Keresés
faster
''The following instructions pertain to all current and recent Symantec antivirus products, including the Symantec AntiVirus and Norton AntiVirus product lines.
Disable System Restore (Windows Me/XP).
Update the virus definitions.
Restart the computer in Safe mode or VGA mode.
Run a full system scan, and delete all files that are detected as W32.Spybot.Worm.
Delete the value that was added to the registry.
Delete any zero-byte files in the Startup folder.''
[L]http://securityresponse.symantec.com/avcenter/venc/data/w32.spybot.worm.html[/L]
- S22 Ultra 512/12
- BESZÁMÍTÁS! ASRock B450M R5 4500 16GB DDR4 512GB SSD GTX 1660 Super 6GB Zalman T3 Plus DeepCool 400W
- HIBÁTLAN iPhone 11 128GB Black -1 ÉV GARANCIA - Kártyafüggetlen, MS4411, 100% Akksi
- BESZÁMÍTÁS! Asrock B450M R5 5500 16GB DDR4 512GB SSD GTX 1660 Super 6GB Zalman T3 Plus DeepCool 400W
- GYÖNYÖRŰ iPhone 13 Pro 128GB Gold -1 ÉV GARANCIA - Kártyafüggetlen, MS4675, 100% AKKSI
