Asztee
Csicsóka
#34030
Megnéztem ezt azt a könyvtárat és nálam is ugyan azok a fileok vannak amiket felsoroltál.
Kiadtam avcdbg log msgparancsot (ezt olvastam valahol) és ez az eredmény :002613.121: arasan: arasan_emmc_open
002615.307: arasan: arasan_emmc_set_clock C0: 0x00000000 C1: 0x000ef447 emmc: 200000000 actual: 200000 div: 0x000001f4 target: 200000 min: 100000 max: 400000 delay: 10
002732.072: arasan: arasan_emmc_set_clock C0: 0x00000000 C1: 0x000ef447 emmc: 200000000 actual: 200000 div: 0x000001f4 target: 200000 min: 100000 max: 400000 delay: 10
002739.226: arasan: arasan_emmc_set_clock C0: 0x00000f00 C1: 0x000e01c7 emmc: 200000000 actual: 130039 div: 0x00000301 target: 130000 min: 100000 max: 400000 delay: 15
002781.090: arasan: arasan_emmc_set_clock C0: 0x00000f06 C1: 0x000e0307 emmc: 200000000 actual: 33333333 div: 0x00000003 target: 40000000 min: 0 max: 40000000 delay: 1
002813.092: brfs: File read: /mfs/sd/config.txt
002813.719: brfs: File read: 1800 bytes
002814.682: brfs: File read: /mfs/sd/distroconfig.txt
002814.959: brfs: File read: 228 bytes
002869.848: brfs: File read: /mfs/sd/config.txt
002870.486: brfs: File read: 1800 bytes
002871.436: brfs: File read: /mfs/sd/distroconfig.txt
003071.744: gpioman: gpioman_get_pin_num: pin DISPLAY_DSI_PORT not defined
003074.217: *** Restart logging
003074.255: brfs: File read: 228 bytes
003111.870: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
003111.912: HDMI0: hdmi_pixel_encoding: 600000000
003111.923: HDMI1: hdmi_pixel_encoding: 162000000
003113.026: brfs: File read: /mfs/sd/cmdline.txt
003113.074: Read command line from file 'cmdline.txt':
003113.103: 'boot=UUID=2107-3427 disk=UUID=7df7ff03-b4ad-429f-b34e-ad7a78303add quiet'
003113.365: brfs: File read: 74 bytes
003947.736: brfs: File read: /mfs/sd/kernel.img
003947.802: Loading 'kernel.img' to 0x8000 size 0x7c69c8
003952.192: No kernel trailer - assuming DT-capable
003952.265: Trying Device Tree file 'bcm2711-rpi-4-b.dtb'
003952.330: brfs: File read: 8153544 bytes
003961.040: brfs: File read: /mfs/sd/bcm2711-rpi-4-b.dtb
003961.097: Loading 'bcm2711-rpi-4-b.dtb' to 0x7ce9c8 size 0x9d5c
003993.696: dtdebug: delete_node(/__local_fixups__)
004030.496: dtdebug: /aliases:i2c_vc=i2c0
004049.882: dtdebug: /__symbols__:i2c_vc=i2c0
004063.698: dtdebug: /__overrides__:i2c_vc=i2c0
004090.290: dtdebug: /__overrides__:i2c_vc_baudrate=i2c0_baudrate
004099.069: dtdebug: /aliases:i2c=i2c1
004118.721: dtdebug: /__symbols__:i2c=i2c1
004132.649: dtdebug: /__overrides__:i2c=i2c1
004141.447: dtdebug: /aliases:i2c_arm=i2c1
004161.105: dtdebug: /__symbols__:i2c_arm=i2c1
004175.083: dtdebug: /__overrides__:i2c_arm=i2c1
004201.960: dtdebug: /__overrides__:i2c_baudrate=i2c1_baudrate
004228.869: dtdebug: /__overrides__:i2c_arm_baudrate=i2c1_baudrate
004243.541: dtparam: uart0_clkrate=48000000
004253.582: dtdebug: /__overrides__ has no uart0_clkrate property
004253.597: Unknown dtparam 'uart0_clkrate' - ignored
004253.657: brfs: File read: 40284 bytes
004256.556: brfs: File read: /mfs/sd/config.txt
004257.206: brfs: File read: 1800 bytes
004260.092: dtdebug: Opened overlay file 'overlays/hifiberry-digi.dtbo'
004261.777: brfs: File read: /mfs/sd/overlays/hifiberry-digi.dtbo
004311.850: Loaded overlay 'hifiberry-digi'
004311.929: dtparam: spi=on
004312.110: dtdebug: /__overrides__ node not found
004321.828: dtdebug: Found override spi
004321.863: dtdebug: override spi: string target 'status'
004339.960: brfs: File read: 959 bytes
004341.015: brfs: File read: /mfs/sd/distroconfig.txt
