kovaax
#24366
ezt adja vissza:
linux-vdso.so.1 => (0x00007fff091ff000)
libv4l1.so.0 => /usr/lib/libv4l1.so.0 (0x00007fd8c5d27000)
libc.so.6 => /lib/libc.so.6 (0x00007fd8c59a6000)
libv4l2.so.0 => /usr/lib/libv4l2.so.0 (0x00007fd8c579a000)
libpthread.so.0 => /lib/libpthread.so.0 (0x00007fd8c557d000)
/lib64/ld-linux-x86-64.so.2 (0x00007fd8c614b000)
libv4lconvert.so.0 => /usr/lib/libv4lconvert.so.0 (0x00007fd8c530e000)
librt.so.1 => /lib/librt.so.1 (0x00007fd8c5105000)
libm.so.6 => /lib/libm.so.6 (0x00007fd8c4e82000)mondjuk ez most 64 bites, de van egy rakás probléma vele, mindjárt visszateszem a 32-est, amint lejön az iso...
#16820480
FixY67
#24363
hát, az egy ilyet ad:
linux-gate.so.1 => (0x00e7d000)
libasound.so.2 => /usr/lib/libasound.so.2 (0x00b7b000)
libXv.so.1 => /usr/lib/libXv.so.1 (0x002bd000)
libXss.so.1 => /usr/lib/libXss.so.1 (0x00fc3000)
librt.so.1 => /lib/tls/i686/cmov/librt.so.1 (0x0031b000)
libQtDBus.so.4 => /usr/lib/libQtDBus.so.4 (0x00370000)
libQtGui.so.4 => /usr/lib/libQtGui.so.4 (0x00fc7000)
libQtNetwork.so.4 => /usr/lib/libQtNetwork.so.4 (0x006ec000)
libQtCore.so.4 => /usr/lib/libQtCore.so.4 (0x003e9000)
libpthread.so.0 => /lib/tls/i686/cmov/libpthread.so.0 (0x00332000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00a3e000)
libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0x008c7000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00b55000)
libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0x00c43000)
libdl.so.2 => /lib/tls/i686/cmov/libdl.so.2 (0x00df5000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x008ed000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x00110000)
/lib/ld-linux.so.2 (0x001fb000)
libQtXml.so.4 => /usr/lib/libQtXml.so.4 (0x00120000)
libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0x0084e000)
libaudio.so.2 => /usr/lib/libaudio.so.2 (0x00165000)
libglib-2.0.so.0 => /lib/libglib-2.0.so.0 (0x00e7e000)
libpng12.so.0 => /lib/libpng12.so.0 (0x00e42000)
libz.so.1 => /lib/libz.so.1 (0x0017c000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x00218000)
libgobject-2.0.so.0 => /usr/lib/libgobject-2.0.so.0 (0x00191000)
libSM.so.6 => /usr/lib/libSM.so.6 (0x001d1000)
libICE.so.6 => /usr/lib/libICE.so.6 (0x001da000)
libXrender.so.1 => /usr/lib/libXrender.so.1 (0x0028e000)
libgthread-2.0.so.0 => /usr/lib/libgthread-2.0.so.0 (0x001f3000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x00298000)
libexpat.so.1 => /lib/libexpat.so.1 (0x002c3000)
libXt.so.6 => /usr/lib/libXt.so.6 (0x00667000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x002b2000)
libpcre.so.3 => /lib/libpcre.so.3 (0x002ea000)
libuuid.so.1 => /lib/libuuid.so.1 (0x002b6000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00324000) -
#16820480
kovaax
#24358
nem, ez simán lefut:
sheratan@frozendawn:~$ strings /usr/lib/libv4l/v4l1compat.so
__gmon_start__
_init
_fini
__cxa_finalize
_Jv_RegisterClasses
v4l1_munmap
mmap64
v4l1_mmap
v4l1_read
v4l1_ioctl
v4l1_dup
v4l1_close
open64
v4l1_open
libv4l1.so.0
libc.so.6
_edata
__bss_start
_end
v4l1compat.so.0
GLIBC_2.1.3 -
#16820480
Kendek
#24344
hát ezt kár volt megváltoztatni!
mert egyrészt kell a halálnak az az mikroblogos rész, ahogy írtad is, másrészt meg így kétszer szerepel a billentyűzetbeállítás ikonja, mivel mind a notification area-ban, mint ebben az indicator-ban megvan. meg hova kéne mégis kiférjen ez a szar...? így is tele van már a panelom
#16820480
Kendek
#24341
pontosan mi az az értesítésgyűjtő? nem a notification area? mert nekem már elég régóta ott van a hangerőszabályzó, nem pedig külön ikonként adtam hozzá. mondjuk ehhez volt valami progi régebben, lehet, hogy az okoz valami konfliktust, ha már alapból oda kéne tegye?
