan (pppoe-wan)
Fri Apr 29 16:51:37 2016 user.emerg syslog: - init complete -
Fri Apr 29 16:51:38 2016 user.notice firewall: Reloading firewall due to ifup of wan (pppoe-wan)
Fri Apr 29 16:51:39 2016 daemon.err transmission-daemon[2575]: UDP Failed to set receive buffer: requested 4194304, got 327680 (tr-udp.c:78)
Fri Apr 29 16:51:39 2016 daemon.err transmission-daemon[2575]: UDP Failed to set send buffer: requested 1048576, got 327680 (tr-udp.c:89)
Wed May 4 20:11:43 2016 user.notice ddns-scripts-myddns: Running IP check ...
Wed May 4 20:11:43 2016 daemon.notice miniupnpd[2102]: shutting down MiniUPnPd
Wed May 4 20:11:43 2016 daemon.info pppd[1642]: System time change detected.
Wed May 4 20:11:43 2016 daemon.err miniupnpd[3048]: could not open lease file: /var/upnp.leases
Wed May 4 20:11:43 2016 daemon.notice miniupnpd[3048]: HTTP listening on port 5000
Wed May 4 20:11:43 2016 daemon.notice miniupnpd[3048]: HTTP IPv6 address given to control points : [2a01:36c:118:2541:7846:2e8:368f:7120]
Wed May 4 20:11:43 2016 daemon.notice miniupnpd[3048]: Listening for NAT-PMP/PCP traffic on port 5351
Wed May 4 20:11:45 2016 user.notice ddns-scripts-myddns: Update successful
Wed May 4 20:11:45 2016 daemon.notice miniupnpd[3048]: shutting down MiniUPnPd
Wed May 4 20:11:46 2016 daemon.err miniupnpd[3275]: could not open lease file: /var/upnp.leases
Wed May 4 20:11:46 2016 daemon.notice miniupnpd[3275]: HTTP listening on port 5000
Wed May 4 20:11:46 2016 daemon.notice miniupnpd[3275]: HTTP IPv6 address given to control points : [2a01:36c:118:2541:7846:2e8:368f:7120]
Wed May 4 20:11:46 2016 daemon.notice miniupnpd[3275]: Listening for NAT-PMP/PCP traffic on port 5351
Wed May 4 20:11:49 2016 daemon.err miniupnpd[3275]: upnp_event_recv: recv(): Connection reset by peer
Wed May 4 20:11:49 2016 daemon.err miniupnpd[3275]: chain MINIUPNPD not found
Wed May 4 20:11:53 2016 daemon.info dnsmasq-dhcp[2171]: DHCPDISCOVER(br-lan) 14:d6:4d:2e:db:03
Wed May 4 20:11:53 2016 daemon.info dnsmasq-dhcp[2171]: DHCPOFFER(br-lan) 192.168.1.145 14:d6:4d:2e:db:03
Wed May 4 20:11:53 2016 daemon.info dnsmasq-dhcp[2171]: DHCPREQUEST(br-lan) 192.168.1.145 14:d6:4d:2e:db:03
Wed May 4 20:11:53 2016 daemon.info dnsmasq-dhcp[2171]: DHCPACK(br-lan) 192.168.1.145 14:d6:4d:2e:db:03 Szomszed
Wed May 4 20:12:04 2016 daemon.info hostapd: wlan1: STA 7c:dd:90:a2:d7:ce IEEE 802.11: authenticated
Wed May 4 20:12:04 2016 daemon.info hostapd: wlan1: STA 7c:dd:90:a2:d7:ce IEEE 802.11: associated (aid 1)
Wed May 4 20:12:04 2016 daemon.info hostapd: wlan1: STA 7c:dd:90:a2:d7:ce WPA: pairwise key handshake completed (RSN)
Wed May 4 20:12:09 2016 daemon.err miniupnpd[3275]: chain MINIUPNPD not found
Wed May 4 20:12:09 2016 daemon.err miniupnpd[3275]: addnatrule() : chain MINIUPNPD not found
