Thom!
P10P 730MB
Audio
Fix for a delay in displaying the speaker icon when adjusting audio settings*[1]
Fix for issue occasionally causing audio crashes*[1]Camera
Fix for an issue that caused the camera service to crash, improving overall camera stability*[2]Display & Graphics
Fix for an issue causing system crashes and impacting overall Android stability*[2]
Fix for device screen freezing that occasionally renders the phone unusable*[3]
Fix for issues causing occasional fuzzy or incorrect display behavior*[3]
Fix for the issue where the background blur briefly disappeared in the All Apps screen during search*[1]
Improvement for Pixel 10 GPU performance by optimizing the OpenCL driver to reduce overhead and increase benchmark scores*[3]Framework
Fix for an issue that could cause the UI to freeze in certain conditions*[2]
Fix for an issue that could cause a temporary freeze or unresponsiveness related to background processing of Android intelligence features*[1]
Fix for an issue that could cause the device to crash when certain services start up*[1]
Fix for issues where the device incorrectly reported battery status (e.g., abnormal temperature or missing battery), particularly when using a wireless charger*[3]Telephony
Fix for unexpected device instability that could cause temporary loss of cellular service*[2]
General improvements for network connection stability and performance in certain conditions*[2]User Interface
Fix for an issue that could cause an application to get stuck after quickly using recent apps and navigating home*[2]
Fix for the delay experienced when opening the audio output selector after playing music in the background*[1] -
Thom!
Don't Panic
#11685
Természetesen azért írom mert nálam jelentkezik.
Főleg appbol kilépve főképernyőre lépve. Ne legyünk naivak! [link] -
Thom!
10Pro szépen laggol januári frissítés óta..
Thom!
A másik dolog. Szerintem a Pixel 4 színhelyesebb mint 10Pro.
Sajnos nekem kicsit túlszaturáltnak tűnik a 10Pro vagy a kijelző mutatja színesebbnek mint a valóság. -
Thom!
Rengeteg micro-laggot tapasztalatok P10Pro-n.
Decemberi nagy update szerintem a simaságon csiszolt most kicsit se rossz de Chrome is a rendszer is szeret laggolni nem vészes de Samsung volt anno hasonló.
Baromira rontja a felhasználói élményt.
Thom!
OTP
Google Wallet kártyaregiszitráció nem műkődik -
Thom!
Tudtok mondani 9Pro képernyőidőt?
Thom!
9pro olyan szinten merül mint az istennyila.
Thom!
tomboy0013
#10309
OTP kártyával nem megy
Wise kártyával nem megyPixel 9Pro tökéletesen vitte, Pixel 4 itt van mellettem tökéletesen megy.
Újra tettem már a telót mindent kipróbáltam más telefonnal megy. 2 kártyával nem megy nem a kártya a hiba... -
Thom!
NFC fizetés nem megy nem tudom továbbra sem regisztrálni a kártyákat.
Thom!
Google Wallet nem tudom a bankkártyát hozzádani van 2db is. Pixel 10 Pro
Pixel 4 tökéletesen megy. Az érintéses fizetés nem megy a gyári appal, simple-el megy.
Teljes rendszervisszaállítás mindet is kipróbáltam, wallet app újratelepítés, bankkártyák törlése... -
Thom!
Jövő héten jön valószínűleg novemberi update szokásosan legkésőbb szerdáig.
Thom!
A főkamera 50MP szinte úgyanolyan gyors volt mint 12MP módban, majdnem ZSL.
5x 50MP nem volt eltérés ZSL ügyben.
Ellenben 10Pro 12MP 2* módja szerintem megdöbbentően jó lett rossz fényviszonyok között. Itt a 9Pro elvérzik. De 50MP 2* módban nem igazán láttam különbséget a kettő között. -
Thom!
Nekem volt/van P9Pro/P10/P10Pro.
Szinte mindent tudok róluk.
Ár/ értékben P9Pro a legjobb ha jó áron tudsz hozzájutni.P10Pro nagyon jó lett szerintem.
Pont ott fejlődött a kamera ahol kellett. -
Thom!
10Pro nem kapta meg a legújabb 10.1 kamera alkalmazást.
9Pro pedig igen.
Play áruház mindkettő szeptemberi. -
Thom!
Pixel 9 és 10 Pro 2x zoom
- sokat használom és van javulás
Thom!