szerintem lehet, hogy ha lesz holnap időm, akkor fogom, és csinálok végre egy teljesen tiszta telepítést. elég bosszantó, hogy mindig van valami marhaság, ami nem megy
igaz ez még csak béta, de akkor is (az előző két bétával nem volt ennyi bajom)... -
#16820480
Kendek
#24336
cserélnék én akár, ha tudnám, hogy melyik működik normálisan... de sajna ezt szinte lehetetlen megmondani, mert manapság a márkás kamerák belseje is lényegében ugyanaz a 2 filléres kínai chip, ami akár a jelenlegiben is van. 20 ezerért meg nem veszek webkamerát, annyit nem ér...
nekem is régebben mutatta az ikonját, ha nem volt kapcsolat, most van csak ilyen problémám. nem tudom miért. ráadásul például a hangerőszabályzó ikonja is eltűnt (hozzá se tudom adni a panelhoz), amióta lucid-ra frissítettem... lehet, hogy fel kéne tenni normálisan, és nem a 4-5 kiadás óta görgetett beállításokat használni.
tomtyi: egészen sokáig wicd-t használtam, de aztán valamiért mégis visszacseréltem az alap network managerre. most nem jut eszembe, hogy miért, de valamit nem tudott, ami jól jött volna...
kovaax: de, valóban nagyon jó lenne, de nem értek annyira hozzá, hogy erre legyen ötletem. azt hittem, hogy jogosultság probléma, de chmod 777 után is ugyanaz a hibaüzenet.
#16820480
Kendek
#24334
a beállítások a legkevesebbek, de ha root user alatt fut, akkor mint írtam nem képes használni az ibus-t, amivel ugye ázsiai nyelveken lehet többek közt írni.
amúgy más téma, csak ma botlottam bele: amikor nem csatlakozik éppen sehova, akkor nem jeleníti meg a network manager ikonját az értesítési területen, ez kicsit probléma, mert így nem tudok wifi-t keresni, ugyanis nincs mire kattintani, hogy jelenítse meg az elérhető hálózatokat. illetve még egy gond a network managerrel, hogy amióta egyszer beállítottam a pppoeconf segítségével egy dsl kapcsolatot, azóta nem képes simán dhcp-vel csatlakozni routerre a gép, bedugom a kábelt és nem történik semmi... illetve előtte volt egy "auto" kapcsolat a vezetékesnél, de azóta nincs, és hiába adnék hozzá, ha azt mondom, hogy az összes user tudja használni, akkor nem adja hozzá, ha meg csak magamnak csinálom, akkor meg nem használja (vagyis nem tud csatlakozni)
#16820480
Kendek
#24332
ez viszont így azért izgi, mert eddig úgy tűnik, hogy root jogokkal, de a saját usernevem alatt futott a skype, viszont most teljesen root-ként fut, és így az összes beállítás megszűnt létezni... ez persze azért baj, mert így nem működik az ibus sem alatta, meg még egy-két aprósággal gond van. hajajj
vajon miért nem működik a gksu akkor, ha simán a parancsikonnál írom elé?igazából csak zavar, hogy plusz egy terminál van megnyitva... lehet, hogy az lenne a legjobb, ha belépnék a tty2-n, és onnan indítanám el a paranccsal...
#16820480
Kendek
#24328
nekem sajátként azt írja, hogy nincs ilyen fájl. milyen jogosultság kéne hozzá?
most nézegettem, és ha ezt a verziót próübálom, amikor a skype nem root-ként fut, akkor nem megy a kamera, csak ha az egészet emelt jogosultságokkal indítom.
viszont a másik meg, hogy ez a parancs csak akkor megy, ha "application in terminal" jelleggel indítom, mert amúgy "nem tud" hol jelszót kérni, és nem csinál semmit. erre nincs valami megoldás? -
#16820480
van egy olyan problémám, hogy nem igazán szereti az új skype a gspca-s webkamerámat. van rá egy workaround a readme-ben, hogy futtassam a LD_PRELOAD=/usr/lib/libv4l/v4l1compat.so skype előtaggal, viszont ezt csak rootként tudom futtatni (skype-pal együtt persze). azt meg lehet oldani, hogy ez töltődjön be mondjuk minden startup-kor ez a preload string, vagy nem ilyen egyszerű?
