Keresés
  • szesa
    En mar feladtam majd ha visszajottem a ''telelesbol'' probalkozom tovabb :(((
    grrr ms grrr
  • szesa
    igy karacsony elsonapjan egy jokivansag: dogolj meg ms...
    kiprobaltam a fentebb irt modszert hatha bejon a remote access - hat nem jott be...nem is latszik a gep a halon.
    a fentebb irtak alapjan egyszeruen az egesz rendszerhez (vinyo) nem fer hozza maga a computer management, a regedit adatbazist se latja mert nem egyeznek meg a meghajto-nevek.
    remek...van egy eredeti winfosom, van egy haldoklo vinyom, jelenleg meg nem veszett el semmi, siman le tudom menteni, csak eppen mukodokepes allapotban egy masik vinyora lehetetlen visszaallitani...
    ezzel szivok 2 hete a faxkivan
    :O
    kellemes unnepeket...
  • szesa
    >I've been trying for the past couple of days to transfer a Windows XP system from
    >a failing IDE drive to a new SATA drive, and have been stymied by this 0x80090006
    >problem. Like someone else who posted I have the corporate version of WinXP and
    >shouldn't have been getting any of the activation issue problems. I tried the BootitNG
    >solution of removing the signature from the MBR, but that didn't work, so I assumed
    >I had the drive letter problem.
    >I started through the whole process of creating a BartPE disk like someone suggested,
    >and while I was waiting for it to do it's thing I noticed that the computer on which
    >I was doing this had an active file share to the computer giving the 0x80090006 error.
    > At first I thought it was a leftover, but when I checked it was valid, although
    >the drive on the target system was showing files from a different drive, confirming
    >the problem was drive letters! Turns out that even though you can't logon the computer
    >is up and active and will accept a remote connection for Computer Management and
    >Regedit!! Of course after that it was easy to fix. I changed all the drive letters
    >except the system drive back to what they should be using a remote disk management
    >connection. Then I used a remote regedit connection to fix the drive letter for
    >the system drive (HKLM\System\Mounted Devices). It was a piece of cake, as having
    >the remote disk management connection up gave a picture of exactly what letters were
    >wrong, and made it easy to avoid mistakes.
    >So in summary if you get this error, first go to another machine on the network and
    >check to see if it's because the drive letters are hosed. It's a trivial fix now
    >that one knows the system is up and can be remotely accessed even though you can't
    >logon locally. Now I will say that I had already removed the MBR disk signatures
    >with BootitNG before trying this, so it's possible that you have to do both things
    >to get it to work.
    >Good luck all. BTW this thread was the best resource I found on the entire Internet
    >discussing this issue and potential fixes. Thanks everyone!
  • szesa
    Kozben beirom amiket talaltam eleg durvak...
    #1
    added a disk and removed 2 SCSI Disks
    ''WPA - ...preventing checking license... Error Code 0x80090006''
    Yes, even though this XP version has no WPA.
    Found following in www.annoyances.org:
    switched drives, formatted the old drive, and got this error. I booted up from a BartPE CD (google for that, don't have url handy) and loaded up regedit.
    Once in there I highlighted local machine, and did a load hive. I loaded up c:\windows\system32\config\system and once in there I navigated to the MountedDevices key. Well, there's my P: drive staring back at me. So, I opened up that \DosDevices\P: key and did a Select All, Copy, and then cancelled out of there and opened up the \DosDevices\C: key. Then I did a Select All again, and Paste. Exit regedit, reboot, working. woot.
    This worked very well, but after i changed the active Partition and again 0x80090006 occured.
    After reboot the 0x80090006 Problem occured. I have a multi boot PC and if you encounter this problem try to look at your boot.ini bevor trying anything else. It worked fine for me, the boot partition was chanched to partition 5. As a maximum of 4 primary partitions are allowed it was clear.
    #2
    Here's how I successfully cloned XP:
    1) I installed WinRescue XP and backed up my Windows configuration
    2) I created a partition the same size as my C drive with Partition Magic 5.0 (DOS)
    3) I started XP and cloned by C drive
    4) I did not let my computer restart, I disconnected my C drive and connected my new drive as the C drive (master)
    5) I booted to DOS, ran Partition Magic and set the new partition as active
    6) I rebooted to DOS ran WinRescueXP (wnresqxp.exe) and restored my backup
    7) then I booted to Windows, no problems
    One note, when you run WinRescue to restore you must put a floppy in the drive. It doesn't matter what's on the floppy. The program just searches for a floppy before it begins, and it will give error codes, but the process will complete successfully.
    I hope this information helps someone
    Ash
    az elso az hogy beletur a registrybe csak nemtom - felbootolt win nelkul?
    a masodik meg hogy menet kozbe csereld ki a vinyot pff egyre jobb
    amugy az ms-nek is van vmi dumaja erre a hibara, bar ott a sajat klonozo programjaval jon elo...
  • szesa
    válasz Protezis #9 üzenetére
    Megprobalom ezt is hatha jo lesz. Eddig kozvetlenul csinaltam a clonozast.
  • szesa
    ''the problem is that XP associates the partition volume ID with the identifying characteristics of the HD''
    When you go to install the clone and try to boot XP, it sees that the volume ID and HD characteristics don't match and throws out the error''
  • szesa
    Ahogy nezem neten a forumokat egy csomoan belfutottak ugyan ebbe a csapdaba, azaz regi rendszer vinyo csere nagyobbra, majd ghost majd 0x80090006 msg...
    vkinek a gdisk diskno /mbr segitett - nekem nem, vank akinek a winxp recovery konzol fixmbr, van akinek egy xxcopy nevu progival tortent klonozas segitett, de nalam minden hatastalan mert ezek mind abbol indultak hogy hogy a ''c'' akarom klonozni, egy masik vinyo elsodleges particiojara, hat igy ott vagyok ahol a aprt szakad mert nalam masodik particion van a rendszer, es az uj vinyon is oda kell tenni...grrr
    :F
  • szesa
    mxms first :)
    next:
    Ugyan ebbe a godorbe estem bele en is.
    Az bosszant a leginkabb hogy mar tobb tucat ghostolast csinaltam es meg ilyet egy se muvelt, igaz korabban win2kt hasznaltam.
    Szoval van egy winxp, kb 4 gigas particion.
    Van egy uj vinyo ahova atghostoltam.
    Szepen be is bootol minden franko, de amint beloginolok azonnal kozli hogy aktivalasi gond szevasz es kilep. Safemodeban ugyan ez, semmit nem tudok csinalnai az agyam eldobom...
    Ez mellesleg egy nem aktivalos winxp prof eng (ceges licenszcsomag reszekent csomo gepre felhuzhato stb..) sosem aktivaltam ez a hibauzenet is vmi baromsag amugy...de vmi megoldast kene talaltom, uhogy johet barmi amivel megoldhatom a system reinstall nelkul az egeszet, mert csak egy uj vinyot tettem a rendszerbe pontosan a regi helyere...
    HELP!
    :F :F :F
