Keresés
anaqer
Note
There are four common versions of the MPEG Layer-3 codec that appear the same, except for the compression formats supported:
* L3CODECX.ACM - no compression supported
* L3CODECA.ACM (Advanced) - up to 56Kbps
* L3CODECP.ACM (Professional) - up to 128Kbps
* L3CODECP.ACM (Radium warez version) - up to 256Kbps
All four of these codecs are very similar and have the same ID in the Windows Audio Compression Manager, so two programs that come with different versions sometimes overwrite each others' codecs when installing. If you used to have certain MP3 compression options and no longer have them, it's possible a program you recently installed has done this.
// VirtualDub Help
- Dell Precision 7550,15.6",FHD,i7-10850H,16GB DDR4,512GB SSD,Quadro T2000 4GB VGA,WIN11, 2 KAMERA
- HIBÁTLAN iPhone 12 Pro 128GB Pacific Blue- 1ÉV GARANCIA -Kártyafüggetlen, MS3948
- Minden szoftver mellé teljesen audit és NIS2 biztos, jogilag hiteles licencigazolást adunk át!
- Sosemhasznált! HP OmniBook 5 i3-1315U 8GB 512GB 16" FHD+ Gar.: 1 év
