Abu85
HÁZIGAZDA
Ezt a kérdést ide kellett volna feltenni. [link] - Nem nyitunk mindennek új topikot. A további eszmecserét, a linkelt topikba folytassuk.
Mindenesetre megkerestem a Canopus Stormtest esetében a tech support válaszát:
Here's the full reply from Canopus tech support, covers PCI Ex Cards and an alternative solution. The only downside is that they also advised (standard jargon) about latest drivers and there is a '2007' driver which I downloaded and now the system crashes when I try to encode with Procoder from the timeline. Time for a clean install I think.
Anyway, here's the full reply.......You will find instructions (DVStorm-RT\ReadMe\readmeWW.txt) how to fix
the PC video overlay in this document. I have pasted below for your
convenience.When screen overlay does not show correctly with certain graphics
cardsIf your screen overlay does not show correctly with PCI Express
graphics cards), please add the below lines in the Canopus.ini file
located in the C:\WINDOWS folder.
[DVStorm-RT.stmcore.conf]
OverlayMethod=1When the overlay does not show correctly when using certain graphics
cards, you may also try adding the below lines in the Canopus.ini file
located in the C:\Windows folder.
[DVStorm-RT.stmdd]
OverlayUpdateMethod=1If the above setting still does not fix the issue, please try changing
the settings as below:
[DVStorm-RT.stmdd]
OverlayUpdateMethod=0A többi programot nem ismerem, mert nem írtad le őket, de érdemes felkeresni a fejlesztőket egy esetleges megoldás felől.
- Apple iPad Air 2 (A1567) 32GB Wi-Fi + Cellular Arany
- HP ZBook Studio G8 i7 32GB RAM 1TB SSD RTX A3000/Garancia
- Részletfizetés Kamatmentes 12 havi részlet Acer Predator 18 AI Gamer / Laptop RTX 5070 Ti Ultra 9
- Apple iPhone 13 128GB,Átlagos,Adatkabel,12 hónap garanciával
- ÁRGARANCIA!Épített KomPhone Ryzen 5 7500F 32/64GB RAM RTX 5070 12GB GAMER PC termékbeszámítással
