Z_A_P
GodGamer5
#40940
Bakker, 10 vonal, mindegyik a zold egy picit mas arnyalataval
Bocs, Petykemano-nak ment
Z_A_P
Lehet nem jol tudom, de a Mellanox-ot meg nem okezta le a kinai hatosag, es mar lejart a hatarido, ujra benyujtottak ,de ezt is huzzak.
Feb. 19, 2020
Nvidia and Mellanox refiled merger paperwork with China's State Administration for Market Regulation, according to Dealreporter sources.
The companies refiled after the 180-day review period expired earlier this month.
SAMR had already started testing remedies for potential antitrust concerns.
The deal has an outside date of March 10 with a possible extension to June 10. -
Z_A_P
Állítólag olyan osztalék várható most
Haaaatooo, mivel most (ha jol latom) 0.24% az osztalek, ezert ha 10 szeresere (azaz 1000%!!) novelik , meg az is KEVES lenne magas osztaleknak (2.4%). Talan egy 20* emeles mar abba a kategoriaba lokne
Magyarul, az nvidia minden csak nem osztalek reszveny. -
Z_A_P
bertapet11
#40055
Nvidia-t lassitja az async, meg a 2000 sorozatot is
Z_A_P
Z_A_P
Z_A_P
#38786
As mentioned in the introduction, this is an NVIDIA title, and they've been all over the developer to get RTX ON supported. It is nice to see DX-R / RTX mode included. Currently, NVIDIA offers Raytracing High and Ultra modes. We've had a very hard time noticing any difference, and as such recommend RTX high should you use it. DXR itself is very hard to actually spot but moreover softens shadows and creates more scening (darker atmosphere) scenes. The problem with such details is that you need to stand still really, in a fast moving/pacing game details can quickly outrun you. RTX On you'll spot in the water reflections and atmospheric light effects, train tracks that properly bounce reflections. Granted though, while we need to look very hard to find the difference, it does look nice.
Pont ezt lattam en is a huzogathato kepen, a felson konkretan semmi kulonbseget nem latok, az alson a viz az uton megcsillan.
Szerk: sokaig nezegetve, kontrasztosabb a kepe.
Z_A_P
szmörlock007
#38474
Nem uj product, revolution lesz.
Szoval jon az APU
Kerdes, Intel vajon meg tudja-e mozgatni a fejlesztoket annyira hogy elkezdjenek valoban erre dolgozni? Szerintem nem...de kiderul. -
Z_A_P
velizare
#38280
nem volt az olyan rossz
Ne az elozohoz nezd, hanem az elemzoi varakozasokhoz. Ott nem hozta a bevetelt. Kulonosen rossz hogy sem a data center sem a client computing nem hozta amit vartak. Ja, es darabszamra is csokkent az eladas minden teren, viszont a profit/db nott.
De ez a kisebbik gond. A nagyobb, hogy a jovore nezve nagyon durvan visszavagta a szamait (16 vs 17.3 / 0.87 vs 1.02). A piac a jovot arazza. Es az most nem tul fenyes. -
Z_A_P
imi123
#36786
With adaptive shading, an algorithm looks at the previous frame and then will determine which parts of the current frame can contain less detail (I)without it having noticeable image quality loss(/I)
Az a baj ezzel, hogy ez szubjektiv dolog. Ha erre fognak ragyurni a gyartok, akkor hamarosan eljutunk oda hogy "Pentium, 2+2=5...jo, de en voltam
gyorsabbtobb FPS" -
Z_A_P
bertapet11
#34727
Frankly we’re impressed with how well optimized Strange Brigade is. And not just for AMD hardware (who is a sponsor), but also Nvidia hardware, which is great to see. In fact, this is becoming a common trend, where every game AMD has a hand in developing turns out being extremely well optimized for all.
Z_A_P
legnagyobb teljesítményt ma konkrétan szoftverből nyerhetik a hardvergyártók
Ez kb a "3DNow!" ota vilagos pedig. De sajnos a sw-fejlesztoknek nincs ideje "szarra" optimalizalni a kodot, mert nem kapnak se annyi penzt, se annyi idot, es mire kijonnek vele, mar kint van az ujabb hw, szoval kezdhetnek elorol...
Z_A_P
Ez lehet pont olyan mint a BR lemez megszunese, helyette van online stream. Szarabb minosegu hang es kep, de az atlagot nem erdekli, emiatt nincs eselye a lemeznek (jobbnak).