#16820480
wine alatt hogy tudok megadni alapértelmezett betűtípust? van egy ázsiai karaktereket használó progim, amit szeretnék futtatni, de csak négyzeteket látok (tehát nem locale probléma).
illetve pontosan melyik betűtípust kéne megadni neki? ahogy elnézem az ilyen arial és társai csak pár száz kilobájtosok, szóval biztos nem unicode fontok. -
#16820480
TrollBalint
#21492
ha egy lemezt nem a /media alá csatolsz fel, akkor nem jeleníti meg az asztalon az ikonját.
#16820480
-=Sziszi=-
#21231
Ctrl+Alt+F1 után persze, hogy kér felhasználónevet, mivel az egy másik tty-ra való bejelentkezés, nem szintváltás. ahogy az összes tty egészen F1-től F6-ig.
#16820480
-=Sziszi=-
#21229
szintváltáskor csak a jelszót kell megadni. nem lehet, hogy eltérő a billentyűzet nyelve amikor már beléptél az X-be? caps lock, num lock probléma?
#16820480
body007
#21223
ha kimásolom a címet és betolom mplayerbe, akkor lejátsza szépen (totem kifagy tőle).
amúgy én úgy tudom, hogy a betöltődések után számolnak valamit a reklámok esetében, nem (csak) a kattintásra. mondjuk én majd akkor kezdem el nem blokkolni a reklámokat, amikor majd leszoknak az animált flash és gif bannerekről, mert ezek egyszerűen idegesítenek, elvonják a figyelmet.
#16820480
body007
#21208
elvileg ha megvannak a kodekek, akkor a totem is le kéne játszon mindent. esetleg próbáld meg feltelepíteni a több gstreamer plugint is.
reklám blokkóból szerintem az adblock+ a legjobb. kicsit fapados a chromiumos reklámblokkolókhoz a kezelése, de korrektül blokkol mindent, amit beállítok neki. -
#16820480
Nagytalp
#21173
köszi! megpróbálom majd, ha nem megy aptitude-dal.
ntomka: nem volt melléírva, hogy béta. amikor hozzáadtam a tárolót, akkor a restricted drivers részen azt íta, hogy ez az ajánlott. de még attól, hogy hiba van a telepítésnél, visszaállíhatná a régi verziót igazán...
rtom: nekem is elvileg valami hasonló kártyám van, quadro nvs135 néven fut, de asszem ugyanarra a magra épül, mint a 8400gs.
majd ha hazaérek megnézem, csak grafikus felület nélkül nem töltődik be anetwork manager, amivel felmegy az otthoni wifire a gép, és nem volt kéznél kábel, amivel rádugjam a routerre...
#16820480
#21102
erre esetleg valakinek ötlete? (bár most ideiglenesen nem annyira érdekes, mert visszatértem a FF-ra egyelőre)
illetve van egy másik problémám, amit egy IM alkalmazás okoz: amióta frissíŧettem 9.10-re, azóta folyton azt csinálja, hogy kiagy abban a pillanatban, amint egy párbeszédablakban a szöveg eléri az ablak alját (és scrolloznia kellene). upgradelt rendszeren és friss rendszeren is csinálja, linuxMint-en is, illetve a progi mindkét verziója, ami elérhető. terminálból indítva ezt az üzenetet hagyja, valamire lehet következtetni belőle?
sheratan@frozendawn:~$ qq
[Warning]Some other program is already using the key 'a' !
(qq:13341): GLib-GObject-WARNING **: invalid uninstantiatable type `-g-type-private--dependants-array' in cast to `GObject'
(qq:13341): GLib-GObject-CRITICAL **: g_object_unref: assertion `G_IS_OBJECT (object)' failed
(qq:13341): Gtk-WARNING **: /build/buildd/gtk+2.0-2.18.3/gtk/gtkwidget.c:4321: no accelerator (65293,4) installed in accel group (0xb36a75a0) for GtkButtonEx (0xb3649dd8)
(qq:13341): Gtk-WARNING **: /build/buildd/gtk+2.0-2.18.3/gtk/gtktextview.c:4567: somehow some text lines were modified or scrolling occurred since the last validation of lines on the screen - may be a text widget bug.
Gtk:ERROR:/build/buildd/gtk+2.0-2.18.3/gtk/gtktextview.c:4568:gtk_text_view_paint: code should not be reached
Aborted
sheratan@frozendawn:~$ -
#16820480
van valakinek ötlete, hogy ha több workspace-t használok, akkor a chromium miért mindig a következőre nyílik meg, és sosem arra, amelyik éppen aktív?
