Keresés
robee24
Erre gondolsz:
Nvidia Reg Patch
his patch is a compilation of settings that the author has gathered which are designed to produce the best overall performance and quality of any Nvidia card using 5.xx and 6.xx Detonator drivers.
This program is a REG file, which means you simple click it to install. Make sure you back up your registry first. Instructions on how to do so are in the readme.txt file
Szintén ott van ez is! -
robee24
qpakcovboy
#3
Itt van néhány cucc Nvidiához:
http://www.voodoofiles.com/type.asp
Érdemes megnézni!
- BESZÁMÍTÁS! ASRock B550 R5 5600 16GB DDR4 512GB SSD RTX 4060 8GB Zalman S2 TG be quiet! 500W
- Noctua NH-L12S L-Type
- HP EliteBook 840 G7 i5-10210U 16GB 256GB FHD 400nit 1 év garancia
- iPhone gyári/emelt kapacitású akkumulátor csere 6 HÓNAP GARANCIÁVAL
- PlayStation Okosító Blu-ray lemezek - PS4 GoldHEN Loader / BD-JB Lapse és PS5 Auto Jailbreak AIO
