X-E5 tulajdonosok olvassák el: [link]
trex4d
Ha ez igaz...
RUMOR: New Firmware with Improved AutoFocus for X-T1 coming in May (New Source)!
trex4d
X-T1, X100T és OIS obi firmware update-ek!
X-T1 FIRMWARE
X-T1 firmware update: 1. Improvement of the flash function when “MECHANICAL+ELECTRONIC” is selected. An external non-TTL flash will fire when the “MECHANICAL+ELECTRONIC” is selected in the “SHUTTER TYPE” option of the SHOOTING MENU. If “S (Shutter-Priority)” or “M (Manual Exposure)” mode is selected, set the shutter speed to 1/180 sec. or slower. 2. Improvement of the Wi-Fi function when “FUJIFILM PC AutoSave” is used. The phenomenon is fixed that Wi-Fi communication with “FUJIFILM PC AutoSave” stops at the moment the LCD turns off 3. Improvement of the display for the “USB MODE” in the SET-UP menu
1) When “PC SHOOT FIXED” is selected, the warning of “IMAGES ARE NOT SAVED IN THE CARD” appears [screenshot]. 2) In case that “PC SHOOT FIXED” is selected in the “USB MODE” and the camera is not connected to a PC via a USB cable, you cannot turn off the camera when you turn the ON/OFF switch to the OFF positon or remove the lens from the camera becasue the camera stays in the waiting mode for image transfer. With this upgrade, the message below will appear to confirm whether you stop the image transfer to the PC or not in such operations. If you press “OK” button, the camera will turn off without recording images.X100T FIRMWARE
X100T firmware update: 1. Addition of the messages when “COVERSION LENS” setting is changed in the FUNCTION (Fn) SETTING. When an Fn button with “CONVERSION LENS” setting is pressed, one of the messages below appears in a cyclic manner in addition to the icons. 2. Improvement of flash function when “MECHANICAL+ELECTRONIC” is selected. An external flash will fire when the “MECHANICAL+ELECTRONIC” is selected in the “SHUTTER TYPE” option of the shooting menu. 3. Improvement of the viewfinder display. When the dual optical viewfinder/electronic range finder (ERF) display is used with the Digital Split Image, the white Focus frame appears in the center of the viewfinder. 4. Improvement of Focus Peaking display in the electronic viewfinder under a dark environment for easy focus setting.
IMPROVED OIS
Also, the OIS has been improved for the following lenses (download link): XF 10-24, XF 18-55, XF 18-135 and XF 55-200.
trex4d
Nem tudom volt e már, de Artwork bemutató és Fuji 10%-os akcióhét közeleg:
Most kellene venni 50-140-et?
trex4d
Scharm1976
#7550
Gratulálok!
Én most egyelőre megálltam az 50-140 vásárlást, de a 90 f/2 megjelenéstől már most tartok, nehogy elrabolja a szívemet!
trex4d
Ez? Ő?!
Nocturnus F0.95, 35mm?
trex4d
MC Pite
#7409
Igen, éreztem hogy nem sikerült "átadnom", jogos
Itthon használtam a 600exRt-t egy softbox-ban boudoir és aktfotók világításához. Teljesítményben közel sem használtam ki, mivel ez alapból túl erős volt ilyen célra. A softbox-on belül 2 rendszervakunak van hely. Mivel nem vagyok nagy rajongója az ilyen yonguo és társainak, ezért reménykedtem, hogy ugyanezt a feladatot ellátná egy Fuji is. Tehát távvezérléssel szeretném kihasználni a korlátozott lehetőségeket, amit a rendszervaku nyújt. Gondolkoztam egy stúdiólámpán is, de így a rendszerváltás után( Canonról-Fujira ) már azt sem tudom egyáltalán mivel kompatibilis egy Fuji...
Köszönöm, utánanézek a Meike-nek. -
trex4d
Nekem vakus kérdésem lenne (XT-1-hez) ...van a Fuji vaku, amiről nem sok jót olvasok, meg van a Nissin...
