OpenWrt topic
Gondom van a 22.03.0-rc4 verzion a wifivel
Ha wps-en keresztul csatlakoztatok barmely eszkozt egy ujrainditas utan az eszkoz nem tud újból csatlakozni, authentikacios hibát latok a logban.
Ha ismet csatlakoztatom wps-en jo ameddig nem indul ujra a router.
Van erre valami megoldás? -
Sat Apr 16 13:02:30 2022 daemon.info pppd[8141]: Plugin rp-pppoe.so loaded.
Sat Apr 16 13:02:30 2022 daemon.info pppd[8141]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sat Apr 16 13:02:30 2022 daemon.notice pppd[8141]: pppd 2.4.8 started by root, uid 0
Sat Apr 16 13:02:31 2022 daemon.notice netifd: Network device 'wan' link is down
Sat Apr 16 13:02:31 2022 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Sat Apr 16 13:02:31 2022 daemon.notice netifd: Interface 'wan' has link connectivity loss
Sat Apr 16 13:02:31 2022 kern.info kernel: [ 191.209571] mt7530 mdio-bus:1f wan: Link is Down
Sat Apr 16 13:02:31 2022 daemon.err pppd[8141]: select (waitForPADO): Interrupted system call
Sat Apr 16 13:02:31 2022 daemon.warn pppd[8141]: Timeout waiting for PADO packets
Sat Apr 16 13:02:31 2022 daemon.err pppd[8141]: Unable to complete PPPoE Discovery
Sat Apr 16 13:02:31 2022 daemon.info pppd[8141]: Exit.
Sat Apr 16 13:02:31 2022 daemon.notice netifd: Interface 'wan' is now down
Sat Apr 16 13:02:32 2022 daemon.notice netifd: Interface 'wan6' is now down
Sat Apr 16 13:02:34 2022 kern.info kernel: [ 194.281813] mt7530 mdio-bus:1f wan: Link is Up - 100Mbps/Full - flow control off
Sat Apr 16 13:02:34 2022 daemon.notice netifd: Network device 'wan' link is up
Sat Apr 16 13:02:34 2022 daemon.notice netifd: Interface 'wan6' has link connectivity
Sat Apr 16 13:02:34 2022 daemon.notice netifd: Interface 'wan6' is setting up now
Sat Apr 16 13:02:34 2022 daemon.notice netifd: Interface 'wan' has link connectivity
Sat Apr 16 13:02:34 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sat Apr 16 13:02:34 2022 daemon.err insmod: module is already loaded - slhc
Sat Apr 16 13:02:34 2022 daemon.err insmod: module is already loaded - ppp_generic
Sat Apr 16 13:02:34 2022 daemon.err insmod: module is already loaded - pppox
Sat Apr 16 13:02:34 2022 daemon.err insmod: module is already loaded - pppoe
Sat Apr 16 13:02:34 2022 daemon.info pppd[8255]: Plugin rp-pppoe.so loaded.
Sat Apr 16 13:02:34 2022 daemon.info pppd[8255]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sat Apr 16 13:02:35 2022 daemon.notice pppd[8255]: pppd 2.4.8 started by root, uid 0
Sat Apr 16 13:02:35 2022 daemon.notice netifd: Network device 'wan' link is down
Sat Apr 16 13:02:35 2022 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Sat Apr 16 13:02:35 2022 daemon.notice netifd: Interface 'wan' has link connectivity loss
Sat Apr 16 13:02:35 2022 kern.info kernel: [ 195.305576] mt7530 mdio-bus:1f wan: Link is Down
Sat Apr 16 13:02:35 2022 daemon.err pppd[8255]: select (waitForPADO): Interrupted system call
Sat Apr 16 13:02:35 2022 daemon.warn pppd[8255]: Timeout waiting for PADO packets
Sat Apr 16 13:02:35 2022 daemon.err pppd[8255]: Unable to complete PPPoE Discovery
Sat Apr 16 13:02:35 2022 daemon.info pppd[8255]: Exit.
Sat Apr 16 13:02:35 2022 daemon.notice netifd: Interface 'wan' is now down
Sat Apr 16 13:02:36 2022 daemon.notice netifd: Interface 'wan6' is now down
Ilyesmivel van tele a log és a pppoe kapcsolatot eldobja
openwrt 21.02.3 ,a 22.xx verzióval is ezt csinálja
a 19.xx verzióval egyelőre nincs ilyen hiba
szolgáltató oldaláról volna a hiba? azután jelentkezett egy nappal, hogy eszközt cseréltek -
Frissítettem az openwrt-t 21.02.3-ra (R3G)
gondom van a VPN-el
a wireguard a routerre telepítve sehogy nem akar csatlakozni a lan-hoz, csak wan-ig jut el, kifele van internet elérés, belső lan-on routolás nincs
a 19.x.x verzióval semmi gondom, azon megy tökéletesen
(https://openwrt.org/docs/guide-user/services/vpn/wireguard/server)
sőt van OVPN szerver a nason, az se tud lanhoz csatlakozni 21.02.3 verzió alatt, az is kifele látja az internetet, 19.x.x alatt megy gond nélkül, mindkét VPN működik
visszaraktam a 19.x.x verziót, minden rendben
mit kellene átnéznem, beállítanom másképp a 21.02.3 verzión?
köszönöm -
Xiaomi Mi3g-n nincs WPS gomb, viszont lenne a hálózaton egy készülék amit csak így lehet wifire csatlakoztatni
esetleg virtuális gomb luciban?
thx -
vargalex
#16047
nekem a fő szerver gépen dockeben fut a jwilder nginx proxy, az úgy tűnik nem támogatja, sőt ha beállítom a proxy_pass-t más IP-re domain szinten akkor szétcseszi az egészet, semmi nem működik, rátelepszik globálisan, újra kell építenem a konténert
lehet más reverse proxy után kellene néznem, ha van bevált megnézem
vagy kipróbálom owrt alatt hogy futegyébként ha leáll a router, akkor nálam semmi nem megy lanon, semmit nem érek el, ha meg nincs net akkor külső hálózatról sem lesz elérhető, úgyhogy mindegy...
vagy nem jól gondolom? -
Openwrt mögött több webszervert kellene uzemelnem belso halon, fizikailag tobb gep.
