westlake
westlake
- Fixed Windows 10 detection
- Fixed CUDA detection in Windows 10
- Added GPU voltage monitoring for AMD Fiji
- Added memory controller load monitoring for AMD Sea Islands, Volcanic Islands, Pirate Islands
- Board Id moved into BIOS version tooltip
- Validation Id now displayed in GPU-Z window title
- Revision Id of recent AMD GPUs will now be displayed
- Added support for NVIDIA GeForce GTX 970M & 980M (GM204-B), GeForce 940M, 930M
- Added support for Intel Atom x7-Z8700, Celeron N3150
- Added support for AMD R9 370, R9 370X, R9 380, R9 390, R9 390X, R9 Fury, A8-7100 -
westlake
- Added PowerColor Radeon Fury X Giveaway
- Added full AMD Radeon Fury X support
- Added support for AMD R7 360
- Added support for Broadwell GT3e
- Added high-quality DPI aware vendor logos
- Whitespace cleanup in Intel VGA BIOS strings
- Fixed UEFI checkbox color on ASUS ROG
- Fixed UEFI checkbox displayed as checked when unknown -
westlake
- Added VGA BIOS UEFI support indicator
- Added support for NVIDIA GTX 980 Ti, GTX 965M, GTX 950M, NVS315, GT 750 (GK106)
- Added support for AMD Fiji, Radeon R2/R3 Graphics (Mullins APU)
- Added support for various Intel Broadwell SKUs
- Fixed missing NVIDIA PerfCap sensor in some cases
- Added support for HBM memory
- Fixed GT200B die size
- Fixed some NV42 specs
- Improved OpenCl detection code -
westlake
- GPU-Z window can be resized while sensor tab is active.
- Fixed incorrect readings on GeForce Tesla cards.
- Added support for AMD Radeon R9 295X2, R9 M275, HD 7500G, FirePro W9000.
- Added support for NVIDIA GeForce Titan Z, GTX 745, GTX 880M, 870M, 860M, 850M, 775M, NVS 510.
- Fixed release date for GTX Titan Black, GTX 780 Ti. -
westlake
- Added graphics memory vendor detection.
- Updated integrated NVFlash for BIOS readings.
- Improved voltage monitoring support for GTX 780 Ti.
- Added support for new Intel Iris 5200 variant.
- Added support for AMD Radeon R7 M265, R5 M230, Kaveri A10-7850K, A10-770K, AMD FireStream 9350, HD 8530M, HD 8650D.
- Added support for NVIDIA GTX Titan Black, GTX 750 (GM107), GTX 750 Ti (GM107), GeForce 840M (GM108), GTX 760 (192-bit), GT 750M (Apple), GT 735M, GT 720M. -
westlake
Ha már van ennek a jó kis programnak topikja.
0.7.5
Fixed crash/hang on NVIDIA Optimus
Fixed crash during CUDA detection
Added voltage monitoring support for new Bonaire/Pitcairn SKUs
Fixed BIOS reading on AMD Mars and Oland
Added support for AMD Radeon R7 260, HD 7600A, HD 8850M, HD 8400, HD 8240, HD 7620G
Added support for NVIDIA GeForce 705A, GTX 645, GTX 650 OEM, Grid K260Q, Quadro K5100M, K6000
Added support for Intel GMA (Bay Trail), HD 4200
Windows 8.1 will now be detected properly
Sensor data in shared memory will now update once per second, as intendedCsak nekem furcsa, hogy akkor is x16 v3.0-át ír aktuális működésre, mikor csak i7-3940K CPU-m van?
westlake
* Added support for RV740 (HD 4750, HD 4770) and RV790 (HD 4890)
* Fixed G98 shader count
* Fixed GT200 process size calculation
* Added support for GTX 275[ Módosította: Thrawn ]
westlake
* Fixed crash on systems without NVAPI (Win 2K, old NV drivers)
* Optimized RV770 BIOS reading code for speed (faster application startup)
* Improved voltage reading code for recent ATI cards
* Added support for fan speed monitoring on ForceWare 180.xx and up
* Added voltage monitoring for NVIDIA (GT200)
* Changed reading method for RV770 sensors, fixes race conditions with other software and on-board fan control
* NVIDIA 9800 GTX+ listed as 55nm now
* Added support for Intel Q43/Q45
* Added support for NVIDIA Quadro FX 4700 X2, GTX 295, GTX 285
* Added preliminary support for NVIDIA GT212, GT214, GT215, GT216, GT218[ Módosította: Thrawn ]
westlake
Added logging of sensor data to file
Added option to disable polling for individual sensors
Added support for AMD RV730
Added clock reading support for Catalyst 8.9 on RV770 and RV730
Added support for NVIDIA 9400 GT, 9500 GT, 9600 GS, 9800M GS, 9600M GS, 9300M GS, 9200M GE
Added support for AMD R580 Stream Processor, RV730 and one M88 variant
Fixed PCI subvendor ID 1787 to be ATI AIB
Fixed readings and added monitoring support for ATI M88
Fixed fan speed readings on ADT7473 sensor
Added support for ADT7473 sensor chip on ATI
Added release dates for several NVIDIA mobile GPUs[ Módosította: Thrawn ]
westlake
* Added display for GPU release date. The data is incomplete, if you have more info please post in the sticky thread in the support forums.