#16820480
tulajdonképpen a rendszer elkülönítése az adatoktól nem olyan nehéz, általában elég az is, ha a /home másik partíción van. újratelepítéskor így sem sérül semmi, csak a partíciót kézzel kell megadni, és azt a részt, ahol a hom könyvtárad van /home-ként csatoltatni a telepítőben (természetesen formázás nélkül
). én így csinálom már egy ideje, és nincs vele semmi baj. -
#16820480
nem tudom sajnos, nem használtam ilyesmit még. de elvileg képes kell legyen wildcard-okat kezelni, szóval akár minden oldalhoz beállíthatod.
egyébként a méretnövelés nem hiszem, hogy olyan bonyolult kellene legyen, talán csak azért tűnik komplexnek, mert rengeteg lehetőség van benne, gyakorlatilag bármit megváltoztathatsz ezzel a módszerrel. -
#16820480
no, mi történt? úgy emlékszem még nem olyan régen eléggé ext4 ellenző voltál.
amúgy szerintem nem olyan vészesen bonyolultabb ez a grub2 (már amit az átlagembert érinti belőle), viszont az jobban zavart, hogy min8 alatt egy kernelfrissítés után (ami érdekes módon a grub1 menu.lst-jét akarta írni a grub2 helyett) nem találta meg az új kernelt, még update-grub paranccsal sem (mondjuk hozzá kell tenni, hogy nem egy rossz biztonsági húzás, mert így bootolásnál csak egy hibaüzenet fogad, és a bootmenüben kézzel kellett szerkeszteni a kernel nevét, hogy felálljon a rendszer
erre jó sok ember nem jönne rá egyből) -
#16820480
elvileg azt írják, hogy ez a verzió támogatja a scripteket, amit a régi grub nem tudott. mondjuk én nem használok ilyesmit, de azt hittem, hogy nektek (értve itt a power usereket) ez ilyen nagy dolog lesz.
mondjuk nem egészen értem, amilyen magabiztosan, és gyorsan bevezették... -
#16820480
hmm, érdekes, most nicns igazán más tippem, de ha nem produkálja, akkor végülis egyelőre nem gond. amúgy közvetlen friss boot után szokott ez a probléma lenni? vagy esetleg sleep-ből visszatérve, és hasonlók?
Takhanto: pffff, te azt az őskövületet használod, amikor már van 10.04 prealfa
(vicc volt, ne vedd komolyan
#16820480
ez szerintem nem feltétlenül van kapcsolatban a vga driverrel. nem lehet, hogy a a cairo dock a hibás? nem ismerem annyira a progit, de a screenleteknél van olyan, hogy stay on top vagy stay on bottom, illetve stick to desktop, és ennek megfelelően vannak az ablakok alatt vagy felett, vagy mindig legalul. nincs valami olyan lehetőség a dock-ban, hogy odaszögezd a desktopra?
a régebbi kérdésed alapján még arra is gondoltam, hogy compizban van egy olyan opciót, hogy "mouse position polling" (ezt a compizconfig settings manager progiban tudod elérni például), ami azt csinálja, hogy a képernyőről kérdezi le az egér pozícióját. ez kell asszem például ahhoz, hogy ha egy videóablak fölé viszed a mutatót, akkro eltüntesse. ennek a kapcsolgatása nem segít a problémán? -
#16820480
sasa134
#20807
igazából meg lehet oldani külön program telepítése nélkül is. én egy panelra raktam ki az ikonokat, amiket használok, és átlátszóvá tettem. persze ez az ablakok helyéből vesz el, de ha ez zavar, akkor beállíthatod autohide-ra is akár.
tudom, ez nem teljesen ugyanaz, csak én így szoktam meg. -
#16820480
VaniliásRönk
#20351
skype alatt nekem csak static verzióval volt webkamera, amúgy csak zöld zaj jött be a képbe. azt esetleg próbáltad?
#16820480
VaniliásRönk
#20325
mondjuk egy ideje én sem használok kétpaneles filekezelőt, mert sajna a gtk-sok nem tudják amit szeretnék. illetve a GC egész jó, de vannak bosszantó dolgai, és szerintem a nautilus gyorsabban is másol, bár ez nem tényállás, csak érzésre.
#16820480
Kendek
#20322
igen, bocsánat, pontatlanul fogalmaztam: nem találtam még olyan gtk+ fájlkezelőt, ami ezt tudta volna. próbálgattam régebben a kruzadert, de gnome alatt nekem tele volt grafikai hibával (eltűntek sorok vagy hasábok, és csak görgetéssel jelenítette meg jól, vagy átléptem egy másik könyvtárba, és még mindig a régit mutatta, stb.)
ha csinálnának egy "gruzader"-t is, akkor az szuper lenne
#16820480
VaniliásRönk
#20317
nem arról van szó, hogy attól már nem linux, de sok embernek kényelmetlen lehet. én legfeljebb akkor támogatnám, ha kikapcsolható lenne, ahogy a dupla-szimpla kattintás is a fájlok megnyitására. én windows alatt többek közt ezért sem használtam intézőt.
