Milyen belső merevlemezt vegyek? Összefoglaló!
chaser83
Core2duo6600 #7093 üzenetére
Meg van a 640-es Samsung HDD-m és gyönyörűen működik az nforce4 chipsetes lapommal. Felismeri teljes méretben. Csendes, gyors, amire lehetett számítani
Köszönöm mindenkinek aki segített, főleg Neked.
A legjobbakat.
chaser83
"With 48-bit LBA there is a limit of 144 petabytes (144,000,000 gigabytes). The next capacity barrier will come sooner than that at 2.2 terabytes (2,200 gigabytes) because many of today's operating systems are based on 32-bit addressing"
Szóval 137GB - 2200GB között nem lesz probléma ekkor is az Op rendszer lehet az ok a nem megfelelő méretkezelésre."We have received questions from users installing serial ATA (SATA) 48-bit LBA hard drives asking whether requirements involving Windows Service Packs and 48-bit LBA BIOS compatibility apply to these drives. We could not find anything in the Microsoft Knowledge Base regarding SATA 48-bit LBA hard drives and Windows. The following information is from our own testing.
48-bit LBA requirements for SATA hard drives are the same as those for IDE hard drives. You will need to make sure you have the correct Windows Service Packs installed and EnableBigLba registry value set for Windows 2000. If not, your SATA hard drive will not be recognized at full capacity.
Regarding 48-bit LBA BIOS compatibility, in theory that is also required. In reality, since SATA technology is basically newer relative to 48-bit LBA we expect all motherboards which support SATA will also have 48-bit LBA compatibility in the BIOS. Most likely, you will not need to check for this if you are having problems installing your SATA hard drive. You should make sure you have the latest Windows Service Packs and drivers installed first"
...Meggyőző.
chaser83
Core2duo6600 #7089 üzenetére
http://www.48bitlba.com/
Szóval ha jól értelmezem, ha műxik a 320 Gb-os WD-m, akkor nem lesz gondom a 640 GB-os Samsunggal (de a 144 000 TB-ossal sem lenne
) legalábbis méretfelismerés szempontjábol, reméljük más szempontból sem.
Az everest szerint 48 bites címzés engedélyezve van erre a 320GB-os vinyómra, a 120 GB-os maxtoromra nem (igaz 137 GB-ig jó a 28 bites címzés is).
Meg ha jól olvasom ez ATA-nál lehet ez probléma, szoval az SATA-s lapok már "ismerik" a 48 bites címzést? A többi az op.rendszeren múlik (Service Pack).
De javíts ki ha valamit félreértettem.
Amugy az ABIT KN8 topikban egy KN8-SLI tulaj vidáman használ több merevlemez mellett egy 750GB-os HDD-t is.... bíztató.
Na majd meglátjuk. -
chaser83
Core2duo6600 #6950 üzenetére
Igen ez a lapom.
chaser83
Core2duo6600 #6943 üzenetére
Köszönöm szépen a válaszodat. Mi az az OS? Szinonímája a déli hídnak? A déli híd kezeli a HDD-ket, ugye? Na adtál egy ötletet, hátha ezen a vonalon -déli híd típusát kell megvizsgálnom- kéne elindulni. Az elképzelhető, hogy a BIOS nem ismeri fel vagy hülyén, ahogy írtad de a folyamatos alaplapi driver frissítéseknek köszönhetően, hisz azt mindig frissítik, tökéletesen fog működni? Nálad ugyebár így van. És a többieknek...?
chaser83
Belső HDD-t tervezek venni pluszban -a hozzászólások alapján Samsung 640 Gb-osat- és nem tudom hogy lehet-e problémám ha az Abit KN8 (nforce4-es chipset) típusú alaplapomhoz csatlakoztatom; gondolok itt a HDD méretkezelésre ami anno probléma volt (120 GB felett). Legfrissebb BIOS van rajta (2006 májusi) SP2-es vindóz. Jelenleg egy 320 GB-os WD üzemel.
Válaszotokat előre is köszönöm!
- Hír Új 12 és 14 TB-os merevlemezek jönnek az év végére a Toshibától
- Hír 2020-tól gyorsan nőhet a Seagate HDD-k tárkapacitása
- Hír 14 és 15 TB-os merevlemezeket mutatott be a Western Digital
- Hír Nagy kapacitású héliumos Seagate merevlemezek érkeztek
- Hír Drasztikusan növeli az adatátvitel tempót konvencionális HDD-iben a Seagate
- Hír Alig van eltérés a HDD-k között a Backblaze megbízhatósági statisztikájában
- Hír Megérkeztek a Western Digital 10 és 12 TB-os Purple merevlemezei
- Hír Itt a Western Digital 14 TB-os PMR HDD-je
- Hír Hatékonyabb notebookokba szánt HDD-t mutatott be a Toshiba
- Hír Hagyományos irányt követő modellekkel frissíti vállalati HDD-it a HGST
- Hír Új technikával gyorsítaná a merevlemezek működését a Seagate
- Hír Seagate SkyHawk AI merevlemezek mesterséges intelligenciához
- Hír Egy év múlva érkezik a Seagate 20 TB-os HDD-je – HAMR technológiával
- Hír 40 TB-os HDD-ket ígér a Western Digital MAMR technológiája
- Hír Elsőként mutatott be 14 TB-os merevlemezt a HGST
- Hír 12 TB-os HDD-vel bővült WD Gold sorozat
- Hír Olcsó és gyors 8 TB-os merevlemezt hozott a Toshiba
- Hír Új HDD-családdal támadja az adatközpontokat a Western Digital
- Külpolitika
- FErgeteges frissítés: két rajongói mobil kapott One UI 7-et
- Ez lenne a népkártya? Teszten a GeForce RTX 5060 Ti 16 GB
- Kalandor: Elhunyt I. Ferenc pápa
- Milyen légkondit a lakásba?
- Disney+
- Windows 11
- Viccrovat
- Western Digital Elements 750GB HDD alig használt!
- Samsung 990 EVO Plus 4TB M.2 NVME PCI-E 4.0 x4/5.0 x2 - Új - Eladó!
- SAMSUNG 2TB 990 PRO M.2 NVME PCI-E 4.0 x4 - Új - 7450-6900 MBs - Eladó!
- Crucial P3 Plus 2TB M.2 NVME PCI-E 4.0 x4 - Új - Eladó! 37.000.-
- Hozz a Nyuszi Tárolót? Hozzon! Yó áron érdekel? Persze! WD 2TB LILA (WD20PURZ) INGYÉ FOX-al mégjobb?
- Eredeti Lenovo 230W töltők - 4X20Z83995
- AKCIÓ! ASUS PRIME Z390-P i5 8600K 16GB DDR4 512GB SSD RX 6600 8GB GDDR6 DEEPCOOL Matrexx55 630W
- HyperX Cloud Alpha Wireless + HyperX Cloud Alpha 2 Olvasd el
- iPhone 15 Pro 128GB, Szép állapot, Független, 100%, Garanciával!