Ha pár napon belül vennék egy vakut ( most Canon 600exRT van, amit elvisznek - Yonguo vezérlővel használom ), akkor mit vegyek? Várjam meg az új Nissint ( valaki mintha linkelte volna nemrég ), vagy tudni valami új Fujiról / régihez új Fw? Köszönöm! -
trex4d
Egy kis fashion Fujival:
"For me, C1Pro8 is the obvious choice if you want the best out of your Fujifilm rawfiles. And I’m not talking about pixel peeping! Bit why waste time choosing a good camera, quality lenses, a cool location with great light, and then use software that just isn’t the best?! Just sayin’….."
trex4d
trex4d
Hihetetlen hogy mennyivel gyorsabb pl. a CaptureOne curve-editálása ( vagy a vsco-k miatt lassult be a LR, vagy más preview-megoldással dolgoznak, de a C1 mint kés a vajban ) Nálam LR-ban irgalmatlan lassúnak tűnik minden curve-állítás.
Ez a Silkypix meg...ahogy rendereli minden apró változtatásnál a fotót, elalszom.Olyan mint egy beta release.
Egyébként mintha úgy rémlene, hogy magyar ember is dolgozik annál a cégnél. Régebben láttam egy videóban, be is mutatkozott. Majd megkeresem. -
trex4d
Egyelőre hatalmas csalódás ez a program (ismét). Anno a Nikon verziója ( mert ők is ezt az utat választották - Capture NX-D néven - [link] ) a beta alatt a lassúsága ellenére hihetetlen minőséget produkált - Nikon Df RAW-t teszteltem vele - majd amikor kijött a végleges, akkor megdöbbentem, mert eltűnt az a "húúbazz"-érzés, megmaradt viszont az ócska és lassú kezelőfelület.
Tény, hogy a Lightroom szerintem színtelítettségben és még jópár dologban elmarad pl. a CaptureOne-tól, de az az igazság, hogy még mindig a LR-ban a leggyorsabb dolgozni.
Igen, ez a Silkypix tényleg egy időutazás...csak nem a jó irányba
trex4d
A fujirumors beta-tesztje az új konverterről - csak így szépen, magyarosan!
trex4d
Azért azok a kis "bütykök" jól jönnének! Valaki találkozott már hasonló megoldással?
Ezek szerint tényleg van "újabb verziójú" d-pad.
(nem tudom volt e már ez a téma, a kereső nem adott eredményt ezzel kapcsolatban) -
trex4d
50-140 review:
trex4d
Pár perce megérkezett a portrémarkolat ( VG-XT1 ), annyira jó a fogása, hogy nincs is kedvem több horizontális képet készíteni
( igazából csak a plusz akksi miatt vettem, hogy hosszabb ideig ne kelljen vele foglalkozni - persze 700 kép sem sok egy rendezvényen
A menü okosan már 2 akksit rajzol ki, majd elolvasom hogyan kezeli őket...
trex4d
De jó fotók mindenkitől!!!
Gratulálok!!!!
trex4d
trex4d
Mr.Zazi
#6875
Nem nehéz, MS+ES és egy kapkodós kis "utcai hancúr", máris hajlani fog a tér...főleg ha sorozatot lő az ember!
Egyébként tényleg érdekelne a technikai oka-megfejtése ennek a típusú képnek.
Jobb lenne sem elsőnek, sem utolsónak lenni "léghajlításban", remélem kiderül milyen user-hibával érem el, és elhagyom ezt a trükköt
trex4d
silmatauki
#6865
Igen, korrigáltam. FF alacsony ISO-ra gondoltam, a "tükrös" egy rossz megközelítés volt a részemről.
A zajt pont dícsértem magas ISO-n! "LowLight képzaj csinos, abszolút tolerálható!!"
trex4d
Senkit nem akartam kiakasztani, csak azt mondom, amit látok
Igen, FF-re gondoltam! Nekem eddig csak FF tükrösöm volt, nem volt más összehasonlítás.
Ettől még nagyon jó a gép!
trex4d
XT1 tapasztalatok 2 nap után, röviden:
Képminőség kiváló, iránygombok viccnek inkább (pff) - pedig én is fókuszpontot szeretnék állítani velük, de nem egy felhasználóbarát megoldás - apropó! Több helyen olvasom, hogy Angliában cserélgetik ki ingyen a felhasználóknak a hivatalos szervízben? És állítólag nem csak városi legenda. Mivel sokakat zavar a béna kivitelezés.
ElectronicShutter hihetetlenül jó nappali fényben tág rekesszel lövöldözésre. Viszont óvatosan kell használni, eddig 2-3 alkalommal sikerült meghajlítanom ES-el a teret...elég egy gyors mozdulat exponálás közben és mindenki túlzottan hajlékony lesz
Alacsony ISO-n meg megszokható a kis "szemcsézettség", gondolom nem lesz soha tükrös minőség.
