OLVASD VÉGIG ALAPOSAN MIELŐTT ÚJ HOZZÁSZÓLÁST ÍRNÁL!!!
GIORGIONE76
TESCO-Zsömle
#23139
gondolom úgy vannak vele hogy ezt az ígéretet már korábban megtették, egy sorozat (át)jelölés kapcsán nem fognak szerintem rajta változtatni, azaz, a következő asztalikhoz megkapjuk a supportot,
legyen is így, mert akkor mehet a lap az apróra!
GIORGIONE76
TESCO-Zsömle
#23128
tom'sHARDWARE cikkben volt:
"AMD Zen 3 Ryzen 4000 Motherboards
With a new wave of chips about to crash down on the market, the first question on enthusiast's minds is: Can I drop a Zen 3 Ryzen 4000 chip in my motherboard?
If you have a B550, X570, B450, or X470 motherboard, the answer is yes. Ryzen 4000 series processors will drop into the tried-and-true AM4 socket, and AMD will support the chips on the aforementioned chipsets. Enthusiasts with 300-series motherboards are left in the cold, though, but you're probably better served by stepping up to more modern accommodations anyway.
The new BIOS revisions for existing 400-series boards will enable the full functionality of Zen 3 processors. However, you will still not gain access to the PCIe 4.0 interface on B450 and X470 motherboards (they don't support the interface). AMD says the 400-series BIOS updates come as a one-way path: You can flash your motherboard to the new firmware, but you will not be able to flash back to previous BIOS versions that support pre-Zen 3 processors.
AMD will also require an as-yet-undefined process that verifies you have purchased a Zen 3 processor. AMD says that verifying a customer has purchased a Zen 3 processor is designed to prevent irreversible BIOS flashing issues, but AMD's reasoning behind the forward-only flash requirement is unclear.
AMD's updates also mark the end of the line for 400-series motherboards: AMD will not support future processors on the platform."
de hogy miként fog majd a frissítés végbemenni az még titok
GIORGIONE76
TESCO-Zsömle
#23126
ezt a kört már lefutottuk, fog menni, csak kikukáznak legalább 1 gent tutira és még talán pár aput, csak nem tudni mi fér majd bele...
GIORGIONE76
még tíz nap és Lisa kiteríti a kártyáikat, de mikor jönnek az új bioszok
remélem az x470emnél a kis athlont nem kukázzák ki mert még frissíteni sem tudok majd
vagy olyannal is lehet frissíteni amit épp kiszednek belőle???
GIORGIONE76
TESCO-Zsömle
#23101
hát az árazást azért már sejtem,
de annak tekintetében nagyot kell ütnie
Az ide nem illő hozzászólások topikja:[link]
A topik témája:
Az AMD éppen érkező, vagy jövőbeni új processzorainak kivesézése, lehetőleg minél inkább szakmai keretek között maradva.
- Dell Latitude 5430 14" Touchscreen i5-1235U 16GB 512GB 1 év garancia
- Beszámítás! LENOVO LOQ 15AHP10 FHD Gamer notebook - R7 250 32GB DDR5 1TB SSD RTX 5050 Max-Q 8GB
- Akció!!! Sosemhasznált! HP OmniBook 5 Ultra 7 255U 5.2GHz 16GB 1000GB 16" FHD+ Gar.: 1 év
- 228 - Lenovo LOQ (15IRX10) - Intel Core i7-13650HX, RTX 5060
- DELL Precision 5540 Workstation i7-9850H Nvidia Quadro T2000 32GB 512GB 15.6" 1év garancia
