Strottler
Valahogyan biztosan lehet. Különben nem tartalmazná a k3B-t, nem?
Strottler
Azt nem tudja valaki, hogy hogyan lehetséges CD-t írni, amikor az egyetlen optikai meghajtóból nem lehet kiszedni a knoppix boot CD-jét? Azt hiszem umount-tal sem...
Strottler
Itt is a megoldás:
# Boot the Knoppix CD.
# When the boot prompt comes up, choose your language.
Most of us speak English, so we'll type:
boot: knoppix lang=en
then press ENTER (you don't type the 'boot:' part, of course)
# Wait till the system is fully launched, including the KDE desktop
# Press CTRL-ALT-F1, to get a root console. You should see a shell prompt
# Type: knx-hdinstall
# Follow the guided installation menus. This will include:
* Creating a Linux partition (at least 2.5GB
* Creating a Linux Swap partition (at least 256MB)
* 'Mounting' the Linux partition as root
* Initialising the swap partition
* Copying all the required files (automatically)
* Setting up networking
* Setting passwords
* Setting up the bootloader (Note: take care with this stage - it could render your system incapable of booting into Windows. If you really need Windows, then it might be a good idea to set up GRUB Bootloader with a 'chainloader' entry, so that you can dual boot. Working this out is an exercise left to the reader - there are too many possible scenarios for me to cover in this short guide. Also see man grub and the files in /usr/share/doc/grub)
* Rebooting (without the CD)
# When you've rebooted Knoppix from your hard disk, click on the KDE Control Centre icon in the launcher at the bottom of the screen (icon of a colour monitor with a card in front of it)
# Within the Control Center, click on Personliche Einstellungen
# Click on Land und Sprache
# Choose the locale and language of your choice
# Click on Andwenden at bottom of that window
# Close and restart the Control Center
# Click on Peripherals, then Keyboard, and choose your preferred keyboard layout (which will probably be US.English. Click OK and close the window
# Press CTRL-ALT-F2 to get to the root console, and log in as root (using the password you chose when you ran the installer)
# (Optional) - type apt-get update (followed by ENTER). This will update your list of available packages, and takes about 5-10 minutes.
# Hey, presto, you've got a fully installed GNU/Linux desktop -
Strottler
Egyébként ha nagyon megtetszik a Knoppix, akkor telepítheted a wincsire is. Én már csináltam ilyet. Nagyon egyszerű. Keress rá a neten. (valami kdninstall a parancsfájl neve)
- Elektromos autók - motorok
- E-book olvasók
- Diablo II: Classic és Resurrected
- talmida: Változások 2. rész
- iPhone 15 Pro Max 512GB 87% Esim-es verzió (3hónap Garancia) Kijelzőn pici folt!
- Fotó állvány eladó
- MacBook felváráslás!! MacBook, MacBook Air, MacBook Pro
- DDR4 Szerver RAM felvásárlás - napi árak, elsősorban nagy mennyiségben
- Dell Latitude 7340 2-in-1 i5 13.gen, 16GB DDR5, 512GB SSD, QHD+ érintőkijelző, ÚJ ÁLLAPOT!
