F34R
Naj csak meglett.
lame, mutagen, mplayer (vagy tetszes szerint mplayer2 es a fork mpv)
es a script
#!/bin/bash
DEFAULT_OUTPUT_DIR=/tmp/mp3ify
QUALITY=2
VBR_QUALITY=4
MIN_BITRATE=64
MAX_BITRATE=256
SAMPLE_FREQ=44.1
function any_to_mp3 {
PIPE=`mktemp -u -t mp3ify.pipe.XXXXXX`
mkfifo "$PIPE"
mplayer -ao pcm -ao pcm:file="$PIPE" "$INPUT_FILE" -noconsolecontrols > /dev/null 2>&1 &
lame -m j -q $QUALITY -v -V $VBR_QUALITY -b $MIN_BITRATE \
-B $MAX_BITRATE -s $SAMPLE_FREQ "$PIPE" "$OUTPUT_FILE" > /dev/null 2>&1
rm "$PIPE"
python2 -c "
import mutagen
input = mutagen.File(\"$INPUT_FILE\", easy = True)
output = mutagen.File(\"$OUTPUT_FILE\", easy = True)
for tag in [ 'artist', 'album', 'tracknumber', 'date', 'genre', 'title', 'comment' ]:
value = input.get(tag)
if value: output[tag] = value[0]
output.save(v1=2)"
function usage {
echo "mp3ify <input_dir> [<output_dir>]
Transforms structure <input_dir>/X/Y/.../Z into structure <output_dir>/X/Y/.../Z
according to the following rules:
flac, ogg, m4a, ape, aac, mpc files will be encoded to mp3 preserving tags.
Everything else will be copied without modification.
Requires: mplayer, lame, mutagen.
exit 1
INPUT_DIR="$1"
[ -d "$INPUT_DIR" ] || usage
OUTPUT_DIR="${2:-$DEFAULT_OUTPUT_DIR}"
find "$INPUT_DIR" -name '*.*' | while read INPUT_FILE
do
INPUT_EXTENSION="${INPUT_FILE##*.}"
OUTPUT_FILE="$OUTPUT_DIR/${INPUT_FILE#$INPUT_DIR}"
mkdir -p "`dirname "$OUTPUT_FILE"`"
case $INPUT_EXTENSION in
flac|m4a|ogg|ape|aac|mpc)
OUTPUT_FILE="${OUTPUT_FILE%.$INPUT_EXTENSION}.mp3"
echo -n "Converting ${INPUT_FILE##*/}... "
any_to_mp3
echo -n "Copying ${INPUT_FILE##*/}... "
cp "$INPUT_FILE" "$OUTPUT_FILE"
esac
echo "done."
done -
F34R
nem tudom hogy ismeretek-e ilyet de szuksegem volna olyan scriptre mint flac>mp3 eseteben:
#!/bin/bash
for a in *.flac; do
< /dev/null ffmpeg -i "$a" -qscale:a 0 "${a[@]/%flac/mp3}"
donenamarmost nekem musepack (*mpc)-bol kellene mp3-t varazsolni.
fent van a decoding library a libmpcdec is. valakinek valami otlete ?
- Elektromos autók - motorok
- Windows 11
- Alaposan helyretette az AI ellenzőit az NVIDIA vezetője
- Így nézhet ki a Huawei Pura 90
- A CannonKeys felkavarja a slim profilos billentyűzetek állóvizét
- Nem átlagos PC-s kézikonzolban gondolkodik a Gigabyte
- Két 16 GB-os GeForce gyártását szüntette meg az ASUS
- Ilyen se volt még: mégsem kell sok memória az új James Bond játékhoz
- 170 - Lenovo Legion Pro 7 (16IRX9H) - Intel Core i9-14900HX, RTX 4090
- BESZÁMÍTÁS! LENOVO ThinkPad P15 Gen2 munkaállomás - i7 11800H 16GB DDR4 1TB SSD RTX A2000 4GB W
- Apple iPhone XR 64GB,Átlagos,Dobozaval,12 hónap garanciával
- Samsung Galaxy A16 5G 128GB, Kártyafüggetlen, 1 Év Garanciával
- Honor 200 Lite / 8/256GB/ Kártyafügetlen / 12Hó Garancia
