OLVASD VÉGIG ALAPOSAN MIELŐTT ÚJ HOZZÁSZÓLÁST ÍRNÁL!!!
Z10N
https://videocardz.com/newz/amd-raphael-zen4-am5-presentation-from-march-2020-leaks-out
Z10N
AMD next-gen AM5 platform to feature LGA1718 socket
- LGA-1718
- Dual-channel DDR5
- PCI-e 4.0
- 600 series chipset -
Z10N
Z10N
Aya Neo Founder is a handheld new gaming console with AMD Renoir SoC
"This console ships with AMD Ryzen 5 4500U system on a chip, which features Zen cores and AMD Vega 6 graphics. The CPU is limited to 6 cores and 6 threads, while Vega 6 offers 6 Compute Units (384 Stream Processors). With a default GPU clock of 1.5 GHz, we are looking at 1.1 TFLOPs of performance, almost 19 times slower than Radeon RX 6900XT.
According to the video posted by Aya, the mass production of the device is about to begin shortly. The pricing has been set to 3999 Yuans (605 USD) for the Founders Edition with 500GB storage. A model with 1TB of storage will cost 4599 Yuan (756 USD). That was an induction price that may increase as the development costs need to be covered."
Z10N
Z10N
AMD confirms to skip 4000 series, Zen3 CPUs are called Ryzen 5000
The announcement will take place exactly 10 hours from now.
Z10N
Nem 100%.
Z10N
Z10N
Z10N
Z10N
Kinek mi a tippje, hogy az SR3/5/7 hogyan fog megoszlani?
sr3: 4c/8t
sr5: 6c/12t
sr7: 8c/16tA 2-4 core-t gondolom meghagyjak az apu vonalra.
A masik az arazas. Az >1500cny nalam jelenleg (>$217), a <900cny pedig (<$130). Hogyan jottek ki a $300 es $180-s arak?
Z10N
Koszonom a kimerito valaszt. Meg annyit, hogy a cpu alap dolgai meg mik lesznek ilyen teren. Bar ugy nez ki nekem szuksegem lesz a Promontory-ra.
Mas: Az mitol lehet, hogy 785G es A55M bootolosnal laggol (caps, num, scrlk csak addig eg amig nyomvatartom, illetve par mp-vel kesobb reagal) vagy skippeli (egyaltan nem reagal es ps2 bill kell) az usb-s bill-t? A lag neha win alatt is elojon, foleg jatek kozben, de csak egy-ket specifikusnal.
Z10N
Panzika
#16971
Pedig az, mas nem lehet. Hacsak az AMD nem tert vissz a vaskos hangchippekhez
Mint mondtam az a szerencsenk, hogy nincs rajta, kulonben talalgatni se tudnank. Bar mar "alig" csinal valamit, igy nem nagyon melegedhet. Ideiglenes vrm hutes nincs
Visszaneztem es a Carizzoban mar egybe van az nb+sb.
Z10N
lezso6
#16972
Mert mondjuk mas egy 45W-s br-t etetni, mint egy 95W-s zen-t. Ezenkivul mar alapon is tud melegedni. Ertem en, hogy oem lap, de csak a nagyon budget lapoknal sporoljak le. Egy teszt lapnal meg nem jo ha throttlingol. Akkor a 2x6pin lesz a tap gondolom, ha nem koveti az atx szabvanyt.
Z10N
Nincs vrm hutes? Igy nagyobb zen-t nem tesztelhettek benne, max br-t. A ddr4 fogazata hova esik? Az megerositen a dolgot. Akkor meg szerencse, hogy a Promontory-ra nem kerult borda
Fura helyen van a sata, anno k8-nal volt ilyen. Hol az atx tap? Mi az a 2x6pin egymas mellett (fekete-feher). M2-t nem latok.dezz: bar igaz, hogy a kodneveket nem is hallani
Panzika: nezd meg jobban (szurke amd logoval)
Z10N
Ugy latszik le vagyok maradva. Mar minden integralva lett a cpu-ba es nem kell sb? Mondjuk, ha nelkule jonne akkor a pci fajna szamomra a studio dsp kartya miatt egyedul. Persze vehetnek pcie_x1-t megint 100k-ert, de csak ennyi lenne a kulonbseg. Ezenkivul meg a sata3/usb3 bovitonek is jol jonne a pcie_x1. Az usb3, sata3, pcie akkor benne van cpu-ban, szamszerint mennyit tud kezelni? A 24 pcie sav az kicsit szukos. Foleg aki sok bovitovel dolgozik. Cf/sli-t igy nem is lehet hasznalni. Mondjuk igy lehet arat csokkenteni es johet matx lapkent. Az m2 tovabbra is pcie savon van? A br-nek eleg lenne mar egy vga-val, de mar reg ki kellet volna adni, ha nem kell fch. A fch akkor csak sata3/usb3/pcei ad a platformhoz? Viszont mi lehet a gond, ha csak ilyen keves funkcioja van. Lehetseges, hogy az egysegesitett am4 vrm/fesz resze nem mukodik jol? Mondjuk egy kompakt matx platform eleg lenne egy zen apu-hoz + rx480-hoz
Z10N
Ezeket talaltam most.