amúgy ha már TC, akkor Ctrl+T és új fület nyit arra a panelra, ami éppen aktív, így lényegében sokkal több mappát hasonlíthatsz és kezelhetsz vele egy belátható képernyőnyi területen, mint intézővel. másolásnál pedig F5 aztán F2 és egy külön kisablakba sorbaállítja a másolási feladatokat (USB-s eszközre jó dolog, ha nem több szálon másolsz, mert sokat lassít. a linuxos fájlkezelőkből ez a funkció hiányzik legjobban), így simán visszatérhetsz a fájlkezelő ablakhoz, és azt csinálsz benne, amit akarsz, miközben a háttérben megy a másolás. plusz a következőkben ezt a kombót ismételve a sor végére teszi az újabb másolásokat is. plusz megvan az az előnye, hogy csak billentyűzettel is gyorsan kezelhető, ami eléggé megdobja a hatékonyságot (ahogy például a gnome-commanderben is az az ötlet, hogy a jobbra-balra nyilakkal tudsz ki-be lépkedni könyvtárakba/-ból)
#16820480
VaniliásRönk
#20310
mire gondolsz pontosan? nem egészen értem ennek a featurenk a lényegét...
Kalandor: az egyik ismerősömnek is előjött ez a probléma, ő képernyővédőt akart beállíŧani, és a preview-ban ment, de nagyban nem. felvillan, aztán megy tovább a gép, mintha nem történt volna semmi. de amúgy pár napja volt valami frissítés a screensaverhez, esetleg azt megpróbálhatod visszavonni, hátha a régivel megy.
#16820480
#20299
köszi! hát ez szomorú, mert így akkor kézzel kell utánanézni, hogy van-e frissíés. bár amilyen gyakran frissíik...
meg azt hiszem ez volt az utolsó dolog, amiért még szenvedtem a medibuntuval, de akkor legközelebb már az sem fog kelleni...body007: így sem fejlesztik túl gyors ütemben, ha még kétféle verziót is kéne csináljanak, akkor aztán tényleg 10 évente lenne egy kiadás...
#16820480
róland
#20233
én is néztem, hogy jól eltűnt a skype... pont ma telepítettem rendszert, és nem akarta az igazságot a medibuntu, azt hittem rosszul adtam hozzá, de akkor nem.
amúgy a weblapjukon fent van a deb csomag, le lehet tölteni.moma: annál már van újabb. most valami 2.1.0.4xx van asszem
#16820480
upszilon
#20204
a kérdéses fetőzést azt sem tudni mikor szedted össze. akkor meg?
de amúgy is több rendszert használsz a gépen, virtuállis gépet is, tehát azt sem tudni, hogy melyik szedte be a fertőzést, de a feltételezés alapján ugy root jog kell hozzá, ahogy minden másfajta fertőzéshez is, így gyanítható, hogy esetleg windows alatt szedted össze, ahol alapértelmezett user is rottként van jelen a rendszerben.nem becsméreltem senkit, bár ettől függetlenül nem fogok hasraesni attól a PQDI progitól. képzeld, nem vagyok teljese hülye, be tudom szerezni, csak egy kis keresés kell hozzá.
egyébként elolvastam a linkelt cikket, és levontam belőle a következtetést, hogy óvatosan kell babrálni a géppel, mert ilyen is létezik. de ha nem haragszol, akkor nem fogok fejvesztve rohangálni és sikítozni egy ilyen hír hallatán. -
#16820480
upszilon
#20199
ott írták a cikkben, hogy root jogokra van szüksége a fertőzéshez ennek az überveszélyes cuccnak is. szóval ha nem amatőr módjára rootként használod a rendszert, akkor eléggé esélytelen, hogy beszivárogjon. illetve telepíteni is olyan csatornákból érdemes, amit felülvizsgának, és biztonságos.
(amúgy meg ha már paranoiánál tartunk: te miért bízol meg jobban egy-néhány olyan cég szavában, akinek érdekük pénzért eladni a saját termékeiket, és midnen alkalmat megragadni az önreklámra?)
#16820480
a linux mint képes azokat a tárolókat használni, amiket pl. ubi alá betehetek? például egy-két lanchpad-os ppa tárolót karmichoz, és így tovább.
#16820480
VaniliásRönk
#19983
nem tudom pontosan hogy működik, de elvileg lehet Aqualungban manipulálni a replay gain-t: [link]
hátha segít. ha jól veszem ki, akkor ki lehet kapcsolni azzal leglaábbis, ha manuálisan nullára állítod a fájlban. -
#16820480
VaniliásRönk
#19978
szerintem az a lassúság az adatbázis felépítése miatt lehetett, ez általában percekig eltart, főleg sok zenével. de ugye csak egyszer kell megtegye.
