Keresés
  • Phobos
    he stepping code is a 4 or 5 letter string printed on the CPU either on the core (on Durons , Athlons and Athlons XP with Palomino core) , or on a black label near the core (on the Athlons XP Tbred core or Bartons) . Every stepping indicates a revision/change in the CPU manufacturing process , wich usually has an impact on the overclockability and on the temperature of the CPU .
    Duron Spitfire:
    600-800: AKAA < AKCA < AKBA
    800-950: AKCA < ALCA < AMCA = ANCA < ANDA
    Duron Morgan:
    AHHAA < AHLCA < AHLDA
    9 < Z < Y
    Athlon Thunderbird :
    AXHA = ALUM < AQGA = AGGA = ASHHA < ADFA < AJFA = ARGA < AXIA = BXIA = AVIA = AXIAR < AVHA = BVHA < AYHJA = EYHJA < AYHJAR
    9 < K < Y
    Athlon Palomino:
    AGKFA < AGKGA < ARKGA < AGLHA < AGNGA < AGOGA < AGOIA < AROIA < AROGA
    9 < 4 < K < F < Y
    Athlon Thoroughbred :
    A : AIRCA < AIRDA < AIRGA < RIRGA < RIWGA < RIUGA < AIUGA < AJUGA
    B :
    1600+ : KIUHB < JIUHB
    1700+ and 1800+ : JIUCB < JIUGB < KIUHB < JIUHB
    over 2000+ : AIUAB < AIUCB < AIUGB < AIUHB
    Athlon Barton :
    AIUAA < AQUCA < AQXDA < AQXEA < AQZEA
    Duron Applebred :
    MIUHB < MIXHB
    PROCESSOR CARACTERISTICS
    Palomino - 0.18 microns , model 6 , FSB 266 , cache : 128K Level1 , 256K Level2
    Name Mult X FSB Vcore Power
    1500+ 10.0 X 133 1.75V 53.8W
    1600+ 10.5 X 133 1.75V 56.3W
    1700+ 11.0 X 133 1.75V 57.4W
    1800+ 11.5 X 133 1.75V 59.2W
    1900+ 12.0 X 133 1.75V 60.7W
    2000+ 12.5 X 133 1.75V 62.5W
    2100+ 13.0 X 133 1.75V 64.3W
    Thoroughbred A - 0.13 microns , model 8 CPUID 680 , FSB 266 , cache : 128K Level1 , 256K Level2
    1700+ 11.0 X 133 1.50V 44.9W
    1800+ 11.5 X 133 1.50V 46.3W
    1900+ 12.0 X 133 1.50V 47.7W
    2000+ 12.5 X 133 1.60V 54.7W
    2100+ 13.0 X 133 1.60V 56.4W
    2200+ 13.5 X 133 1.65V 61.7W
    Thoroughbred B - 0.13 microns , model 8 CPUID 681 , FSB 266 , cache : 128K Level1 , 256K Level2
    1600+ 10.5 X 133 1.60V 48.5W
    2100+ 13.0 X 133 1.60V 55.9W
    2200+ 13.5 X 133 1.60V 57.0W
    2400+ 15.0 X 133 1.65V 62.0W
    2600+ 16.0 X 133 1.65V 64.0W
    Thoroughbred B - 0.13 microns , model 8 CPUID 681 , FSB 333 , cache : 128K Level1 , 256K Level2
    2600+ 12.5 X 166 1.65V 64.0W
    2700+ 13.0 X 166 1.65V 64.0W
    Barton - 0.13 microns , model 10 , FSB 333 , cache : 128K Level1 , 512K Level2
    2500+ 11.0 X 166 1.65V 53.7W
    2800+ 12.5 X 166 1.65V 55.9W
    3000+ 13.0 X 166 1.65V 58.4W
    Barton - 0.13 microns , model 10 , FSB 400 , cache : 128K Level1 , 512K Level2
    3200+ 11.0 X 200 1.65V 58.4W
    Applebred - 0.13microns , model 8 , FSB266 , cache : 128K level1 , 64K Level2
    1400 10.5 X 133 1.50V 00.0W
    1600 12.0 X 133 1.50V 00.0W
    1800 13.5 X 133 1.50V 00.0W
    UNLOCKING
    The Duron , Athlon Thunderbird , Athlon XP Palomino processors have the multiplier locked from the factory , and to unlock it you must connect the L1 bridges . It will unlock all the multipliers in the 5X-12.5X range , except for the XP2100+ and XP2200+ with Palomino core , wich will have the 13X-18.5X range available . On any CPU you can toggle between the multiplier ranges (5-12.5X to 13X-18.5X) by changing the connection of the L10 bridges (cut one and connect the other) .
    The Athlon XP Thoroughbred core and Barton processors have the multiplier unlocked from the factory , so any motherboard that has the option for multiplier setting cand adjust it . The processors under 2000+ have the 5X-12.5X range available , and the 2100+ and higher have the 13X-18.5X range available . The exceptions are XP2600+ / 333FSB and Barton 2500+ , wich have the 5X-12.5X range available . To toggle between ranges , you need to connect/cut the rightmost L3 bridge .
