OFF beszélgetős topic nyílt, a nem Battlefield 4 témákról kérjük, hogy ott beszélgessetek, ez a téma maradjon meg szakmainak! Cheatek a topikban szintén tiltottak!
Kérlek olvasd el mielőtt kérdezel, köszönjük!
iMaverick
Enigma1945
#100312
iMaverick
fornettisuti
#99866
Most nem azért, de én egy BC1 PC-s portnak is örülnék...
iMaverick
Enigma1945
#97938
Ez a "leteszteltem" mit jelent? Egy "teljes" teszt minimum 2-3 teljes körbe ciklust jelentene.
iMaverick
Enigma1945
#97869
Nem lehet, hogy magával a hw-rel van valami gikszer? Memória hiba? Más játékok (ártsd: nem BF) mennek normálisan?
iMaverick
}{3@Đ$}{0ot
#97422
Szerintem az...
iMaverick
Prosector
#97371
Jól írja CJ4567 kolléga! Direkt rákerestem és valóban (idézem a cikkből):
As a result, many users have noticed that there’s an unusually high number of svchost.exe processes running in Windows 10 Creators Update. (As a quick reminder, a svchost.exe executable file is a system process that hosts multiple Windows services.) Its main role is to allow two or more services to share a process. In this manner, Microsoft reduces consumption of computer resource.
Microsoft splits service hosts into separate processesStarting with build 14942, all Windows 10 Creators Update builds will feature a dedicated svchost.exe process for every Windows service. As a result, the number of svchost.exe processes has significantly increased.
At first, many Windows 10 users may find this change confusing. However, Microsoft explains that there’s no need to worry as this change won’t have a negative impact on system resources. The recommended RAM for PCs has dramatically increased over the years, which means that memory capacity is no longer an issue for users.
It is worth mentioning that Microsoft decided to use svchost.exe files to group processes in order to reduce pressure on computer memory. Since memory is no longer a problem, the company can now ungroup services. Windows 10 will ungroup services only on PCs with 3.5 GB+ of RAM.
Tehát dióhéjban: eddig az SVCHOST.EXE-k több Win szolgáltatást is összefogtak, mostanra viszont általánosságban annyira megnőtt a PC-kben a ram mennyisége, hogy szét lehet kapni ezeket és mindnek külön (!) SVCHOST.EXE-t adni. Viszont ezt csak a 3 és fél giga ramnál többel rendelkező masinákon csinálja.
Amúgy meg nem tudom, hogy van-e lehetőséged elodázni ezt az update mutatványt! Ugye a MS-t már nem varizik, nem lehet kihagyni bizonyos update-eket, mindet fel kell rakni.
iMaverick
westcoastog
#97349
Nincs gond. Tegnap előtt frissítettem kézzel a CU-re, tegnap toltam a BF4-et ranked server-en, nem volt baj.
iMaverick
general
#95302
Statisztikailag szerintem is a Locker a legfelkapottabb.
Személy szerint (BF4-ben): gyalogkakukk stílusra a Pearl Market, járművezésre a Gulf of Oman. (Ez a BF2 óta nagy kedvencem. Ráadásul tudom, hogy sokan "utálják" a porvihar miatt, nekem viszont nagyon megdobta az élményt a map-on.)
iMaverick
fornettisuti
#92333
Most nem kötekedésképp, de akkor a Slam az mi a jófene?
szerk: részlet a bf4blog.com-ról:
The M2 SLAM (Selectable Lightweight Attack Munition) is a small portable anti-vehicle mine unlocked after accumulating 74,000 points playing as the engineer class.
Most akkor az "akna", az "akna"?
iMaverick
fornettisuti
#92330
M2 Slam "ráragad". Mondjuk minden másra is. (Falra, alagútra, stb.)
iMaverick
juve600
#91740
Próbáltam kicsit ironizálni. Ennyi.
Ahogy én látom: ilyen játékot, tehát ahol számít (!), hogy milyen gyorsan reagálsz valamire és sok mindenen megcsúszhat (pl. ott van az internet, ehm-ehm), ott ne a helyi masinán legyen már a probléma. Tehát ne kelljen már arra várni tizedmásodperceket, hogy a HDD feje oda seek-el a kért adatra (textúra, hang, bármi).
(Emlékszem a régi szép időkre, amikor pl. a Quake 2-vel nyomultunk, és voltak olyan haverok, akik teljesen "lecsupaszították" a játékot, tehát nem csak a felbontást és a grafikát vették vissza, hanem minden (!) effektet lekapcsoltak! Konzolba írogatták be a parancsokat, fejből. Aztán hogy hogyan nézett ki a játék, az másodlagos volt.)
iMaverick
Látom megint változott a "széljárás".