én is rengeteget próbálgattam zenelejátszókat, miután váltottam linuxra. eleinta az audacious jött be, de aztán rájöttem, hogy elég gyenge a hangminősége, így kerestem tovább, és végül a songbirdnél maradtam, de a többiek közt is van sok jó, csak mindnek volt számomra bosszantó hibája.
amúgy az ilyen fejlettebb lejátszókból a felét a funkcióknak ki lehet simán kapcsolgatni a pluginek leszedésével. bár nem tudom ez eredményez-e teljesítménybeli javulást, de illene neki. -
#16820480
VaniliásRönk
#19974
mit értessz azalatt, hogy lassú? egy 5 perces zenét 10 perc alatt játszik le?
amúgy ha van kedved próbálkozni, akkor a listen-hez egy elég hasonló progi a Quodlibet, vagy egy kicsit nagyobb program a Banshee. ezeken túl én próbáltam még az Aqualung-ot, erre azt írják a fejlesztők, hogy a hangminőségre gyúrnak (sajna amikor próbáltam nem volt túl stabil), illetve ott van még a Sonata is, amit elég fapados (külsőleg), de nem tűnik olyan rossznak. -
#16820480
upszilon
#19911
ha annyira nem tetszik, akkor tegyél fel mások bootloadert. például: [link]
ebben le lehet jelszavazni az egyes rendszereket, így hiába hozná be a bootmenüt akárki, nem tudna mást bootolni.
bár lehet, hogy grubban is meg lehet cisnálni, főleg az új verzióban, arra azt íták, hogy scriptbarát. -
#16820480
Kendek
#19893
úgy emlékszem újraindíásnál is van,. bár azt rikábban szoktam. az a baj, hogy csendes környezetben az is zavaró, ha a fülhallgatón keresztül sípol, de ráadásul ha kihúzom, de úgy kapcsolom ki, hogy az utóbbi pár percben volt bedugva valami, akkor meg a beépített hangszóróból sípol egy k. nagyot.
VaniliásRönk: ha fel van nagyon tekerve, akkor nekem is búg, de amióta az új pulseaudio van, azóta elég hangos olyan 30% körül is a mixer, akkor is jó hangos már.
#16820480
másnak is jelentkezik az a probléma, hogy a gép kikapcsolásánál, ha valami be van dugva a lineout kiementbe, akkor sípol egyet (de rohadt hangosan) a gép. volt ilyen bug még a béta korszakában a koalának, de aztán azt lehetett orvosolni azzal, hogy vagy feketelistázza az ember a megfelelő modulokat (ezek feketelistán is vannak), vagy kiadom a xset b off; xset b 0 0 0 parancsokat.
viszont az emlíŧett problémánál ezek egyike sem működik, a sípolást nem is a speaker okozza, hanem a hangkimeneten küldi a gép a hangfalra/fülhallgatóra. hogy lehetne végleg kiírtani? -
#16820480
Major Major
#19862
hát igen, nem volt egy sebességbajnok sosem, amióta használtam, de funkciókban sokat tud, és nagyjából ez felel meg a követelményeimnek. viszont az újabb (ppa-ból feltehető) verzió egész gyors már.
VaniliásRönk: na igen, más ízlések.
esetleg próbáld meg a listen-t, az elég fapados, szerintem ugyanazt a lib-et használja lejátszásra, mint az mplayer. -
#16820480
VaniliásRönk
#19860
a hangzás javítására van equalizer
amúgy a songbird-öt is kipróbálhatod, remek kis lejátszó, rengeteg pluginnel. mondjuk érdemes a ppa repóból feltenni, mert az ott levő verzió sokkal gyorsabb, mint amit a honlapjukról .deb-ként letölthetsz. -
#16820480
Huawei E630-as hsdpa modemet használ valaki?
most kaptam egyet külcsön (mondjuk sim nélkül), és azt szeretném csak megtudni, hogy kezeli-e a gép, de nem nagyon van ilyenben tapasztalatom. zölden villog néha a modemen levő led, de úgy a rendszerben nem láttam nagyon nyomát, hogy történne valami. -
#16820480
upszilon
#19781
az Evolution tud importálni Outlook pst fájlból például. azt nem tudom, hogy van-e különbség az OE és a sima Outlook közt ilyen téren (mármint hogy a fájl szerkezete más-e).
aztán ha nem jók a cuccok Evolution-ban, akkor tudsz vele például gmail-t szinkronizálni (névjegyzéket is). -
#16820480
Sweet Lou 6
#19560
érdekes... mondjuk én nem próbáltam nagyon sem a kde sem az xfce asztalt, csak az újabb pa-nál vettem észre a hallható különbséget. most kb 30%-on van olyan hangos a hangkártya, mint előző kiadás alatt 80%-on.
