The Division 2 (PC, XO, PS4) összefoglaló
fuvi
ebben a resetben sem invaded Capitol Hill....
legalább lesz rengeteg szabadidőm.... -
fuvi
aszongya vmi reddit poszt h a szinházas heti projektért 20as 5.56-os magazin recit kapott
fuvi
jól látom redditen, hogy a heti invaded rotáció random lett az első 3 hét után? sajna kihagytam első héten egy Nemesis részt, és ha jól látom várhatok még akkor vele pár hetet
fuvi
Anonymus23
#7587
hát igen lehet h a konvertes reci nőtt végig
fuvi
Anonymus23
#7577
lvl 1-est nem tudod upgradelni, csak ezt a másik recit (sweat dream-ból lullaby) adták mellé, ha jól tudom (nem vagyok ultimates)
fuvi
"Hey guys,
There was a lot to talk about on the stream today. I want to start off by saying the raid will drop the highest gear score (TBA), not the Dark Zones. As we've been transparent with our thoughts and decisions up until this point, we will continue to do so going forward. While we do want to experiment with Dark Zone rewards, we're taking everyone's feedback into account. It's still super early and we want to see how the content and looting plays on live. That's not to say things cannot be tweaked."
fuvi
Fixed an issue where players were able to receive unlimited Snitch heroic bounties.
Fixed another issue where players were stuck after being revived while having a DoT state active.
Fixed other issues relating to players being stuck after revival.
Lowered NPC damage and health above normal difficulty.
Increased variety of NPCs spawned at higher difficulty levels.
Difficulty has been significantly decreased in Hard, moderately reduced in Challenge, and barely reduced in Heroic.
Fixed an issue related to Elite NPC aggressiveness in Heroic / Alert Level 4.
Reduced the damage output of Named bosses.TLDR: NPC nerf
fuvi
Nemesis sniper talentjei:
Active Talent: Counter-Sniper
Shots fired from this weapon require the trigger to be held down to charge. Once charged, these shots deal increased body shot damage. If the charged shot does not kill the target, then the next shot charges quicker.
After aiming at a target, it is marked so that it can be tracked through the world. The longer the mark is on the target, the more damage your shots with this weapon will deal to the target.
Active Talent: Nemesis
Aiming at an enemy marks them as your nemesis for 15 seconds, letting you see them through walls.Your shots gain 5% damage to your nemesis for each second they are marked, to a max of 50%
Holstered Talent: Preparation
While Holstered, gain 25% headshot damage when scoped with your current weapon
fuvi
fuvi
Anonymus23
#7476
fuvi
egyik heti projektemnél devastating talentes geart kéne adakoznom, erre jó pl kraftolni cuccost? elfogadja azt donate-ként? csak mert ugye rekalibrálni nem lehet ezeket.
fuvi
-=Jam=-
#7391
reggel direkt megnéztem, kesztyűn lévő 8%-ot beleszámolja a fegyverbe, de pl a rajta lévő talentből (Compensated) jövő 15%-ot és a Surviból jövő 15-öt nem. öszesen 18% jön nekem gearból (kesztyű 8+Brand bonus 10) + 4% all weapon dmg. 23k a dmg most ráírva a fegyverre, ezt elosztom 1.22-vel (18+4%)és kijön 18.852 base dmg a fegyveren
fuvi
Anonymus23
#7315
Mi köze a Base dmg-nek a CHC-hez?
fuvi
sikerult felig meddig osszeraknom egy Unstoppable Force/Compensated/Safeguard/Patience geart, szar maskkal (keves elite dmg), egy hard hitting/hardened hianyzik, 270k armor/48k hp, P416 Optimist/Allegro, es nagyon beteg
fuvi
jövő héten jön még patch:
"We will have an additional patch next week, Patch 2.1 which will include the following changes:
Crafting Bench
We have a fix for the bench not upgrading to World Tier 5 in the works.
This will also fix the issue for players that have their crafting bench stuck in different World Tiers.Characters getting stuck
We are trying to reproduce this internally. If you have more information on the topic, please share it with us (e.g. if you’re experiencing high latency).
We have one fix for players getting stuck in the revive animation.Revive Hive
Made first improvements with TU2.
Another fix incoming to reduce more occurrences in 2.1.
We'll apply more fixes in the future as needed.True Patriot
Fix coming to address the two piece gear set bonus of True Patriot not working."ezekkel foglalkoznak még a közeljövőben:
Community Update - Title Update 2.0 & Beyond - April 11th, 2019 -
fuvi
fuvi
Anonymus23
#6874
eredetileg aszem szólóról volt szó, és ott nem tudta egymaga telepumpálni ólommal, hogy visszaforduljon, több főnél ha többen ráfordulnak meg is pusztul ált.
fuvi
redditen felvetődött egy probléma, amire válaszolt egy fejlesztő!
