blattida
trance89
#452
Amit akkor vettek, az még valóban, igazi lifetime licenc, de ezt a lehetőséget a malwarebytes megszüntette, amik pedig néhány oldalon keresztül megvásárolhatóak, azok a szó igazi értelmében már nem lifetime licencek, csak nincs időkorlát a használatukban, a frissítésükben viszont igen.
blattida
Tölthető a 2.0.2 publikus béta.
Változások, fejlesztések:
• Changed some of the terminology used in scan results and scan logs to make them clearer
• Enabling or disabling self-protection should now be more responsive under most circumstances
• Each language name is now listed in its native tongue rather than being translated to make switching languages easier
• Blank window is no longer observed flashing on screen during startup and shut down of system when Malwarebytes Anti-Malware is running in the tray on Windows Vista and newer operating systems
• Main program window now opens to the Dashboard by default to simplify navigationJavítások:
• Several crashes and BSOD issues fixed with rootkit scanning
• Scan speed improved with rootkit scanning enabled under some circumstances
• Rootkit scans should no longer hang indefinitely under certain conditions
• Compatibility issues with certain VPN client software fixed
• Protection no longer fails to start after upgrade under some circumstances when self-protection is active prior to upgrading
• Entire General Settings tab now responds to clicks correctly
• Several issues with Access Policy restrictions not restricting access as they should
• Editing the Access Policy password no longer results in restricted areas of the software being inaccessible when the correct password is entered
• Access Policy feature now functions when Bitdefender Total Security is installed
• Manual scan of individual files and folders using context menu scan feature in Explorer no longer results in the scan failing to run under certain circumstances
• Green checkmark status is no longer indicated when Malwarebytes Anti-Malware is unable to reach update servers when attempting to update
• Text is no longer cutoff in the UI on Windows XP or when the 'Classic' theme is used on Windows 7
• Scan time is now reflected accurately at the end of a scan
• Quarantined objects remain listed correctly in Limited User Accounts when restoration of an object fails due to lack of permissions
• Some words in UI which were not translated into non-English languages now are when those languages are selected
• Driver left behind during uninstallation of Malwarebytes Anti-Malware is now removed as it should be when the product is uninstalledÉrdemes vele egy próbát tenni, dolgoznak a fiúk rendesen.
blattida
Itten van az MBAM 2.00 RC1
Változások és javítások:
Language translations are now included with 2.0
Several issues with rootkit removal and repair fixed
Issue where databases were sometimes reported as corrupt after an update fixed
Obsolete Malwarebytes Anti-Malware 1.75 help file removed from 2.0 installer
Path for folders and registry keys removed by scans are no longer reported as blank
Items removed by a scan may now be restored from quarantine after a system restart with self-protection enabled
Cancelling a scan when using Chameleon to run Malwarebytes Anti-Malware no longer results in a BSOD
Print preview function in Firefox is no longer blocked when self-protection is enabled
Issue with fixing malicious GPO policies with Chameleon fixed
BSOD with Webroot SecureAnywhere fixedFrissítéssel tessék lehúzni.
Ha minden jól megy és nincsenek vele gondok, akkor belőle lesz nagyjából két hét múlva a végleges változat.
blattida
Megérkezett a harmadik béta: 2.00.0.504
Several notifications removed based on user feedback so that there are now fewer pop-ups
Amount of system RAM used by Malwarebytes Anti-Malware Premium/Trial significantly reduced
Memory leak in scans fixed
Memory leak in database updates fixed
Scan speed improved drastically on some systems where scans were very slow in previous betas
Browsing speed now faster when Malicious Website Protection is enabled than in previous betas on some systems
Multiple items may now be selected in Quarantine for deleting or restoring at once
Several issues with limited user accounts fixed
Scans now run as expected under limited user accounts (it is still highly recommended that users scan regularly from an administrative user account in order to detect and remove all threats from the system)
Malware Exclusions and Web Exclusions are now retained when upgrading from one version of 2.0 to another
"Help" button in About tab now opens Malwarebytes Support webpage
MBAMService no longer crashes when upgrading from version 1.75 PRO or trial
Protection is no longer disabled after upgrading from previous 2.0 versions
MBAM no longer crashes under some circumstances after updates
Legal text removed from About tab
Antirootkit Database and Malware Database versions now identified separately in scan logs
Scan logs now contain more information about protection and license status
Scan logs now list status of Chameleon self-protection
Scan logs now show accurate information about license type and user account type
Scan logs list additional information about detections
Protection logs now show more information about items detected by Malware Protection
Database Out of Date notifications now contain an "Update Now" button
New EULA included with Malwarebytes Anti-Malware
Tray icon changes to reflect status of the software and protection
MBAMScheduler no longer runs on startup when Malwarebytes Anti-Malware is configured not to start with Windows
Updating through a proxy when configured via the Update Settings tab now functions correctly
Chameleon updated to deal with the latest rogue/fake AV malware
Quarantined items now display immediately after being quarantined
Users are now prompted to decide what to do when Malware Protection detects PUP items when PUP is set to "Warn user about detections"
MBAM no longer becomes unresponsive when computer wakes from sleep
Crash in MBAMService fixed
Updates can no longer cause the program to report that the database is missing or corrupt
MBAM 2.0 now accepts MBAM 1.x license keys
Using "Copy to Clipboard" or "Export Log" at the end of a scan no longer results in MBAM crashing or showing blank logs
System crash/BSOD caused by antirootkit driver under some circumstances fixed
Issue where some parts of the UI were not being translated as reported by translators now fixed (non-English languages will be available soon!)
