TP-Link WR1043ND - N450 router
Tarkov
Gargoyle firmware változtatások december 27:
New in 1.5.2 (experimental):
Fixes bug causing router crash when installing packages via opkg
Allows selection of several DNS server options, including OpenDNS and Google DNS servers from a dropdown without the need to enter IPs manually
Enables resolution of NameCoin and OpenNIC alternate root domains by default
Automatically mounts swap partitions on attached USB drives
Tor is disabled on routers with less than 64MB of memory (including swap space)
Fixes error in updating namecheap.com domains via dynamic DNS
Some improvements in looking up host IP for dynamic DNS -- rotating pool of servers for lookups is now used
Bumps OpenWrt Backfire version to 10.03.1 final
Time initialized to be Jan 1st, 2001 instead of 1970 before NTP started, so timezone shift never puts it before unix epoch
QoS accounting improved for PPPoE connections which will improve overall QoS performance on these systems.New in 1.4.5 (stable):
QoS accounting improved for PPPoE connections which will improve overall QoS performance on these systems. -
Tarkov
Hegylakónak érzem magam a sok vargalex-es openwrt -s közt
Tarkov
Nos, meg van a routerem és tettem is rá egy Gargoyle firmware-t (1.4.5.).
Valaki használ itt rajtam kívül Gargoyle fw-t?
Tarkov
Hello!
Hogy van az, hogy a hivatalos oldalon nincs 64MB rammal rendelkező router míg Mo-on lehet kapni?
Erre a 64Mb-ra is igaz a 5 év gyártói garancia?
- Projektor topic
- Tesla topik
- Sorozatok
- Okos Otthon / Smart Home
- Hobby elektronika
- Nintendo Switch 2
- Dell Latitude 5400 14" FHD IPS, i5 8365U, 8-16GB RAM, SSD, jó akku, számla, 6 hó gar
- Apple iPhone 12 Mini 64GB, Kártyafüggetlen, 1 Év Garanciával
- GYÖNYÖRŰ iPhone 12 Pro 256GB Pacific Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS4155,100% Akksi
- BESZÁMÍTÁS! MSI B450M R5 5500 16GB DDR4 512GB SSD RX 6500 XT 8GB Rampage SHIVA ADATA 600W
- HIBÁTLAN iPhone 12 mini 64GB Purple -1 ÉV GARANCIA - Kártyafüggetlen, MS3481
vargalex
