Jim-Y
Jim Tonic
#6418
Hát, pedig ezt írja ki:
Array assignment to [Village People - YMC ...] failed: Cannot convert value "Village People - YMCA.mp3" to type "System
.Int32". Error: "Nem megfelelő a bemeneti karakterlánc formátuma.".
At E:\_ATTILA\SCRIPTS\checkMusic.ps1:8 char:13
+ $multiples[ <<<< $key] = $value
+ CategoryInfo : InvalidOperation: (E:\_ATTILA\70\Village People - YMCA.mp3
SObject) [], RuntimeExceptio
n
+ FullyQualifiedErrorId : ArrayAssignmentFailedkód:
$multiples = @()
foreach($elem in $files){
$key = $elem.Name.toString()
$value = $elem
$multiples[$key] = $value
Jim-Y
Jim Tonic
#6416
Mert mindenképp Int32-t szeretne kulcsnak
Példa:$files = get-childitem ... //fájlok beolvasása
$hashTable = @() //hashtable inicializálás
foreach($hash in $files){
//ezek közül egy se működött valamiért:(
$hashTable.$hash.Name = $hash
$hashTable[$hash.Name] = $hash
$hashTable["$hash.Name"] = $hash
$hashTable += {name=$hash.Name,value=$hash}
}több ötletem így hirtelen nem volt :/
Jim-Y
Közben próbálkoztam 1-2 dologgal
1: az eredeti
$loc = get-location
$files = get-childitem -Path $loc -Recurse | where {$_.Length -gt 0}
$length = $files.length
$multiples = @()
$rows = 0
$groups = 0
[int]$10n = $length*0.1
[int]$20n = $length*0.2
[int]$30n = $length*0.3
[int]$40n = $length*0.4
[int]$50n = $length*0.5
[int]$60n = $length*0.6
[int]$70n = $length*0.7
[int]$80n = $length*0.8
[int]$90n = $length*0.9
[int]$100n = $length
for($i=0;$i -lt $length;++$i){
$ismultiple = 0
$tempi = $files[$i]
switch($i)
$10n { write-host "10%" }
$20n { write-host "20%" }
$30n { write-host "30%" }
$40n { write-host "40%" }
$50n { write-host "50%" }
$60n { write-host "60%" }
$70n { write-host "70%" }
$80n { write-host "80%" }
$90n { write-host "90%" }
$100n { write-host "100%" }
if($multiples -contains $tempi.FullName){ } else {
for($j=$i+1;$j -lt $length;++$j){
$tempj = $files[$j]
if($tempj.Name -eq $tempi.Name -and $tempj.Length -eq $tempi.Length){
$multiples += $tempj.FullName
$rows++
$ismultiple = 1
if($ismultiple){
$multiples += $tempi.FullName
$rows++
$groups++
$multiples += "`n"
$multiples += "$loc folder has $length files, there are $groups files multiplied,`n and you could delete $($rows-$groups) files from the $rows multiplications!"
$multiples > multiples.txtEz a tesztmappán ~21-22mp-ig futott
2: nem tömbbe írós, hanem fileba:
Ebben a verzióban a $multiples tömb helyett amit a végén fájlba írok, egy fájlhozz appendelem szekvenciálisan a dolgokat
$multiples = @() -> New-Item multiples.txt -type file -force
$multiples += $files[$j].FullName ->
Add-Content multiples.txt -value $files[$j].FullName
stb..Ez a tesztmappán 1-2mp-el futott hosszabb ideig mint az első
3: hashmap
Sajnos nem sikerült olyan sszociatív tömböt csinálnom ahol a key-nek megette volna a fájl nevét
Így egy .NET-es ArrayList-el próbálkoztam. Sajnos ez fut legtovább, a tesztmappán olyan 24mp-ig..$loc = get-location
$hashTable = New-Object System.Collections.ArrayList(,(get-childitem -Path $loc -Recurse | where {$_.Length -gt 0}))
$duplications = New-Object System.Collections.ArrayList($null)
$rows = 0
$groups = 0
$length = $hashTable.Count
$ism = 0
if($duplications.Contains($hashTable.Item($i).FullName)){ } else {
$temp = $hashTable.Item($i)
$tempj = $hashTable.Item($j)
if($tempj.Name -eq $temp.Name -and $tempj.Length -eq $temp.Length){
$duplications.Add($tempj.FullName)
$rows++
$ism = 1
if($ism) {
$rows++
$groups++
$duplications.Add($temp.FullName)
$duplications.Add("`n")
Write-Host "$length files, there are $groups files multiplied,`n and you could delete $($rows-$groups) files from the $rows multiplications!"
