A warez minden formában tilos a topicban!
bugmenot1
ez mi? windows 8.1 virtualbox-ban
---- Minecraft Crash Report ----
// Oops.Time: 2015.03.03. 20:12
Description: Initializing gameorg.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:247)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at avf.ap(SourceFile:534)
at avf.am(SourceFile:363)
at avf.a(SourceFile:310)
at net.minecraft.client.main.Main.main(SourceFile:124)A detailed walkthrough of the error, its code path and all known details is as follows:
----------------------------------------------------------------------------------------- Head --
Stacktrace:
at avf.am(SourceFile:363)-- Initialization --
Details:
Stacktrace:
at net.minecraft.client.main.Main.main(SourceFile:124)-- System Details --
Details:
Minecraft Version: 1.8.3
Operating System: Windows 8.1 (x86) version 6.3
CPU: 4x Intel(R) Core(TM) i3-2310M CPU @ 2.10GHz
Java Version: 1.8.0_31, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 48107520 bytes (45 MB) / 101236736 bytes (96 MB) up to 518979584 bytes (494 MB)
JVM Flags: 2 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.8.3
LWJGL: 2.9.4
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: No
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs: []
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled) -
bugmenot1
hogyan lehet jó pvp set-et enchantolni? mindig élesség, védelem, erő I-II-t dob...
bugmenot1
valaki tudja, hogyan kell egyszerű cave spider xp farmot építeni?
bugmenot1
egy dolgot kérhetek Tőletek? fel kéne jönni a szerverre...
bugmenot1
egy vízalatt templomot hogyan lehet lebontani? a nagy guardiant megöltem, de van bányászfáradtság... a tej nem jó, mert a többi poti hatása is elveszik (láthatatlanság, vízalatti légzés)
bugmenot1
van teljesen ingyenes minecraft szerver? nem találok
bugmenot1
indítottam egy szervert, és nem tudok csatlakozni... ettől még másnak működik?
így csináltam: [link]
privátban küldök IP-t
szerk.: ha az ip helyére localhost-ot írok, működik.
bugmenot1
Milyen jó kreatív védelmi plugint ismertek?
LimitedCreative - Nem véd rendesen, a blokk mentőjétől összeomlik a szerver.
LimitCreative - Túl keveset tud.
Creativecontrol - Összeomlik tőle a szerver.
Antishare - Összeomlik tőle a szerver. -
bugmenot1
mennyi a max enchant szint? IV? az üllőn melléteszem a könyvet, és nem írja, hogy rárakta, attól még rajta van? nem változik semmi a leírásban.
bugmenot1
janos1988
#13921
majd lesz hozzá eGPU, 16gb ramot is lehet beletenni, i7 processzor.... ssd már van, 120gb-os kingston
egy kérdés: 35w-os i3 2310m helyére mit lehet betenni? i5-ös van a laptopból... i7 is megy benne? insyde bios.szerk.: ez menne? [link] hűtés bírja? 35w-os van benne, a max 80fok egy 23 fokos szobában
bugmenot1
megnézem "szélsőséges" világgal
szerk.: ez megfagyott
bugmenot1
csináltam egy új világot, és nagyon laggol.... van víz, lávató, hegyek, minden
i3 2310m, hd3000, 4gb ddr3 1333 nem elég a minecraftnak? multiplayer jó
és mindenhol tehén van
bugmenot1
Komplikato
#13900
játszol a szerveren? mi a neved?
bugmenot1
Van PH! szerver? Ha van, mi az IP-je?
bugmenot1
megvan, mi a baj... . is van a névben.
ha username-t írok be, és próbálok rámenni a szerverre: invalid username
átírtam az usernamet, most jó!!!!
bugmenot1
bugmenot1
- AliExpress tapasztalatok
- Androidos tablet topic
- Docker konténerizálás
- GL.iNet OFF topik
- Energiaital topic
- Konzol felvásárlás!! Playstation 5, Playstation 5 Pro
- OnePlus Nord CE3 Lite 128GB, Kártyafüggetlen, 1 Év Garanciával
- HIBÁTLAN iPhone 14 Pro 256GB Deep Purple -1 ÉV GARANCIA - Kártyafüggetlen, 100% Akkumulátor
- Bomba ár! Dell Latitude 5290 - i5-8GEN I 16GB I 256SSD I 12,5" HD I Cam I W11 I Garancia!
a far lands-on miért van ez a fal? nem lehet kiütni?
máshogy nem lehet? a vizet nem tudom kiszedni, mert visszafolyik...
vagy zombi, skeleton, pók is jó