Bar 2016 Apr 5.
Z10N
Yutani
#16630
Kivancsisagbol csinaltam egy CB R15 tesztet az 1090T-vel, bar 4200-n most nem kinoztam.
4000: 601 (friss inditas)
3900: 568 (munkamenet)
3800: 536 (munkamenet)nb2800
ht2400
dram1600-cl8Amit mondtal kijott a 0,025-s arany. Ebbol ket dolog latszik szamomra. Elsokent, hogy a Phenom2 meg mindig eleg szamomra es bizonyos esetekben meg mindig jobb a 4 modulos fx-nel. Illetve a zen-tol legalabb masfelszeres novekedest varnek minimum. Szoval cb900+ avagy 0,0375-t varnek el tole, ami ha jol nezem i7-4700 szint.
Simid kalkulacioja alapjan "0,0388 lenne ami már sokkal közelebb van a skylake-hez" ez kivitelezheto is lenne, mivel a sandy teljesitmenye mar keves (foleg a 0,032). Surun hasznalom a cinema4d-t szoval nem artana, ha hozna az elvarhatot. Bar studio munkanal (vst/transzponalas/wav render/stb.) meg kivalo az X6, de az x264@1080p-ben enkodolas mar neha kohog, nem beszelve az x265-rol. Gamer szempontbol meg van dx12
http://cbscores.com/
https://us.rebusfarm.net/en/tempbench?view=benchmark -
Z10N
Petykemano
#14947
Igazabol Excavator es GCN3 kellene. Ez igy ebben a formaban total felesleges, csak marketing megtevesztes. Az AMD az APU-k grafiakai tejesitmeny alapjan vezet, de nincs olyan pozicioban, hogy henyeljen. Minnel inkabb el kene huznia a konkurencia mellet, ahogy ok is csinaljak. Lehet a Zen miatt mar nem foglalkoznak ezzel.
Z10N
Nem ugy volt, hogy 2017 legkorabban a Summit/Bristol Ridge? Mondjuk mindegy, mivel a DDR4 arak ugy is kesobb allnak be. Az FM2+ a Kaveri-vel veget is er.
Z10N
Ezt most nem ertem, eddig ugy volt csak refresh. Az uj fonok lehet beleszolt a dolgokba?
Z10N
Balala2007
#14703
Ugy nez ki kovetkezo platform valtasnal mar csak alaplapot es apu-t kell venni, mivel meg a cut-down verzio is eleg lesz otthonra (se dgpu, se dram). Ha a HSA bevalik erdekes chip kiszerelesek lesznek. Mar csak a hotermeles es a hutes a kerdes.
Z10N
Volt mar? 16 Zen Cores with Greenland HBM GPU
Z10N
Ezek voltak mar?
Zen nyirbalas
Linux engedelyzes
Az ide nem illő hozzászólások topikja:[link]
A topik témája:
Az AMD éppen érkező, vagy jövőbeni új processzorainak kivesézése, lehetőleg minél inkább szakmai keretek között maradva.
- Hivatalos a Poco X8 Pro Max gigantikus akkukapacitása
- Futárcégek
- Epson nyomtatók
- Lightyear - befektetési app
- Arc Raiders
- GYÖNYÖRŰ iPhone 15 Pro Max 256GB White Titanium -1 ÉV GARANCIA - Kártyafüggetlen, MS4694
- NEC MultiSync V422 42" Monitor
- iPhone 13 mini 128GB Green -1 ÉV GARANCIA - Kártyafüggetlen, MS4052, 94% Akkumulátor
- Samsung Galaxy Book 3 Amoled 360 i5 13.gen, 16GB RAM, 512GB SSD, érintőkijelzős kedvező áron!