004341.168: dtdebug: Found fragment 0 (offset 36)
004362.108: dtdebug: merge_fragment(/soc/i2s@7e203000,/fragment@0/__overlay__)
004362.136: dtdebug: +prop(status)
004366.699: dtdebug: merge_fragment() end
004366.755: dtdebug: Found fragment 1 (offset 112)
004392.290: dtdebug: merge_fragment(/soc/i2c@7e804000,/fragment@1/__overlay__)
004392.315: dtdebug: +prop(#address-cells)
004396.270: dtdebug: +prop(#size-cells)
004400.255: dtdebug: +prop(status)
004417.532: dtdebug: merge_fragment(/soc/i2c@7e804000/wm8804@3b,/fragment@1/__overlay__/wm8804@3b)
004417.560: dtdebug: +prop(#sound-dai-cells)
004421.704: dtdebug: +prop(compatible)
004425.632: dtdebug: +prop(reg)
004429.684: dtdebug: +prop(PVDD-supply)
004434.826: dtdebug: +prop(DVDD-supply)
004439.990: dtdebug: +prop(status)
004444.111: dtdebug: merge_fragment() end
004444.142: dtdebug: merge_fragment() end
004444.220: dtdebug: Found fragment 2 (offset 348)
004478.110: dtdebug: merge_fragment(/soc/sound,/fragment@2/__overlay__)
004478.136: dtdebug: +prop(compatible)
004481.024: dtdebug: +prop(i2s-controller)
004485.176: dtdebug: +prop(status)
004488.073: dtdebug: merge_fragment() end
004488.163: brfs: File read: 228 bytes
004510.386: dtdebug: Opened overlay file 'overlays/vc4-fkms-v3d.dtbo'
004512.969: brfs: File read: /mfs/sd/overlays/vc4-fkms-v3d.dtbo
004567.046: Loaded overlay 'vc4-fkms-v3d'
004567.159: dtdebug: Found fragment 0 (offset 36)
004567.584: dtdebug: merge_fragment(/chosen,/fragment@0/__overlay__)
004567.610: dtdebug: +prop(bootargs)
004574.002: dtdebug: merge_fragment() end
004574.055: dtdebug: Found fragment 1 (offset 120)
004574.111: dtdebug: fragment 1 disabled
004574.165: dtdebug: Found fragment 2 (offset 204)
004574.220: dtdebug: fragment 2 disabled
004574.275: dtdebug: Found fragment 3 (offset 288)
004574.330: dtdebug: fragment 3 disabled
004574.385: dtdebug: Found fragment 4 (offset 368)
004574.441: dtdebug: fragment 4 disabled
004574.496: dtdebug: Found fragment 5 (offset 448)
004608.119: dtdebug: merge_fragment(/soc/fb,/fragment@5/__overlay__)
004608.147: dtdebug: +prop(status)
004611.140: dtdebug: merge_fragment() end
004611.196: dtdebug: Found fragment 6 (offset 528)
004643.596: dtdebug: merge_fragment(/soc/firmwarekms@7e600000,/fragment@6/__overlay__)
004643.622: dtdebug: +prop(status)
004646.750: dtdebug: merge_fragment() end
004646.803: dtdebug: Found fragment 7 (offset 604)
004683.311: dtdebug: merge_fragment(/v3dbus/v3d@7ec04000,/fragment@7/__overlay__)
004683.339: dtdebug: +prop(status)
004686.001: dtdebug: merge_fragment() end
004686.054: dtdebug: Found fragment 8 (offset 680)
004713.748: dtdebug: merge_fragment(/soc/gpu,/fragment@8/__overlay__)
004713.775: dtdebug: +prop(status)
004717.513: dtdebug: merge_fragment() end
004740.433: dtparam: uart1=off
004750.227: dtdebug: Found override uart1
004750.263: dtdebug: override uart1: string target 'status'
006014.202: dtparam: cam0-pwdn-ctrl=46
006024.466: dtdebug: Found override cam0-pwdn-ctrl
006024.492: dtparam: cam0-pwdn=5
006034.750: dtdebug: Found override cam0-pwdn
006034.783: dtparam: arm_freq=1500000000
006045.085: dtdebug: Found override arm_freq
006045.108: dtparam: core_freq=550000000
006055.736: dtdebug: /__overrides__ has no core_freq property
006055.750: Unknown dtparam 'core_freq' - ignored
006064.807: dtparam: cache_line_size=64
006075.148: dtdebug: Found override cache_line_size
006090.359: dtdebug: delete_node(/hat)
006116.022: Device tree loaded to 0x1ffe5c00 (size 0xa318)
006118.613: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined <== Nekem ez gyanús !