#16820480
kw3v865
#19550
melyik ubuntu van telepíŧve? illetve inkább talán az alsa meg a pulseaudio verziója kéne, csak abban nem tudok pontosat mondani sajna. nekem ez volt 9.04 alatt, aztán 9.10 alatt változott, mostmár úgy működik, ahogy te elvárnád, illetve eleve hangosabb is lett a maximális hangerő.
amúgy ez nem bug, hanem feature inkább, egyszerűen annyi, hoyg nem lineáris a hangerő csúszka. de elvileg az újabb rendszerben már úgy kéne működjön, ahogy elvárod. -
#16820480
upszilon
#19417
az, hogy a vírusok száma nem egyenlő nullával, mégnem azt jelenti, hogy érdemes is egy komplett internet biztonsági csomagot megvenni és futtani a gépen. a fertőzés veszélye elég kicsi, ivel a repókat ellenőrzik kártékony kód után, illetve a gépeden sem korlátlan jogosultságokkal vagy bejelentkezve. ezt mondjuk azzal kombinálva, hogy egy fizikai tűzfal (router pl.) mögé dugod a gépet, elég kellene legyen ahhoz, hogy ne érje meg a gépeddel vesződni, mert millió számra vannak odakint olyan gépek, amiket ehhez képest két kattintás feltörni.
amúgy itt egy összfoglaló linuxos malware-ről, biztonsági szoftverek listájával: [link] -
#16820480
az mitől lehet, hogy néha iszonyatosan lassan megy a másolás a telefonomra usb-n keresztül (700-800kB/s), néha meg repeszt (~4MB/s), pedig azonos a kábel, az usb aljzat meg minden.
pendrive-ra másoláskor nem szokott ilyen gond lenni, csak a telefonnal. -
#16820480
upszilon
#18820
lehet, hogy ezt is annál a pixel-smoothing beállításnál kéne keresgélni, a rendszer szintű betűtípus beállításakor. igazából nem néztem még utána ilyesminek, mert mindig elég volt a (szinte) alapbeállítás.
body007: már éppen akartam kifogálsoni, hogy a te screenshotodon is pixelesek a képek
ráadásul van vagy kétszer akkor a felbontás, mint nálam... -
#16820480
body007
#18816
hmm, most hogy mondod, valóban. mondjuk én sosem teljes fullscreenben használom, mert úgy nem látom, ha történik valami a háttérben, hanem csak a maximalizált ablak méretben (ezért is fontos, hogy minél keskenyebb legyen a menüsáv).
de ha fullscreenben használod, akkor mindegy milyen a GUI-ja, nem?
használd parancssorból, az az igazi
upszilon: [link]
#16820480
upszilon
#18622
ha nem adsz meg swap partíciót, akkor nem fog sawp területet használni a rendszer. az indexelés alapból ki van kapcsolva a 9.04 véglegestől kezdve, szóval ezek nem használják agyon a kártyát. esetleg konfigurációs fájloknál lehet gond, ha nem írhatóak, de kipróbálni ki lehet éppen. memóriakártyából van olyan, amin van írásvédés kapcsoló.
janos666: simán kimásolva az isoból a fájlokat nem fog menni, mert kell bootloader is, meg mbr is. viszont van pár olyan progi, ami kiteszi neked a pendrive formázása nélkül is az iso tartalmát. például ez, és itt van hozzá pár command line opció.
#16820480
grabber
#18615
neked kell, mert magától csak akkor tudja, ha vagy a legnagyobb összefüggő szabad helyet adod meg a telepítéskor, vagy a teljes vinyót az ubuntu partícionálja. én mondjuk jobban bízom a manuális beállíásban, úgy látni pontosan mit csinál.
az a lényeg, hogy csinálsz egy partíciót, amin ext4 fájlrendszer van, ennek a csatolási pontja legyen "/", és egy akkora swap (elfelejtettem pontosan hogy hívják magyarul) területet, amekkora a memóriád a gépben. aztán ha akarod, akkor lehet a "/home" külön partíción, de nem szükséges.floatr: ez nem kéne olyan nagy ördöngősség legyen, nem? amikro legutóbb rádugtam egy külső monitort, akkor ki lehetett választani, hoyg az egyik a másik toldása legyen, vagy külön x szerver.
#16820480
Speeedfire
#18583
az operával az a baj, hogy Qt-s környezetben írták, így gnome alatt nem az igazi.