Elsőre ennyi. -
trex4d
Scharm1976
#6786
Jah, neten rendeltem. Nem személyesen vettem ott.
trex4d
Scharm1976
#6786
Nem vittem vissza az 56-ost, még meghallgatom másnál is a fókuszhangját mielőtt visszavinném-a képével semmi gond! Lehet hogy csak nekem hangos a Canon obik után. Viszont a visszavitellel meg elekezdődik a szokásos kálvária, hogy miután én beviszem - ők megállapítják hogy hibás e - utána visszaküldik a Fujinak, akik majd lecserélik, amikor egyáltalán kapnak kintről cseredarabot.... Pedig felajánlottam, hogy én személyesen elviszem a Fujihoz, ahol azt hittem legalább van egy másik 56-os, amivel össze lehet hasonlítani, hogy ne kelljen a boltban saccolni...de persze ilyen lehetőség nincs. Ennyi
trex4d
Scharm1976
#6780
De, én vagyok!
Te is venni szeretnél?
Erre írtam, hogy a Fuji szerintem jobbat érdemelne ennél, hogy egy ilyen sikeres gépet nem lehet kapni, ráadásul a tartozékokat is vadászni kell...és megy a csodálkozás, amikor kintről rendelnek az emberek dolgokat. A forgalmazó meg a képviseletre mutogat, jogosan.
Én csak a magyar garancia miatt vettem itthon...remélem soha nem kell rájönnöm hogy volt e értelme ezért itthon venni.
Ami zavar még, hogy folyamatosan bemutató darabokat adnak el. Tehát a boltban csak 1 darab van, amit kibontanak, mindenkinek azt mutatják, aztán eladják
Ez is bontott volt ( nem csak a doboz a papírok miatt, hanem a gép sem volt már az eredeti csomagolásban. A kijelző is ujjlenyomatos volt ). Gőzöm sincs "mennyit ment"
A Fuji Magyarországnak meg nagyon oda kellene figyelni a megfelelő készletmennyiségre! -
trex4d
"NépKit" lesz
Szerintem majd akkor vedd meg (olcsóbban), amikor bejelentik az új Pro-t! Akkor eladom!
Egyébként még mindig nem értem, hogy a magyar Fuji képviselet miért nem promózza jobban ezt a sorozatot, ami egyébként nemzetközileg is elismert lett ( a raktárkészletükről nem is beszélve...)
Többet és jobbat érdemel a Fuji! -
trex4d
Én is friss tulajdonosa vagyok tegnap óta egy fekete XT1-nek. Lassan ugyan, de kezdem ki-megismerni.
A képminősége előtt le a kalappal! 56 1.2-vel vettem, még pár dologgal kiegészíteném...de most szembesültem vele, hogy itthon milyen nehéz bármit beszerezni
Ha valaki pl. megválna a VG-XT1 markolatától, jelezze!
A továbbiakban itt figyelek-tanulok a Fuji tulajdonosoktól
( ha úgy alakul hogy megszeretem, akkor eladom a 6D-met )
- Elemlámpa, zseblámpa
- Geri Bátyó: Agglegénykonyha különkiadás 2 – Kajás poénok
- Hálózati / IP kamera
- Garmin Venu 4 - a nagy ugrás
- Okos Otthon / Smart Home
- World of Tanks - MMO
- Videó stream letöltése
- Deezer
- AKCIÓ! Apple Studio Display 27 5K Nanotexturált üveg monitor garanciával hibátlan működéssel
- iPhone 13 mini 128GB Green -1 ÉV GARANCIA - Kártyafüggetlen, MS4052, 94% Akkumulátor
- GYÖNYÖRŰ iPhone 13 Pro Max 128GB Silver -1 ÉV GARANCIA - Kártyafüggetlen, MS4160
- Lenovo ThinkPad T14s Gen 3 i5-1245U 14" FHD+ 16GB 512GB 1 év teljeskörű garancia
Azért ebből a 16-23-35 hármasból egyet csak "ki kellene ejteni"...node van ezek között egyáltalán gyenge láncszem?
Egyelőre közülük csak 35-ösöm van...eddig olcsón megúsztam
hemaka