009075.927: vchiq_core: vchiq_init_state: slot_zero = 0xcfd80000, is_master = 1
009078.059: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
009079.231: TV service:host side not connected, dropping notification 0x00000002, 0x00000004, 0x00000000
046508.691: mmal: mmal_ril_set_port_settings: ril.video_decode:in:0: failed to set port definition (4) buffers 1/1/81920
046508.739: mmal: mmal_ril_set_port_settings: ril.video_decode:in:0: fail: color format 0x0, encoding 0x4 stride 0
046508.788: mmalsrv: mmal_server_do_port_info_set: ril.video_decode:in:0(MP4V): failed (handle 1, status 3)
823071.093: mmal: mmal_ril_set_port_settings: ril.video_decode:in:0: failed to set port definition (4) buffers 1/1/81920
823071.147: mmal: mmal_ril_set_port_settings: ril.video_decode:in:0: fail: color format 0x0, encoding 0x4 stride 0
823071.205: mmalsrv: mmal_server_do_port_info_set: ril.video_decode:in:0(MP4V): failed (handle 1, status 3)Ez sajnos számomra nem túl informatív...
Asztee
tatu611088
#34028
Sziasztok ! Van egy friss ropogós RPi4-em és felraktam rá a 9.1.002-es LibreELEC-et és van hozzá egy Hifiberry-Digi+ hangkártyám is ,ami sajnos nem akar működni.
Ez alapján próbáltam beüzemelni , de nem jelenik meg a hangeszközök között.
Rpi3-mal müködött ! Mi lehet a probléma.
Köszönöm.
Asztee
MaCS_70
#30472
Na ma megérkezett a kicsike ,bedugtam a teljesen frissen telepített LibreElec 8.2.5-s Rpi-mbe ,de semi. A connectoins menü teljesen üres és sehol máshol se látom semmilyen jelét bármilyen hálózatnak.
Természetesen próbálkoztam reboot-tal is ,de semmi. Kipróbáltam az asztali gépben is és ott működött. (azaz az egység működőképes) Mit lehetne tenni még ? Van valamilyen tipped ?
Asztee
Sziasztok ! Azt szeretném megkérdezni hogy egy ilyen usb-s wifi jó lenne-e nékem ?
Van egy Rpi 1-esem ,abba kellene és Libreelec-et szeretnék rá rakni. A Libreelec felfogja ismerni magától vagy telepíteni kell valamit még hozzá ? ...és sebesség tekintetében mi a helyzet ? Azt tudom hogy ez a wifi sávszélesség az elég , de nem tudom hogy az Rpi-ben a buszok meg hasonlók tekintetében mi a helyzet. Szóval megfelelhet ez a célnak vagy vegyek inkább egy 8m-es LAN kábelt ?
Köszi. -
Asztee
Csicsóka
#27310
Bevált !!!
Már sleep 5-tel is jó.
Egy kérdés : ebben a hozzászólásban cigman azt írta hogy : restart=allways , te pedig azt írtad hogy restart=on-failure. Mi a különbség és melyik mire jó ?
Esetleg még valami... (ha már ezt idáig ilyen klasszul összehoztuk.
) Arra van valami tipped hogy hogy lehetne törölni a kijelzőt kikapcs/reboot hatására. (Nem életbe vágó csak azért mégis elegánsabb lenne.) Most ha kiadok egy reboot-ot akkor a kijelzőn ott marad a teljes reboot idejére , ami éppen akkor ott volt.
Nagy köszönet az eddigiekért !!!
Asztee
Nálam az volt ott hogy Host='localhost' ,de ezelőtt ezzel is működött. Most átírtam az ip címre ,de azzal sem lett jó.
Legfrissebb megfigyeléseim :
- Újraindítás után az van a kijelzőn amit utoljára indítottam(!). (tehát nem az ami utoljára szólt)
- Kiadtam egy top-ot. Ott volt egy 353... python2. Kiadtam egy kill 353-t és a kijelző elkezdett normálisan működni.
Újra top , ott volt egy 770... python2.
Lehet hogy túl korán indul el automatán !? Tegyek bele egy sleep-et !?
Asztee
Csicsóka
#27295
Természetesen szétnéztem a fórumán és ahogy azt írtam korábban egy csomó dolog nem működött úgy ahogy ott írták ezért nem az ott leírtak szerint sikerült életre keltenem. A fórumnak csak az első 6 oldalát néztem át és addig nem volt szó az autostart-ról.
Most megnézve a 12.(!) oldalon lévő leírást az egész hasonló ahoz amit én csinaltam. (Csak én közben benéztem egy-két zsákutcába is.
Asztee
Csicsóka
#27283
systemctl start rc-local.service-re elindult !
A másodikra :
Loaded : loaded (/usr/lib/systemd/system/rc-local.service; enabled)
Active : active (runing)
Process : 758 ExecStart=/etc/rc.local
Main PID : 759 (python2)
CGroup : /system.slice/rc-local.service
'759 python2 /lcd/RuneAudioLCD-master/start.py -
Asztee
Csicsóka
#27267
A loadkesy az a prog. start előtt van.
