Prego
body007
#10092
Csatolom, nyomtam egy top-ot, aztán kimásoltam a tetején lévő processzeket.
a szaggatott vonal alatt ugyanaz csak az UTF-8 alatt
a dbus-daemon a gyanús ...Cpu(s): 75.2%us, 23.8%sy, 0.7%ni, 0.0%id, 0.0%wa, 0.0%hi, 0.3%si, 0.0%st
Mem: 1026392k total, 510500k used, 515892k free, 63076k buffers
Swap: 979924k total, 0k used, 979924k free, 225968k cachedPID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1480 peregi 20 0 3164 1340 660 S 20.9 0.1 0:36.19 dbus-daemon
1558 peregi 20 0 58896 23m 8596 S 12.9 2.3 0:26.18 indicator-apple
941 root 20 0 54256 37m 9852 R 8.3 3.7 0:10.72 Xorg
3020 peregi 20 0 31044 15m 8880 S 4.6 1.5 0:08.22 python
1505 peregi 20 0 45456 17m 13m S 3.6 1.8 0:03.31 gnome-panel
1492 peregi 20 0 11636 8304 2000 S 2.0 0.8 0:01.81 gvfsd
4613 peregi 20 0 46376 13m 9.8m S 2.0 1.3 0:01.77 gnome-terminal
1442 peregi 20 0 25636 6984 5608 S 1.7 0.7 0:03.10 gnome-session
1506 peregi 20 0 49636 10m 8300 S 1.7 1.0 0:02.06 nm-applet
1557 peregi 20 0 31576 13m 10m S 1.7 1.3 0:01.96 clock-applet
1515 peregi 20 0 19336 7876 6364 S 1.3 0.8 0:02.74 gnome-power-man
1583 peregi 20 0 24092 4144 3388 S 1.3 0.4 0:01.57 indicator-appli
1424 peregi 20 0 23384 2716 2244 S 1.0 0.3 0:01.12 gnome-keyring-d
1562 peregi 20 0 17424 2696 1412 S 1.0 0.3 0:01.81 gnome-screensav
4509 peregi 39 19 37024 21m 3276 R 0.7 2.1 0:01.26 apt-check
1 root 20 0 2804 1708 1184 S 0.3 0.2 0:00.83 init
8418 peregi 20 0 2544 1216 900 R 0.3 0.1 0:00.07 top-------------------------------------------------------------------------------------
Cpu(s): 9.9%us, 3.3%sy, 0.0%ni, 69.5%id, 16.9%wa, 0.3%hi, 0.0%si, 0.0%st
Mem: 1026392k total, 439336k used, 587056k free, 57404k buffers
Swap: 979924k total, 0k used, 979924k free, 201972k cachedPID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
955 root 20 0 53220 36m 8856 S 5.0 3.6 0:08.46 Xorg
1652 peregi 39 19 49348 5668 3208 D 2.0 0.6 0:00.06 apt-check
1649 peregi 20 0 19412 7664 6192 S 1.3 0.7 0:00.04 update-notifier
776 messageb 20 0 3204 1496 760 S 0.7 0.1 0:00.26 dbus-daemon
239 root 20 0 0 0 0 S 0.3 0.0 0:00.03 scsi_eh_1
761 syslog 20 0 33616 1568 1008 S 0.3 0.2 0:00.04 rsyslogd
1495 peregi 20 0 43028 9916 6216 S 0.3 1.0 0:00.05 php
1512 root 20 0 15652 3036 2436 S 0.3 0.3 0:00.07 udisks-daemon
1528 peregi 20 0 35064 10m 8088 S 0.3 1.1 0:00.14 notify-osd
1546 peregi 20 0 24092 4144 3388 S 0.3 0.4 0:00.02 indicator-appli
1573 peregi 20 0 47528 13m 9.9m S 0.3 1.3 0:00.20 gnome-terminal -
Prego
Szeretném hogy a 10.04es Ubuntum alapértelmezettként mindenben ISO-8859-2 kódolást használjon (programozásnál még megoldom hogy a cpp fájlt ISO-ba mentse, de amikor adatbázisból kell lekérdeznem, akkor folyamatosan hibás eredményt kapok az ékezetes karakterek miatt).
Ezt a műveletet hajtottam végre, az eredmény jó is lett, viszont a processzorterhelés folyamatosan 100%-on van.
Van valakinek valami ötlete?
Kössz -
Prego
Szerintem egy átlagos dummy falhasználót (mint a mi úgymond célközönségünk), nem érdekelnek olyan fogalmak, mint: csomagkezelés, kernel (ezt én is úgy csempésztem bele az írásaimba), de még csak az sem, hogy Debian alapú, stb.