$duplications > multiples.txtMost véletlenül az egész partíció gyökerére futtattam le az első verziót, 10perc alatt csinált meg 10%-ot
Jim-Y
Sk8erPeter
#6411
Nagyon ráérek, és ahogy ez lenni szokott, persze nem tanulással töltöm a feles időt
Ezzel kezdtem, így jutottam el a lentiig. -
Jim-Y
Magát a tömböt összeírni alig pár másodperc, nem az a hosszú, hanem ami a for ciklusban van, csináltam egy olyan kiiratást ami 10 százalékonként kiír a képernyőre, bár ez nem mutatja meg, hogy ténylegesen mi a sok idő...
Ami ötletem még van, az az, hogy ha egy fájlhoz összeszedi a duplikációkat, akkor azokat kitörli a tömbből, így a következő vizsgálandó fájlnál már annyival kevesebb elemet kell végignézni, bár ha kevés a duplikáció a mappában, akkor ez szinte semmit nem segítene. A másik ötletem, hogy az is lassú lehet amikor valamit hozzáadok a $multiples tömbhöz, mert elméletileg ilyenkor mindig készít egy másolatot az aktuális tömbről, legalábbis valami ilyesmit olvastam a neten, tehát lehet ezt a tömbhöz hozzáadok dolgot ki kéne cserélni valamire, például arra, hogy már az elején hozzon létre egy fájlt, majd utána csak appendoljon hozzá, hátha így gyorsabb lesz... majd mindjárt kipróbálom.
Jim-Y
PowerShellben csináltam egy olyan scriptet ami egy directoryban rekurzívan megnézi a duplikációkat, és a duplikált állományok nevét kigyűjti egy fájlba.
A problémám az, hogy az algoritmus amit használtam/írtam nagyon lassú. Ha ~2000 fájlt kell összehasonlítania az még viszonylag gyors 10,15mp, de 5500 állománnyal már percek óta szöszöl :S
megj: közben 2-3 perc múlva végzettAz ilyen rekurzív összehasonlítgatós dolgokat hogyan lenne célszerű megoldani?
Jelenleg a kódom:
$loc = get-location
$multiples = @()
$ismultiple = 0
if($multiples -contains $files[$i].Name){ } else {
$elem = $files[$i]
if($files[$j].Name -eq $elem.Name -and $files[$j].Length -eq $elem.Length){
$ismultiple = 1
if($ismultiple){
$multiples += $elem.FullName
$multiples += "`r`n`r`n"
$multiples > multiples.txtLátható, hogy először kigyűjtöm a fájlneveket egy tömbbe, majd az első rekordot keresem a fennmaradó elemek között, ha van duplikáció, akkor kiírom azokat a fájlba, és ugrok a második elemre.
Szinte biztos vagyok benne, hogy van ennél hatásosabb módszer, de már túl késő van ahhoz, hogy rájöjjek, hogy mi az
megj: haha, lehet csak azért szöszölt annyit, mert muter fél mappája duplikált, egy rahedli duplikációja van
Jim-Y
Sk8erPeter
#6347
Laborra lehet menni BsC-n is, t.k egy projektmunka, de tudtommal nincs kreditértéke, tehát csak olyanok mennek akiket érdekel a téma, vagy sok szabadidejük van. Gyakorlat szinte mindenből van, ellenben hardvert semmihez sem használtunk, egyszer még az elején kinyitottunk egy gépházat és kábé ennyi, ilyen szempontból egyáltalán nem gyakorlatias..
