moonman
oettinger01
#96
a linkelt gspot programmal megvizsgálod a fájlt, hogy milyen codec kell neki.
a codec pack-ekről viszont én pont lebeszélnélek, csak azokat tedd fel, amik kellenek. -
moonman
How do I back up my media usage rights?
This version of the Player does not permit you to back up your media usage rights. However, depending upon where your protected files came from, you might be able to restore your rights over the Internet. For more information, see the question in this topic about how to restore your media usage rights.
How do I restore my media usage rights?
If you encounter an error message that indicates you are missing play, burn, or sync rights for a file and you had these rights previously, you might be able to resolve the problem by restoring your media usage rights. You have several options:
If you obtained the file from an online store, contact the store to find out if it offers media usage rights (license) restoration (some stores refer to this procedure as computer activation, computer authorization, or license synchronization).
The procedure for restoring your rights varies by store. For example, you might be able to right-click the file in your library or click an Error button or an Information button next to the file, and then click a command. Or you might be required to delete the file from your computer and then download the file again.
The store might limit the number times that you can restore your rights or limit the number of computers on which can use the songs or videos that you obtain from them. Some stores do not permit you to restore media usage rights at all.
For details, see the store's customer support or Help links.
If the file is a song you ripped from a CD with the Copy protect music option turned on, you might be able to restore your usage rights by playing the file. You will be prompted to connect to a Microsoft Web page that explains how to restore your rights a limited number of times. -
moonman
Windows Media Player 11 Beta [link]
moonman
jaffa 2843
#75
sehogy, telepítéskor gondolom olvastad a figyelmeztetést, hogy a system restore az egyetlen visszaút.
moonman
akkor próbáljuk meg magyarul Bővebben: link
amúgy XP RTM: wmp8, XPSP2: wmp9
- Revolut
- Melyik tápegységet vegyem?
- Tápos kibeszélő offtopik
- Samsung kuponkunyeráló
- Milyen notebookot vegyek?
- Elektromos rásegítésű kerékpárok
- Racoon City árnyékában: Teszteltük a Resident Evil Requiemet
- iking.hu Apple iPhone 15 128GB Blue használt, karcmentes 86% akku 6 hónap garancia
- BESZÁMÍTÁS! Asus PRIME H510M i5 11400 16GB DDR4 512GB SSD RX 6600 8GB Rampage SHIVA Adata 600W
- szinteÚJ! Microsoft Surface Laptop 5 13.5" i5-1245U 16GB 512GB Alcantara 1év garancia
- HP 150W töltők (19.5V 7.7A) kis kék, kerek, 4.5x3.0mm
- Akció! HP ZBook Firefly 14 i7-1165G7 16GB 512GB Nvidia Quadro T500 4GB 14" FHD 1 év garancia