Az egyik linkelt cikkemben is csak megemlítettem, hogy az OPR feladata pl a memória és folyamatkezelés, erre különböző megoldások léteznek, és a különböző oprendszerek ebben térnek el. Eszem ágában sincs kitérni olyanokra, hogy a WIndowsnál a Kernelbe integrálták a GUI-t, melyik fájlrendszer hány bites blokkokat használ, stb...
Már azt is megbántam, hogy engem érdekelt.
Szóval igyekszem inkább a felhasználói élmény szögéből megközelíteni a cikkeket, de ha már leírtam valamit, akkor azt nem árt helyesen leírni.
Erre van egy mondás: ''Boldogok a szegények, mert övéké a mennyek országa'' (ez nem csak az anyagi gazdagságra vonatkozik sztem).
[Szerkesztve] -
Prego
Tudtam, hogy pont ezekbe fogtok belekötni:
az Ubuntuban NINCS root jelszó, lehet ugyan megadni, de felesleges
a fenti parancsnál nem a root jelszót, hanem a felhasználó saját jelszavát kéri, aki ezzel bizonyítja hogy valóban ő ül a gép előtt és akar rendszergazdai jellegű feladatokat végezni (jelen esetben a csomaglistát frissíteni)
Én a drájrvertelepítésnél szembesültem a problémával, de valóban igaz a dolog, javítani fogom.
A KDE meglepetést szerzett, mivel a megnyitás/futtatás nem két, hanem egy kattintással érhető el. Ez igényel némi megszokást, a miértjét abban látom, hogy a Microsoft már levédte a duplakattintást.
Nem állítgattam semmit, ez az alapbeállítás, és szerintem egy kezdő Linux felhasználó sem fog kotorászni, hogy márpedig nekem duplakattintás kell. Egyébként nekem tetszik az egykattintásos rendszer, és az utolsó megjegyzés csak egy elmélet.
Az UHU látványosan az Ubuntura épül
Látványosan félre fogalmaztam.
Még szép, hogy a két rendszernek semmi köze egymáshoz. Csak azt akartam mondani, hogy az UHU annyiban különbözik az Ubuntutól (megjegyzem: látványban), hogy a kiegészítő alkalmazásokat nem kell letölteni (ez így megint nem pontos ), hanem alapból felmegy.
A hibák javítva lesznek, de előtte a Turing-gép és veremautómatákat kell benyalnom holnapra.
[Szerkesztve] -
Prego
Először letöltésvezérlővel, majd nélküle próbáltam letölteni:
uhu-linux-2.0-dvd.sfv:
Rossz CRC: uhu-linux-2.0-dvd.iso
Hiba: 1
Rendben: 0, Nincs meg: 0, Olvasási hiba: 0, Hibás ellenőrzőszám: 1
nem lehet a gépemben a hiba, mert az openSUSE és az ubuntu lejött
Van valakinek valami ötlete? -
Prego
Feltettem az Ubuntu 7.04 dektop x86 verzsönt.
Ez először úgy működött mint egy Live CD, majd az asztalra kirakott egy telepítés nevezetű ikont. Feltelepítettem, és minden grafikus felületről ment. Már akkor gyanakodtam:
Kért egy felhasználónév/jelszó párost és annyi.
Próbáltam aztán a konzolban a su parancsot, persze a jelszót nem fogadja el.
Már nem emlékszem milyen feladathoz kellett super lúzerként bejelentkeznem, remélem ZH-ban nem kérik majd. -
Prego
ngabor2
#2957
Hááát, azért ez sokmindenről elmondható, a Windows parancssor is tud egyet s mást
Azért egy próbát megér, sztem egyre többen gondolkodnak egy ingyenes rendszeren, mivel egyre nehezebb lopni a Windowst, illetve a hozzá tartozó alkalmazásokat.
Ezért mondom, hogy csak néhány fontosabb témakört ölelnénk fel:
-Felhasználói felület: mennyire kezelhető egyszerűen, hol találhatóak az alapvető utasítások (ki-be kapcsolás, menüszerkezet, programok telepítése)
-Multimédia, Játékok, szórakozás: Médialejátszók kodekek telepítése, TV tuner kezelése, melyiknek szebb a képe-hangja, milyen játékokkal játszhatunk.
-Office alkalmazások: OpenOffice vs. MS Office
Kihagynánk a Shell scriptelést, Hálózat konfigurálását, a moduláris kernel felépítését.