* Added display for transistor count
* Added mouseover readings for sensors graph
* Correctly named the three on-die sensors of RV770 and RV730
* Added support for voltage regulator monitoring on HD 4870 and HD 4870 X2
* RV770 GPU on HD 4870 X2 now called R700
* Added support for reading HD 4870 X2 3D clocks
* Added display of CrossFire Sideport status on HD 4870 X2
* Added more RV730 device IDs
* Added support for GeForce 9800 GT, 9800M GT, 9600M GT, 9700M GS/GT, 9500M G
* Added detection for RS780D
* Fixed incorrectly read ATI OD5 clocks
* Fix for memory clock reading on RV730
* Fixed ROM reading on RV730
* Fixed crash when no supported card detected
* Sensor graph width adjusted when scrollbars visible[ Módosította: Thrawn ]
westlake
* Added full support for HD 4870 X2
* Added support for reading clocks on newer ATI drivers (R700)
* Fix for realtime clock sensor showing double memory speed on RV770 GDDR5
* Added detection for GeForce 9800 GT, GeForce 9300 GE
* Added support to start GPU-Z minimized (use -minimized)
* Added tray icon when GPU-Z is minimized
* Fixed crash when uploading large BIOS files
* Fixed rare crash that could happen on some NVIDIA cards
* Added detection for Intel Q43. G45 and some variants of G35, G965, GM965[ Módosította: Thrawn ]
westlake
* Fixed BIOS Reading on HD 4870. Please do not flash non-128K BIOSes to GDDR5 cards
* Fixed GDDR5 bandwidth calculation
* Fixed texture fillrate on RV770 and RV730
* Added three extra on-die temperature sensors to RV770 monitoring
* Removed states.dmp file creation
* Fixed GPU activity readings on RV770
* Changed devices list order to be more intuitive (by bus number now)
* Added Shared Memory support, see the forum for more info
* Fixed more 190°C PCB readings on NVIDIA
* Catalyst Beta versions no longer displayed as version 2.2
* Fixed sensor graph overflow
* Sensor graphs will try to autoscale now
* Fixed RV505 process size
* Fixed memory bus width reading on some ATI RS300
* Fixed rare crash when reading NVIDIA sensors
* Fixed GDDR3 detection for G71[ Módosította: Thrawn ]
westlake
* Added support for variants of i945G, Q35, G31/G33, G84, G92, G96, GT200, G86M, G84M, C79
* Improved RV770 and GT200 detection code
* Updated NVIDIA temperature reading code
* Fixed updater getting stuck during refresh
* CrossFire on Vista64 now reported with note "unsure", instead of just "unknown"
* Added mini graph to sensors
* Screenshots are uploaded as PNG now
* Added crash report error handler
* Updated G70 number of ROPs
* Added PCI Vendor Point of View
* Improved S3 Chrome 400, S20, S18 and S8 detection[ Módosította: Thrawn ]
westlake
sihuhu..
0.1.6
* Added GPU Sensors tab
* Fixed CrossFire detection under Vista
* Screenshot will now work on Windows 2000 without PSAPI.DLL installed
* Update check default interval is now 1 week
* Added a link to test build forum from validation page
* GPU variant names removed for all ATI and NVIDIA cards. For example "G80 GTX" will be called "G80" from now on
* Added several missing ASICs from families: RV610, RV630, R600
* Added several future ATI ASICs
* Fixed clock detection for some RV6xx ASICs
* Fixed pipeline count on modded RV430 GPUs
* Added ROP/shader readings for RV620, RV635 and future ATI ASICs
* Fixed memory bus width reading for R200 and similar ASICs
* Improved low-level BIOS reading code to work on more GPUs (pre-R500)
* Added detection for ASICs from families: G80, G92, G94, G92 M
* Fixed negative temperature readings in ADT7473 sensor
* Added some missing die sizes for ATI and NVIDIA
* Added bus width reading for NV10
* Fixed bus width reading for NV44
* Fixed ROP/shader counts for NV41, NV42, NV43, G70, G71, G73
* Added detection for i740, GM45
* i865G correctly reports DDR memory now
* Multi GPU dropdown is now a static readout
* Shortened HP PCI vendor name[ Módosította: Thrawn ]
westlake
a 0.0.9 meg mindig nem ismeri fel a beta forceware-t (163.75) es hiaba allitom at a web update-et never-re, minden ujrainditasnal keresi az ujabb verzioz.. gagyi
westlake
a legjobb betateszter maga a juzer.. wizzard tok jol csinalja.. kiad egy finoman szolva is alpha verzios progit, aztan a visszakuldott bugreportok alapjan ketorankent kiad egy uj verziot.. kis szerencsevel 1 het mulva lesz egy jul mukodo gpu-z nevu progink.. hol itt a gond?
#101: a progi mar nem supportalja a win98-at.. ideje valtanod
- Robot fűnyírók
- Az eddigi legolcsóbb, 3D V-Cache-t használó CPU-ját hozta forgalomba az AMD
- Óvodások homokozója
- sziku69: Szólánc.
- GoodSpeed: Daikin FTXF35E / RXF35F Sensira 3,3 kW Inverteres klíma - a Sztori
- Elektromos autók - motorok
- NVIDIA® driverek topikja
- Honor 200 Pro - mobilportré
- ÚJ AKKU! Ár/ÉRTÉK BAJNOK! Dell Latitude 5330 i3-1215U 6mag! 16GB 512GB 13.3" FHD 1 év gar
- 226 - Lenovo LOQ (15IRX10) - Intel Core i7-13650HX, RTX 5060
- Dell Precision 3561,15.6" FHD,i7-11850H,16GB DDR4,512GB SSD,T600 4GB VGA,WIN11
- Bomba ár! Dell Latitude 5290 - i5-8GEN I 16GB I 256SSD I 12,5" HD I Cam I W11 I Garancia!
