A 10. oldalnál a „A projekt létrejötte után..”-nal kezdődő bekezdésnél elakadtam...
Output:
ant -f /home/balazs95/NetBeansProjects/J2MECalc -Ddist.jad.url=http://localhost:8082/servlet/org.netbeans.modules.mobility.project.jam.JAMServlet//home/balazs95/NetBeansProjects/J2MECalc/dist//J2MECalc.jad run
pre-init:
pre-load-properties:
exists.config.active:
exists.netbeans.user:
exists.user.properties.file:
load-properties:
exists.platform.active:
exists.platform.configuration:
exists.platform.profile:
basic-init:
cldc-pre-init:
cldc-init:
cdc-init:
semc-pre-init:
semc-init:
savaje-pre-init:
savaje-init:
sjmc-pre-init:
sjmc-init:
ojec-pre-init:
ojec-init:
cdc-hi-pre-init:
cdc-hi-init:
nokiaS80-pre-init:
nokiaS80-init:
post-init:
init:
conditional-clean-init:
conditional-clean:
deps-jar:
pre-preprocess:
do-preprocess:
Pre-processing 0 file(s) into /home/balazs95/NetBeansProjects/J2MECalc/build/preprocessed directory.
post-preprocess:
preprocess:
pre-compile:
extract-libs:
do-compile:
post-compile:
compile:
pre-obfuscate:
proguard-init:
skip-obfuscation:
proguard:
post-obfuscate:
obfuscate:
lwuit-build:
pre-preverify:
do-preverify:
post-preverify:
preverify:
pre-jar:
set-password-init:
set-keystore-password:
set-alias-password:
set-password:
create-jad:
add-configuration:
add-profile:
do-extra-libs:
nokiaS80-prepare-j9:
nokiaS80-prepare-manifest:
nokiaS80-prepare-manifest-no-icon:
nokiaS80-create-manifest:
jad-jsr211-properties.check:
jad-jsr211-properties:
semc-build-j9:
do-jar:
do-jar-no-manifest:
update-jad:
Updating application descriptor: /home/balazs95/NetBeansProjects/J2MECalc/dist/J2MECalc.jad
Generated "/home/balazs95/NetBeansProjects/J2MECalc/dist/J2MECalc.jar" is 934 bytes.
sign-jar:
savaje-prepare-icon:
savaje-build-jnlp:
post-jar:
jar:
pre-run:
netmon.check:
open-netmon:
cldc-run:
Copying 1 file to /home/balazs95/NetBeansProjects/J2MECalc/dist/nbrun5081933253332984433
Jad URL for OTA execution: http://localhost:8082/servlet/org.netbeans.modules.mobility.project.jam.JAMServlet//home/balazs95/NetBeansProjects/J2MECalc/dist//J2MECalc.jad
Starting emulator in execution mode
java.lang.UnsatisfiedLinkError: /home/balazs95/file/WTK2.5.2/bin/sublime.so: /home/balazs95/file/WTK2.5.2/bin/sublime.so: hibás ELF osztály: ELFCLASS32 (Possible cause: architecture word width mismatch)
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary1(ClassLoader.java:1939)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1864)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1825)
at java.lang.Runtime.load0(Runtime.java:792)
at java.lang.System.load(System.java:1059)
at com.sun.kvem.Sublime.<init>(Sublime.java:29)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:525)
at java.lang.Class.newInstance0(Class.java:374)
at java.lang.Class.newInstance(Class.java:327)
at com.sun.kvem.Lime.createLime(Lime.java:40)
at com.sun.kvem.KVMBridge.<init>(KVMBridge.java:46)
at com.sun.kvem.KVMBridge.getBridge(KVMBridge.java:37)
at com.sun.kvem.midp.MIDP.run(MIDP.java:699)
at com.sun.kvem.environment.EmulatorInvoker.runEmulatorImpl(EmulatorInvoker.java:107)
at com.sun.kvem.environment.EmulatorInvoker.main(EmulatorInvoker.java:135)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:601)
at com.sun.kvem.environment.JVM.main(JVM.java:103)
/home/balazs95/NetBeansProjects/J2MECalc/nbproject/build-impl.xml:782: Execution failed with error code 1.
BUILD FAILED (total time: 1 second)
Szeretnék megtanulni j2me-ben programozni, de elképzelésem sincs, hogy hogyan kezdjek hozzá.
valaki tudna segíteni benne?
- E-roller topik
- Kedvenc zene a mai napra
- Kicombosította az M5-ös SoC-családot az Apple
- Megérkezett az Apple 5K-s, 120 Hz-et biztosító monitora
- MWC 2026: Farsangra Galaxy Ultrának öltözött a gyerek
- Gtx 1080/ Intel I7 8700K/ 16GB Ram/ 256GB M2 SSD/ 1TB HDD/ Win11
- Gtx 1050Ti/ Intel I5 7500/ 16GB Ram/ 256GB Sata SSD/ 1.5TB HDD/ Win11
- Gtx 1050Ti/ Intel I5 7500/ 16GB Ram/ 128GB M2 SSD/ 1.5TB HDD/ Win11
- Acer Aspire 3 A317-53-76NV. Intel 11.gen I7 / 16Gb ram / 512Gb ssd / 17,3"
- Intel 545S 512GB M2 Sata SSD
- BESZÁMÍTÁS! Gigabyte B450M R5 5 2600 8GB DDR4 512GB SSD GTX 1650 4GB ZALMAN T3 Plus Deepcool 400W
- iPhone 15 Pro Max 256GB 100% (1év Garancia)- AKCIÓ
- Lenovo LEGION 5 PRO Ultra 7 255HX 24GB RAM 512GB SSD RTX 5070 8GB 16" QHD+ 3év Prémium GAR
- Prémium iPhone 15 Pro Max 256 GB tárhellyel, 100%-os akkumulátorral (5 ciklus) és 6 hónap garival
- Új és használt laptopok , üzletitől a gamerig , kedvező áron. Garanciával !