Pixel 9Pro és 10Pro
10-es széria
-jobb HDR
-low-light jobb főleg 2* zooomnál (és jobb színkezelés főleg mesterséges lámpafénynél)
- főkamera 50MP mód sokkal gyorsabb shutter lag! majdnem mint 12MP autó módban
-jobb porté mód (sose érdekelt a kamu bokéh)Az esetek 90% kb egál a kettő képminőség.
Thom!
Pixel kamera cache törlése, vagy toroljetek az alkalmazást.
Play áruház frissítés. Utána jó lesz -
Thom!
Valahogy megjött P10-re is.
Töröltem a gyorsítótárat és cache-t. -
Thom!
Pixel kamera 10.1 valaki már megkapta?
Thom!
manokaki
#9379
S25 nem rossz fotóban szerintem, S25U jobb nem sokkal, de jobb, kar hogy kompakt méretben nincs.
A méret, a súly ês OneUI szerintem hibátlan.
Stock Androiddal sincs semmi bajom sőt. OneUI 8 már minden tekintetben baromi jó.
Videóban jobb Samsung, a zoom is nagyon jó Samsungnál szerintem. VideoBoost megint más tészta a Pixel reszéről.Hibát lehet mindenben találni.
Thom!
10.0.081.803700610.37
Pixel kamera legfrissebbNekem eggyel régebbi van.
Thom!
Semmi baj.
Sokkal gyengébb üzemidő. -
Thom!
[link] pixel 10 pro mélyteszt
Vannak bajok
Thom!
Jött 116MB Pixel kamera frissítés ez már második Pixel 10hez.
Pixel 8 még 9.9 verziónál tart. -
Thom!
P10 az embereket 1x, 2x módban vörös szint ad a bőrtónusnak .. és low-lightban is vörös eltolódás figyelhető meg ami nem tetszik, de nem mindig.
Thom!
P10 nincs makrófókusz.
Háttermosás a kisebb szenzor miatt gyengébb P8 képest.
Low-light jobb is meg nem a P10. 2x zoomnàl kevesebb fénynél főleg ha ember akarsz fotózni gyengébb lehet az eredmény. 1x mód elég jó a legtöbb esetben.
Mesterséges lámpafény fehér egyensúly probléma még mindig fennáll.
10x hibrid zoom kapcsoló nincs csak ha te odáig görgeted.
Kamera app gyors, lencse változtatás elég jó, de még mindig nem iPhone szint. -
Thom!
Az új tárcsázó egy katasztrófa. Látom más is panaszkodik..
Lássuúcska, akad és hányadék a kinézete -
Thom!
Btel 0 garancia 2 szoptam be, mindkét pixel telefon a kukába landolt.
Soha nem vennék sufni gsm telót -
Thom!
tomboy0013
#8375
Értelek.
De az ár nő a minőség stagnál/csökken.Jövő hét végén megnézem P8 vs. P10 mekkora fejlődés.
Thom!
P10 pár korai teszt alapján:
GPU elmarad a várakozastól rosszabb mint a 9Pro, CPU hozza minimális kötelezőt
Kamera app lassú, akadozik?! GPU driver gond lehet
-Engem a kamerák közötti lencseváltás érdekel leginkább
ProRes Zoom 30* fölött bizonytalan, tele műtermékkel
= 5x, 10x legyen jobb mint 9Pro esetén a többi nem igazán számítA kamerát nagyon dícsérik alapvetően. A színek, expozíció, talán fehéregyensúly, 3 kamera képe konzisztens, portré sokat javult
- de 50MP portré hibázik néha -
Thom!
Egy dologra vagyok kíváncsi.
P10 és P10P 20* zoomig mennyire tartja a lépést bármilyen helyzetben? -
Thom!
P10 kamera ízelítő -
Thom!
80e és 100e bónusz bármilyen telefonra érvényes csak működő legyen?
Thom!
A Google Pixel 10 nem lesz gőzkamrával felszerelve, mint a Pro modellek.
A hagyományos Pixel 10 128 GB-os és Pixel 10 Pro 128 GB-os változatai továbbra is támogatják a régebbi UFS 3.1 típusú tárhelyet. Azonban az összes új, 256 GB-os vagy nagyobb tárhellyel rendelkező Pixel 10 telefon támogatja az UFS 4.0 tárhelyet.Igazából apró dolgok ezek, de 500e alatt nem kapsz UFS 4.0 tárhelyet.
Thom!