Jim-Y
Van grafika, C szakirányon is, OpenGL + DirectX
Azért így is maradt elég sok matek..
Analízis x4
Lineáris Algebra x1
Numerikus Módszerek x2
Diszkrét Matematika x2
Valószínűségszámítás x1asszem ennyi
Mondjuk így, hogy már megvan a diplomám nem bántam meg, hogy ide jöttem és nem a BME-re. De véleményem szerint nehéz lenne megmondani, hogy melyik jobb, nem hiszem, hogy a BME-t könnyebb lenne elvégezni, vagy fordítva.
Én BMF-ről hallottam még, mai nevén Óbudai Egyetem, az is felejtős, nagy vicc az egész
Jim-Y
Sk8erPeter-el értek egyet, mindkét képzés jó, azt válaszd amelyik hozzád közelebb áll:
matek -> ELTE
fizika -> BMEIgazából tök mindegy melyiket csinálod meg, ha van egy kis sütnivalód, akkor egyetem után mindkét diplomával fogsz állást kapni...
Jim-Y
Üdv, nekem az lenne a kérdésem, hogy a JSP mennyire van jelen még? Lenne egy feladat, amit ebben kéne megcsinálnom, de azt is hallottam, hogy eléggé leszálló ágban van, és a legtöbb helyen már JSF-et használnak. Nektek erről mi a véleményetek?
Jim-Y
gondoltam jelzem, hogy tényleg van az apinak egy heatlayeres része, ami úgy néz, ki, hogy jó lesz nekem
Jim-Y
Használta már valaki közületek a Google Maps API v3-at a HeatMapAPI-val?
Adatokat szeretnék megjeleníteni magayarország térképen, és első blikkre a fenti két toolt találtam alkalmasnak erre. Ha valaki ebben a témában otthon van, vagy csináltált már ilyet, vagy tudna valami tényleg jó, és használható tutorialt linkelni, vagy annyit tudna segíteni, hogy milyen toolokat érdemes erre használni, azt megköszönném. Üdv -
Jim-Y
peter9228
#6146
Hát, meg ez annyira nem triviális kérdés, mert a Perl/Python scriptnyelv, míg a Java,C++,C# nem. Lehet azért ajánlották a Pythont, mert azokat a feladatokat, amiket kaphattok érettségin egy scriptnyelvben könnyebb megvalósítani, meg gyorsabb is. Ha így van, akkor vagy a Python vagy a Perl legyen, nekem utóbbival van tapasztalatom, nem rossz. De ha az érettségi feladat megoldása nem szempont, akkor Java vagy C#, mert ezeknek később hasznát fogod venni! Nagyobb hasznát mint egy scriptnyelvnek, mert míg előbbieket relatíve nehezebb megtanulni, vagy legalábbis több idő, addig egy felaldatot megoldani perlben vagy pythonban kevesebb utánaolvasást igényel.
Jim-Y
Nekem egy olyan kérdésem lenne, hogy a Windows Run-ról hol tudok mélyrehatóbban olvasni? Googlis keresés nem járt sikerrel. Azt szeretném kideríteni, hogy hogyan tudnám rávenni a run-t, hogy én adhassam meg, hogy mit, milyen névvel indítson?!
Bővebben: ha beírom, hogy firefox, akkor azt megnyitja, ha beírom, hogy iexplore, akkor az Explorert nyitja meg, kérdésem, hogy milyen mappában lévő exéket nyit meg, illetve pl a Chrome.exe-t hova rakjam, hogy a "chrome"-ot begépelve elindítsa pl a chromot?
Nem lehet erről bővebben olvasni valaol, hogy hogy működik a Run?
