TP-Link WR1043ND - N450 router
tomi8821
Üdv,telepìtettem egy csomagot,de nem jelenik meg a telepìtettek közt, viszont a hely kevesebb lett. Találkozott már valaki ilyennel?
tomi8821
Üdv, előzőre valaki?
tomi8821
Üdv, eddig működött az automata visszacsatolás, de most ez fogad:
Feb 11 21:44:44 OpenWrt daemon.notice ntfs-3g[918]: Unmounting /dev/sda1 ()
Feb 11 21:44:44 OpenWrt user.notice qssbutton: /dev/sda1 umounted
Feb 11 21:44:44 OpenWrt user.notice qssbutton: ""Most már lehuzhatod a winyot""!!!
Feb 11 21:44:58 OpenWrt kern.info kernel: [ 161.920000] usb 1-1.3: USB disconnect, device number 3
Feb 11 21:44:59 OpenWrt kern.info kernel: [ 163.700000] usb 1-1.3: new high speed USB device number 4 using ar71xx-ehci
Feb 11 21:45:00 OpenWrt kern.info kernel: [ 163.820000] scsi1 : usb-storage 1-1.3:1.0
Feb 11 21:45:00 OpenWrt user.notice usb-modeswitch: 1-1.3:1.0: Manufacturer=USB_Reader Product=USB_Mass_Storage_Device Serial=816820090724
Feb 11 21:45:01 OpenWrt kern.notice kernel: [ 164.820000] scsi 1:0:0:0: Direct-Access USB Mass Storage Device PQ: 0 ANSI: 0 CCS
Feb 11 21:45:01 OpenWrt kern.notice kernel: [ 164.830000] sd 1:0:0:0: [sda] 3964928 512-byte logical blocks: (2.03 GB/1.89 GiB)
Feb 11 21:45:01 OpenWrt kern.notice kernel: [ 164.840000] sd 1:0:0:0: [sda] Write Protect is off
Feb 11 21:45:01 OpenWrt kern.err kernel: [ 164.840000] sd 1:0:0:0: [sda] Assuming drive cache: write through
Feb 11 21:45:01 OpenWrt kern.err kernel: [ 164.860000] sd 1:0:0:0: [sda] Assuming drive cache: write through
Feb 11 21:45:01 OpenWrt kern.info kernel: [ 164.860000] sda: sda1
Feb 11 21:45:01 OpenWrt kern.err kernel: [ 164.880000] sd 1:0:0:0: [sda] Assuming drive cache: write through
Feb 11 21:45:01 OpenWrt kern.notice kernel: [ 164.880000] sd 1:0:0:0: [sda] Attached SCSI removable disk
Feb 11 21:45:01 OpenWrt user.notice startservices: Transmission download directory doesnt exists.
Feb 11 21:45:01 OpenWrt daemon.notice ntfs-3g[2320]: Version 2011.4.12 integrated FUSE 27
Feb 11 21:45:01 OpenWrt daemon.notice ntfs-3g[2320]: Mounted /dev/sda1 (Read-Write, label "", NTFS 3.1)
Feb 11 21:45:01 OpenWrt daemon.notice ntfs-3g[2320]: Cmdline options:
Feb 11 21:45:01 OpenWrt daemon.notice ntfs-3g[2320]: Mount options: allow_other,nonempty,atime,fsname=/dev/sda1,blkdev,blksize=2048
Feb 11 21:45:01 OpenWrt daemon.notice ntfs-3g[2320]: Ownership and permissions disabled, configuration type 1
Feb 11 21:45:02 OpenWrt user.notice startservices: Transmission download directory doesnt exists.
Tudja valaki mi ez? -
tomi8821
Üdv, egy ftp-n megosztott meghajtón lehet olyan mappát létrehozni,amihez a többi felhasználó nem tud hozzáférni, ha igen akkor hogy?
tomi8821
Felhasználónév:ftp. Jelszót hiába változtatom meg nem enged be.
tomi8821
Üdv, vargalex firmware-ben mi az alapértelmezett ftp jelszó és felhasználó?
tomi8821
Üdv, azt én se találom,igen arra.
Ezt kapom:
cannot open /usr/lib/lua/luci/model/cbi/admin_network/proto_3g.lua: No such file or directory -
tomi8821
Üdv, ezek sincsenek meg.
tomi8821
Üdv, vargalex féle firmware alatt próbálok be üzemelni egy zte mf 637 3g modemet, luci-proto-3g-t hiányol de nem találom sehol, illetve a többi csomagot se.
Ha valakinek meglennének megköszönném ha elküldené. -
tomi8821
Üdv, tudna nekem mondani valaki egy olyan 3g modemet,amit dd- wrt-vel biztosan kezel a router?
tomi8821
Üdv, érdeklődnék hogy,lehetséges dd-wrt-vel, usb-hubra kötni egy 3g modemet, és egy külső hdd-t úgy,hogy mind a kettő menjen egyszerre?
- 3D nyomtatás
- Milyen okostelefont vegyek?
- Tőzsde és gazdaság
- Project Motor Racing-Straight4 Studios
- Call of Duty: Black Ops 7
- TCL LCD és LED TV-k
- Vállalom Xianomi Okos kamerák, szoftveres javíttását
- Apple iPhone 13 Pro Max / 128GB / Kártyafüggetlen / 12Hó Garancia / Akku:87%
- HIBÁTLAN iPhone 13 256GB Pink -1 ÉV GARANCIA - Kártyafüggetlen, MS3734
- ÁRGARANCIA! Épített KomPhone Ultra 7 265KF 32/64GB RAM RTX 5070 12GB GAMER PC termékbeszámítással
- Bontatlan DJI OSMO Mobile 6 - ez elbírja a 16 pro max-ot!
vargalex
