Up!
Up!
Nos azt hiszem 1, másfél hónap tökölés után sikerült rájönni a titok nyitjára
Gamespy Arcade bárminemű patchelés és egyéb addonok, crackek hozzáadása nélkül is képes játékosokat összehozni... Én már intenziven nyomon neten. Aki szeretne magyarokkal játszani (jelenleg én és két barátom vunk egyedül), az szóljon rám MSN-en (sandorcsz@gmail.com).
Remélem segítettem, és remélem jöttök majd
Up!
meg egy UP! 100-ik hsznek
A hsz végén megtaláljátok lefordítva
Please red this to the bottom....
There IS a solution. Howeve, I think what you are about to read is right abot the serials. if its illegal it wont work. I had problems connecting until i bought the thing.
I found the followning text at:
It works..just go to your network game folder and have a look...thats really cool, and i think its better that Westwood Onlines tournament modes.
Red Alert 2 ONLINE Without a valid cd key!!
With a program called kahn its possible.
INSTRUCTIONS !!!!PLEASE READ TO SAVE YOURSELF HOURS OF TIME!!! You will need three files.
1.kahn13-installer.exe installs the program
2.3.games.txt copy this into the directory you installed kahn and ovewrite the current file.
Next, make sure u have ipx enabled and installed on the Network Card or Dialup adapter you use to access the internet. (please direct any help requests to the message board)
After restarting launch kahn from the start menu. Either connect to the kahnserver.net server or host your own server by right clicking in the window and selecting start local server. This might open up a chat window, just ignore this as it is not a necessary part of the program to play RA2 and will probably just confuse people. The only window you need open is the kahn control panel.
You can add another persons server by right clicking and selecting Insert server.
Once connected.. all you have to do is manually launch the game, and go to NETWORK game, and you will see all the people who are connected to the same server as you.. and u can play as if u are on a giant LAN.
-=IMPORTANT NOTES!!!!!!!! READ!!!!!=-
If you experience trouble.. like, your game quits after 10 seconds or all your guys blow up, make sure you have not used the serial changer by class, or used the latest patch for that game. Also make sure you have not used the cd key provided by fairlight in thier nfo or class, as these are probably very common and will already be used by someone else. We suggest using the Key generator by class available here
Dont be afraid to reinstall your game! especially if u have used the serial changer or the patch.
We believe these are 2 causes for the game stopping play.
Also, This program only works in WinME and Win9x. Not win2k.
Any questions? please direct them to the message board.
the file in question can be found at:
http://www.kahncentral.net
which is a very good free online gaming service.
while im at it: some ppl asked for the 1.01 update?
Find it at http://www.tynthro.com if its not at GCW
Have phun
Tehát elmondom magyarul is annak, aki nem vágja a dolgot (vagy csak nem tud angolul). Létezik egy kamu szerver, ami hasonló a kani.hu szisztémához (tört StartCraft, Diablo2, WarCraft 3 Bnet szerver). Ez a cucc a Kahncentralon érhető el
Bővebben: link és 3 fájl szükséges: kahn13-installer.exe, games.txt illetve az a .reg fájl ami az oldalukon van a download szekcióban... az exe-t telepiteni, a reget elinditani a games.txt-t asszem a telepitett kahn könyvtárába berakni és kész. Asszem el kell inditani az kahn-t aztán a ra2-t és egy golbális lannak látja a netgame-eket. Remélem müxik egyelőre még nem próbáltam ki csak ezt a segédletet forditottam le... Sok sikert
Jah FONTOS!!!!! Csak Win9x és Millenium alatt megy, nos tudom hogy sokaknak van xp-je. Ha nem akartok Win-t telepiteni, akkor MS Virtual PC, pofon egyszerű a használata, Arra telepitetek egy Win98at mondjuk (a virtuális gépre) és azon belül játszotok. Ennyi lenne! Üdvözlet
[Szerkesztve] -
Nos én találtam vmit, rendszerezem, és beirom ide is... (mármint a neten játszhatóságra gondolok)
Up! plz help meeeee! A haverommal szeretnénk játszani ra2-t neten de nem megy csak dial-uppal azt meg nem szeretjük mert pénzbe kerül, minek fizessünk pluszba, ha van adsl is meg egyéb... Szal ha vki tud segiteni akkor legyen szíves help me
- Apple MacBook
- Projektor topic
- OLED monitor topic
- Pedzegeti az új Xbox irányát a Microsoft
- Motoros topic
- Gumi és felni topik
- Honor X8a / 4/128GB / Kártyafüggetlen / 12HÓ Garancia
- iPhone 17 256 GB Levander - Bontatlan !! www.stylebolt.hu - Apple eszközök és tartozékok - Számlás
- Lenovo IdeaPad Slim 3 Ryzen 7 8840HS 15" FHD+ 16GB 1000GB Teljeskörű garancia
- AZONNAL KÉSZLETRŐL! Intel Core i5 14600K 32GB 6000MHz RAM 2TB Gen4 SSD RTX 5060 8GB FSP 750W
