Marcelldzso
Azt hiszem vonalon vagyok ezzel a parancssal:
storcli /cx/cv start learn
Azt meg tudja valaki mondani, hogy 128MiB-el vagy 256-al mérve miért ilyen nagy a különbség?
5 mintavétel esetén is ennyi.
Marcelldzso
Marcelldzso
#11231
Meg ez... többet nem spammelek!
Firmware_Status :
Property Value
NVCache State OK
Replacement required No
No space to cache offload No
Module microcode update required No
GasGaugeStatus :
Property Value
Pack Energy 237 J
Capacitance 105 %
Remaining Reserve Space 0
Marcelldzso
Marcelldzso
#11230
Egy ilyenem van még pluszban.
Hasonlóak az eredmények mint fudi2002 kikapcsolt cache mellett.
[root@esxi:/opt/lsi/storcli] ./storcli /c0/v0 show all
CLI Version = 007.0525.0000.0000 Aug 13, 2018
Operating system = VMkernel 6.7.0
Controller = 0
Status = Success
Description = None
/c0/v0 :
DG/VD TYPE State Access Consist Cache Cac sCC Size Name
0/0 RAID10 Optl RW Yes RWBC - ON 14.552 TB sasVD
Cac=CacheCade|Rec=Recovery|OfLn=OffLine|Pdgd=Partially Degraded|Dgrd=Degraded
Optl=Optimal|RO=Read Only|RW=Read Write|HD=Hidden|TRANS=TransportReady|B=Blocked|
Consist=Consistent|R=Read Ahead Always|NR=No Read Ahead|WB=WriteBack|
AWB=Always WriteBack|WT=WriteThrough|C=Cached IO|D=Direct IO|sCC=Scheduled
Check Consistency
PDs for VD 0 :
EID:Slt DID State DG Size Intf Med SED PI SeSz Model Sp Type
252:1 17 Onln 0 7.276 TB SAS HDD N N 4 KB HUS728T8TAL4204 U -
252:0 18 Onln 0 7.276 TB SAS HDD N N 4 KB HUS728T8TAL4204 U -
252:3 15 Onln 0 7.276 TB SAS HDD N N 4 KB HUS728T8TAL4204 U -
252:2 16 Onln 0 7.276 TB SAS HDD N N 4 KB HUS728T8TAL4204 U -
EID-Enclosure Device ID|Slt-Slot No.|DID-Device ID|DG-DriveGroup
DHS-Dedicated Hot Spare|UGood-Unconfigured Good|GHS-Global Hotspare
UBad-Unconfigured Bad|Onln-Online|Offln-Offline|Intf-Interface
Med-Media Type|SED-Self Encryptive Drive|PI-Protection Info
SeSz-Sector Size|Sp-Spun|U-Up|D-Down/PowerSave|T-Transition|F-Foreign
UGUnsp-Unsupported|UGShld-UnConfigured shielded|HSPShld-Hotspare shielded
CFShld-Configured shielded|Cpybck-CopyBack|CBShld-Copyback Shielded
VD0 Properties :
Strip Size = 256 KB
Number of Blocks = 3906727936
VD has Emulated PD = No
Span Depth = 2
Number of Drives Per Span = 2
Write Cache(initial setting) = WriteBack
Disk Cache Policy = Enabled
Encryption = None
Data Protection = Disabled
Active Operations = None
Exposed to OS = Yes
OS Drive Name =
Creation Date = 03-01-2017
Creation Time = 11:10:43 PM
Emulation type = default
Cachebypass size = Cachebypass-64k
Cachebypass Mode = Cachebypass Intelligent
Is LD Ready for OS Requests = Yes
SCSI NAA Id = 600605b009c519101ffeebf33ec8b5f5
SCSI Unmap = No -
Marcelldzso
Megnézitek ezt nekem?Kolléga cache-elt eredményein felbuzdulva megnéztem mik a beállításaim egy
LSI 9361-4i vezérlőn.
FW Package Build = 24.21.0-0148
BIOS Version = 6.36.00.3_4.19.08.00_0x06180205
FW Version = 4.680.00-8555
Driver Name = lsi-mr3
Driver Version = 7.708.07.00
Current Personality = RAID-Mode
Cachevault_Info :
Model State Temp Mode MfgDate
CVPM02 Optimal 29C - 2017/03/18
------------------------------------Én úgy látom, hogy a cache nincs bekapcsolva és a BBU sem üzemel.
Magán a kártyán egy NVCache modul és egy SuperCapacitor van.Hogyan tudnám bekapcsolni a RAID-et?
Most akkor a BBU nem egyenlő a super capacitorral?Itt a teljes show:
https://pastebin.com/EUhM6r7z
Marcelldzso
Nokedli92
#11145
Ha tényleg az a kártya akkor lsi oldalról leszeded a megfelelőt és felülírod.
Ha nem akarsz vele próbálkozni akkor valami pc szervizben szerintem megcsinálják bios frissítés árban.
Ne it módba legyen, aztán megaraid szoftverrel ki is alakíthatod a tömböket.
Mivel ez csak 7 disk, ezért egy plusz ssd-t még berakhatsz a hdd tömbhöz cacheként.Ez nem rossz vezérlő, tökéletesen elég lesz arra amire szeretnéd.
Marcelldzso
mgergo76
#11137
A 3-as lábat ragasztottam csak le és láss csodát it works!
Sikerült is megformáznom az asus bios-án keresztül uefivel és már látja is az esxi.
Hálás köszi!
Ezt a weboldalt és benne a videót néztem először:
https://www.instructables.com/How-to-Fix-the-33V-Pin-Issue-in-White-Label-Disks-/ -
Marcelldzso
Marcelldzso
#11113
Merész de elég sok helyen írják:
Initially, the drives would not show up, and I thought the cable was defective. It turns out that my SSD's have the Power Disable feature on the 3.3V pins, so they power down if voltage is detected. Just cut the 3.3V pins from my PSU going to the SATA connectors and the drives are working.
Főleg az adott kábel amazon oldalán. -
Marcelldzso
mgergo76
#11103
Szia,
Ugyanez a problémám nekem is.
Ugyanez a vezérlő csak a 4i-s verzió viszont a kábel stimmel.
Én nem tudok vele SAS diszket felismertetni, egyszerűen fel sem pörgeti.
SATA kábellel gyönyörűen működik. Már gondolkodom egy másik kábelen csak 25ezer alatt nem találok az meg tesztre kicsit drága lenne. -
Marcelldzso
Van egy épülő gépem és egy Dell H310es controllert találtam használtan.
Lap az valószínű valami matx desktop lesz, az i3-8100t mellé kell valamit keresnem amiben van 2db pcie x8-as slot.
1db Raid0 és 1db Raid10 lenne a terv. esxi az os.
Van valami tipp, hogyan tudnám rendesen tesztelni mielőtt rábízom az életem?
- AMD vs. INTEL vs. NVIDIA
- Mikrotik routerek
- Milyen okostelefont vegyek?
- Horgász topik
- Milyen egeret válasszak?
- MWC 2026: Na, fussunk vele még egy kört!
- Bomba áron dobozos Hp Laptop! /AMD Ryzen 5-7520U/8 GB/256 SSD/FHD/Garancia
- DELL Latitude 5285 (Tablet) 2 az 1 ben,FHD +,12.3,i5-7200U,8GB 128GB SSD,LTE, WIN11
- Apple iPhone 13 Pro 256GB,Újszerű,Dobozaval,12 hónap garanciával
- Huawei Free Clip - Hüvely a füledre, de a füled a hüvelye