#16820480
V.Stryker
#18577
mert a win7 az betol egy rakás dolgot a memóriába, amiről úgy gondolja, hogy használni fogod (vagy a nap azon szakaszában gyakran indítod, stb). persze ez nem azt jelenti, hogy ezeket a területeket nem szabadítja fel, ha másnak van rá szüksége, csak előtölt dolgokat, hoyg gyorsabban induljanak. persze ettől függetlenül az is remek, hogy egy XP, ilyen szolgáltatás nélkül legalább dupla annyi memóriát foglal, mint egy ubi
amúgy a chromium nagyon jó, csak a reklámszűrés menne úgy, mint ff alatt, és más nem is kéne már talán.
#16820480
CPT.Pirk
#18292
lehet, hogy amikor új catalystet akart leszedni, az nem ment fel jól. esetleg próbálj meg egyet telepíteni parancsossorból, hátha segít. fx5200-on szerintem nem lesz ilyen baj, nekem nvidia kártyával tökéletesen ment már az alpha verzióktól (najó, egyszer egy napi frissítés után nem, de az valami bug volt)
#16820480
ha a telepíŧéskor a partícionálóban megadod, hogy azt a helyet, amit most /home-ként csatol, hogy /home legyen az új rendszerben, akkor simán használnia kell a felhasználók mappáit. sőt, minden beállítás itt kell legyen elvileg, én már egy ideje így használom, és az újratelepítésnél szinte teljesen azt a desktopot kapom vissza, mint előtte (néhány, még nem telepített program persze nem indul el, de ha felteszed, akkor már minden megy megint)
Vladi: ubuntuban system -> administration -> software sources -> download from (és itt szervert választ az ember)
#16820480
CPT.Pirk
#18279
szerintem vga lesz a gond. az új login screen (meg a splash is asszem) már az X szervert használja (usplash helyett xsplash). volt ilyen a szüleim gépén is, nekik intel vga-juk van, de az új kernellel sehogy nem sikerült összehozni (illetve meguntam egy fél óra után).
v.attis: nyilván sokan akarnak egyszerre frissíteni, és nincs elég kapacitásuk. esetleg állíŧsd át ideiglenesen a szervert valami olyanra, ahol már alszanak az emberek (Japán, Hong Kong, Szingapúr, Korea, Ausztrália...)
a vinyót megnézheted a hdsentinellel. -
#16820480
csibor
#18254
9.10 alatt a 3.5-ös FF az alapértelmezett, az meg nem annyira királyság sajnos. fejlesztői repóból fel lehet tenni a 3.7-et, de az még csak pre-alpha állapotban van. előnye, hogy sokkal gyorsabb, és tapasztalat szerint nem kevésbé stabil, mint a 3.5, hátránya viszont, hogy nem mennek vele a kiegészítők meg témák még sajna (illetve nagyon kevés). jelenleg mindennapi használatra a chromium szerintem jobb lenne, ha végre működne egy adblock+ szintű plugin rendesen.
Vladi: bakker, még mindig nem mennek a kiegészítők? az jutott még eszembe, hogy esetleg nem developer build van a repódban. esetleg forrásból nem tudsz forgatni magadnak egyet?
amúgy nekem az adsweep (amióta új arc fejleszti) nem csinál semmit, az adblock+ meg ugyan szűr, de úgy tűnik, mintha néha nem jegyezné meg rendesen a filtereimet, amiket kézzel hozzáadok. illetve nem képes importálni ff-os adblock+ listát... -
#16820480
#18241
amíg nem próbálod ki, hogy mennyire instabil, addig ne írd le azért. teljesen jól megy, repóból telepíthetó (chromium-browser, bár asszem külön launchpad-es ppa repó kell neki), és villámgyors! illetve frappáns kiegészítéssel letilthatóak a flash tartalmak
egyedül azért álltam vissza most ideiglenesen ff-ra, mert a reklámszűrő chrome alá még nem olyan üzembiztos.
- The Elder Scrolls Online Imperial Collector s Edition
- GYÖNYÖRŰ iPhone 14 Pro Max 256GB Space Black -1 ÉV GARANCIA -Kártyafüggetlen, MS4031
- új NAGYakku!!! 6-10óra üzemidő, 5G! Dell Latitude 5330 i3-1215U - 16GB 512GB 13.3" FHD 1 év gar
- Apple iPad mini 6 (64GB) Wi-Fi + Cellular (5G) - Asztroszürke
- Corsair VENGEANCE Pro 32GB (4x8GB) DDR4 2800MHz
- Dell Latitude 5580,15.6",FHD,i5-6300U,8GB DDR4,256GB SSD,WIN11