Volt már ez az SSD vs. HDD téma korábban is (tehát hogy érdemes-e a BF4-et az SSD-n tárolni) és akkoriban az volt az általános, hogy nem, lévén a pálya betöltésének a gyorsasága teljesen mindegy, lévén úgyis betették a játék készítői a kényszerített várakozást a kör elejére.Most akkor megint ott tartunk, hogy tegye mindenki az SSD-re. (Mondjuk én eleve oda telepítettem: nem baj az, ha gyorsan betölt a játék. Pláne ha el is fér...)
iMaverick
iMaverick
#91591
Mondom van 5 percem rá, kicsit utánaolvasok... Hát nem tudom... Találtam pár oldalt (pl. EZT), ahol elég szubjektíven leírja, hogy mi újság...
Voltaképpen semmi "egetverőt" nem olvastam:
- korai tervezési gondok (pl. lőszer típus)
- bal kezesek nem használhatják (mint a FAMAS-t)
- gyakran elakadt a kosztól (ilyet is láttunk az M16-snál)
- (ha jól értettem) lövés közben véletlenül kinyomták a tárat(?) (mondjuk ez tényleg gáz)Viszont az A2-s modellel sokat javult a konstrukció. Az meg, hogy az SAS másik fegyvert választott? Ja kérem szépen, az egyik csúcs elit alakulat gondolom választhat magának olyan fegyvert, ami sokkal inkább illik a "profiljukba" és nyilván 150%-ig megbízható. A Királyi Tengerészgyalogság meg lehet inkább finnyás volt és azért választotta az M-16A3 "klónt". Azt azért hozzátenném, hogy a múltkorjában volt egy videó a "mi" fiainkról is: idehaza megy az AK, a kinti missziókon már ők is M16-ossal nyomulnak. Gondolom így "praktikusabb" a kooperáció a NATO-s partner hadseregekkel.)
iMaverick
FollowTheORI
#91589
Amikor reggel olvastam a cikket, megakadt a szemem a következőn: "de sokkal kevésbé közismertek a hátrányai, mint a problémás brit SA80-as, ami a világ valószínűleg legszarabb, rendszerben tartott fegyvere."
??? SA80? Aztán rákerestem és a Wiki-n mit ad ki? L85A1 Ja, így már ismerősebb. Az megint más kérdés, hogy nekem jó ideje (a játékokban) az egyik kedvencem... A valóságban meg akkor tré lenne?
iMaverick
Don't Panic
#91555
A VGA-d is: LINK
Idézet:
AMD Freesync technology
No stuttering. No tearing. Just gaming.AMD FreeSync™ technology allows a compatible graphics card and monitor to dynamically change frame rates for the optimum display quality without tearing or stuay.
Industry-Standard DisplayportFreesync uses industry-standard displayport Adaptive-Sync Eliminates screen tearing without all the usual lag and latency
Synchronizes the refresh rate of a compatible monitor to the frame rate of your content, however much it varies
Monitor partners are validating with drivers from AMD now -
iMaverick
fenergie84
#90383
Szoktak pörögni ezek is.
iMaverick
fenergie84
#90381
Ezzel az akcióval "megveszed" a cuccost, így meg fog maradni.
iMaverick
}{3@Đ$}{0ot
#90127
Wake Island 1. helyen. Finom! Nem véletlenül "vonyítottam" itt a topicban, hogy azt kellett volna a 4-be is megcsinálni...
iMaverick
FollowTheORI
#89761
85 ropi... Azért még eléggé húzós nem?
iMaverick
Részeges karatemester? Amúgy én is szeretek némi célzóvizet kortyolni játék közben. Folyamatosan küzdök a dehidratálódás ellen...
(#87850) kovy29: mindeközben a Gamepod-on... LINK
Bár szerintem április 1 a mutatvány...
Meglepő módon a széria legújabb része kizárólag PC-re jelenik meg, a konzolosok pedig egy Battlefield 1942 felújítást kapnak.
iMaverick
Azért vannak ott még "címek"... Imperial Commando? Ez a Republic Commando folytatása lenne? Fincsi!
Új C&C játék... Pöpec.
A másik kép meg valamiféle 5letelésnek tűnik: milyen témájú legyen a BF5... Mondjuk ettől az Eastern Front-os dologtól nem estem hanyatt, akkor már lehetne European Front, így lehetne össze-vissza varizni a harcoló csapatokat (amik, angolok, oroszok - németek, olaszok), változatosabb helyszínek lehetnének... Stb.
Egyébként felőlem kiadhatnák a BF1943-at PC-re, felújított grafikával.
iMaverick
Bjørgersson
#87460
Mert ment volna még további komment is (ami nem off lett volna), csak közben betámadott egy kolléga itt melóban.
iMaverick
#86135
Hmm. Olvastad mit írtam? Akkor "rávilágítok": dogs not allowed in exceptional cases...
