Vladi
Van ez a keytouch-os init szkript:
#!/bin/sh
# /etc/init.d/keytouchacpid
# Subsystem file for keytouch-acpid
# chkconfig: 2345 95 05
# description: keytouch-acpid lets ACPI hotkeys work as normal keys
# processname: keytouchacpid
# http://keytouch.sourceforge.net
# Heavly edit to match with fedora init scripts schemes
# First edit by Xavier Lamien aka SmootherFrOgZ < lxtnow[at]gmail.com >
# Source function library.
if [ -f /etc/init.d/functions ] ; then
. /etc/init.d/functions
elif [ -f /etc/rc.d/init.d/functions ] ; then
. /etc/rc.d/init.d/functions
else
exit 0
fi
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
DESC="keytouch-acpid daemon"
DAEMON="keytouchacpid"
SCRIPTNAME=/etc/init.d/keytouchacpid
prog="keytouch-acpid"
RETVAL=0
exec="/usr/bin/keytouch-acpid &"
PID="ps axo "%p,%a" |grep "$NAME"|grep -v grep|cut -d',' -f1"
getpid () {
start () {
#start daemon
action $"Starting $prog daemon:" $exec
RETVAL=$?
if
[ "$RETVAL" -eq "0" ]; then
touch /var/lock/subsys/keytouchacpid
fi
return
stop () {
getpid
if [ -n "$PID" ]; then
#stop daemon
killproc $NAME
fi
RETVAL=$?
if
[ $RETVAL -eq "0" ]; then
rm -f /var/lock/subsys/keytouchacpid
restart () {
stop
start
case $1 in
start)
start
stop)
stop
restart)
restart
condrestart)
[ -f /var/lock/subsys/keytouchacpid ] && restart || :
reload)
echo -n $"Reloading $DESC: $NAME "
killproc $NAME -HUP
RETVAL=$?
echo
status)
status $NAME
restartlog)
stop
cat /dev/null >/var/log/keytouchacpid/error_log
start
echo $"Usage: $NAME {start|stop|restart|condrestart|reload|status}"
exit 1
esac
exit $RETVALErre azt mondja nekem:
[root@localhost ~]# /etc/init.d/keytouchacpid status
/etc/init.d/keytouchacpid: line 60: syntax error near unexpected token `}'
/etc/init.d/keytouchacpid: line 60: `}'
[root@localhost ~]#
A kérdéses sor ennek a vége:
stop () {
getpid
#stop daemon
killproc $NAME
fi
RETVAL=$?
if
}Nem bírok rájönni mi itt a szintaxis hiba. Csomagból lett telepítve, nem én követtem el.
- Intel Core Ultra 3, Core Ultra 5, Ultra 7, Ultra 9 "Arrow Lake" LGA 1851
- A Honor profi iPhone másolásban
- Tőzsde és gazdaság
- Apple MacBook
- Futás, futópályák
- Revolut
- Ableton Live 12 Suite Education
- iPhone X 64GB 100% (3 hónap Garancia) - AKCIÓ
- LG 27GX704A-B - 27" OLED evo / QHD 2K / 240Hz & 0.03ms / 1300 Nits / NVIDIA G-Sync / AMD FreeSync
- AKCIÓ! Asrock B450M R5 4500 16GB DDR4 512GB SSD GTX 1660 Super 6GB Zalman T3 Plus DeepCool 400W
- Apple iPhone 13 /128GB /Kártyafüggetlen / 12 Hó Garancia / akku: 85%