Próbáltam Raspbian-nal megoldani ,de nem jártam sikerrel. Az sd kártya boot partícióját sikerült mount-olnom ,de a többire hibát dobott.
Utána megpróbáltam "dózerrel" és tálaltam egy progit amivel sikerült megoldanom.
Ez alapján kezdtem neki ,de sok minden nem működött úgy ahogy ott írták - gondolom az eltelt két év alatt volt néhány frissítés a rendszeren és azért - azután keresgettem még és tálaltam ezt és ezt és ezekből sikerült nagynehezen összekovácsolni. (majdnem 0 linux tudással !!!
) Tapasztalt még nincs ,még csak ott járok ,hogy végre "működik" ! Lehet finomhangolni/testre szabni ,de ott még nem járok. Egyenlőre örülök hogy sikerült feléleszteni ,ráadásul úgy hogy egy digi card is rá van dugva !
Az autostartra van valami tipped esetleg ? -
Asztee
doberman
#27263
De nem ám sajnos.
Azért is mertem belebabrálni a /etc/profile-ba ,mert előtte amikor elindítottam a progit (manualisan) és nem tudtam leállítan , akkor ssh-n még tudtam rá hatni, de most ssh-n belépve is (gondolom szintén lecsekkolja mi van a profile-ban) elindul automatikusan (és mégegyszer !!!
gondolom , mert onnantól értelmetlen dolgok vannak az LCDn) a kis progi ,amiből nem tudok kilépni.
Az egyébként miért van hogy a ctrl+c nem működik ? Vagy az nem egy álltalános python kilépő bill.komb. ? (Más kis python proginál működött) -
Asztee
Csicsóka
#27253
Nem tudom hogy milyen szintű , de ez egy Python progi azt tudom. Ez van beírva az etc/profile-ba ,hogy "python2 /lxy/xy/start.py" és amikor bekapcsolom a pi-t (most ideiglenesen rá van dugva a tv-re) akkor bootolás után várakozik a bejelentkezésre. Akkor a telefonos app-pal már tudom használni a RuneAudio-t ,de az LCD kijelzokijelző még üres amíg be nem jelentkezek. (Egyébként beírtam az is a profile-ba , hogy "loadkeys hu" és az is csak a bejelentkezés után lett érvényes.)
Az a "&" egy ilyen python-os proginál is működik !? (Pl. "Python2 start.py &" ?)
"Kiveszed az SD-t, beteszed egy Linuxos gépbe"
Sajnos nincs kéznél linuxos gépem.
Nincs valami win-os segédprogram ami tudja kezelni az ext4-es sd kártyákat ?
Vagy az lehetséges lenne -ez most jutott az eszembe-, hogy egy masik sd kártyáról bebootolok a RPi-n (raspbian) és ezt a mostanit meg usb-s kártyaolvasóval bedugom és akkor ott átszerkesztem. Gondolom igen csak fogalmam sincs, hogy hol találnám meg...
Asztee
Sziasztok !
Nagynehezen sikerült RuneAudio-val/ban életre keltenem az i2c-s LCD kijelzőmet.
DE ! Kérdéseim még azért lennének. A program ,ami vezérli az ugyebár magától alapból nem indul el ,ezért hát próbálkoztam valamilyen autostart-tal. Egy weboldalon azt olvastam ,hogy írjam be az /etc/profile-ba amit indítani akarok. Ez meg is tettem ,de kár volt ugyanis így sem ibdul teljesen automatikusan csak ha bejelentkezek.
A következő problémám az meg az ,hogy az előző problémámon még változtatni sem tudok ,mert ha bejelentkezek ,akkor ugye rögtön el is indul a program amiből sehogyan sem tudok kilépni. (A ctrl+c nem vált be)
Hogyan tudnék kilepni a programból , van erre valami más opciói a ctrl+c-n kívül ? Vagy hogyan tudnám kitörölni az etc/profile-ból az indítást ? Az (is) baj hogy ha ssh-n próbálok belépni,akkor ott is elindítja a programot és ott sem tudok parancsolgatni.
Please help !!!
Asztee
helltp
#26948
Ezek lenni ocó kínai termék és nem lenni hozzá részletes doksi.
Az összes infóm róluk ,ami az eBay leírásban volt meg amit innen-onnan a netről össze szedegettem.
Az LCD és a hangkártya.
Ez utóbbit újra elolvasva azt látom ,hogy ez is használja az I2C-t, a kijelzőmről meg ezt eddig is tudtam.
Az viszont új infó volt számomra ,amit írtál az I2C-vel kapcsolatban. Szerinted akkor tényleg használhatom mindkettőt megosztott labakkal !?
Köszi. -
Asztee
helltp
#26942
Sajnos számomra nem teljesen egyértelmű ,hogy melyiket használja és melyiket nem.
Küldjek közeli fényképet mindkét oldaláról hogy meg tudd nekem mondani a helyes megfejtést.
