Hi!
Na lefuttattam egy darabig, még haza nem értem kb 2 órát ment és ezt kaptam...
Type: Blend - stress CPU and RAM Min: 8 Max: 4096 InPlace: No Mem: 767 Time: 15
CPU: 2750MHz FSB: 250MHz [250MHz x 11.0 est.]
2006.05.05. 12:16 Beginning a continuous self-test to check your computer.
Press Stop to end this test.
Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
Test 4, 4000 Lucas-Lehmer iterations of M19174369 using 1024K FFT length.
Test 5, 4000 Lucas-Lehmer iterations of M18874369 using 1024K FFT length.
Self-test 1024K passed!
Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
Test 2, 800000 Lucas-Lehmer iterations of M163839 using 8K FFT length.
Test 3, 800000 Lucas-Lehmer iterations of M159745 using 8K FFT length.
Test 4, 800000 Lucas-Lehmer iterations of M157695 using 8K FFT length.
Test 5, 800000 Lucas-Lehmer iterations of M155649 using 8K FFT length.
Self-test 8K passed!
Test 1, 560000 Lucas-Lehmer iterations of M212991 using 10K FFT length.
Test 2, 560000 Lucas-Lehmer iterations of M210415 using 10K FFT length.
Test 3, 560000 Lucas-Lehmer iterations of M208897 using 10K FFT length.
Test 4, 560000 Lucas-Lehmer iterations of M204799 using 10K FFT length.
Test 5, 560000 Lucas-Lehmer iterations of M200705 using 10K FFT length.
Test 6, 560000 Lucas-Lehmer iterations of M196607 using 10K FFT length.
Self-test 10K passed!
Test 1, 4500 Lucas-Lehmer iterations of M17432577 using 896K FFT length.
Test 2, 4500 Lucas-Lehmer iterations of M17432575 using 896K FFT length.
Test 3, 4500 Lucas-Lehmer iterations of M17115073 using 896K FFT length.
Test 4, 4500 Lucas-Lehmer iterations of M16815071 using 896K FFT length.
Test 5, 4500 Lucas-Lehmer iterations of M16515073 using 896K FFT length.
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 1 hours, 2 minutes 47 seconds - 1 errors, 0 warnings.
Execution halted.
Ilyenkor mi a teendő, ez mire utal?
250fsb, 400-as ramok 500-on, 4x HT ennyin megy ... -
Srácok még annyit mondjatok, ha memtestem lement gond nélkül, akkro ugye a memóriát teljesen kizárhatom a sorból?
#1212
thx a gyors reakciót, na most ez a dolog már megtörtént 2,5-3-3-6-ról feltettem 3-3-3-6 ra és lefuttattam vele egy memtest-et is, ami 3 órán keresztül ment és nem volt ERROR, azért nem értem akkor mit parázik ez a kis fos a game...
Elképzelhető ennek ellenére még nagyobb időzítéssel kéne próbálkoznom, ha igen pl: mekkorával ???
[Szerkesztve] -
Jah a kis tuninghoz még annyit hozzátennék, eléggé elszomorit, hogy a konfigom szinkronban a ramokkal húzva, mindössze 250fsb bír
azaz 2750mhz-et
Vannak itt a PH-án szép számban, akik ugyanezt a procit 3Ghz-en járatják, gond nélkül...
Nekem 2800mhz felett már fagy, és nem nagyon tudok vele mit kezdeni
Hi tuningbajnokok!
Lenne 1 kérdésem.
Adott a konfigom, kis túlhajtással, mindössze 25%-al.
Memtest, CPU test lement, minden OK, viszont ha pl: a W3-al gamlélok időnként lefagyok
Vagy kapok gey ilyen hiba üzit
Egyszerüen nem tudom felfogni, hogy egy ilyen kis semmi tuning ekkora galibát okoz..
Ha valakinek van valami érdemleges 5lete please ossza meg velem...
A Win-em is friss , most volt pár napja telepítve.
Thx! -
Motion_Blur
#1125
- Riasztó topik
- Villanyszerelés
- Fotók, videók mobillal
- iPhone 13 mini 128GB 100%(1év Garancia) - AKCIÓ
- 5G Lenovo ThinkPad P14s Gen 3 Intel Core i7-1280P Nvidia T550 32GB 1000GB 1 év teljeskörű garancia
- KERESEK: Poly Voyager 4320 M UC USB-C 218478-02M Part number: 77Z30AA
- iKing.hu Apple iPhone 14 Pro Deep Purple 128GB használt megkímélt 100% akku 6 hónap garancia