A probléma lényege hogy hard fokozatig, ha rád fut egy enemy (kb csak a rusherek futnak rád) és beleeresztesz egy tárat, akkor visszafordul és fedezékbe húzódik. WT5 Challenge fokozaton (és Heroicon) viszont nem fordul vissza hanem jól agyonb@sz. Illetve minden mob rádfut, nemcsak a rusherek. semmit sem tehetsz hogy visszaforítsd őket.
Massive válasza:
• Igazából akkor futnak rád a mobok amikor alacsony életen vagy, és ez nem jól skálázódik most (ezt a skálázást nem értem, a challenge fokozatra gondol-e, vagy hogy hány fős csapatban vagy-e), ezt mindenképpen javítni fogják. a lényeg h kevesebb mob fog rádrohanni
• A túlélésünk most nem érződik megfelelőnek, ezen is változtatnak.
• Fedezékből fedezékbe rohanásnál kevesebbszer fognak eltalálni amobok, most elég rizikós ez.
Nem akarnak agyon nerfelni mindent, a Challenge és a Heroic fokozatok nehezek lesznek/maradnak, ha az lesz a visszajelzés hogy könnyű lett, akkor visszatoljákforrás: Reddit
fuvi
healer build (redditről)
- Survivalist
- fegyvernek a suppression miatt LMG, de igazából mind1, equipped talent legyen ezek közül vmelyik: Protected Deploy, In Rhythm, Rooted, Recharged
- 2 db Alps, 2 db Providence, 1 Gila, 1 Airaldi
- Gear talentek: 4 Capacitive, 2 Surge, Efficient legyen a backpack-en.
- 200k armor, 50k hp, 2k skillpower és jó vagy.
- Chem Launcher +Ammo és + Healing modokkal
- Mender Mine +Healing és +CDR modokkal -
fuvi
klán vendor 490es geart árul T5-ön, farmolás elött érdemes beruházni
forrás: reddit
fuvi
fuvi
Ra's al Ghul
#6430
snipernél ennyi headshot mellé én nem gyúrnék critre, sajnos csak összeadódik és nem szorzódik a kettő
Riflére Breadbasket talentet használok és elég beteg -
fuvi
Hogyan neveld sárkányodat, avagy a karakterépítés mikéntje
nemrég találtam egy jó kis leírást a redditen, saját példamat belerakva lefordítottam
Először is, játékstílusod/felfogásod határozza meg, hogyan és mit is szeretnél a játékban csinálni.
Én egyelőre PvE tartalmakat szeretnék csinálni, magányosan és csapatban is, ezeken belül főleg Challenge küldetéseket, ill. 3-as szintű Control Pointokat.Kedvenc fegyvertípusod(aid) szerint alakítsuk ki fegyvereinket és felszerelésünket.
Imádom az AReket, illetve a Rifleket ezért ezeket fogom felszerelésben is támogatni talentekkel, Attribute pontokkal.Számodra legfontosabb Talent(ek)
Válassz ki egy fegyver és egy (vagy több) ruha talentet ami köré epíted a karaktert.Mik azok az Attribute (Tulajdonság) pontok?
Minden felszerelés tartalmaz legalább egy tulajdonságot (armor, damage, cooldown reduction stb). Ezeket 3 kategóríába soroljuk (zárójelben a hozzátartozó ikon): offensive (célkereszt), defensive (pajzs) és utility (elem). Minél kevesebb ilyen stat van egy itemen annál nagyobbak az értékei.Mik a Modok és a Mod slotok?
Felszereléseken lehetnek az előző 3 kategóriába sorolható Mod slotok. Ezek a kategóriák (offensive, defensive, utility) még 2 részre vannak szedve: “System” vagy “Protocol”. A megfelelő Modok ezekbe a slotokba (foglalatokba) tehetők. “Generic” Modokat bármely kategóriába betehetjük, csak a System ill. Protocol különbözteti meg ezeket. Maguk a Modok véletlenszerűen generált Attribute pontokat tartalmaznak (lila: 2 stat, lego: 3 stat)Mi az az ODU pite:
Az ODU (offensive, defensive, utility) pite a karakterlap bal felső részében található ábra, ami jelzi mennyi és milyen Attribute pontokat és Modokat (1db mod 1-el növeli csak, hiába van rajta pl 3 érték) használunk. Bizonyos talenteknél láthatunk követelményeket, amiknek megfelelve aktív lesz az a talent.Talentek köré építkezz
A fegyveremen található “Strained” talenthez maximum 5 offensive érték társulhat, mivel ehez a talenthez sok Crit kell ezért főleg “crit hit chance” -re raktamBrand Szett bónuszok
Némelyik szettbónusz egész jó, hogy rámenjünk, de én nem eröltettem a dolgot, talán egy kettes bónuszom van, nagyon macerás jó értékekkel találni geart és még erre is figyelni kéne.Szinergia
