ödönke
Abit NF7-S
Chipset
- NVIDIA nForce2 SPP chipset with MCP2-T
- Integrated 128-bit memory controller
- Accelerated Graphics Port connector supports AGP 8X/4X (0.8V/1.5V)
Memory
- Four 184-pin DIMM sockets
- Supports 3 DIMM DDR 200/266/333 (Max. 3GB)
- Supports 2 DIMM DDR 400 (Max. 2GB)
Serial ATA
- On board Serial ATA PCI Controller
- Supports SATA data transfer rates 150MB/s (1.5G bps)
Audio
- 6-Channel AC 97 CODEC on board
- Professional digital audio interface supports 24-bit S/PDIF Out
- Supports real time AC-3 Encode by Soundstorm™ Technology
System BIOS
- SoftMenu™ Technology to set CPU parameters
- Supports Plug-and-Play (PNP)
- Supports Advanced Configuration Power Interface (ACPI)
- Supports Desktop Management Interface (DMI)
LAN
- On board 10/100Mb Operation supports ACPI & Wake on LAN
IEEE 1394
- Supports IEEE 1394a at 100/200/400MB/s transfer rate
Internal I/O Connectors
- 1 x AGP8X/4X, 5 x PCI slots
- 1 x Floppy Port supports up to 2.88MB
- 2 x Ultra DMA 33/66/100/133 Connectors
- 2 x SATA 150 Connectors
- 2 x USB 2.0 headers, 2 x IEEE1394 header
- 2 x CD-IN
- 1 x IrDA
Back Panel I/O
- 1 x PS/2 Keyboard, 1 x PS/2 mouse
- 2 x Serial, 1 x Parallel
- 1 x S/PDIF Out port
- Audio connectors (Front Speaker, Line-in, Mic-in, Center/Sub, Surround Speaker)
- 2 x USB 2.0, 1 x RJ-45 LAN Connector
Miscellaneous
- ATX form factor
- Hardware monitoring - Including Fan speeds, Voltages, System environment temperature -
ödönke
Epox 8RDA+
Processor AMD Athlon, Athlon XP, Duron
Core Logic nforce2 Platform Processor Chipset
BIOS Award/Phoenix BIOS v6.0
Max. FSB 333MHz
Memory 3 x DDR SDRAM PC3200, 3GB max.
Form Factor ATX
Expansion Slots
AGP 1, 8x
PCI 6, 32-bit
Ports
PS/2 1 mouse, 1 keyboard.
Serial 2
Parallel 1
USB 4 onboard, 2 optional. USB 2.0
Network 1 x Realtek RTL8201 PHY
Floppy 2 drives max.
IDE 2 x E/IDE Ultra DMA/133, 4 drives max.
Controllers
Sound Realtek ALC650E 6-channel full-duplex integrated sound
Option IEEE1394 Firewire interface
Special Features
Hardware Monitoring Function provided by Winbond
Keyboard Power On (KBPO)
Suspend To RAM (STR)
CPU clock settings are adjustable by BIOS
CPU V-core settings are adjustable by BIOS
Memory voltage settings are adjustable by BIOS
AGP voltage settings are adjustable by BIOS
Wake On Lan (WOL)
P80P Diagnostic LED
- VR topik
- Geri Bátyó: Agglegénykonyha különkiadás 2 – Kajás poénok
- Revolut
- Pedzegeti az új Xbox irányát a Microsoft
- Autós kamerák
- Doky586: SecureBoot kulcsok frissítése (2026 nyara)
- BESZÁMÍTÁS! ASRock A520M R5 5500 16GB DDR4 512GB SSD RTX 2060 6GB CM Masterbox MB311L ARGB 500W
- Samsung Galaxy S23 Ultra 8/256GB - Kártyafüggetlen, Fekete - 1 Év Garanciával
- Gamer PC-Számítógép! Csere-Beszámítás! R7 5700 / RTX 2080Ti 11GB / 16GB DDR4 / 1TB Nvme SSD
- HIBÁTLAN iPhone 15 128GB Yellow-1 ÉV GARANCIA - Kártyafüggetlen, MS4489, 100% Akksi
- AKCIÓ! Microsoft XBOX Series S 512GB játékkonzol garanciával hibátlan működéssel
