WiZARD
"First up, the phone can be configured to check out your calendar every morning and automatically download all sorts of information about the people, places, and companies you're going to visit, including maps -- an especially awesome feature if you're dealing with spotty 3G coverage. Even cooler, though, has to be the lateness notifier -- the phone uses GPS to determine where you are, compares it to where you're supposed to be at the moment, and if it figures out that you're screwed, it'll let you know. What's more, it can automatically email people to let them know that you've screwed up (just blame it on the traffic -- we always do). "
WiZARD
WiZARD
Operating system Palm® webOS™
Network specs 3G EVDO Rev A
3.1-inch touch screen with a vibrant 24-bit color 320x480 resolution HVGA display
Keyboard Physical QWERTY keyboard
Built-in GPS
3 megapixel camera with LED flash and extended depth of field
Ambient light, accelerometer, and proximity sensors
Wi-Fi 802.11b/g with WPA, WPA2, 801.1x authentication
Bluetooth® 2.1 + EDR with A2DP stereo Bluetooth support
Memory 8GB of user storage (~7.4GB user available)
USB mass storage support
Phone as laptop modem
Bluetooth tethering
MicroUSB connector with USB 2.0 Hi-Speed
Headphone jack - 3.5mm stereo
Palm® Touchstone™ charging dock Compatible
Dimensions
Width: 59.5mm (2.3 inches)
Height: 100.5mm (3.9 inches)
Thickness: 16.95mm (0.67 inches)
Weight 135 grams (4.76 ounces)elsőre nagyon tetszik. os-re kiváncsi leszek.
kapacitív multitouch kijelző, mint a szifonban[ Módosította: Viktor0610 ]
- Óvodások homokozója
- talmida: Változások 2. rész
- GL.iNet OFF topik
- Samsung kuponkunyeráló
- Revolut
- Dell Core i5 - i7 - 8-10-11-12. gen. üzleti kategóriás notebookok számlával
- GYÖNYÖRŰ iPhone 13 Pro Max 256GB Graphite -1 ÉV GARANCIA - Kártyafüggetlen, MS4522
- ÁRGARANCIA!Épített KomPhone Ryzen 5 7500F 32/64GB RAM RTX 5060 Ti 8GB GAMER PC termékbeszámítással
- Használt Palladium G-Lab angol games billentyűzet / 12 hó működési garancia