Esetleg végszóban el lehet mondani, hogy mely felhasználóknak ajánljuk (Hard Core Gamereknek egyáltalán nem, kis teljesítményű gépeken és laptopokon inkább el tudom képzelni, rendszergazdáknak kötelező ismerni kívül belül).
Ilyesmikre gondoltam:
Melyik GUI-t a legkönnyebb megszokni, melyik a legjobb médialejátszó, hangszerkesztő, videó szerkesztő, MP3 tömörítő, melyek a népszerű játékok. -
Prego
VladimirR
#2945
Nem akarok téríteni, csak egy egész hetet szánnánk a Linuxra, és az említett témaköröket járnánk körbe. Arra keresnénk a választ, hogy egy ''dummy'' felhasználó mennyire tudná kezelni (telepíteni, programokat telepíteni) a rendszert.
Tehát kéne olyan disztribució(k), ami könnyen használható, és lehet hozzá jó progikat szerzni.
Én példáúl most az Ubuntut próbálgatom, és tegnap meghallgattam néhány mp3-at, amelyek tartalmaztak néhány nagyon apró hibát. A Windows Media Playerrel nem hallom ezeket a hibákat (nem is tudtam hogy vannak, valszeg valami visszhang effekt miatt), az Ubuntu 7.04 alap lejátszójában viszont igen.
Viszont, hogy jót is mondjak, egyáltalán nem kellett konfigurálgatnom semmit ahhoz, hogy kitűnő (szubjektív vélemény) hangon szóljon az 5.1-es rendszerem.
A WMV formátum lejátszásához viszont kérnék segitséget, mert nekem nem sikerült kodeket telepítenem hozzá. -
Prego
Forest_roby
#2936
Hát ahogy elnézem, a Novell SUSE nem ingyenes, csak az OpenSUSE (a kettő nem ugyanaz: az Opel és a SAAB sem ugyanaz az autó, pedig mégis
Az UHU weboldalát néztem még, de eléggé félreérthető az oldaluk. Most így megtaláltam.
Ez az UHU kissé nagy méretű.
[Szerkesztve] -
Prego
Az lenne a kérdésem, hogy melyk ingyenes Linux most a legjobb? Jelenleg egy Ubuntu 7.04-et telepítek, de nemsokára egy cikksorozatot kell írnom a Linuxról, Felhasználói felület, Multimédia-játékok, és Office alkalmazások témakörben.
Szóval ha tudtok olyat, amivel lehet embereket téríteni, akkor szóljatok.
Prego
Leszedtem egy Ubuntu Linuxot is, asszem 6.10 verziót. Elindítom VPC alatt, és mindig kiírja, hogy Kernel Panic és valami Syncronising probléma.
Ha a memóriatesztelőjét futtatom, akkor a procimat csak 3000 esnek ismeri holott 3200es (még csak BETA BIOS ismeri fel), illetve SATA vinyóm van, tehát erre a kettőre tippelek. Hogy oldhatnám meg a dolgot? -
Prego
Sziasztok. A suliban most Shell programozást tanitanak, csak azt nem árulják el, hogy kell feltelepíteni a Linuxot.
A Debian Linux Netinstallt tettem fel VirtualPC-re.
A Nano Editorban próbálnék Shell skriptet írni, de szükségem lenne két karakterre:
AltGr+x = #
AltGr+é = $ Ez még fontosabb lenne.
A sima Alt - al nem működnek a billentyűkombinációk. viszont amikor az AltGr+ bármit használok, akkor egyszerűen átvált, és minden billentyűlenyomásra valamilyen parancsot hajt végre (pl.: d betű a Delete parancsot hajtja végre).
Belépésnél pedig nem hajlandó elfogadni a rootnak beállított (felhaszn: hallgato; passwd: nik119) kombinációt, és csak felhasználóként enged beengedni (user user).
Az első probléma fontosabb lenne
THX
[Szerkesztve]
Milyen program ami... [link]
- Teszt [Linux] A Flatpak
- Witcher 1 Collector's Edition
- Eladó Steam kulcsok kedvező áron!
- Bitdefender Total Security 3év/3eszköz! - Tökéletes védelem, Most Ünnepi áron! :)
- magyar billentyűzet - 151 - Lenovo LOQ (15IAX9) - Intel Core i5-12450HX, RTX 4060
- Samsung Galaxy S25 Ultra 256GB, Kártyafüggetlen, 1 Év Garanciával
- LG OLED TV 55CS6LA
- Microsoft Surface Go 2 m3-8100Y 8GB 128GB 4G LTE 1 év garancia
- BESZÁMÍTÁS! Apple Watch Ultra 2 49mm Cellular okosóra garanciával hibátlan működéssel
CPT.Pirk