P10 fényes hátlap 390e
P10Pro keret szintén fényes
Ezen van még mit javítani tudom sok embernél nem számít.
Hasra nem estem eddig max az árától.
Thom!
Én valós tesztekre leszek kíváncsi. Mai keynote annyira nem fog érdekelni mindent tudunk valószínűleg.
De tegyük mellé i17Pro és Maxot is.A sima 10 369e 10Pro 449e lesz szerintem ami nevetséges de ez van.
Thom!
Samsung S26Pro nézd meg 6.3 collban 50g könnyebb lesz és min. 1.5mm vékonyabb és utána beszélgessünk kicsit a méretről és használhatóságról, S24/25 ebben is nagyon jó...
Samsung a kamerát cseszi el mindig, de ez se igaz..
-Expertrawban 0 különbség van a sima S25 és S25U között mert volt mindkettő. -
Thom!
Thom!
Én kivàrok. P10
1-2 hónapot biztosan.Nem várok a telefontól semmi egetrengető dolgot, még a kötelezőt sem, lehet el fogom hagyni a Pixel vonalat.
Ez a mostani iphone design szapulás unalmas nagyon. Ha csökkentenék a súlyt és a vastagságot akkor az ergonómia hatalmas mértékben javul, fogd a kezedbe az s25-öt és rájössz akár a sima akár az ultra az Edge nem is beszélve.
Thom!
i17pro lehet hogy folyamatos optikai zoomos kamerát kap, hasonló mint Sony telókban. Nem szenzorkivágásos lenne vagyis de
Google, Samsung, Kína telók mehet a lecsóba... -
Thom!
Pixel 10 utolsó esélyt adok Tensor ide vagy oda...
A16 új felülete nem hoz lázba, OneUI szerintem sokkal következetesebb, jobb.Samsungnál is van mit javítani természetesen
Thom!
ghiottone
#8069
Pixel 6-7-8 már megéri váltani...
S22,23,24 is lehet jó alternatíva viszont itt méretben és súlyban a Samsung a nyerő...Én sokat nem várok a P10től. AI fog szólni ami engem nem igazán érdekel.
Remélem a kamera fog fejlődni mert 4-5 éve álló víz a kamera képfeldolgozása, sőt számomra P4, P5 az etalon. -
Thom!
Ergonómia:
6.3coll
P10pro
152.8 x 72 x 8.7mm=207g6.2coll
S25
146.9 x 70.5 x 7.2mm=162g6.3coll
S26Pro
>150 x 71.5 x 6.x mm= ~160g vagy kevesebbKisebb ház, közel 2mm vékonyabb!!!, közel 50g kevesebb!!
Google ébresztő mindig lemaradsz, AI az emberek fülén jön ki!👿
Thom!
P10 egy bajom van sem nem lett könnyebb, mert a súlya nőtt és a vastagság se csökkent konlrétan nőtt...
P8 sokkal jobb volt kézben tartani mint a P9Prót minden tekintetben, a súly a fogás köröket vert a Pixel9-re és itt nincs javulás legalább erre a Samsung odafigyel! -
Thom!
A16 nem fog debütálni Material 3 Expressive első körben.
Szerintem P10re tartogatják. -
Thom!
grizlisandor
#6526
valószínűleg jövő hónap közepe rosszabb esetben vége A16 jön!
- Pedzegeti az új Xbox irányát a Microsoft
- Projektor topic
- Automata kávégépek
- AI, GitHub Copilot, Claude, Gemini
- Facebook és Messenger
- EA Sports WRC '23
- iPhone 14 Pro 128GB gyári független új akku!
- Makulátlan Samsung S24 Ultra 512Gb !!! Garanciával + sok kiegészítővel !!!
- Eladó iPhone 14 Pro Max Deep Purple 256 GB
- Apple iPhone 13 Pro Max 128GB 100% Akku Újszerű,Kártyafüggetlen,Tartozékaival. 1 Év Garanciával!
- Apple iPhone 13 Pro Max 128GB 98% Akku Újszerú,Kártyafüggetlen,Dobozos,Tartozékaival. 1 Év Gari!
- Új könyv: Harrari: Sapiens Rajzolt történelem
- HIBÁTLAN iPhone 15 Plus 128GB Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS4504
- Lenovo IdeaPad Slim 3 Ryzen 7 8840HS 15" FHD+ 24GB 1000GB Teljeskörű garancia
- GYÖNYÖRŰ iPhone 13 mini 128GB Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS4062