Én így nyitom meg a calculátort, a paintet, a kedvenc böngészőmet, és ezt szeretném még több installált programra kiterjeszteni. Előre is köszi, üdv
Jim-Y
Kéne írnom egy szerver oldali programot PHP-ban,mivel szerver oldali dolgokat nem kódoltam még, csak kliens oldalit, ezért nem tudom hogyan kéne hozzákezdeni. 2 google keresés közben hozzátok fordulok linkekért, tanácsokért.
Kezdetben annyi lenne a program dolga, hogy feldolgozzon egy bejövő kérést. De nekem még csak nem is magával a kóddal lenne a legnagyobb gondom, hanem a többivel. Gondolok itt arra, hogy hogy szokott ez menni? Csak simán feltöltöm a szerverre a kódom ami lekezeli a kérést? A szerveren futó alkalmazásokkal nem fog összeveszni? Vagy úgy irom a kódot, hogy egy bizonyos porton érkező kéréseket kezeljen? Ez a gond, hogy még soha nem láttam közelről webservert, és nem tudom hogy működik..:S
Jim-Y
Sk8erPeter
#5572
Kicsit már belekavarodtam sajnos, meg sem tudom mondani már, hogy mi oldotta meg:/ Kezdek fáradni
Jim-Y
Sziasztok, kis help jól jönne, Java:
String line;
for (line = freader.readLine(); line != null; line = freader.readLine()) {
String[] user = line.split(":");
System.out.println("Current user :: " + currentUser);
System.out.println("Felhasznalonev :: " + user[0]);
System.out.println("Jelszo :: " + user[1]);
if(user[0].equals(currentUser)) {
writer.println(user[1]);
writer.flush();
freader.close();
writer.println("null");
writer.flush();freader egy fileból olvas aminek 4 sora van, íme:
alpha:111
beta:222
charlie:333
tango:444A kódban ezek:
System.out.println("Jelszo :: " + user[1]);csak debug miatt vannak. A probléma az, hogy nem működik jól, azt szeretném elérni, hogy:
- a currentUser-ben az van, hogy "alpha"
- ezt keresse meg a fileban, ha megtalálta, akkor a hozzá tartozó jelszót küldje rá a socketre, itt a writer jelenti a socketet.Sajnos most úgy működik, hogy:
- a currentUserben szépen benne van, hogy alpha
- a fileon is szépen végigiterál
- de visszaküldeni már null-t küd és nem a jelszót:SSzerintem valamilyen alapvető szintaktikai hiba van benne, olyasmire gyanakszom, hogy amikor megtalálja az alpha-t a fileban akkor vagy nem áll meg és küldi el a hozzá tartozó jelszót, vagy simán nem küldi el valamiért:/ ötlet? üdv
mod: arra közben rájöttem, hogy a végére nem kéne a writer.println("null") , mert így ezt mindig elküldi, az meg nem jó:/ Hogy tudom azt megcsinlni, hogy null-t csakis akkor küldjön ha nincs currentUser a fileban? üdv
Jim-Y
Geriman25
#5243
Uhh, hát azért először jó lenne kicsit böngészni a wikipediát a témában, hogy azért tisztában legyél az alap dolgokkal, írd be a wiki keresőbe, hogy programozás, és kezdj el olvasni, a linkeken keresztül kiterjeszteni a tudásod.
Nagyon pongyolán, ha webre akarsz programozni, weboldal alá akarsz programkódot írni, akkor PHP,javascript,html,css, html-dom,jquery,AJAX ... ezek nézd át.