Tehát valami olyas valamire utal, hogy "bizonyos esetekben" nem tűrik a kuttyot. (Gondolom attól tartanak, odaállítasz valami 80 kilós rotival, akkor a többi vendég kijelentkezik... Vagy hogy ha egész nap ugat... Ilyesmi.
Szerintem küldj a kutyáról egy fényképet és valami szöveget, hogy izé-bizé, nyugodt, nem sz@rik a szőnyegre, etc, etc.
(#86139) szunya1: az enyém már leszokott a velem való BF4-ezésről: párszor amikor dühömben szétvertem az egeret, ez a kis hülye ott rettegett az ágyon... Most öregkorára hogy megsüketült, akár a billentyűzetet is szétverhetem, olyan halál nyugodtan alszik, hogy jó ránézni.
(#86204) Csabroncka: végülis volt (talán X-Box-ra?) a BF1943... Azt kiadhatták volna PC-re. Megjegyzem most sem lenne késő. Kicsit felturbóznák a grafikát és jöhetne is.
iMaverick
#86115
Én csak az 5 eurót nem értem... A többin nem vágom, mit nem vágtok? "A kutyák kivételes esetekben nem engedélyezettek." Utána gyakorlatilag azt írja, hogy mennyire állatbarátok. "A Te kutyád engedélyezett."
Mondom, azt az 5 eurót nem tudom hová tenni! ?? Szerintem ennyi pízt kérnek 1 napra a kutya után.
iMaverick
}{3@Đ$}{0ot
#85824
Ezek az eddig elképzelhetetlen felvételek azt mutatják, hogy sok más terület mellett az orosz haditechnika a rakétaelhárításban is egyelőre előrébb tart az amerikai támadóeszközök képességeinél.
Előtte meg írja a TOW-ot... Ami egy a 70-es évek elején kifejlesztett technika. Most hol járunk? 2016? Hmmm. Az oké, hogy a TOW rendszert modernizálgatták, de az alapja akkor is vagy 40 éves...
szerk: hmm. Erre a Stora-1-re meg 1980-at írnak. Mondjuk a lényegi részen akkor sem változtat: egy 1970-es fejlesztésű tankelhárító rakétát meg tud téveszteni egy 1980-as elhárító rendszer...
iMaverick
FollowTheORI
#85235
iMaverick
Bjørgersson
#85216
Gondolom hogy hallott-e valaki valami tuti pletykát... Mármint a megjelenésre, vagy egyáltalán a játék témáját tekintve.
szerk: jah, a vigyorgó fejből gondolhattam volna, hogy amolyan ironikus kérdés volt.
iMaverick
#84992
Mondom rálesek, mi ez a "future tech"?
Azt írják, hogy 1980-ban lépett szolgálatba (annyi idős, mint én). Ahogy nézem, ez gyakorlatilag a BM21-es "katyusa" egy variánsa: a kilőtt rakéták foszforos vagy üzemanyagos (fuel-air) töltetet tartalmaznak és ezek robbannak fel x méterrel a föld fölött. Gondolom az ellen legnagyobb örömére...
szerk: annyit még hozzátennék, hogy a BM21 ugye egy teherautó platóján van telepítve, ez meg a T72-es alvázára... Hmmm, fincsi.
iMaverick
Én is Win10-zel tolom a BF4-et, nincs probléma.
iMaverick
}{3@Đ$}{0ot
#79724
Közben módosult...
WE ARE AWARE OF ACCESS ISSUES TO THE SERVER BROWSER ON BATTLELOG AND ARE WORKING TO RESOLVE THEM AS SOON AS POSSIBLE. We do not currently have a set ETA on when this will be resolved, we will ensure to update you as soon as more information is available. SIC!
(#79719) G4ula84
szerk: Smoke grenades now block FLIR/IRNVEz most komoly??? Akkor már csak az éjjeli Zavod-ra lesznek jók!
iMaverick
kisza25
#78601
Szerintem jól összefoglaltad.
Viszont ez a "nincsenek lehívható segítségek," ez nem teljesen korrekt. Lehívhatod a haverokat a helikopterrel.
Komolyra fordítva: aki Commander-kedik, az "leküldhet" a harcoló csapatoknak ilyen "segítségeket"... UAV, supply, missile strike, stb. -
iMaverick
Franklin
#78556
Azok Commander-nek mennek.
(#78576) }{3@Đ$}{0ot: Így már érthető. Mindenesetre nem tudom megérteni az ilyen kis csicskákat, hogy ha máshogy nem tud játszani, akkor miért nem hagyja az egészet a francba? Ráadásul rögtön bukó van, hisz a paraméterekből látszódik, hogy nem stimmel a dolog.
iMaverick
Bjørgersson
#78367
Te kis kötözködős...
