eddie303
Idézet innen: [L]http://www.aggsoft.com/rs232-pinout-cable/pinout-and-signal.htm[/L]
'' Signals May Have No Fixed Meaning
Only 3 of the 9 pins have a fixed assignment: transmit, receive and signal ground. This is fixed by the hardware and you can't change it. But the other signal lines are controlled by software and may do (and mean) almost anything at all. However they can only be in one of two states: asserted (+12 volts) or negated (-12 volts). Asserted is ''on'' and negated is ''off''. For example, Advanced Serial Port Monitor may command that DTR be negated and the hardware only carries out this command and puts -12 volts on the DTR pin. A modem (or other device) that receives this DTR signal may do various things. If a modem has been configured a certain way it will hang up the telephone line when DTR is negated. In other cases it may ignore this signal or do something else when DTR is negated (turned off).
De ha ez nem kell, úgyis mindegy :) -
eddie303
Van egy olyan probléma, hogy soros porton kellene legyen 12 volt, ami laptopoknál nem nagyon van, mert az akksi 10.8 voltos szokott lenni, a töltõrõl meg annyira úgyis leszabályoz.
Szerk:
Oops, most látom, hogy RX/TX/Test kell csak, ezexerint nem szóltam semmit :U
[Szerkesztve]
- Gamer PC /Ryzen 7 9800X3D, 32GB RAM, 1TB SSD/ akciós áron eladó! BeszámítOK!
- BESZÁMÍTÁS! ASROCK B550M R5 5600X 32GB DDR4 512GB SSD RTX 3060 Ti 8GB Zalman Z1 Plus CM 750W
- HIBÁTLAN iPhone 12 Mini 128GB Black-1 ÉV GARANCIA - Kártyafüggetlen,MS3634,100% Akkumulátor
- ÁRGARANCIA! Épített KomPhone Ryzen 5 5600X 16/32/64GB RAM RTX 5050 8GB GAMER PC termékbeszámítással
- BESZÁMÍTÁS! Sony PlayStation 5 825GB SSD lemezes konzol garanciával hibátlan működéssel