Limited users are no longer warned that they might be infected because antirootkit driver cannot load under limited user accounts
We have now disabled the previous beta test key, however you may now use your existing 1.x license keys with this version or you may use the trial.Letöltés: MBAM Beta 3
Alakul...
blattida
Megjött a második béta: 2.00.0.0503
Malwarebytes Anti-Malware now scans the registry hives (HKCU keys) for all user accounts instead of just the current user account so that a single scan can now detect and remove all malware and malware traces from the entire system
Chameleon now functions for running Malwarebytes Anti-Malware against infections
Chameleon updated to deal with the latest rogue/fake AV infections
Several application crashes fixed
Several issues causing BSODs under certain scenarios fixed
Scan and protection logs improved to use more consistent formatting
Several items in the UI will now display in their translated language instead of showing only in English
Scan results can now be saved at the end of a scan prior to taking any actions against detected items
Threats quarantined by Malware Protection may now be restored without rebooting the system
Quarantine tab now refreshes to display recently quarantined threats without restarting Malwarebytes Anti-Malware
Scan logs are no longer blank under certain scenarios
HTML and BBC options removed from export log function
Number for objects detected during scans is no longer misaligned
Malwarebytes Anti-Malware Premium now functions correctly on XP with self-protection enabled
Dashboard now informs user when they have a 1.x license key installed but no 2.x key and gives them the opportunity to input a valid 2.x key
Several issues with removable drives and removable media fixed for Custom scans and right-click context menu scans
avp.exe (Kaspersky) and avastsvc.exe (Avast!) can no longer be excluded from Web Exclusions in order to prevent users from inadvertantly disabling Malicious Website Protection
Antirootkit scans no longer detect encrypted non-OS drives as containing forged sectors -
blattida
Megjelent a Malwarebytes Anti-Malware 2.00.0.0502 béta
Újdonságok:
• Completely redesigned user interface to make the product easier to use, more informative, and providing quicker access to key functionality
• Quick Scan has been renamed to Threat Scan, our recommended scan type
• Malwarebytes Anti-Rootkit integrated into the scanner (available under Detection Settings)
• Malwarebytes Chameleon driver integrated to provide self-protection for the Premium version (available under Advanced Settings)
• Enhanced version of Malicious Website Protection for Windows Vista SP2 and above (better performance, added ability to exclude processes such as BitTorrent clients from Malicious Website Protection, ability to manually exclude IP addresses and individual URLs/websites by domain name)
• Native x64 system location scanning, detection and malware removal
• Substantial improvements to core detection and removal technologyJavítások:
• Performance issues when streaming audio on Vista SP2 and newer when using Malicious Website Protection should now be resolved -
blattida
Elérhető az MBAM 1.60.1 béta
Javítások:
• Fixed issue resulting in freezes in certain third-party security products on Windows XP.
• Fixed issue where ignore list was not reloaded after a database update.
• Fixed issue where certain malformed ignore list data would result in a mbamcore.dll crash.
• Fixed issue where desktop icon was not created on certain upgrade installations.
• Fixed issues with Dutch, Belarusian, and Korean language files.
• Added Greek language file. -
blattida
blattida
A topik címét valaki javítsa ki, mert helyesen Malwarebyte's!
blattida
Kezdő vagyok
#106
Az ingyenes pontosan ugyanannyi kártevőt talál meg, mint a fizetős pro, azzal a különbséggel, hogy a free csak manuális kereséskor, mivel nincs rezidens védelem benne.
- Honor 200 Pro - mobilportré
- LG LCD és LED TV-k
- Anime filmek és sorozatok
- Xiaomi 12 - az izmos 12
- Asztalos klub
- Az eddigi legolcsóbb, 3D V-Cache-t használó CPU-ját hozta forgalomba az AMD
- The Elder Scrolls Online Imperial Collector s Edition
- PC Game Pass előfizetés
- AKCIÓ! LENOVO ThinkPad P15 Gen1 munkaállomás - i7 10850H 16GB DDR4 256GB SSD Quadro T1000 4GB W
- AKCIÓ! Sony PlayStation 5 825GB digital extra fejhallgatóval garanciával hibátlan működéssel
- iPhone 16 Pro Max 256GB 92% (1év Garancia)- AKCIÓ
- szinteÚJ, dobozos Dell Pro 14 Core Ultra 7 255U 32GB DDR5 1TB AI PC FHD+ 1 év garancia
- G.Skill Aegis 32GB (2 16GB) DDR4 3200MHz ÚJ, AZONNAL KÉSZLETRŐL