A kijelzőnek egyébként biztos jó akármelyik másik GPIO láb !? Ezen a képen pl. a GPIO2 és GPIO3 lábhoz (a videón erre van kötve a kijelző) van írva valami speckó szöveg (SDA1 I2C és SCL1 I2C) ami nincs ott a többi lábnál és az az I2C az ismerős a kijelző leírásából is.
Varom a valaszod !
Köszönöm szépen.
Asztee
Celtis
#26920
Abban mondjuk igazad van ,hogy nem eszik sokat csak láttam azt a videót a YT-on (és van ott még sok egyéb power button videó is) és gondoltam megpróbálom .
Más : van egy 4x20-as lcd-m. Ahoz meg ez alapján tudnék csatlakozni. (Kb 2.20-tól van a bekötés) A kérdés kb. ugyan az mint az előbb : hogy tudom ezt összehozni a hangkártyával !?
Köszönöm -
Asztee
Hali !
Müszaki szakik segítségére lenne szükségem.
Lenne néhány kérdésem. Van itt ez a video a Yt-on a RPi power buttonról. Ebben ugye rövidre zárja az 5-ös és a 6-os lábat és szerinte ez jó (?). Kipróbáltam - egyenlőre még csak csavarhúzóval
- ,de semmi nem történt. Most akkor mi van !?
Aztán (még ha az müködött is volna), itt jön a következő kérdés... Ugyan ebben a Pi-ben van egy ilyen
hangkártya, ezt nem vágná haza az 5-ös 6-os rövidzár !?
Köszönöm.
Asztee
Kroni1
#26786
Nekem a lejátszással nem volt problémám ,viszont ha lejátszás közben mászkáltam az adatbázisban ,akkor attól nagyon besokalt néhány lépés után. ( borítók helyett fekete négyzet ,betűk helyett fehér négyzetek , akadozás ,stb) Azután láttam ezt a videót és megcsináltam amit ott javasolnak és azóta nyugottan mászkálhatok össze-vissza lejátszás közben is és nincs semmi gond vele.
Asztee
Hali !
Van egy RPi-m Runeaudio-val és digi kártyával , nem tudja valaki hogy hol lehet - lehet-e - állítani maximum kimeneti frekit . Az a gondom ,hogy az erősítőm nem mai darab és nem tud mit kezdeni a 24bit/96khz-cel.
Köszönöm. -
Asztee
Openelec 8.0.2 / Kodi 17.3-hoz van már valami dual-audiós megoldás ???
Asztee
Tegnap megjött a Digi kártyám az RPi-mhez .
Gyorsan bele is raktam. (RuneAudio Project
) Gond nélkül felismerte. Azután már csak döbbentem hallgattam micsoda külömbség van a hangzásban az RPi analóghoz képest.
Ja , és SPDIF kábellel kötöttem össze és féltem ,hogy majd esetleg búgni fog, de hála az égnek semmi alapzaj.
Asztee
Asztee
Sziasztok !
RuneAudio-s kérdésem lenne. Tegnap feltelepittetem és beállitgattam néhány dolgot (forrás hozzáadása, webui, androidapp,stb) ,de az erősítőmre csak ma volt időm rádugni (egyenlőre még csak jack kimeneten) és egy igen furcsa dolgot tapasztaltam : olyan volt mintha kétszer indult volna el a zene néhány tízedmásodperc különbséggel.
Ez vajon mitől lehet ???
Köszi. -
Asztee
Nekem ilyen van. Müködik is csak annyi a baj ezzel a megoldással amit az előttem író is irt ,hogy nincs egyszerre hang a hdmi kimeneten és a digi kártyán. Szóval vagy mindent az erősítőn (vagy tv-n) hallgatsz vagy mindig váltogatsz a menüben ,hogy most éppen mire van igény.
Illetve - tegnap óta tudom hogy - létezik dual audios verzió (vagy kiegészítő
) is ,de erről még nem tudok nyilatkozni. -
Asztee
envagyok
#26575
Nem próbáltam még ,mert eddig nem is hallottam róla.
Lehet hogy hamarosan megpróbálkozom vele.
Arra van valami mód ,hogy úgy frissítsek Libreelec 8-ra ,hogy ne keljen mindent előről kezdeni. (Beállítások ,fájl listák ,stb ugyanúgy maradjanak ahogy most vannak )
Amúgy gondolom igen a válasz, mert Openelec-ről is úgy váltottam Libreelec-re ,hogy minden maradt a régi ,de már nem emlékszem ,hogy hogy csinaltam.
Asztee
Lenne egy hanggal kapcsolatos problémám is...
Van a Pi-re rakva egy ilyen digital sound card és végre sikerült hangot is kicsikarnom belőle.
(Azért végre,mert megvan már több mint fél éve,de eddig még nem sikerült.
igaz már hónapok óta nem is próbálkoztam.