LINKEhhez az "IQ háborúhoz": Chuck Norris elszámolt a végtelenig. Kétszer.
iMaverick
Ez melyik elit csapat lehet? Szerintem ide engem is felvennének!
iMaverick
te biztos az vagy, ha aknára hajtasz, az is baj, MBT LAW, az se tetszik, a shorty is fáj, ha épp nem vagy tankban.
Na én pontosan az ilyen dolgok miatt járok no rules-os szerverre. Tolom az engi-t, távol meglátok egy gyalogkakukkot, mivel lőjem ki? Pisztollyal? Egy frászt! Elő az RPG, oszt had szóljon. Persze ez vica-versa történet: amikor már ötödjére lő ki ugyanaz a kemper noob, akkor is maximum az ALT+F4 marad.
Az egyik favourite szerver "mottója": No rules - War is hell. (Kb. ez is megy fent.)
iMaverick
iMaverick
spanglee001
#77427
Nekem mind a 4 megvan. Sörike jöhet ide is.
(#77423) san01: a többi Phantom-os assigment meg van?
iMaverick
CptAdamica
#77419
Most már utólag annyira nem egyszerű. Annó külön szerverek futottak, amik a dogtag keresésre és a bow unlock-ra voltak kihegyezve.
iMaverick
FollowTheORI
#77133
Azért arra számítottam, hogy nem lesz kemper paradicsom. Erre tegnap este is hol recon lőtt ki, hol meg DMR-rel felszerelt akármilyen kaszt... Persze FLIR és IRN mindenhol...
iMaverick
Új Community mission:
Community Mission: 50 Million Assault Rifle Kills
5 nap van rá. Hmmm.
iMaverick
A "pöccsöt" felraktam, ki-be léptem az Origin-be, de nekem nem adta fel ezt az új "DLC-t"...
iMaverick
Látom a Flashbang-et is kicsipázták kicsit.
Flashbangs
- Effective angle is now 145 degrees
- Flash duration reduced for friendlies to 0.6s
- No longer blinds dead people
- Increased the suppression effect from flashbang explosions
- Reduced number of default flashbangs from 3 to 2Rá is fért...
(#76879) Griff55: night operations expansion? Külön DLC-nek nézi ezeket az éjjeli pályákat? WTF?
(#76881) Zolar: Helyes. Már tele volt a t@k@m ezzel a folyamatos "fehér fénnyel". Szerintem a Locker-en is el van túlozva az effekt, amikor kimész a börtön részből a havas részre. Nagyon sokszor ott is teljesen "kifehéredik" a kép.
iMaverick
FollowTheORI
#76808
17 óra van, mire hazaérek... Ezek szerint nem érint.
iMaverick
kriszpontaz
#76197
A cikket is olvassátok már el! A tankokat idehozzák és váltott amerikai személyzettel lesznek itt. Szerintem nem "adják" nekünk, így nem is kerül pénzbe... Az meg külön haszon, hogy a tatai laktanya egy részét a saját pénzükön felújítják.
iMaverick
Colos1
#75547
Egy kicsit tartottam tőle, hogy a Win10 felrakásnál beleszaladok ugyanebbe, de nálam nem jött elő!
Én úgy csináltam, hogy elkezdettem letölteni az Origin-nel a játékot és a DLC-ket, majd Pause és "rámásoltam" a mentésemet. Utána Continue, kicsit szöszölt, majd közölte, hogy kész. Eddig még nem ugrott fel, hogy nincs feltelepítve valami.
- AI Workstation RTX 3090 24GB / 32-128GB RAM / I5 13400F / 1000W
- Latitude 9430 27% 14" FHD+ IPS i5-1245U 32GB 512GB magyar vbill IR kam gar
- ThinkPad T14 Gen3 27% 14" FHD+ IPS i7-1255U 16GB 512GB NVMe ujjlolv IR kam gar
- AMD Ryzen 7 Gamer! Ryzen 7 5700X / B550 Aorus Elite/RX 6600 XT 8GB OC / 500GB M.2 SSD+HDD /700W/LED
- Ryzen 5 Gamer! Ryzen 5 3400G PRO / 16GB DDR4 / Nvidia GTX 1660 Ti 6GB OC / SSD+HDD / 600W /RGB LED!
- Samsung Galaxy A23 5G 128GB, Kártyafüggetlen, 1 Év Garanciával
- BOMBA ÁRrR! Lenovo ThinkPad T14 Gen 4 Ryzen 5 PRO 7540U 14" FHD+ 32GB 1TB Lenovo gar: 2028.01.07!
- LG 65C5 - 55" OLED evo - 4K 144Hz - 0.1ms - NVIDIA G-Sync - FreeSync - HDMI 2.1 - A9 Gen8 CPU
- S22 Ultra 256/12 Dobozában
- Apple iPhone 12 128GB,Átlagos,Adatkabel,12 hónap garanciával