Fegyverem “Strained” talente elég jó együttműködik chestemen lévő “Berserk” talenttel, illetve ugyanaz a követelménye, mint a backpackomon lévő “Safeguard”-nak. Kesztyűn pedig “Cluth” aktív talentnek hasonló a követelménye, mint a “Berserk”-nek.Ne felejtkezzünk el persze a sebzésről se
Sebzés még mindíg az elsődleges dolog amire figyeljünk. Nemigazán beszélhetünk farmolásról ha egy tárból alig ölsz meg egy normál ellenfelet.Felszerelés és az ODU tervezése
Mostanra tudjuk hogy milyen talenteket és bónuszokat akarunk a fegyverünk mellé, de nem ilyen egyszerű a dolog. Bizonyos ruhákon csak bizonyos talentek lehenek ill bizonyos ruhákon csak bizonyos talentek lehetnek. Talentek lehetnek aktívak vagy passzívak. Ezekre itt egy jó kis táblázat./I] -
fuvi
ImpersonatoR
#5885
csak a side missionok nem termelődnek újra, kérdőjelek majd el fognak tünni ha felfedezed milyen aktivitást takar, de azok az aktivitások újratermelődnek. ki lehet takarítani egy zónát, de másnapra már nem lesz az
fuvi
Éhes disznó is MakróSztájlról álmodik
The Division 2 - Best Weapons For PvP & PvE | All Weapons TestedTLDR:
P416
T821
MK17
M60 -
fuvi
The Division 2 - Gear Attribute Sheet
újabb csini táblázat, ajánlom a Brand Gear fület, van "egy-két" variáció a szetteknél is
fuvi
Anonymus23
#5656
redditen elég sok szép történetet olvastam azokról akik használták, örök barátságok köttettek, azóta is eggyütt játszunk anekdóták, úgyhogy lehet egyszer én is kipróbálom eme amerikai álmot!
fuvi
Anonymus23
#5640
level 3 CP-től dob bármilyen tervrajzot bónuszban, level 4 CP-nél csak nagyobb eséllyel esik legendary cucc, nem éri meg, ezért nem is csinálják
fuvi
Anonymus23
#5439
valóban van közte egy dpula szett item srry
de arról beszél videóban (meg én is magamban), hogy az első szettbónuszok is vannak olyan jók mint a kettes ill. hármas bónuszok, ezért nem érdekes hogy meglegyen 3as bónusz, sőt 2es se. ergo attól még mert szedettvedettnek néz ki, lehet OP -
fuvi
Anonymus23
#5434
fuvi
facebookon ezt találtam most a "The Division Academy" csoportban:
"If anyone in your clan has found an exotic blueprint (either through pre-order or via faction caches), you can visit their BOO vendor (one opposite the quarter master) and purchase the blueprint! Got the chatterbox blueprint like this 🙂 now just to get that final component..!!"
fuvi
!!!Duplán klikkelj, majd tartsd lenyomva a donate gombot a baráti kontrol pontoknál!!! - így sokkal gyorsabb lesz a donate
fuvi
Anonymus23
#4916
én arra akartam igazából reflektálni h kb sztem ezek a szettbónuszok elég gyengusok, az itemeken lévő sima statok fontosabbak
fuvi
arnikusz
#4897
és ezekból a szettekből összvissz egy stat érdekes, a 10% MMR dmg, (esetleg a 10% headshot,) nézzétek inkább a statokat amik magukon az itemeken vannak: 6.5% weapon dmg, 10% MMR dmg, 6% weapon dmg+9.5% headshot+10.5% CHD
a headshotról mondja is h 200% felett annyira nem izgul már rá -
fuvi
#4187
Space Shuttle keychain can be found in the Air and Space Museum.
via reddit
kommentekben írnak még mást is
fuvi
Anonymus23
#4061
mert az bonyolultabb...
oda fel is kell tölteni, ez meg csak egy link (én csak loptam redditről) -
fuvi
shooting range
Distance markers, DPS meter, accuracy meter, change difficulty levels, AOE damage meter
TTK-t is jelzi
fuvi
Anonymus23
#3712
mintha vhol azt olvastam volna hogy egyszerre csak egy aktív, egy passzív és egy holstered talent lehet, ezek szerint is sorba lehetne rakni.
fuvi
fuvi
Anonymus23
#3670
weapon handling=accuracy+stability
amúgy a fordítások jók
#3671 cain69
vki redditen összefoglalta 1 képben:
fuvi
fuvi
miért ne lehetnék több discord szerveren egyszerre? (én legalább ötöt használok)
virágozzék ezer virág... -
fuvi
- Lenovo T490S i5 8365U, 16GB RAM, 256GB SSD, jó akku, számla, 6 hó gar
- Gamer billentyűzetek /Akko/Monsgeek/Asus/SteelSeries/Das Keyboard/Ozone/Deltaco/DE/EN/UK/Számlával!/
- TOP Gamer PC /Ryzen 7 9800X3D, 48GB RAM, RTX 5080, 1TB SSD/ akciós áron eladó!
- MikroTik RB5009UPr+S+IN