) Szóval a probléma az az ,hogy most vagy csak a hangkártyán keresztül szól a renszer és akkor mindig be kell kapcsolni az erősítőm vagy hdmi-n keresztül a tv-n. Az erősítőm egy kicsit korosabb darab és nincs rajta hdmi ,szóval ez nem opció. Nem lehet azt valahogy megoldani ,hogy hdmi-n és digi pass through-on is menjen egyszerre !?
Köszi.
Asztee
drogery
#26521
Persze ,hogy Kodi !
+ Libreelec. A TV-m meg Samu. A kodi restart nálam nem oldja meg
, nekem a tv-t kell kikapcsolom és az TV távirányítójával visszakapcsolni. Az viszont érdekes ,hogy a rpi-s cec paranccsal akkor is le tudtam kapcsolni a TV-t amikor a TV azt írta ki ,hogy nem elérhető.
Asztee
Hi !
A RPi álltali TV kikapcsolással kezdtem el bíbelődni és találtam ezt az oldalt. Működnek is az utasítások:
Turn tv on: echo on 0 | cec-client -s -d 1
Turn tv off: echo standby 0 | cec-client -s -d 1
Tv status: echo pow 0 | cec-client -s -d 1
,de miután visszakapcsoltam a TV-t ,azóta a TV irányítója nem kezeli a Pi-t. "Nem elérhető" üzenetet kapok.
Van rá megoldás vagy valami tipp estleg ?
Köszi. -
Asztee
Celtis
#22587
Megoldodott !!!
A te kérdésed vezetett rá a megoldásra.
Ugyanis nem tulajdonítottam jelentőséget annak ,hogy mi indul újra ,de most megfigyeltem és kiderült ,hogy csak a Kodi , ezért csináltam egy restar-ot és most minden szép és jó !
Bár az okát nem tudom ,de a lényeg ,hogy működik !!!
Asztee
Sziasztok !
Kb egy hónapja frissítettem LibreElec-re nem is volt vele semmi problémám... ...egészen tegnapig.
Tegnap óta viszont nem játszik le néhány filmet, amit eddig gond nélkül vitt. Neki álltam próbálgatni ,hogy mivel is lehet a baj és - bár nem 100%,de - szerintem kodek problémája lehet , mert úgy tűnik, hogy a xvid-ekkel van baj. A acc meg a h264-et lejátsza ,xvid-nél viszont kiírja ,hogy Dolgozom... és kb. 10 másodperc múlva újra indul.
Szerintetek mi lett vele és mi rá az orvosság !?
Köszönöm !
Asztee
Asztee
Hi mindenki !
Kellene egy kis segítség. Frissitettem a LibreElec-re és gondjaim vannak a színekkel. Film közben a fekete csak szürke,de ha közben kilépek a menübe, akkor átvált valami más módra és addig jók a színek, de a gui színe viszont majdnem fekete ami alapból viszont csak sötét szürke kellene ,hogy legyen. Nem értem mi lehet a baj.
Köszi. -
Asztee
Sziasztok !
Nekem most olyan problémám van (többek közt) ,hogy amikor sorozatot nézek és vége az egyik résznek és indulnia kellene a következönek akkor (majdnem) mindig lefagy és újra indul a cucc.
Nem sikerült még rájönnöm, hogy mitől van.
A 6.95.2-es OpenElec van most a RPi3-asomon.
Légyszi' segítsetek !!!
Köszi. -
Asztee
Sziasztok !
Vettem a Pi-mhez egy HiFiBerry Digi+. A problémám az hogy nem jön ki belöle hang. Mit kell vele tennem ?
Kell hozzá telepíteni valami szoftvert ? A mégnagyobb problémám meg az hogy dual-audio-ban szeretném használni-
Visszaolvasva láttam, hogy létezik valami dual audios OpenELEC. Ez valami kiegészitő vagy egy teljes oprendszer ?
És ha igen,akkor most ugye teljesen újra kell raknom az egész rendszert !?
Annak nagyon nem örülnék ,mert alig egy hónapja frissítettem (4.x --> 6.x) és vagy egy hétig eltartott, mire mindent visszaállítottam olyanra ahogy én szeretem és nem szeretném most újrakezdenji.
Illetve esetleg erre van valami olyan backup megoldás ami mindent elment (fájl listák, skin-ek és menük és a teljes adatbázis) ? (A 4-röl 6-ra frissítésnél is próbálkoztam a backuppal,de nem igazán akarta értelmezni.
)Köszi.
Asztee
Erre valki !?
