sanzi89
Tud valaki valami okosat az eBay-en, elég olcsón árult AMD Only ramokról? Egyáltalán mi ez, hogy AMD Only? Találtam egy teóriát neten - sőt, sok fórumban olvasni, hogy egyes Intel lapokban is mennek a ramok:
1) An industry standard DDR2 module must ship with an SPD chip to be compliant. (SPD = serial presence detect)
2) The SPD chip contains JEDEC information which identifies the RAM module to the PC bios .
3) The SPD chip may also include additional information to help the BIOS configure optimal memory settings.
4) Intel call this extra information XMP
5) AMD call this extra information EPP
6) If the PC bios cannot understand EPP or XMP is falls back to the JEDEC information.
7) All PC bios systems can understand JEDEC, irrespective of what other config data is on the SPD chip.
7) So, an industry standard DDR2 module could in theory contain JEDEC, XMP and EPP configuration data.
8) Which means (in theory) any DDR2 PC bios that can at least recognize the installed DDR2 module. (compatible ram timings or not)
9) It is an entirely separate issue if the RAM module timing specs are incompatible.(i.e. CL4 RAM in a "CL6 only" PC)Example 1:
I own an Intel PC that needs CL5 ram modules. I purchase an "AMD" CL5 ram module and install it. BIOS cannot read the AMD EPP info on the SPD but can recognize the CL5 timing info in the JEDEC data table. PC BIOS auto configures for the AMD ram module and boots normally.Example 2:
I own an AMD PC that needs CL6 ram modules. I purchase an "INTEL" CL6 ram module and install it. BIOS cannot read the INTEL XMP info on the SPD but can recognize the CL6 timing info in JEDEC data table. PC BIOS auto configures for the AMD ram module and boots normally.Example 3:
I own an INTEL PC that needs CL6 ram modules. I purchase an "AMD" CL4 ram module and install it. INTEL BIOS cannot read the AMD EPP info on the SPD but can recognize the CL4 timing info in JEDEC data table. PC BIOS recognizes module timings as incompatible an refuses to boot.Továbbá itt makognak valamilyen High Density ramokról, amiről életeben most hallottam először, továbbá random belelapoztam pár alaplap manual-jában, és egy mukkanás sincs erről.
Az egész kérdés úgy merült fel, hogy van egy HP Data Vault X510-es "bigyóm", amiben gyárilag 1 ram foglalat van, amien egy 2GB-os DDR2 csücsül, ezt szeretném 4GB-ra növelni. Elvileg ilyen típusú ramot fogad a gép:
PC2-6400 unbuffered DDR2 non-ECC 800MHz
Az egyik tulaj írta neten, hogy egy Kingston KVR800D2N6/4G-vel bővítette, de ha eBay-en rákeresek, akkor amit találok ezen típus alatt, az AMD Only...
sanzi89
Köszi. Egy gond van, hogy konfigként lett vásárolva egy helyi PC boltban, és ott a teljes konfigra adtak mindenestül 3 év garanciát. Gépház matricával zárva, a garanciajegy egy számla, hogy XY típusú konfig és kész. Tehát külön a memóriáról nincsen se számla se garanciajegy, sőt a konfig számláján is csak annyi szerepel, hogy 2GB DDR2-800 memória, se márka, se típus, se sorozatszám.
Mindegy, egy mailt eresztek a Kingmax-nak, arra pedig még nem tudtam rájönni, hogy ki a hazai forgalmazó. -
sanzi89
Volna egy 2GB-os DDR2-800-as Kingmax memóriám. A memória hibás, a bolt 3 év garanciát adott rá, a cucc 3 és fél éves. A gyártó 5 év garanciát ad a memóriáira, ezt hogyan tudnám érvényesíteni? Köszi a választ!
- ÁRGARANCIA!Épített KomPhone Ryzen 7 5700X 16/32/64GB RAM RTX 5060 Ti 16GB GAMER termékbeszámítással
- Suunto Sonic csontrezgéses fejhallgató
- Lenovo ThinkPad E15 Gen 2 15,6" - i7 1165G7, 16GB RAM, 512GB SSD, jó akku, számla, 6 hó gar
- Apple iPhone 15 Pro / 128GB / Kártyafüggetlen / 12Hó Garancia / Akku: 86%
- Akció! Csere-Beszámítás! Asus Zenbook 14 UM425IA! R7 4700U / 8GB / 512GB SSD!
fudi2002