Na, lehet ez lesz, hiaba tud gyorsabb/szebb kepet a dvga, mivel egyre nagyobb %-nak eleg lesz az igp, ezert lassan elapad a dvga. Ha meg az intel is rasegit, akkor plane. (vagy nem) -
Z_A_P
->Raizen<-
#33246
szar amd
Z_A_P
->Raizen<-
#33155
ez már a sokadik játék....
...ahol allo kepen nezve(!), csuszkaval valtoztatva(!!) gyorsan oda-vissza(!!!), elhanyagolhato kulonbseg van a low es a max kozott
(kiveve FPS...) -
Z_A_P
Nyilvan, "elorehozott vasarlasok" boszen megdobtak az eredmenyt. Egeszen igy is marad amig fut a banyasz biznisz. Ha pukkan, akkor pedig oriasi visszaeses lesz. Ha.
AMD meg (mai napig nem tudjuk miert) keptelen eleg Polaris/VEGA-t gyartani, igy lemaradtak az eladasokban.@Abu, az intel+vega kombo nem csak a laptopba megy? Az AMD IGP pedig 1030/550-ig torli ki a GPU-k piacat (de csak ha eleg a 4/8, es AMD-t veszel), az pedig nem olyan sok. Szoval ez a dgpu halal meg messze van szerintem.
Apropo, AMD APU
Ha tesztelitek, tegyetek mar melle egy A12 AM4-es APU-t is (korabbi arch)
Z_A_P
Remelem igazad van, mert ez a kisebbik rossz (azaz eladjak az osszes gyartott VEGA-t, ami nem kevesebb mint amit terveztek, es szimplan nem tudnak meg tobbet gyartani)
Nade! Ilyen keveset terveztek? Miert, azt hittek senki sem akar majd venni?
Vagy a banyaszok elviszik mindet meg a boltok elott?
Z_A_P
Petykemano
#32028
De Abu azt mondta, Vega64-ből nem lesz 12nm refresh.
Mondjuk az 5xx csalad is nagyon hamar jott a 4xx utan.@petykamano
lehet, hogy valóban sikertermék
Ezt honnan tudni?
Z_A_P
Na, olvasom itt, azert keves a Vega mert:
-nincs eleg HBM
-nincs eleg GPUEzek lennenek az okok?
Kiknek a hibaja ez? GPU-t inkabb AMD nyakaba varrnam... -
Z_A_P
Petykemano
#31471
GPU:
Intel: 65% (mind IGP)
AMD: 15%
Nvidia: 14%Jon a RR, jon az AMD GPUs Intel, megy ez felfele elvileg boven.
Z_A_P
cskamacska
#31408
Raven Ridge pedig mai napig Soon™ státuszban leledzik
Z_A_P
Akkor egy kis VS:
Z_A_P
->Raizen<-
#31293
Z_A_P
Z_A_P
cskamacska
#30629
eleven, thirty, 27th, ...
Z_A_P
Nyilván pro-kontra érv van mellette. Az előnye az, hogy a GeForce úgy ~10%-ot is gyorsulhat tőle a teljes képszáímtásra levetítve, de hátrány az extra másolás, ami GPU stallt okoz, tehát az Intel és az AMD hardverei buknak pár százalékot,
Ez remek
Tekintettel a piaci reszesesdre, inkabb a 2/3-re fognak kodolni, nem az 1/3-ra. Habar...ha nemcsak DGPU-t nezem, akkor maris mas a felallas. Na akkor most hogy lesz? Nem lehet if (nVidia) ... else ... kodot berakni?
Z_A_P
gainwardgs
#29909
Nagyon "jol" sikerult app!
Intel Core i5 6600 3.3 > Intel Core i7 4770K 3.5
AMD Ryzen 3 1300X 3.4 > AMD Ryzen 5 1600X 3.6
Intel Core i3 6100 3.7 > Intel Core i7 3970X 3.5stb..
Megbízhatatlan oldalakat ahol nem mérnek (pl gamegpu) ne linkeljetek.
- Melyik tápegységet vegyem?
- Építő/felújító topik
- Házimozi belépő szinten
- Battlefield 6
- Dell Precision 7550,15.6,FHD,i7-10850H,16GB DDR4,256GB SSD,Quadro T2000 4GB VGA,WIN11,LTE
- Samsung Galaxy A54 5G 128GB, Kártyafüggetlen, 1 Év Garanciával
- Apple iPhone 13 /128GB / Kártyafüggetlen / 12Hó Garancia / Akku: 100% Után gyártott Kijelző
- 192 - Lenovo Legion 5 (15IRX10) - Intel Core i7-14700HX, RTX 5060 (ELKELT)