Kipróbáltam ezt a sokat emlegetett Yatse-t. Idáig nagyon tetszik ,de van vele egy problémám (idáig
Ha a TV irányítóval inditok egy epizódot egy sorozatból, akkor autómatikusan jön a következö is,de ha a Yatse-vel indítok egyet ,akkor csak azt az egyet játsza le. Van erre valami - teljesen kézenfekvő
- megoldás - ami éppen csak hogy nem szúrja ki a szemem
- vagy szokjak hozzá
köszönöm. -
Asztee
Celtis
#16507
Az addonok nem is annyira érdekelnek, inkább csak a menüket nem szeretném újra összeállitgatni meg a file listákat újra kreálni. ( vagy ez utóbbit a médiatár visszaálitás megoldja !?) Az a baj ,hogy olyan régen telepíttettem már ,hogy azóta már el is felejtettem az egészet és még hyperionom is van úgyhogy azt is újra kellene buherálni.
Megéri ez a veszödséget !?
Mit kapok cserébe ??? (Talán azt ,hogy müködni fog a Youtube addonom.
(mert azt most nem sikerül beüzemelnem.
Asztee
Sziasztok !
(megint én !
)Egy másik problémám a frissítés. Nekem még az OpenELEC 4.2.1(?) van fenn Gotham 13.2(?)-vel. Úgy érzem ideje lenne frissíteni egyet a rendszeren.
Az lenne a kérdésem, hogy meg tudom-e oldani valahogy úgy,hogy a beállításaim megmaradjanak ? (menük, skin-ek, adatbázisok, telepített add ons, belinkelt könyvtárak,hálozati meghajtók)
Lehet frissíteni, vagy másoljak ki néhány könyvtárat+file-t és rakjam fel szüzen a frissebb verziót és utána meg visszamásolgassam a cuccokat ? Ha az utobbi ,akkor melyik könyvtárak/file-ok fognak kelleni ?
Köszi megint !
Asztee
Sziasztok !
Digitális hang problémáim/kérdéseim (is) lennének :
HiFi Digi+-t (I2S) valaki próbálta már ? Valahol itt olvastam,hogy valami nem hivatalos OpenElec kell hozzá. Müködik frankón ? Minöség ? Megbizhatóság ? Szoftver ? Az én erősítőm csak DD5.1-et tud. Ez a kütyü tud lefelé konvertálni vagy azt az XBMC setup-jában be lehet állítani ? És a HDMI-n attól még átmegy a hang a TV-re ?
Az'tán még ott van pl. az a lehetöség is hogy a HDMI jelből szedjük ki a digitális hangot valami ilyesmivel. Erre valaki azt írta,hogy akkor viszont a CEC nem müködik. Ezzel kapcsolatban is aktuálisak az előző kérdéseim (minőség, DD5.1-re alakítás,stb) és az jutott eszembe,hogy a CEC-es problémára egy HDMI Y adapter nem lehetne megoldás !?
A válaszokat előre is köszönöm.
Asztee
Sziasztok !
Ezt már próbálta valaki Pi-vel ? Az alap funkciókra jó a Tv -m irányítója is, de pl. szöveget beírni sokkal jobb lenne ezzel és talán van még egy-két extra funkciója is. -
Asztee
Sziasztok !
Én is belefogtam egy Hyperion projectbe,de nálam valami gubanc van.
A szoftver az - azt hiszem - működik (a top szerint fut), de a ledek nem világítanak.
( ez után sem : /storage/hyperion/bin/hyperion-remote.sh --priority 50 --color red --duration 5000) Egyetlen életjel amit kapok a rendszertől az akkor van amikor bedugom a led-sort a csatlakozojába ( a Pi még külön áramforrásról megy),akkor néha csak az első pirosan ,néha meg az összes vegyesen felvillan egy pillanatra,de utána semmi. Nem tudom mi lehet a baj.
Kontakt hiba vagy szoftveres gond vagy valami a bekötésnél ?
( RPi B+ + OpenElec 4.2.1)HELP !!!
Köszi.
Asztee
Sziasztok !
Villany kapcsolásra (is) szeretném használni a pi-met. Meg lehet ezt oldani valamilyen androidos app.pal ?
és hardver részről mi kell hozzá ? Gondolom - minimum - egy relé. Fontos lenne továbbá,hogy manuálisan is lehessen kapcsolni (pl. egy nyomógombbal) még akkor is ha a pi nincs bekapcsolva (ez gondolom kissé bonylítja).
Szerintem kellene valami áramkör ami ami veszi a nyomógombjelét is és a pi-jét is és mindig az ellenkező állapotba kapcsolja a relét,de eféle áramkör megtervezése (vagy megalkotása
) már meghaladja a képességeimet. Azért ha van valami egyszerű megoldás ,ne habozzatok !
Köszi.
Asztee
Valakinél Openelec alatt ez működik ? Tetszene ez a lehetőség,hogy ha a TV-t lekapcsolom ,akkor a XBMC kilép,de nálam a tvservice -n mindig ugyan azt az eredményt adja. Próbáltam már kihúzott hdmi kábellel is és még akkor is és akkor is kiírta a TV-m nevét.
HELP !!!
