Keresés
  • goodluckbenc
    tudna valaki segiteni, egy programot kell irnom ami 1234-et mutat ezt csinaltam eddig de nem akar mukodni.
    * A Program for the 7-Segmen Display Module – Task 4 *
    :O *************************************************************************/
    #include <reg51.h>
    #include <string.h>
    /* Declaration of the Data and Clock Bits for the M5450 */
    sbit Data = P1^4 ;
    sbit Clock = P1^6 ;
    //sbit Enable = ? ; /* Only on some Modules but not all */
    /* A very short Delay of about 10 microseconds */
    /* This doesn’t have to be accurate as explained in the lecture classes */
    void M5450_Delay(void)
    int i;
    for (i=0;i<10000; i++)
    void M5450_Pulse(void)
    /* This function sends a single clock pulse to the M5450 Driver */
    Clock=0;
    Clock=1;
    M5450_Delay(); /* A short Delay */
    Clock=0;
    void M5450_Send (void)
    int D0,D1,D2,D3;
    /* This function sends the 8-bit (byte) D to the M5450 in serial form */
    /* with the least significant bit first */
    D0=0x66;
    D1=0x4F;
    D2=0x5B;
    D3=0x06;
    /* The following function sends a start pulse to the M5450 */
    void M5450_Start(void)
    //Enable = 0; /* Eliminate this line if there is no Enable pin defined */
    Data = 0;
    M5450_Pulse();
    Data = 1;
    M5450_Pulse();
    /* The Main Program */
    void main (void)
    /* Declaration of all local variables in the main part of the program */
    /* First Send a Start Pulse to the M5450 */
    M5450_Start();
    for(;;)
    M5450_Send(0x66);
    M5450_Send(0x4F);
    M5450_Send(0x5B);
    M5450_Send(0x06);
    /* Send a further Three Clock Pulses to Complete the 35 Pulses */
    M5450_Pulse();
    M5450_Pulse();
    M5450_Pulse();
