Headless
SimpleXML-el akadt egy kis problémám.
van egy ehhez hasonló XML-el. (ArchiCad .ifcxml)
Van benne namspace, schema, minden. egyszerűen nem jöttem rá a kiolvasásra.
<?xml version="1.0" encoding="UTF-8"?>
<ex:iso_10303_28 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:ex="urn:iso.org:standard:10303:part(28):version(2):xmlschema:common" xsi:schemaLocation="urn:iso.org:standard:10303:part(28):version(2):xmlschema:common ex.xsd" version="2.0">
<ex:express id="exp_1" external="" schema_name="IFC2X3">
<!--external: When the EXPRESS schema is represented 'by-reference', the external XML attribute shall be present and its value shall identify a resource that contains the EXPRESS schema (text).-->
<!--schema_identifier: For an EXPRESS schema that is defined by a Part of ISO 10303 schema_identifier shall contain the ASN.1 (official identifier for a part of 10303 ) identifier value associated with that schema by that Part of ISO 10303-->
<!--Internal schema is not supported.--> </ex:express>
<ex:schema_population governing_schema="exp_1" determination_method="SECTION_BOUNDARY" governed_sections="uos_1">
<!--governing_schema: IDREF to ID of express_schema element-->
<!--governed_sections: IDREFS to ID of uos elements-->
<!--section_boundary: Algorithm used for selecting entities within uos. See Annex F of ISO10303-28--> </ex:schema_population>
<ex:uos id="uos_1" description="" schema="exp_1" configuration="i-ifc2x3" edo="" xmlns="http://www.iai-tech.org/ifcXML/IFC2x3/FINAL" xsi:schemaLocation="http://www.iai-tech.org/ifcXML/IFC2x3/FINAL ifc2x3.xsd">
<IfcPerson id="i1637">
<FamilyName>Nincs megadva</FamilyName>
</IfcPerson>
<IfcOrganization id="i1639">
<Name>Nincs megadva</Name>
</IfcOrganization>
</ex:uos>
</ex:iso_10303_28>Például az IfcOrganization-ökön végig gyalogolni.
print_rsemmi használhatót nem ír, de azt olvastam, hogy namespace-ek esetében ez normális.
- Windows 10
- Autós kamerák
- Apple MacBook
- Házimozi belépő szinten
- Tarr Kft. kábeltv, internet, telefon
- Gyúrósok ide!
- ASUS TUF Gaming VG279QM1A IPS 280hz
- Eladó iPhone 15 Pro Max 512 GB tökéletes műszaki állapotban
- ÁRGARANCIA! Épített KomPhone i5 12400F 16/32/64GB RAM RX 9060 XT 16GB GAMER PC termékbeszámítással
- AOC C27G4ZXU FHD / 280hz / 0.3ms
- ÁRGARANCIA! Épített KomPhone R7 5700X 16/32/64GB RAM RX 9060 XT 16GB GAMER PC termékbeszámítással
- Lenovo ThinkPad T14S Gen1 Ryzen5 4650U Refurbished - Garancia
- Xiaomi Redmi 9T 64GB, Kártyafüggetlen, 1 Év Garanciával
- 0perces DDR5 5600 vadiúj Ramaxel 2x16GB memória 1 év garancia
- Akció!!! Sosemhasznált! HP OmniBook 5 i7-1355U 16GB 512GB 16" FHD+ Gar.: 1 év
- iPhone 17 256 GB Levander - Bontatlan !! www.stylebolt.hu - Apple eszközök és tartozékok - Számlás