Asztee
Pár száz hsz.sal ezelőtt kérdeztem,hogy nincs-e valami módszer az XBMC médiatár által nem azonosított filmek megkeresésésre. (peresze nem az egyesével leellenőrzésre gondoltam
) Akkor nem jött rá semmi válasz.
DE ! Tegnap találtam valamit... Persze azért ez még nem az a menüből megkeresős kényelmes megoldás,de azért a semminél jobb.
Szóval a lényeg (Windowsból) : Openelec\Logfiles mappában (milyen meglepő
) vannak a log fileok zip kiterjesztéssel és abban 01_XBMC.log-ban elég rákeresni erre : "WARNING: No information found for item" és láthatjuk,hogy mit nem tudott az XBMC azonosítani.
Asztee
Asztee
Sziasztok !
Valaki csinált már Hyperion-t a WS2801-es LED sor öntapadós verziójával ? Érdekelne a tapasztalat. Milyen lett a végeredmény ? (Ez ugyebár hátrafelé világit nem oldara) 3 cm-es led távolság az jó ? 64 leddel még megbirkózik a Pi ?
Nekem fali-konzollal van rögzítve és az egyik oldalon kb 10, a másikon kb 20 cm-re a faltól. Ez a távolság nagyjából oké ?Köszönöm.
Asztee
bencsikgab
#9423
Köszönöm a gyors válaszokat.
Asztee
Sziasztok ! (bocsi, biztos volt már,de már több mint 9000 hsz-nál jár a fórum
) A RPi tud pendrive-ról boot-olni ? ...és gyorsabban fut arról,mint SD-ről ? (érezhetőre különbségre gondolok nem csak mérhetőre) ...és ha igen akkor van-e rá esély,hogy az SD-ről átmentsek mindent a pendrive-ra és ne keljen mindent elöről kezdeni ? (OpenElec + XBMC megy rajta) Köszi. -
Asztee
Nem cáfolni akarom az állításod csak sok helyen olvastam,hogy a TV USB-je is elég neki és gondolom az sincs 1-2 amperes.
Egyébként most a PC USB-jéből átdugtam a router-em USB-jébe és el tűnt onnan a kis négyzetet (pontosabban,ha megy egy film és közben még a médiatárat is vadul használom, akkor egy-egy pillanatra előjön) és az OC is működik.
Asztee
Na , közben a színes kis kockákra találtam magyarázatot (under voltage) ,bár az okát nem tudom. Ugyan az az áramforrás : a PC-m egyik usb portja. Így még az OC sem megy.
700-on megy a proci pedig a config-ban 900 van.
A média tárat meg (csak
) úgy sikerült megoldanom, hogy töröltem a régit és újra pakoltam az egészet.
Az előző hsz. 1. kérdésére még mindig érdekelne a válasz.
Köszi. -
Asztee
Sziasztok !
Eredetileg az első kérdésem az lett volna, hogy nincs-e valamilyen egyszerű módszer arra,hogy megkeressem azokat a filmeket amiket az XBMC nem ismert fel és nem rakta a média tárba. ( nem az egyenként végignézésre gondoltam.
) ,DE (!) gondoltam előtte még gyorsan frissítem az OpenElec-et...
Hát lehet,hogy nem kellett volna...
(4.0.x-ről 4.2.1-re)
Az első ami nem tetszett az az ,hogy betöltéskor az XBMC logo-nál a jobb felső sarogban kicsiben ott volt egy olyan "színkocka",mint ami a bekapcsolásnál szokot lenni full-screenben, azután mikor bejött a menü még akkor is volt.
( más tapasztalt ilyet ?) Gondoltam mindjárt megnézem filmközben is ott marad-e. Hát ekkor ért a legnagyobb sokk...
Bármire mentem azt írta,hogy már nem elérhető.
Akkor gondoltam megnézem a videok / file-ok menüben és ott meg azt írja ,hogy a forrás nem elérhető.
(ami egy NAS és nem azzal van a baj,mert a TV-m,PC-m az látja.)
Please Help !!!
- HP ProLiant DL360e G8 8xSFF 1U 2xE5-2450L (16 mag/32 szál), 144GB DDR3, iLO4, B120i, P410 1GB BBU
- ÁRGARANCIA! Épített KomPhone i5 12400F 16/32/64GB RAM RX 9060 XT 16GB GAMER PC termékbeszámítással
- ÁRGARANCIA! Épített KomPhone R7 5700X 16/32/64GB RAM RX 9060 XT 16GB GAMER PC termékbeszámítással
- HP EliteDesk 800 G3 (USDT), i5-6500T, 8GB DDR4,128GB SSD,WIN11
- ÁRGARANCIA! Épített KomPhone i9 14900KF 64GB RAM RTX 5090 32GB GAMER PC termékbeszámítással
Nagyon sok mindent !
A kérdésedből azt feltételezem hogy talán kéne.
hiszen pont azért kellene a wifi mert ott nincs mibe dugni
wassermann