Mi a legegyszerubb modja, hogy webrol a standard portokon (80, 443) el lehessen erni a szervereket? Tegyek egy nginx reverse proxyt az openwrtre? -
Multicast-ot próbálok beállítani wifinek egy R3G-n, az openwrt oldalán található leírás alapján, de valamiért nem megy, tudna valaki segiteni?
ez inkabb alexnak, van par sonoff pow eszkozom és home assistant alá integrálható firmware csere nélkül, viszont az ewelink felhő kiiktatasahoz, hogy működjön localban az eszkoz, kell neki multicast. Hiába csinálom végig mindazt ami az openwrt oldalan le van irva, a sonoff nem akar működni localban, csak cloudban, erre kérnék egy kis segítséget
Köszönöm -
Headless
#15258
a pfsense 2014-ben változtatott a licenszeiben, lett egy követője az opnsense,
azt nézegettem/próbálgattam, egész okos, viszont a wifi kezelése problémás, hasonlóan a pfsense-hoz, a te javaslatod mindenképp jobb, külön ap-vel.
viszont a pc-ből épített router majd meglátszik a villanyszámlán, de legalább erősebb hardver is lehet, nem mint az olcsó fogyasztói routerek
nasnak inkább az openmediavault, bár kérdés mire kell
az openmediavault tartalmaz dockert is (omvextras), arra meg mehet minden, amit a gép elbír..., nálam az összes szervert kiváltottamás:
wireguard vs openvpn, milyen sebesség különbségeket mértél, ha mértél? vagy bárki más
nálam van mindkettő, wireguard jobbnak tűnik és talán nem terheli annyira az openwrt-s r3g routert -
Az egyik routert switchkent konfigoltam dhcp kikapcsolva, az előtte lévő router osztja az ip címeket.
Switch modban eltárolja valahol a csatlakozott wifi kliensek adatait?
Mac címet ki tudom szedni, de a wifi kliensek nevét nem.
Létezik valami bash parancs hogy kinyerjem a csatlakozott wifi kliensek nevét? Egyáltalán tárolodik valahol?
A másikon, ami routerkènt üzemel a dhcp logban minden benne van, ott könnyű dolgom van...
Legfrissebb openwrt van mindkettőn.
Megköszönöm, ha valaki ad valami támpontot. -
Be szeretném állítani, hogy az egyik megnyitott portot (443) csak a meghatározott országokból (pl HU, DE, stb.)lehessen csak elérni, a többi országra tiltani.
Tud ebben valaki segiteni?
Köszönöm -
Van arra lehetőség hogy naplózzam hogy belső hálózaton levő gépekről milyen weboldalak lettek megnyitva?
Valami olyasmi mint pl. a böngésző előzmények a Firefoxban, de központosítva. -
Ha a szolgáltató NATol és nem hajlandó feloldani, van-e arra valamilyen lehetőség, hogy hálózaton kívülről elérjem az IP kamerákat? Amelyeket NATolás előtt persze elértem ddns-en.
thx -
stickermajom
#12773
Nálam ez van beállítva, de lehet van más megoldás is:
A wifin logó eszköznek fix IP-t kell kiosztani és felvenni a tűzfalba egy szabályt:
etc/config/firewallconfig rule
option src 'lan'
option dest 'wan'
option src_ip '192.168.1.77'
option target 'REJECT'
option name 'block access to internet'option src_ip kicserélni a wifi-s eszköz IP címére
Beírom ide is hátha valaki:
Egy Archer c5-nél ha wan-nál pppoe-t választok a mac cím végig nulla.
Gondolom ennek nem így kellene lennie.
Esetleg valakinek megoldás?
LEDE Reboot 17.01.0 r3205-59508e3 -
lecseréltem az openwrt-t lede-re. (archer c5)
van egy kis gondom vele, valamiért az FTP csatlakozást külső hálózatról nem akarja továbbítani.
port forward beállítva (ill. minden beállítás ugyanaz mint az openwrt-nél, persze előzőleg minden törölve)
tesztelni legegyszerűbb itt:
ftptest.net
ezt a hibát adja vissza:
Error: Server returned unroutable private IP address in PASV replyMás protokoll működik gond nélkül (ssh,http, stb), hálózaton belüli FTP is.
ha valakinek van ötlete megköszönném
- 3D nyomtatás
- BMW topik
- Házimozi belépő szinten
- Linux kezdőknek
- Kuponkunyeráló
- Apple iPhone 16 Pro Max 256GB Black Titanium használt, szép állapot 96% akku (247 ciklus) 6 hó
- 196 - Lenovo Legion Pro 5 (16IAX10) - Intel Core U7 255HX, RTX 5070 (ELKELT)
- Eladó 1db Nokia steel hr hibrid okos óra dobozával
- Thrustmaster TMX Force Feedback Kormány szett + Playseat 3 hónap Garancia Beszámítás Házhozszállítás
- 13-14" Új és használt laptopok , üzletitől a gamerig , kedvező áron. Garanciával !
