Sidaries
Na pontosabban úgy volt, hogy habár azt írtam, hogy a raid-5-ből nem látott semmit igazából a Disk management ablakban látta a raid-5 kötetet Foreign kötetként látta. Ekkor használtuk a következő linken levő registrybuherálást:
Azért idemásolom a pontos szöveget is, ha megszűnne az oldal.
To work around this issue, we need to modify registry.
If you use Registry Editor incorrectly, you may cause
serious problems that may require you to reinstall your
operating system. Microsoft cannot guarantee that you can
solve problems that result from using Registry Editor
incorrectly.
If your system/boot drive is still a basic disk, follow
these steps to correct this
condition:
1. Start Registry Editor (Regedt32.exe).
2. Click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic
es\dmio\Boot Info
3. Under the Boot Info key, delete the ''Primary Disk
Group'' key.
4. Quit Registry Editor, and then reboot the computer.
5. After the reboot, try to import the foreign disks
again.
Please try the suggestion above and let me know the
results.
Srikanth N
This posting is provided ''AS IS'' with no warranties, and
confers no rights.
>-----Original Message-----
>I use hard disks to back things up, and plug them in
alternately (after shutting off the PC).
>For the first time, I have been unable to ''import
foreign disks'' when I plug them in - I get this weird
error message:
>INTERNAL Error - A disk group with the specified name
already exists (C100007A).
>For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.
>Of course, the link provides no help whatsoever.
>What is this C100007A, and why has it screwed up? I
have no way of accessing the data on these disks! (Short
of a fresh XP install somewhere)
>In fact why should I have to reimport the same disks
over and over every time I plug them in?
Na és ezzel egy újraindítás után már látta. -
Sidaries
Na sikerült mindet visszaállítani. Szóval először a raid-1 adatokat sikerült visszanyerni, ezzel nem volt gond. Utána csináltunk egy új raid-1 kötetet két új vinyóval, majd windowsinstall. Azután beraktuk a raid-5 vinyókat és nem látott semmit. Ezután egy registy módosítással, már felismerte a köteteket, habár nem teljes funkcionalitással, de menteni lehetett róla. Ezen az utolsó részen már nem voltam itt, de ha érdekel pontosan is akkor utánakérdezek.
Sidaries
upp
Sidaries
Na új kérdés. Ha van 3 vinyóm, amik Raid 5 voltak
és most Ready állapotban vannak, de Onlineba rakom őket, mint Raid 5 akkor lesz-e adatvesztés? -
Sidaries
Még egy kérdés:
Ha az új Raid 1-re rárakjuk a reconstructot, miközben a Raid 5 nincs bent akkor utána ha visszarakjuk, látni fogja hogy ők egy tömbben voltak? -
Sidaries
Szóval:
Seagate Cheetah Ultra SCSI 320 vinyók
Dell Poweredge 2850 szerver 2*3.2Ghz Xeon proci
Ntfs minden vinyón. -
Sidaries
Eddig kösz. És ha 3 másik vinyóval létrehozom a tömböt és egyszer csak ezt az eredeti hármast berakom akkor látni fogja?
Sidaries
Elég komoly gondom lenne. Van egy Raid 5-ös tömb 3 vinyóval és kidöglött alóla minden. Raid vezérlő meg minden. Nem volt rajtuk oprendszer, mert az egy Raid 1 tömbben volt. A kérdésem az, hogy, ha újra létrehozom az új Raid 1 és 5 tömböt, akkor a Raid 1-re való teljes oprendszerinstall után el tudom-e érni a Raid 5 adatait vagy sem?
- Villanyszerelés
- Tesla topik
- Szintet lépett "lopakodó" alaplap készül a Colorful műhelyében
- Minden USB-C kábel egyforma? Hát NEM. És ez a baj. – Tech Percek #7
- Gitáros topic
- Brutális akkumulátort kaphat a Honor X80 GT
- Apple Watch Series 10 46mm GPS+Cellular Titanium, Újszerű, 1 Év Garanciával
- Telefon felvásárlás!! Samsung Galaxy A50/Samsung Galaxy A51/Samsung Galaxy A52/Samsung Galaxy A53
- Apple iPhone 13 Pro 128GB,Átlagos,Dobozaval,12 hónap garanciával
- Samsung Galaxy A04s / 3/32GB / Kártyafüggetlen / 12Hó Garancia
- Apple iPhone 12 Mini 64GB,Újszerű,Adatkabel,12 hónap garanciával
