Larry303
a syncmaster megtévesztett
azé ennél nagyobbat se hibázzak! de feltételezem nativ felbontásban használod ugye a 17 colosd??? -mert jelen vitában nem a technologia hanem az adott felbontás a releváns-amúgy valójában eszem ágában sincs lerázni téged, úgy használod a hardvereid, ahogy tetszik...a gondom azzal, volt, hogy másoknak is ezt a marhaságot oltod...
és akkor zárszóként még a TÖBBIEKNEK -mert te menthetetlen vagy- kiollózok egy sztem fontos részletet a cikkből, amit te nem bírsz felfogni a 13éves agyaddal:New gaming mice tend to be released with high DPI counts, but how much DPI is really needed to play games? Higher DPI obviously seems better. Like the steering wheel in a car you want continuous and smooth control over turning. The difference is that game graphics is made up of pixels, rather than the real world which has much more detail. At some point, having more DPI becomes unnecessary because the actual bottleneck is the screen. But how much DPI is enough?
I will use the example of playing an FPS game. If you are playing on a screen resolution of 1024 by 768 pixels, then we can roughly work out the number of pixels in a full horizontal rotation of 360 degrees. We multiply the number of pixels across the screen by 4 (since each screen is about 90 degrees viewing angle).
Pixels in 360 degrees = 1024 * 4 = 4096
Now we need to work out how far we want to move the mouse for a full rotation of 360 degrees. This distance changes depending on the gamer, because changing the game sensitivity changes how far you need to move the mouse for the same effect. By dividing the total number of pixels by the total distance (in inches), we get a rough idea of how much DPI is useful.
High Sens: 360 degrees in 0.1 m (4"), roughly 1000 DPI neededMedium Sens: 360 degrees in 0.25 m (10"), roughly 400 DPI needed
Low Sens: 360 degrees in 0.50 m (20"), roughly 200 DPI needed
While 3D games don't need you to turn a whole pixel before the screen changes, this is a sensible way to work out when more DPI resolution stops being useful. What we find is that standard 400 DPI mice are ok if you have a low sensitivity, but there are times when more DPI can improve the game. If you have a High Sens and a huge 2560 x 1600 panel to play on, our formula says that our ideal mouse resolution is a whopping 2500 DPI!
bocs ha hosszú lett...részemről téma lezárva!
Larry303
megmondod hogyan kell
-na ezzel van itt a problema
It would seem that a higher DPI would theoretically mean a better mouse? Before you run out to buy the highest DPI mouse we should think carefully about how much DPI is actually useful on a computer that spends most of its time displaying images made up of pixels.
majd ha értelmezed ezt a mondatot, és tisztában leszel az ilyen fogalmakkal, mint pl dpi és felbontás, majd gondold végig még1x a 2000dpi det a 17es crt monitorodon...
Larry303
oktass csak tovább...látod vannak itt ollan hülék akik meg is eszik...
pofázod a 2000dpidet, de még nemkérdezted meg tőle mekkora felbontásban játszana a kollega... -
Larry303
bocs akkor holnap elégetem a nyelvvizsgám is nyilvánosan...majd készítek neked videot róla...
amúgy nem értem it kéne beismernem...linkeltem egy cikket amit nem én írtam...az, hogy 2000dpin 1280ban a 4centis mozdulat alig mozdít valamit gondolom az még a mai napig áll részedről...amúgy tévedni emebri dolog nem kell ezt olyan komolyan venned...így, hogy csak 13van mögötted, még nagyon sok, ennél sokkal szarabb dolgot tartogat számodra az élet...szal take it easy!!!!
Larry303
Larry303
nesze te núúb
első és második oldal...alapvető ismeretek...rádfér...
imádom amikor így porig égeti magát vki...
ha nem, ilyen lenne a stílusod, és nem mondanál baromságokat másoknak akkor én sem így álltam volna hozzá..amúgy mindenkinek ajánlom a cikket, vonjátok le belőle a következtetéseket!!!
Larry303
nem akarok kötni de ez azért nem illen egyszerű mint leírtad...
nagyon fontos először is, hogy milyen felbontásban játszol...másodszor pedig ho mekkora mozdulattal fordulsz meg teljesen a dpi ill. ajátékban beállított érzékenység mellett...
aki 2000dpin játszik feltételezem nem kis kijelzőn, nem kicsi felbontásban játszik...
jómagam 800 ill 600 dpi (1280as ill 1024es felbontás) környékén érzem a legbiztosabbnak a kezem, e mellett játék szinten kb közepes érzékenység állítva...aztr még hozzátenném, hogy az összes cs ut stb pro gamer ultralow dpin (400körül) játszanak kb fél méteres egérpadokon...
na jó állítgatást mindenkinek
2000dpi mellett (1280ban) az egérpadon egy 4centis mozdulattól 2x megfordul a játékosunk...szvsz úgy elég nehéz...
Larry303
Larry303
Elmagyarázná nékem vki, hogy ez az 500Hz mit is takar???
Annyira tisztában vagyok vele, hogy az usb port sebességéhez van köze, de sztnék tisztábban látni...
Amúgy g5 öm van és fogalmam sincs hogy milyen sebeséggel csatlakozik az usb portra...
- Bowers & Wilkins Dm 303 EISA díjas audiofil hangfal + Lcr 3 center
- Dell ReadyRails A6 1U Rail Kit R210, R210 II, Dx600G, stb. szerverekhez (JWFR6, W6XNW, YNG10)
- Kingston HyperX Fury 2x4GB 2133MHz DDR4 kit / Beszámítás OK! / Akciós Ár!
- Eladó Sony PlayStation 5 (Slim) 1TB Digital Edition 2026.12-ig garanciával!
- ASRock B250M-HDV / MSI B150 PC Mate
- Apple iPhone 14 Pro Max / 128GB / Kártyafüggetlen / 12Hó Garancia / Akku: 100%
- iPhone 14 Pro 128GB Space Black -1 ÉV GARANCIA - Kártyafüggetlen, MS4266
- Beszámítás! LENOVO LOQ 15AHP10 FHD Gamer notebook - R7 250 32GB DDR5 1TB SSD RTX 5050 Max-Q 8GB
- AKCIÓ! Dell Precision 3571 4G LTE i7-12700H 32GB 1000GB FHD RTX A1000 4GB 1 év teljeskörű garancia
- Samsung Galaxy S20 Ultra / 12/128GB / Kártyafüggetlen / 12Hó Garancia