Ha meg objektum orientáltan akarsz programozni akkor ismerkedj meg a JAVA nyelvvel, vagy ha az egyik
legrégebbitlegelterjedtebbet akarod megtanulni akkor C++, vagy ha az újak közül, ASP .NET, C#. -
Jim-Y
Sziasztok, szeretném ha valaki akinek van egy szabad délutánja, és össze tudna dobni egy ehhez hasonló dinamikus honlapot, az jelezze, tervezünk többen egy ehhez hasonlót csinálni, csak pc-házas témában, és kéne hozzá programozói support, hogy később is lehessen szerkeszteni, ha 1-1 új termék megjelenik a piacon, akkor azt fel tudjuk majd tölteni a táblázatba. Ha valakinek lenne kedve, egy ilyen honlapot leprogramozni, akkor azt megköszönjük, ha nem akkor felkeresem ezen honlap készítőjét, hátha ebben is partner lenne, de egyből nem akartam ezzel terhelni, ezért kérdezem meg itt először, üdv
Jim-Y
Sziasztok, szeretnék valakitől segítséget kérni 3-4 SQL parancs legenerálásához, ergo 3 feladat megoldásához
1-1 feladat megoldása cca 2 sor
Jim-Y
Igazából a programozáshoz matematikai logika kell legfőképp, illetve sok gyakorlás 1-1 programnyelvre lebontva, szerintem attól, hogy egy, vagy több logikai játékkal foglalkozol, még nem fog jobban menni a programozás:S
Inkább találj egy olyan programnyelvet amivel sulin kívül is szivesen foglalkozol, abba ásd bele magad, érd el, hogy szívesen programozz benne, ha ez megvan akkor lehet, hogy már a többi is könnyebben fog menni ..
Jim-Y
[pod]Diablo
#5066
Szia, szerintem biztos, sajnos most nem tudok konkretumot irni, de win PowerShellben szerintem nagyon egyszeruen lehet ilyen programot irni. PS win7 ota alapbol megtalalhato az OSben.
Jim-Y
lejárt az időlimit én meg össze-vissza szórakoztam a konvertálatlan/programkód bizbaszokkal, szoval:
var nap = 0;
bool volte = false;
int eljárás Eldont(bevetel_tomb b,kiadas_tomb k) {
ciklus 0..b.length()-ig {
if(k[i] > b[i]) {
nap = i+1;
volte = true;
return 0; // vagy akár visszatérési értékben visszadhatod a 'nap' -ot is.
Jim-Y
Sziasztok, van itt valaki aki tud nekem segíteni egy picit javascriptben?^^
Jim-Y
Sziasztok, prog.hu nem küldte ki a regisztrációs emailt szv itt teszem fel a kérdést:
javascript / HTML -ről van szó:van egy következő iframeem:
<iframe name="chPageName" src="default.html" id="chPageFrame" scrolling="no" frameborder="0" height="270" width="340"></iframe> -> ennek most csak a teszt kedvéért van height és width értéke, ezeket 0-ra fogom állítani ,mert hiddenként fogom használni, ez egy external URL-re mutat. Le szeretném kérdezni scripttel az iframepage contentjét, kéne belőle a getElementsByTagName('td')... egy csomó helyen rákerestem de mindenhol vagy olyan megoldás volt ami a korábbi böngészőkön működött, vagy amit csak én nem tudtam megcsiálni
kéne olyan megoldás ami a legújabb FF-on és IE-n is mükszik
köszi
- Házimozi haladó szinten
- TCL LCD és LED TV-k
- Elektromos autók - motorok
- Bambu Lab 3D nyomtatók
- Szintet lépett "lopakodó" alaplap készül a Colorful műhelyében
- Horgász topik
- GIGA AKCIÓ!!! AKTIVÁLATLAN iPad Air M3 13" WiFi 256GB! KÉK
- Dell Optiplex 390 MT,i3-2130,4GB RAM,500GB HDD,WIN10
- LG 27GS95QE - 27" OLED / QHD 2K / 240Hz & 0.03ms / 1000 Nits / NVIDIA G-Sync / AMD FreeSync
- Részletfizetés. BankMentes. Kamatmentes. Új noblechairs EPIC műbőr FEKETE - KÉK 3 év garancia!
- iKing.Hu - Apple iPhone 13 Pro Max Graphite ProMotion 120 Hz, Pro kamerák 256 GB-100%-3 hó gari!
köszi^^
haha
, otthon kipróbálom, melóban nem tudok belépni a sysadvancedsettings-be.. :/
