Keresés
  • SirL
    válasz Gomezz #279 üzenetére
    Hello !
    Ez gondolom procifuggo. Mint valahol mar leirtam az enyem valoszinuleg TBred B-s valtozat. Valoszinuleg oriasi szerencsem van a procival.
    Udv: SirL
  • SirL
    Sziasztok !
    Ez a legutobbi eredmenyem (csak a lenyeges adatok vannak megtartva) :
    12571 pont GF4 TI4200 128MB 315per604MHZ 1024x768 Ultra memoria 13x163proci
    3DMARK2001 PROJECT FILE
    3DMark Version 300
    DISPLAY
    Platform NVIDIA GeForce4 Ti 4200 with AGP8X
    CPU Optimization D3D Pure Hardware T&L
    Width 1024
    Height 768
    Depth 32 bit
    Z-Buffering 24 bit
    Texture Format Compressed
    Buffering Double
    Refresh Rate Default
    FSAA Mode None
    OPTIONS
    Show Title Screens Yes
    Continuous Benchmark No
    Benchmark Run Count 1
    Demo Sounds Enabled Yes
    Continuous Demo No
    Game Sound Effects Enabled Yes
    Game Music Enabled Yes
    Game Detail Level Low
    RESULTS
    3DMark Score 12571
    Game 1 - Car Chase - Low Detail 183.2 fps
    Game 1 - Car Chase - High Detail 65.1 fps
    Game 2 - Dragothic - Low Detail 229.3 fps
    Game 2 - Dragothic - High Detail 125.4 fps
    Game 3 - Lobby - Low Detail 161.6 fps
    Game 3 - Lobby - High Detail 75.0 fps
    Game 4 - Nature 76.2 fps
    Fill Rate (Single-Texturing) 1045.5 MTexels/s
    Fill Rate (Multi-Texturing) 2400.8 MTexels/s
    High Polygon Count (1 Light) 57.9 MTriangles/s
    High Polygon Count (8 Lights) 12.8 MTriangles/s
    Environment Bump Mapping 86.3 fps
    DOT3 Bump Mapping 151.7 fps
    Vertex Shader N/A
    Pixel Shader N/A
    Advanced Pixel Shader N/A
    Point Sprites N/A
    SYSTEM INFO
    System Info Version 2.2
    Installation ID 0x00000000
    OEM ID
    CPU INFO
    CENTRAL PROCESSING UNITS
    Manufacturer AMD
    Family Duron(tm)
    Internal Clock 2.07 GHz
    Internal Clock Maximum 2.07 GHz
    External Clock 163 MHz
    Socket Designation Socket A
    Type <unknown>
    Upgrade ZIF Socket
    Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE
    Version Unknown CPU Type
    CPUID 0x00000681
    CACHES
    Level 1
    Capacity 128 KB
    Type Internal
    Type Details Synchronous
    Error Correction Type <unknown>
    Associativity <unknown>
    Level 2
    Capacity 256 KB
    Type External
    DIRECTX INFO
    DirectX Version 8.1
    DIRECTDRAW INFO
    DirectDraw Version 4.08.01.0881
    DISPLAY DEVICES
    Description Primary Display Driver
    Manufacturer NVIDIA
    Name NVIDIA GeForce4 Ti 4200 with AGP8X
    Total Local Video Memory 128 MB
    Total Local Texture Memory 128 MB
    Total AGP Memory 64 MB
    Display Driver nvdisp.drv
    Display Driver Version 4.14.01.4201
    Driver WHQL Certified No
    Max Texture Width 4096
    Max Texture Height 4096
    Max User Clipping Planes 0
    Max Active Hardware Lights 8
    Max Texture Blending Stages 8
    Textures In Single Pass 4
    Vertex Shader Version 1.1
    Pixel Shader Version 1.3
    Max Vertex Blend Matrices 0
    Max Texture Coordinates 8
    Vendor ID 0x10de
    Device ID 0x0281
    Sub-System ID 0x2931107d
    Revision 0xa1
    DIRECTSHOW INFO
    DirectShow Version 6.03.01.0400
    MEMORY INFO
    Total Physical Memory 256 MB
    Free Physical Memory 85.97 MB
    Total Pagefile Memory 1.75 GB
    Free Pagefile Memory 1.70 GB
    MEMORY ARRAYS
    Max Module Capacity 768 MB
    Location System Board
    Use System
    Supported Error D&C None
    Supported Speeds <unknown>
    Supported Types <unknown>
    Supported Voltages <unknown>
    MEMORY SLOTS
    Installed & Enabled Size 256 MB
    Form Factor DIMM
    Frequency 0 Hz
    Slot A0 [Bank0/1]
    Manufacturer
    Type <unknown>
    Type Details <unknown>
    Enabled Size 256 MB
    Total Bit Width 0
    Data Bit Width 0
    MOTHERBOARD INFO
    Manufacturer http://www.abit.com.tw/
    Model KD7 (KT400-8235)
    Version 1.x
    BIOS Vendor Phoenix Technologies, LTD
    BIOS Version 6.00 PG
    BIOS Release Date 08/12/2002
    BIOS Properties Plug and Play, Flash, AGP
    OPERATING SYSTEM INFO
    Operating System Microsoft Windows 98
    Version 4.10.1998
    Service Pack
    Locale HU
    Desktop Width 1280
    Desktop Height 1024
    Desktop BPP 32
    Udv: SirL
