--- Még az új vizsgarendszer előtti információk, majd frissítjük! ---
Gyakran ismételt kérdések
Olvasd el a cikkeket itt.
Gery15
router1#debug pppoe packets
PPPoE control packets debugging is on
router1#deb pppoe ev
router1#deb pppoe events
PPPoE protocol events debugging is on
router1#deb pppoe errors
PPPoE protocol errors debugging is onDe most valami csodánál fogva felcsatlakozott.
Viszont nincs net, de kapok dialeren IP-t.Sh ru:
Building configuration...
Current configuration : 2302 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname router1
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$we/w$/F.vf4nAZIgoVICjkPTOM1
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool lan
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip cef
no ip domain lookup
ip domain name teszt.hu
no ipv6 cef
multilink bundle-name authenticated
vpdn enable
username admin privilege 15 secret 5 $1$D8OB$de8tUGK2h/WpDEnPjIZlA/
username user privilege 15 password 0 cisco
archive
log config
hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
description uplink
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet1
description lan
ip address 192.168.1.1 255.255.255.0
ip nat inside
no ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
interface Dialer1
description pppoe
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username password 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list nat interface FastEthernet1 overload
ip access-list standard nat
permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
password cisco
login
line aux 0
line vty 0 4
privilege level 15
password cisco
login local
transport input ssh
line vty 5
privilege level 15
password cisco
login local
transport input ssh
line vty 6 15
privilege level 15
login local
transport input ssh
end -
Gery15
Jelen pillanat ezek vannak be pötyögve.
vpdn enable
description Uplink
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no shinterface Dialer1
description PPPoE
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no shdialer-list 1 protocol ip permit
description LAN
ip nat inside
no ship dhcp pool DHCP
default-router 192.168.1.1ip nat inside source list NAT interface FastEthernet1 overload
ip access-list standard NAT
permit 192.168.1.0 0.0.0.255 -
Gery15
Akkor kínlódtam vele, de nem jött össze. Most neki ültem megint, de továbbra sem megy. Próbáltam több konfigot már, YT videót. Teljes hálózatot másoltam már, és akkor sem. Alapból ott bukik a dolog, hogy hiába állítom, be az általatok vagy mások által leírt dolgokat nem működik. Sh ip int brief parancsra nem kapok Fa0-on IP címet és a 1812-esen a PPP led se világít, mint eddig.
Igazából valami szájbarágós ráérős segítséget kérnék, esetleg aki használna így Cisco routert PPPoe kapcsolattal.
Gery15
Ez mit takar pontosan?
*Jan 31 19:01:08.331: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern et0, changed state to up
*Jan 31 19:01:16.527: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
*Jan 31 19:01:16.535: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t o up
*Jan 31 19:01:16.903: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
*Jan 31 19:01:16.907: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t o downIlletve valakinek működő adsl (pppoe) kapcsolat konfigja nincs esetleg?
Gery15
zsolti.22
#11401
Tehát akkor csak ez kell?
Kliens konfiguráció:
interface FastEthernet0/0
no ip address
ip mtu 1492
duplex auto
speed auto
interface Dialer1
ip address dhcp
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
Gery15
FecoGee
#11399
Ez mind szép és világos, de gondolom ha ezt lemásolom nem fog működni vagy igen?
Nem értem ezt a részt:
ip dhcp pool PPPOE
network 12.0.0.0 255.255.255.0Nem értem ez a hálózat honnan jött? Csak úgy?
Vagy nekem csak a Kliens konfiguráció rész kell?
És azt se értem, hogy felhasználónév, jelszó párost hová teszem?
Gery15
Szóval erről lenne szó.
"Így kellene kinézni majd a hálózatnak. A kérdésem először is az lenne, hogy a 1812-es tudna-e netet a TP-Link nélkül? PPPOE kapcsolatra képes? Nem gond, ha nem, mert akkor a tp-link betárcsáz. Maga a hálózat része működik csak ugyebár nincs internet sehol. Natolással is próbálkoztam, de nem igazán sikerül."
Mint kiderült a 1812-es tud pppoe-t, csak én nem tudom hogyan kell beállítani. Valaki esetleg tudna benne segíteni?
Gery15
Lehetséges ADSL internetemet egy cisco 1812-es routerre továbbítanom?
Gery15
ICND1-es vizsgán mire számíthatok? Mire készüljek, gyúrjak rá jobban?
Gery15
ICND 1-es tananyagot hol találok?
Gery15
Cyber_Bird
#6961
Szerintem én is egyben fogom, vagy nem tudom még.
Én sem azért tanulom, hogy elfelejtsem majd.(#6962) fogi: Átrágom még egypárszor szerintem.
Egyébként, ha ICND 1,2 van akkor ez felér a teljes CCNA-val ugye?
Gery15
Tegnap kaptam meg a második CCNA Discovery oklevelem. Hogy lenne érdemesebb megcsinálni a ICND-t? Most kedvezményesen lehetne ICND1 illetve majd a 3, 4 oklevél után pedig ICND2. Vagy inkább Meg van a 4 oklevelem és úgy CCNA?
- Kérlek használd a keresőt, mielőtt kérdezel!
- Olvasd el a téma összefoglalót mielőtt kérdezel!
- A dumpok és a warez tiltott témának számítanak!
- HIBÁTLAN iPhone 13 Pro 128GB Alpine Green -1 ÉV GARANCIA - Kártyafüggetlen, MS2978
- Apple iPhone 13 Pro 1TB,Újszerű,Dobozával,12 hónap garanciával
- LG 32GS94UX - 32" OLED / UHD 4K / 240Hz - 480Hz & 0.03ms / 1300 Nits / NVIDIA G-Sync / AMD FreeSync
- HP EliteBook 850 G7 (15.6") i7-10610U - Garancia, Akció!
- BESZÁMÍTÁS! MSI B450M R5 5600X 32GB DDR4 512GB SSD RTX 4060 TI 16GB ZALMAN Z1 Plus A-Data 650W