Wed May 4 20:12:17 2016 daemon.info hostapd: wlan1: STA 00:ee:bd:aa:40:cd IEEE 802.11: authenticated
Wed May 4 20:12:18 2016 daemon.info hostapd: wlan1: STA 00:ee:bd:aa:40:cd IEEE 802.11: associated (aid 2)
Wed May 4 20:12:18 2016 daemon.info hostapd: wlan1: STA 00:ee:bd:aa:40:cd WPA: pairwise key handshake completed (RSN)
Wed May 4 20:12:18 2016 daemon.info dnsmasq-dhcp[2171]: DHCPREQUEST(br-lan) 192.168.1.102 00:ee:bd:aa:40:cd
Wed May 4 20:12:18 2016 daemon.info dnsmasq-dhcp[2171]: DHCPACK(br-lan) 192.168.1.102 00:ee:bd:aa:40:cd Bajoros-HTC
Wed May 4 20:12:29 2016 daemon.err miniupnpd[3275]: chain MINIUPNPD not found
Wed May 4 20:12:29 2016 daemon.err miniupnpd[3275]: addnatrule() : chain MINIUPNPD not found
Wed May 4 20:12:49 2016 daemon.err miniupnpd[3275]: chain MINIUPNPD not found
Wed May 4 20:12:49 2016 daemon.err miniupnpd[3275]: chain MINIUPNPD not found -
bajoros
Headless
#648
Jóvanna
Nem földrengés...de nézd el nekem!
a szóképek értelmezése bevitt az erdőbe
A br-lan tanács már meg is érett a köszönetre! Csak a tudatlan mit gondol? Hogy ha mindenütt szórok abból baj nem lehet. És ismét igazságot nyert a " kevesebb néha több "
Működik a felélesztés tanácsodra
DDNS frissül. Ugyan féltem hogy a digis net ipv6 okozza a hibát de visszakapcsolva is megy.
És igen! Mobilnetről próbáltam eddig is és Ajánlásod után is azt vetettem be.Örök hálám Üldözzön! Még ha kenyeret nem is Kapsz érte a bótban
De végszóként valljuk be: ezért van a fórum, hogy egymást támogassuk a megszerzett tudásunkkal.
Hisz senki sem születik mindent tudóként!....Még egyszer- Köszönöm
bajoros
Üdv a jelen levőknek.
1043nd V1.9-et / vargalex/ napokban lecseréltem egy C5 V1-re
Rádobtam Suste aktuális firmjét. Szép is jó is de azért akadt gondom is.A gép felélesztése hálózaton keresztül sehogyan sem akar működni sem WOL sem Earthquake-en
Ezen felül a router távoli hozzáférése sem akar menni annak ellenére hogy a tűzfalon engedélyeztem a httpluci
portot és a noip dns is be van állítva.Hozzáértő ötleteket szívesen fogadnék a gondom megoldására.
Köszönettel: Bajoros
- Eladó LG OLED G4 55'' (OLED55G48LW) 3 ÉV GARANCIA
- ÚJ Samsung 65" Neo QLED 4K QN90F Vision AI Smart TV (2025) QN70F QN80F QN85F 3év Gar
- Szép! Lenovo Thinkpad T14 G3 "Golyóálló" Üzleti Laptop 14" -60% i5-1250P 12Mag 32/512 FHD+
- Gamer PC RTX4080 Ryzen X3D 64GB DDR5 RAM etc...
- ÚJ Samsung OLED 4K 55S95F Vision AI Smart TV (2025) 65S95F 77S95F 83S95F 3év
- 143 - Lenovo LOQ (15IRH8) - Intel Core i5-13500H, RTX 4060 (ELKELT)
- GIGA AKCIÓ!!! AKTIVÁLATLAN iPad Air M2 11" WiFi + CELLULAR 512GB!!! KÉK
- Új Lenovo E14 Thinkpad WUXGA IPS Ryzen7 7730U 16GB 512GB SSD Radeon RX Vega8 Win11 Pro Garancia
- Apple iPhone 14 Pro 512GB,Újszerű,Dobozával,12 hónap garanciával
- Telefon felvásárlás!! Xiaomi Redmi Note 10, Xiaomi Redmi Note 10s, Xiaomi Redmi Note 10 Pro
